[PATCH 1/2] riscv: Avoid the reserved memory fixup if src and dst point to the same place
The copy of reserved memory node from source dtb to destination dtb can be avoided if they point to the same place. This is useful when OF_PRIOR_STAGE is used.
Signed-off-by: Bin Meng bin.meng@windriver.com ---
arch/riscv/lib/fdt_fixup.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/arch/riscv/lib/fdt_fixup.c b/arch/riscv/lib/fdt_fixup.c index 6db48ad..5f523f0 100644 --- a/arch/riscv/lib/fdt_fixup.c +++ b/arch/riscv/lib/fdt_fixup.c @@ -82,10 +82,9 @@ int riscv_fdt_copy_resv_mem_node(const void *src, void *dst) * @fdt: Pointer to the device tree in which reserved memory node needs to be * added. * - * In RISC-V, any board compiled with OF_SEPARATE needs to copy the reserved - * memory node from the device tree provided by the firmware to the device tree - * used by U-Boot. This is a common function that individual board fixup - * functions can invoke. + * In RISC-V, any board needs to copy the reserved memory node from the device + * tree provided by the firmware to the device tree used by U-Boot. This is a + * common function that individual board fixup functions can invoke. * * Return: 0 on success or error otherwise. */ @@ -95,6 +94,11 @@ int riscv_board_reserved_mem_fixup(void *fdt) void *src_fdt_addr;
src_fdt_addr = map_sysmem(gd->arch.firmware_fdt_addr, 0); + + /* avoid the copy if we are using the same device tree */ + if (src_fdt_addr == fdt) + return 0; + err = riscv_fdt_copy_resv_mem_node(src_fdt_addr, fdt); if (err < 0) return err;
Starting from OpenSBI v0.7, the SBI firmware inserts/fixes up the reserved memory node for PMP protected memory regions. All RISC-V boards needs to copy the reserved memory node from the device tree provided by the firmware to the device tree used by U-Boot.
Turn on CONFIG_OF_BOARD_FIXUP by default.
arch/riscv/Kconfig | 3 +++ configs/sifive_fu540_defconfig | 1 - 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index fb5fe5a..5176b35 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -272,4 +272,7 @@ config STACK_SIZE_SHIFT int default 14
+config OF_BOARD_FIXUP + default y + endmenu diff --git a/configs/sifive_fu540_defconfig b/configs/sifive_fu540_defconfig index f805aac..6d61e6c 100644 --- a/configs/sifive_fu540_defconfig +++ b/configs/sifive_fu540_defconfig @@ -9,7 +9,6 @@ CONFIG_FIT=y CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_CPUINFO=y CONFIG_DISPLAY_BOARDINFO=y -CONFIG_OF_BOARD_FIXUP=y CONFIG_DEFAULT_DEVICE_TREE="hifive-unleashed-a00" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM_MTD=y
Ping?
Bin Meng
