[U-Boot] [PATCH] net: sh-eth: Fix coding style checked by checkpatch.pl
This fixes the chord style checked by checkpatch.pl. Details of change details are as follows:
- Fix typo Change from alligned to aligned. - Remove whitespace before ',' - Add spaces preferred around that '|' - Fix missing a blank line after declarations - Remove space after a cast declaration - Fix format of block comments - Add a blank line after function/struct/union/enum declarations
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/net/sh_eth.c | 29 ++++++++++++++++++----------- 1 file changed, 18 insertions(+), 11 deletions(-)
diff --git a/drivers/net/sh_eth.c b/drivers/net/sh_eth.c index 970d730e56..5c6278069c 100644 --- a/drivers/net/sh_eth.c +++ b/drivers/net/sh_eth.c @@ -67,7 +67,7 @@ int sh_eth_send(struct eth_device *dev, void *packet, int len)
/* packet must be a 4 byte boundary */ if ((int)packet & 3) { - printf(SHETHER_NAME ": %s: packet not 4 byte alligned\n" + printf(SHETHER_NAME ": %s: packet not 4 byte aligned\n" , __func__); ret = -EFAULT; goto err; @@ -222,8 +222,10 @@ static int sh_eth_tx_desc_init(struct sh_eth_dev *eth) cur_tx_desc--; cur_tx_desc->td0 |= TD_TDLE;
- /* Point the controller to the tx descriptor list. Must use physical - addresses */ + /* + * Point the controller to the tx descriptor list. Must use physical + * addresses + */ sh_eth_write(eth, ADDR_TO_PHY(port_info->tx_desc_base), TDLAR); #if defined(SH_ETH_TYPE_GETHER) || defined(SH_ETH_TYPE_RZ) sh_eth_write(eth, ADDR_TO_PHY(port_info->tx_desc_base), TDFAR); @@ -237,7 +239,7 @@ err:
static int sh_eth_rx_desc_init(struct sh_eth_dev *eth) { - int port = eth->port, i , ret = 0; + int port = eth->port, i, ret = 0; u32 alloc_desc_size = NUM_RX_DESC * sizeof(struct rx_desc_s); struct sh_eth_info *port_info = ð->port_info[port]; struct rx_desc_s *cur_rx_desc; @@ -283,7 +285,7 @@ static int sh_eth_rx_desc_init(struct sh_eth_dev *eth) i < NUM_RX_DESC; cur_rx_desc++, rx_buf += MAX_BUF_SIZE, i++) { cur_rx_desc->rd0 = RD_RACT; cur_rx_desc->rd1 = MAX_BUF_SIZE << 16; - cur_rx_desc->rd2 = (u32) ADDR_TO_PHY(rx_buf); + cur_rx_desc->rd2 = (u32)ADDR_TO_PHY(rx_buf); }
/* Mark the end of the descriptors */ @@ -465,11 +467,14 @@ static int sh_eth_config(struct sh_eth_dev *eth, bd_t *bd) /* Check if full duplex mode is supported by the phy */ if (phy->duplex) { printf("Full\n"); - sh_eth_write(eth, val | (ECMR_CHG_DM|ECMR_RE|ECMR_TE|ECMR_DM), + sh_eth_write(eth, + val | (ECMR_CHG_DM | ECMR_RE | ECMR_TE | ECMR_DM), ECMR); } else { printf("Half\n"); - sh_eth_write(eth, val | (ECMR_CHG_DM|ECMR_RE|ECMR_TE), ECMR); + sh_eth_write(eth, + val | (ECMR_CHG_DM | ECMR_RE | ECMR_TE), + ECMR); }
return ret; @@ -524,6 +529,7 @@ err: void sh_eth_halt(struct eth_device *dev) { struct sh_eth_dev *eth = dev->priv; + sh_eth_stop(eth); }
@@ -532,6 +538,7 @@ int sh_eth_initialize(bd_t *bd) int ret = 0; struct sh_eth_dev *eth = NULL; struct eth_device *dev = NULL; + struct mii_dev *mdiodev;
eth = (struct sh_eth_dev *)malloc(sizeof(struct sh_eth_dev)); if (!eth) { @@ -566,16 +573,15 @@ int sh_eth_initialize(bd_t *bd) eth_register(dev);
bb_miiphy_buses[0].priv = eth; - int retval; - struct mii_dev *mdiodev = mdio_alloc(); + mdiodev = mdio_alloc(); if (!mdiodev) return -ENOMEM; strncpy(mdiodev->name, dev->name, MDIO_NAME_LEN); mdiodev->read = bb_miiphy_read; mdiodev->write = bb_miiphy_write;
- retval = mdio_register(mdiodev); - if (retval < 0) + retl = mdio_register(mdiodev); + if (ret < 0) return retval;
if (!eth_env_get_enetaddr("ethaddr", dev->enetaddr)) @@ -670,4 +676,5 @@ struct bb_miiphy_bus bb_miiphy_buses[] = { .delay = sh_eth_bb_delay, } }; + int bb_miiphy_buses_num = ARRAY_SIZE(bb_miiphy_buses);
On Thu, Nov 30, 2017 at 5:08 PM, Nobuhiro Iwamatsu iwamatsu@nigauri.org wrote:
Hi Nobuhiro,
addresses */
* addresses
cur_rx_desc->rd2 = (u32)ADDR_TO_PHY(rx_buf); } /* Mark the end of the descriptors */
sh_eth_write(eth,
sh_eth_write(eth,
ECMR); } return ret;
sh_eth_stop(eth);
struct mii_dev *mdiodev; eth = (struct sh_eth_dev *)malloc(sizeof(struct sh_eth_dev)); if (!eth) {
int retval;
if (retval < 0)
It seems you never compiled this. The compiler tells you that it should be "ret", not "retl".
This should be "ret", not "retval".
I'll fix these up inline.
-Joe
Hi Nobuhiro,
https://patchwork.ozlabs.org/patch/843225/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Joe Hershberger
Nobuhiro Iwamatsu
