Hi Tom,
This PR includes the following changes for v2020.04 release:
- verdin-imx8mm board reST documentation update - Intel Edison board ACPI table I2C/USB minor updates - Fix a regression of ns16550 serial driver that breaks Intel Edison
The following changes since commit e0718b3ab754860bd47677e6b4fc5b70da42c4ab:
Merge tag 'dm-pull-1apr20' of git://git.denx.de/u-boot-dm (2020-04-01 14:29:21 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-x86
for you to fetch changes up to 9e6ce62190b7cd874d2bf727c7681292551ba6b9:
serial: ns16550: Fix ordering of getting base address (2020-04-04 22:08:44 +0800)
---------------------------------------------------------------- Andy Shevchenko (3): x86: acpi: Refactor XSDT handling in acpi_add_table() x86: acpi: Add I²C timings to Intel Merrifield platform x86: acpi: Describe USB 3 host controller found on Intel Tangier
Bin Meng (1): serial: ns16550: Fix ordering of getting base address
Igor Opaniuk (1): doc: board: verdin-imx8mm: use mainline TF-A
arch/x86/include/asm/arch-tangier/acpi/southcluster.asl | 77 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/lib/acpi_table.c | 37 +++++++++++++++++++------------------ doc/board/toradex/verdin-imx8mm.rst | 26 ++++++-------------------- drivers/serial/ns16550.c | 39 ++++++++++++++++++++++----------------- 4 files changed, 124 insertions(+), 55 deletions(-)
Regards, Bin
On Sun, Apr 05, 2020 at 07:12:50AM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
