[U-Boot] [PATCH v2 1/3] iomux-v3: Place pad control definitions into common file
Instead of having the same PAD control definition in each MX6 variant pin file, place it into a common location.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v2: - Add missing IOMUX_CONFIG_SION definition arch/arm/include/asm/arch-mx6/mx6dl_pins.h | 27 --------------------------- arch/arm/include/asm/arch-mx6/mx6q_pins.h | 27 --------------------------- arch/arm/include/asm/imx-common/iomux-v3.h | 27 ++++++++++++++++++++++++++- 3 files changed, 26 insertions(+), 55 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h index 9846f1b..0ed12f3 100644 --- a/arch/arm/include/asm/arch-mx6/mx6dl_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6dl_pins.h @@ -22,33 +22,6 @@
#include <asm/imx-common/iomux-v3.h>
-/* Use to set PAD control */ -#define PAD_CTL_HYS (1 << 16) -#define PAD_CTL_PUS_100K_DOWN (0 << 14) -#define PAD_CTL_PUS_47K_UP (1 << 14) -#define PAD_CTL_PUS_100K_UP (2 << 14) -#define PAD_CTL_PUS_22K_UP (3 << 14) - -#define PAD_CTL_PUE (1 << 13) -#define PAD_CTL_PKE (1 << 12) -#define PAD_CTL_ODE (1 << 11) -#define PAD_CTL_SPEED_LOW (1 << 6) -#define PAD_CTL_SPEED_MED (2 << 6) -#define PAD_CTL_SPEED_HIGH (3 << 6) -#define PAD_CTL_DSE_DISABLE (0 << 3) -#define PAD_CTL_DSE_240ohm (1 << 3) -#define PAD_CTL_DSE_120ohm (2 << 3) -#define PAD_CTL_DSE_80ohm (3 << 3) -#define PAD_CTL_DSE_60ohm (4 << 3) -#define PAD_CTL_DSE_48ohm (5 << 3) -#define PAD_CTL_DSE_40ohm (6 << 3) -#define PAD_CTL_DSE_34ohm (7 << 3) -#define PAD_CTL_SRE_FAST (1 << 0) -#define PAD_CTL_SRE_SLOW (0 << 0) - -#define IOMUX_CONFIG_SION 0x10 -#define NO_MUX_I 0 -#define NO_PAD_I 0 enum { MX6_PAD_CSI0_DAT10__UART1_TXD = IOMUX_PAD(0x0360, 0x004C, 3, 0x0000, 0, 0), MX6_PAD_CSI0_DAT11__UART1_RXD = IOMUX_PAD(0x0364, 0x0050, 3, 0x08FC, 1, 0), diff --git a/arch/arm/include/asm/arch-mx6/mx6q_pins.h b/arch/arm/include/asm/arch-mx6/mx6q_pins.h index 1c1c008..02a40d4 100644 --- a/arch/arm/include/asm/arch-mx6/mx6q_pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6q_pins.h @@ -24,33 +24,6 @@
