[U-Boot] Uboot support for MT29F2G16ABBEAH4 NAND 16 bit
Hi
has Anybody managed to load the Linux Kernel using MT29F2G16ABBEAH4 NAND or other 16 bits NAND memory?
Thanks Marcio
-- View this message in context: http://u-boot.10912.n7.nabble.com/Uboot-support-for-MT29F2G16ABBEAH4-NAND-16... Sent from the U-Boot mailing list archive at Nabble.com.
On 03/14/2013 05:52:57 PM, marcio@netopen.com.br wrote:
Hi
I haven't personally, but there's no general reason why 16-bit NAND shouldn't work in U-Boot. Some NAND controllers or drivers don't support it, though -- which controller are you using?
-Scott
Hi Scott
Thanks a lot for your attention.
I am using a custom board based at the Atmel AT91SAM9M10G45-EK Development Kit. I am quite sure The Linux Kernel is properly loaded in the NAND memory.
Here is the U-boot log.
U-Boot 2012.10-00075-g0362411-dirty (Mar 15 2013 - 11:33:53)
U-Boot code: 73F00000 -> 73F370C0 BSS: -> 73F79654 CPU: AT91SAM9G45 Crystal frequency: 12 MHz CPU clock : 400 MHz Master clock : 133.333 MHz dram_init dram_init tam_ram=67108864 testa_ram_readonly: Inicio testa_ram_readonly: Fim monitor len: 00079654 ramsize: 04000000 TLB table at: 73ff0000 Top of RAM usable for U-Boot at: 73ff0000 Reserving 485k for U-Boot at: 73f76000 Reserving 640k for malloc() at: 73ed6000 Reserving 32 Bytes for Board Info at: 73ed5fe0 Reserving 144 Bytes for Global Data at: 73ed5f50 New Stack Pointer is: 73ed5f40 comeca a configurar a DRAM Display DRAM display_dram_config: DRAM: 64 MiB reloca e perde o controle 00000000
relocation Offset is: 00076000 board_init_r: gd=73ed5f50 WARNING: Caches not enabled monitor flash len: 0003C950 Now running in RAM - U-Boot at: 73f76000 NAND: 256 MiB board_init_r: Initialize Environmet env_relocate: Inicio gd=73ed5f50 gd->env_valid=0 Using default environment
env_relocate: Fim board_init_r: jumptable board_init_r: jumptable sai In: serial Out: serial Err: serial board_init_r:interrupts board_init_r: initialize board_init_r: main loop ### main_loop entered: bootdelay=3
### main_loop: bootcmd="nand read 0x70000000 0x200000 0x300000;bootm 0x70000000"
Hit any key to stop autoboot: 0
NAND read: device 0 offset 0x200000, size 0x300000 3145728 bytes read: OK * kernel: cmdline image address = 0x70000000 ## Booting kernel from Legacy Image at 70000000 ... Image Name: Linux-2.6.39.4 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 3630052 Bytes = 3.5 MiB Load Address: 70008000 Entry Point: 70008000 Verifying Checksum ... Bad Data CRC ERROR: can't get kernel image! U-Boot Marcio>
On 03/14/2013
05:52:57 PM, marcio@netopen.com.br [1]wrote:
Hi has Anybody
are you using?
-Scott
Links: ------ [1] mailto:marcio@netopen.com.br
Scott Wood
