[U-Boot] [PATCH 1/3] arm:mmc:goni/exynos: Fix wrong mmc base register devices offset.
On s5pc1xx mmc devices offset is multiply of 0x100000, wrong value was 0x10000. Register offset always points to mmc 0 before this change.
Add macro definition of mmc dev register offset to s5pc1xx and exynos mmc.
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- arch/arm/include/asm/arch-exynos/mmc.h | 6 +++++- arch/arm/include/asm/arch-s5pc1xx/mmc.h | 6 +++++- 2 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/mmc.h b/arch/arm/include/asm/arch-exynos/mmc.h index 96610b8..98312d1 100644 --- a/arch/arm/include/asm/arch-exynos/mmc.h +++ b/arch/arm/include/asm/arch-exynos/mmc.h @@ -8,6 +8,8 @@ #ifndef __ASM_ARCH_MMC_H_ #define __ASM_ARCH_MMC_H_
+#define S5P_MMC_DEV_OFFSET 0x10000 + #define SDHCI_CONTROL2 0x80 #define SDHCI_CONTROL3 0x84 #define SDHCI_CONTROL4 0x8C @@ -55,7 +57,9 @@ int s5p_sdhci_init(u32 regbase, int index, int bus_width);
static inline unsigned int s5p_mmc_init(int index, int bus_width) { - unsigned int base = samsung_get_base_mmc() + (0x10000 * index); + unsigned int base = samsung_get_base_mmc() + + (S5P_MMC_DEV_OFFSET * index); + return s5p_sdhci_init(base, index, bus_width); } #endif diff --git a/arch/arm/include/asm/arch-s5pc1xx/mmc.h b/arch/arm/include/asm/arch-s5pc1xx/mmc.h index 96610b8..55ff10b 100644 --- a/arch/arm/include/asm/arch-s5pc1xx/mmc.h +++ b/arch/arm/include/asm/arch-s5pc1xx/mmc.h @@ -8,6 +8,8 @@ #ifndef __ASM_ARCH_MMC_H_ #define __ASM_ARCH_MMC_H_
+#define S5P_MMC_DEV_OFFSET 0x100000 + #define SDHCI_CONTROL2 0x80 #define SDHCI_CONTROL3 0x84 #define SDHCI_CONTROL4 0x8C @@ -55,7 +57,9 @@ int s5p_sdhci_init(u32 regbase, int index, int bus_width);
This change allow to use sd card on Goni the same like mmc 0. SD card is mmc dev 1, so it can be used like this: "fatls mmc 1:2".
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- board/samsung/goni/goni.c | 32 +++++++++++++++++++++++++++++++- 1 file changed, 31 insertions(+), 1 deletion(-)
diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index c05801d..3b236b4 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -69,6 +69,7 @@ int checkboard(void) int board_mmc_init(bd_t *bis) { int i; + int ret;
/* MASSMEMORY_EN: XMSMDATA7: GPJ2[7] output high */ s5p_gpio_direction_output(&s5pc110_gpio->j2, 7, 1); @@ -91,7 +92,36 @@ int board_mmc_init(bd_t *bis) s5p_gpio_set_drv(&s5pc110_gpio->g0, i, GPIO_DRV_4X); }
- return s5p_mmc_init(0, 4); + ret = s5p_mmc_init(0, 4); + if (ret) { + puts("MMC: Failed to init MMC:0.\n"); + return ret; + } + + /* + * SD card (T_FLASH) detect and init + * T_FLASH_DETECT: EINT28: GPH3[4] input mode + */ + s5p_gpio_cfg_pin(&s5pc110_gpio->h3, 4, GPIO_INPUT); + s5p_gpio_set_pull(&s5pc110_gpio->h3, 4, GPIO_PULL_UP); + + if (!s5p_gpio_get_value(&s5pc110_gpio->h3, 4)) { + for (i = 0; i < 7; i++) { + if (i == 2) + continue; + /* GPG2[0:6] special function 2 */ + s5p_gpio_cfg_pin(&s5pc110_gpio->g2, i, 0x2); + /* GPG2[0:6] pull disable */ + s5p_gpio_set_pull(&s5pc110_gpio->g2, i, GPIO_PULL_NONE); + /* GPG2[0:6] drv 4x */ + s5p_gpio_set_drv(&s5pc110_gpio->g2, i, GPIO_DRV_4X); + } + if (s5p_mmc_init(2, 4)) + puts("MMC: Failed to init SD card (MMC:2).\n"); + } + + /* SD card init is optional so print information when it fails only */ + return ret; } #endif
Hello Minkyu,
Could you review this patch, please?
int ret;
- ret = s5p_mmc_init(0, 4);
- if (ret) {
return ret;
- s5p_gpio_cfg_pin(&s5pc110_gpio->h3, 4, GPIO_INPUT);
- s5p_gpio_set_pull(&s5pc110_gpio->h3, 4, GPIO_PULL_UP);
- if (!s5p_gpio_get_value(&s5pc110_gpio->h3, 4)) {
if (i == 2)
continue;
- /* SD card init is optional so print information when it fails only */
- return ret; } #endif
On 08/28/2013 04:39 PM, Przemyslaw Marczak wrote:
Hello Minkyu,
int ret;
- if (ret) {
return ret;
When eMMC init is failed, immediately return? I think that even if eMMC init is failed, there is worth that try to init SD-card.
Best Regards, Jaehoon Chung
if (i == 2)
continue;
Hi Jaehoon, You're right, I will change this. Regards
Changes in V2: - Init SD card even if eMMC init fail.