-/* Use to set PAD control */ -#define PAD_CTL_HYS (1 << 16) -#define PAD_CTL_PUS_100K_DOWN (0 << 14) -#define PAD_CTL_PUS_47K_UP (1 << 14) -#define PAD_CTL_PUS_100K_UP (2 << 14) -#define PAD_CTL_PUS_22K_UP (3 << 14) - -#define PAD_CTL_PUE (1 << 13) -#define PAD_CTL_PKE (1 << 12) -#define PAD_CTL_ODE (1 << 11) -#define PAD_CTL_SPEED_LOW (1 << 6) -#define PAD_CTL_SPEED_MED (2 << 6) -#define PAD_CTL_SPEED_HIGH (3 << 6) -#define PAD_CTL_DSE_DISABLE (0 << 3) -#define PAD_CTL_DSE_240ohm (1 << 3) -#define PAD_CTL_DSE_120ohm (2 << 3) -#define PAD_CTL_DSE_80ohm (3 << 3) -#define PAD_CTL_DSE_60ohm (4 << 3) -#define PAD_CTL_DSE_48ohm (5 << 3) -#define PAD_CTL_DSE_40ohm (6 << 3) -#define PAD_CTL_DSE_34ohm (7 << 3) -#define PAD_CTL_SRE_FAST (1 << 0) -#define PAD_CTL_SRE_SLOW (0 << 0) - -#define NO_MUX_I 0 -#define NO_PAD_I 0 - enum { MX6_PAD_SD2_DAT1__USDHC2_DAT1 = IOMUX_PAD(0x0360, 0x004C, 0, 0x0000, 0, 0), MX6_PAD_SD2_DAT1__ECSPI5_SS0 = IOMUX_PAD(0x0360, 0x004C, 1, 0x0834, 0, 0), diff --git a/arch/arm/include/asm/imx-common/iomux-v3.h b/arch/arm/include/asm/imx-common/iomux-v3.h index c34bb76..36917c8 100644 --- a/arch/arm/include/asm/imx-common/iomux-v3.h +++ b/arch/arm/include/asm/imx-common/iomux-v3.h @@ -95,7 +95,32 @@ typedef u64 iomux_v3_cfg_t; #define GPIO_PORTE (4 << GPIO_PORT_SHIFT) #define GPIO_PORTF (5 << GPIO_PORT_SHIFT)
-#define MUX_CONFIG_SION (0x1 << 4) +#define PAD_CTL_HYS (1 << 16) +#define PAD_CTL_PUS_100K_DOWN (0 << 14) +#define PAD_CTL_PUS_47K_UP (1 << 14) +#define PAD_CTL_PUS_100K_UP (2 << 14) +#define PAD_CTL_PUS_22K_UP (3 << 14) + +#define PAD_CTL_PUE (1 << 13) +#define PAD_CTL_PKE (1 << 12) +#define PAD_CTL_ODE (1 << 11) +#define PAD_CTL_SPEED_LOW (1 << 6) +#define PAD_CTL_SPEED_MED (2 << 6) +#define PAD_CTL_SPEED_HIGH (3 << 6) +#define PAD_CTL_DSE_DISABLE (0 << 3) +#define PAD_CTL_DSE_240ohm (1 << 3) +#define PAD_CTL_DSE_120ohm (2 << 3) +#define PAD_CTL_DSE_80ohm (3 << 3) +#define PAD_CTL_DSE_60ohm (4 << 3) +#define PAD_CTL_DSE_48ohm (5 << 3) +#define PAD_CTL_DSE_40ohm (6 << 3) +#define PAD_CTL_DSE_34ohm (7 << 3) +#define PAD_CTL_SRE_FAST (1 << 0) +#define PAD_CTL_SRE_SLOW (0 << 0) + +#define IOMUX_CONFIG_SION 0x10 +#define NO_MUX_I 0 +#define NO_PAD_I 0
int imx_iomux_v3_setup_pad(iomux_v3_cfg_t pad); int imx_iomux_v3_setup_multiple_pads(iomux_v3_cfg_t const *pad_list,
mx6 solo-lite is another member of the mx6 series.
For more information about mx6 solo-lite, please visit: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX6SL&n...
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v1: - None
arch/arm/cpu/armv7/mx6/clock.c | 38 ++++++++++++++++- arch/arm/include/asm/arch-mx6/crm_regs.h | 5 +++ arch/arm/include/asm/arch-mx6/imx-regs.h | 63 +++++++++++++++++++++++++++- arch/arm/include/asm/arch-mx6/mx6-pins.h | 4 ++ arch/arm/include/asm/arch-mx6/mx6sl_pins.h | 25 +++++++++++ 5 files changed, 132 insertions(+), 3 deletions(-) create mode 100644 arch/arm/include/asm/arch-mx6/mx6sl_pins.h
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index a50db70..8cba4fd 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -186,12 +186,16 @@ static u32 get_ipg_per_clk(void) static u32 get_uart_clk(void) { u32 reg, uart_podf; - + u32 freq = PLL3_80M; reg = __raw_readl(&imx_ccm->cscdr1); +#ifdef CONFIG_MX6SL + if (reg & MXC_CCM_CSCDR1_UART_CLK_SEL) + freq = MXC_HCLK; +#endif reg &= MXC_CCM_CSCDR1_UART_CLK_PODF_MASK; uart_podf = reg >> MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET;
- return PLL3_80M / (uart_podf + 1); + return freq / (uart_podf + 1); }
static u32 get_cspi_clk(void) @@ -252,6 +256,35 @@ static u32 get_emi_slow_clk(void) return root_freq / (emi_slow_pof + 1); }
+#ifdef CONFIG_MX6SL +static u32 get_mmdc_ch0_clk(void) +{ + u32 cbcmr = __raw_readl(&imx_ccm->cbcmr); + u32 cbcdr = __raw_readl(&imx_ccm->cbcdr); + u32 freq, podf; + + podf = (cbcdr & MXC_CCM_CBCDR_MMDC_CH1_PODF_MASK) \ + >> MXC_CCM_CBCDR_MMDC_CH1_PODF_OFFSET; + + switch ((cbcmr & MXC_CCM_CBCMR_PRE_PERIPH2_CLK_SEL_MASK) >> + MXC_CCM_CBCMR_PRE_PERIPH2_CLK_SEL_OFFSET) { + case 0: + freq = decode_pll(PLL_BUS, MXC_HCLK); + break; + case 1: + freq = PLL2_PFD2_FREQ; + break; + case 2: + freq = PLL2_PFD0_FREQ; + break; + case 3: + freq = PLL2_PFD2_DIV_FREQ; + } + + return freq / (podf + 1); + +} +#else static u32 get_mmdc_ch0_clk(void) { u32 cbcdr = __raw_readl(&imx_ccm->cbcdr); @@ -260,6 +293,7 @@ static u32 get_mmdc_ch0_clk(void)
return get_periph_clk() / (mmdc_ch0_podf + 1); } +#endif
static u32 get_usdhc_clk(u32 port) { diff --git a/arch/arm/include/asm/arch-mx6/crm_regs.h b/arch/arm/include/asm/arch-mx6/crm_regs.h index 7676457..b1ed62f 100644 --- a/arch/arm/include/asm/arch-mx6/crm_regs.h +++ b/arch/arm/include/asm/arch-mx6/crm_regs.h @@ -244,7 +244,12 @@ struct mxc_ccm_reg { #define MXC_CCM_CSCDR1_USBOH3_CLK_PRED_MASK (0x7 << 8) #define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_OFFSET 6 #define MXC_CCM_CSCDR1_USBOH3_CLK_PODF_MASK (0x3 << 6) +#ifdef CONFIG_MX6SL +#define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK 0x1F +#define MXC_CCM_CSCDR1_UART_CLK_SEL (1 << 6) +#else #define MXC_CCM_CSCDR1_UART_CLK_PODF_MASK 0x3F +#endif #define MXC_CCM_CSCDR1_UART_CLK_PODF_OFFSET 0
/* Define the bits in register CS1CDR */ diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index eaa7439..2d8fe69 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -25,6 +25,13 @@
#define ROMCP_ARB_BASE_ADDR 0x00000000 #define ROMCP_ARB_END_ADDR 0x000FFFFF + +#ifdef CONFIG_MX6SL +#define GPU_2D_ARB_BASE_ADDR 0x02200000 +#define GPU_2D_ARB_END_ADDR 0x02203FFF +#define OPENVG_ARB_BASE_ADDR 0x02204000 +#define OPENVG_ARB_END_ADDR 0x02207FFF +#else #define CAAM_ARB_BASE_ADDR 0x00100000 #define CAAM_ARB_END_ADDR 0x00103FFF #define APBH_DMA_ARB_BASE_ADDR 0x00110000 @@ -37,9 +44,14 @@ #define GPU_2D_ARB_END_ADDR 0x00137FFF #define DTCP_ARB_BASE_ADDR 0x00138000 #define DTCP_ARB_END_ADDR 0x0013BFFF - +#endif /* CONFIG_MX6SL */ /* GPV - PL301 configuration ports */ +#ifdef CONFIG_MX6SL +#define GPV2_BASE_ADDR 0x00D00000 +#else #define GPV2_BASE_ADDR 0x00200000 +#endif + #define GPV3_BASE_ADDR 0x00300000 #define GPV4_BASE_ADDR 0x00800000 #define IRAM_BASE_ADDR 0x00900000 @@ -70,10 +82,17 @@ #define WEIM_ARB_BASE_ADDR 0x08000000 #define WEIM_ARB_END_ADDR 0x0FFFFFFF