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Minkyu Kang mk7.kang@samsung.com --- board/samsung/goni/goni.c | 31 ++++++++++++++++++++++++++++++- 1 file changed, 30 insertions(+), 1 deletion(-)
diff --git a/board/samsung/goni/goni.c b/board/samsung/goni/goni.c index c05801d..2bb2507 100644 --- a/board/samsung/goni/goni.c +++ b/board/samsung/goni/goni.c @@ -69,6 +69,7 @@ int checkboard(void) int board_mmc_init(bd_t *bis) { int i; + int ret;
/* MASSMEMORY_EN: XMSMDATA7: GPJ2[7] output high */ s5p_gpio_direction_output(&s5pc110_gpio->j2, 7, 1); @@ -91,7 +92,35 @@ int board_mmc_init(bd_t *bis) s5p_gpio_set_drv(&s5pc110_gpio->g0, i, GPIO_DRV_4X); }
- return s5p_mmc_init(0, 4); + ret = s5p_mmc_init(0, 4); + if (ret) { + puts("MMC: Failed to init MMC:0.\n"); + } + + /* + * SD card (T_FLASH) detect and init + * T_FLASH_DETECT: EINT28: GPH3[4] input mode + */ + s5p_gpio_cfg_pin(&s5pc110_gpio->h3, 4, GPIO_INPUT); + s5p_gpio_set_pull(&s5pc110_gpio->h3, 4, GPIO_PULL_UP); + + if (!s5p_gpio_get_value(&s5pc110_gpio->h3, 4)) { + for (i = 0; i < 7; i++) { + if (i == 2) + continue; + /* GPG2[0:6] special function 2 */ + s5p_gpio_cfg_pin(&s5pc110_gpio->g2, i, 0x2); + /* GPG2[0:6] pull disable */ + s5p_gpio_set_pull(&s5pc110_gpio->g2, i, GPIO_PULL_NONE); + /* GPG2[0:6] drv 4x */ + s5p_gpio_set_drv(&s5pc110_gpio->g2, i, GPIO_DRV_4X); + } + if (s5p_mmc_init(2, 4)) + puts("MMC: Failed to init SD card (MMC:2).\n"); + } + + /* SD card init is optional so print information when it fails only */ + return ret; } #endif
Hi Przemyslaw,
Changes in V2:
int ret;
- if (ret) {
Can remove the bracket. Then looks good to me.
Acked-by: Jaehoon Chung jh80.chung@samsung.com
if (i == 2)
continue;
- return ret;
} #endif
Dear Przemyslaw Marczak,
Changes in V2:
Your v1 patchset is made by 3 patches. But this patch is only one patch.
Do you want to separate patchset? Then please send each patches again. or not, please send whole patchset.
Thanks, Minkyu Kang.
On 08/30/2013 04:16 AM, Minkyu Kang wrote:
Dear Przemyslaw Marczak, ... Your v1 patchset is made by 3 patches. But this patch is only one patch.
Hello Minkyu Kang, I send patchset by mistake and each patch will be send again soon.
Thank you
This change allows using every mmc device instance with ums, like eMMC or SD cards.
Example: ums <device_number> for mmc devices.
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com CC: Marek Vasut marek.vasut@gmail.com --- common/cmd_usb_mass_storage.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/common/cmd_usb_mass_storage.c b/common/cmd_usb_mass_storage.c index 33a4715..4181d3a 100644 --- a/common/cmd_usb_mass_storage.c +++ b/common/cmd_usb_mass_storage.c @@ -14,6 +14,7 @@ int do_usb_mass_storage(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { + struct mmc *mmc = NULL; char *ep; unsigned int dev_num = 0, offset = 0, part_size = 0; int rc; @@ -28,8 +29,10 @@ int do_usb_mass_storage(cmd_tbl_t *cmdtp, int flag,
dev_num = (int)simple_strtoul(argv[1], &ep, 16);
- if (dev_num) { - puts("\nSet eMMC device to 0! - e.g. ums 0\n"); + mmc = find_mmc_device(dev_num); + + if (!mmc) { + printf("\neMMC device: %d not found! Try ums 0.\n", dev_num); goto fail; }
Hello Marek,
- struct mmc *mmc = NULL; char *ep; unsigned int dev_num = 0, offset = 0, part_size = 0; int rc;
- if (dev_num) {
- mmc = find_mmc_device(dev_num);
- if (!mmc) {
goto fail; }printf("\neMMC device: %d not found! Try ums 0.\n", dev_num);
- if (dev_num) {
- if (!mmc) {
You still use dev_num further in the code, why not convert the whole thing to use *mmc ?
Best regards, Marek Vasut
Best regards, Marek Vasut.
Hello, I don't know exactly what do you mean. I suppose that putting "mmc device number" as a parameter is easy to maintain at command code and also intuitive to use at prompt. Do you prefer set mmc dev number by command "mmc dev <num>" ? Should we depends one command on another? If yes, then what about e.g. fat or ext command set?
Thank you.
What I mean is ... for example, you pass dev_num to board_ums_init() . See the trats board, find_mmc_device() is called again in there. Why not just pass the *mmc directly?
Oh, now I see. You are absolutely right, it was just code duplication. I will change it and resend patch. Thank you,
Try and see if *mmc can not be passed all around instead of the dev_num too.
Hi Minkyu,
- #define SDHCI_CONTROL2 0x80 #define SDHCI_CONTROL3 0x84 #define SDHCI_CONTROL4 0x8C
- return s5p_sdhci_init(base, index, bus_width); } #endif
Looks good to me.
On 08/28/2013 04:11 PM, Przemyslaw Marczak wrote:
Hi Minkyu,
} #endifreturn s5p_sdhci_init(base, index, bus_width);
Jaehoon Chung
Minkyu Kang
Przemyslaw Marczak