+#ifdef CONFIG_MX6SL +#define MMDC0_ARB_BASE_ADDR 0x80000000 +#define MMDC0_ARB_END_ADDR 0xFFFFFFFF +#define MMDC1_ARB_BASE_ADDR 0xC0000000 +#define MMDC1_ARB_END_ADDR 0xFFFFFFFF +#else #define MMDC0_ARB_BASE_ADDR 0x10000000 #define MMDC0_ARB_END_ADDR 0x7FFFFFFF #define MMDC1_ARB_BASE_ADDR 0x80000000 #define MMDC1_ARB_END_ADDR 0xFFFFFFFF +#endif
#define IPU_SOC_BASE_ADDR IPU1_ARB_BASE_ADDR #define IPU_SOC_OFFSET 0x00200000 @@ -89,6 +108,16 @@ #define ECSPI2_BASE_ADDR (ATZ1_BASE_ADDR + 0x0C000) #define ECSPI3_BASE_ADDR (ATZ1_BASE_ADDR + 0x10000) #define ECSPI4_BASE_ADDR (ATZ1_BASE_ADDR + 0x14000) +#ifdef CONFIG_MX6SL +#define UART5_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x18000) +#define UART1_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x20000) +#define UART2_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x24000) +#define SSI1_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x28000) +#define SSI2_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x2C000) +#define SSI3_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x30000) +#define UART3_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x34000) +#define UART4_IPS_BASE_ADDR (ATZ1_BASE_ADDR + 0x38000) +#else #define ECSPI5_BASE_ADDR (ATZ1_BASE_ADDR + 0x18000) #define UART1_BASE (ATZ1_BASE_ADDR + 0x20000) #define ESAI1_BASE_ADDR (ATZ1_BASE_ADDR + 0x24000) @@ -96,6 +125,8 @@ #define SSI2_BASE_ADDR (ATZ1_BASE_ADDR + 0x2C000) #define SSI3_BASE_ADDR (ATZ1_BASE_ADDR + 0x30000) #define ASRC_BASE_ADDR (ATZ1_BASE_ADDR + 0x34000) +#endif + #define SPBA_BASE_ADDR (ATZ1_BASE_ADDR + 0x3C000) #define VPU_BASE_ADDR (ATZ1_BASE_ADDR + 0x40000) #define AIPS1_ON_BASE_ADDR (ATZ1_BASE_ADDR + 0x7C000) @@ -128,18 +159,35 @@ #define SRC_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x58000) #define GPC_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x5C000) #define IOMUXC_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x60000) +#ifdef CONFIG_MX6SL +#define CSI_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x64000) +#define SIPIX_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x68000) +#define SDMA_PORT_HOST_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x6C000) +#else #define DCIC1_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x64000) #define DCIC2_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x68000) #define DMA_REQ_PORT_HOST_BASE_ADDR (AIPS1_OFF_BASE_ADDR + 0x6C000) +#endif
#define AIPS2_ON_BASE_ADDR (ATZ2_BASE_ADDR + 0x7C000) #define AIPS2_OFF_BASE_ADDR (ATZ2_BASE_ADDR + 0x80000) #define CAAM_BASE_ADDR (ATZ2_BASE_ADDR) #define ARM_BASE_ADDR (ATZ2_BASE_ADDR + 0x40000) +#ifdef CONFIG_MX6SL +#define USBO2H_PL301_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x0000) +#define USBO2H_USB_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x4000) +#else #define USBOH3_PL301_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x0000) #define USBOH3_USB_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x4000) +#endif + #define ENET_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x8000) +#ifdef CONFIG_MX6SL +#define MSHC_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0xC000) +#else #define MLB_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0xC000) +#endif + #define USDHC1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x10000) #define USDHC2_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x14000) #define USDHC3_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x18000) @@ -149,7 +197,12 @@ #define I2C3_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x28000) #define ROMCP_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x2C000) #define MMDC_P0_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x30000) +#ifdef CONFIG_MX6SL +#define RNGB_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x34000) +#else #define MMDC_P1_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x34000) +#endif + #define WEIM_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x38000) #define OCOTP_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x3C000) #define CSU_BASE_ADDR (AIPS2_OFF_BASE_ADDR + 0x40000) @@ -364,12 +417,20 @@ struct cspi_regs { #define MXC_CSPICON_POL 4 #define MXC_CSPICON_PHA 0 #define MXC_CSPICON_SSPOL 12 +#ifdef CONFIG_MX6SL +#define MXC_SPI_BASE_ADDRESSES \ + ECSPI1_BASE_ADDR, \ + ECSPI2_BASE_ADDR, \ + ECSPI3_BASE_ADDR, \ + ECSPI4_BASE_ADDR +#else #define MXC_SPI_BASE_ADDRESSES \ ECSPI1_BASE_ADDR, \ ECSPI2_BASE_ADDR, \ ECSPI3_BASE_ADDR, \ ECSPI4_BASE_ADDR, \ ECSPI5_BASE_ADDR +#endif
struct iim_regs { u32 ctrl; diff --git a/arch/arm/include/asm/arch-mx6/mx6-pins.h b/arch/arm/include/asm/arch-mx6/mx6-pins.h index 63f4856..ce865a6 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6-pins.h @@ -24,7 +24,11 @@ #if defined(CONFIG_MX6DL) || defined(CONFIG_MX6S) #include "mx6dl_pins.h" #else +#if defined(CONFIG_MX6SL) +#include "mx6sl_pins.h" +#else #error "Please select cpu" +#endif /* CONFIG_MX6SL */ #endif /* CONFIG_MX6DL or CONFIG_MX6S */ #endif /* CONFIG_MX6Q */
diff --git a/arch/arm/include/asm/arch-mx6/mx6sl_pins.h b/arch/arm/include/asm/arch-mx6/mx6sl_pins.h new file mode 100644 index 0000000..bfe4f00 --- /dev/null +++ b/arch/arm/include/asm/arch-mx6/mx6sl_pins.h @@ -0,0 +1,25 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. All Rights Reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef __ASM_ARCH_MX6_MX6SL_PINS_H__ +#define __ASM_ARCH_MX6_MX6SL_PINS_H__ + +#include <asm/imx-common/iomux-v3.h> + +enum { + MX6_PAD_SD2_CLK__USDHC2_CLK = IOMUX_PAD(0x055C, 0x0254, 0, 0x0000, 0, 0), + MX6_PAD_SD2_CMD__USDHC2_CMD = IOMUX_PAD(0x0560, 0x0258, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT0__USDHC2_DAT0 = IOMUX_PAD(0x0564, 0x025C, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT1__USDHC2_DAT1 = IOMUX_PAD(0x0568, 0x0260, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT2__USDHC2_DAT2 = IOMUX_PAD(0x056C, 0x0264, 0, 0x0000, 0, 0), + MX6_PAD_SD2_DAT3__USDHC2_DAT3 = IOMUX_PAD(0x0570, 0x0268, 0, 0x0000, 0, 0), + MX6_PAD_UART1_RXD__UART1_RXD = IOMUX_PAD(0x05A0, 0x0298, 0, 0x07FC, 0, 0), + MX6_PAD_UART1_TXD__UART1_TXD = IOMUX_PAD(0x05A4, 0x029C, 0, 0x0000, 0, 0), +}; +#endif /* __ASM_ARCH_MX6_MX6SL_PINS_H__ */
mx6slevk board is a development board from Freescale based on the mx6 solo-lite processor.
For details about mx6slevk, please refer to: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX6SLEVK&...
MAINTAINERS | 1 + board/freescale/mx6slevk/Makefile | 28 +++++ board/freescale/mx6slevk/imximage.cfg | 118 ++++++++++++++++++++ board/freescale/mx6slevk/mx6slevk.c | 102 ++++++++++++++++++ boards.cfg | 1 + include/configs/mx6slevk.h | 189 +++++++++++++++++++++++++++++++++ 6 files changed, 439 insertions(+) create mode 100644 board/freescale/mx6slevk/Makefile create mode 100644 board/freescale/mx6slevk/imximage.cfg create mode 100644 board/freescale/mx6slevk/mx6slevk.c create mode 100644 include/configs/mx6slevk.h
diff --git a/MAINTAINERS b/MAINTAINERS index 0f19078..723a316 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -665,6 +665,7 @@ Fabio Estevam fabio.estevam@freescale.com mx6qsabresd i.MX6Q mx6qsabreauto i.MX6Q wandboard i.MX6DL/S + mx6slevk i.MX6SL
Daniel Gorsulowski daniel.gorsulowski@esd.eu
diff --git a/board/freescale/mx6slevk/Makefile b/board/freescale/mx6slevk/Makefile new file mode 100644 index 0000000..43af351 --- /dev/null +++ b/board/freescale/mx6slevk/Makefile @@ -0,0 +1,28 @@ +# (C) Copyright 2013 Freescale Semiconductor, Inc. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := mx6slevk.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/mx6slevk/imximage.cfg b/board/freescale/mx6slevk/imximage.cfg new file mode 100644 index 0000000..df39a16 --- /dev/null +++ b/board/freescale/mx6slevk/imximage.cfg @@ -0,0 +1,118 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License or (at your option) any later version. + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ + +BOOT_FROM sd + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ +DATA 4 0x020c4018 0x00260324 + +DATA 4 0x020c4068 0xffffffff +DATA 4 0x020c406c 0xffffffff +DATA 4 0x020c4070 0xffffffff +DATA 4 0x020c4074 0xffffffff +DATA 4 0x020c4078 0xffffffff +DATA 4 0x020c407c 0xffffffff +DATA 4 0x020c4080 0xffffffff + +DATA 4 0x020e0344 0x00003030 +DATA 4 0x020e0348 0x00003030 +DATA 4 0x020e034c 0x00003030 +DATA 4 0x020e0350 0x00003030 +DATA 4 0x020e030c 0x00000030 +DATA 4 0x020e0310 0x00000030 +DATA 4 0x020e0314 0x00000030 +DATA 4 0x020e0318 0x00000030 +DATA 4 0x020e0300 0x00000030 +DATA 4 0x020e031c 0x00000030 +DATA 4 0x020e0338 0x00000028 +DATA 4 0x020e0320 0x00000030 +DATA 4 0x020e032c 0x00000000 +DATA 4 0x020e033c 0x00000008 +DATA 4 0x020e0340 0x00000008 +DATA 4 0x020e05c4 0x00000030 +DATA 4 0x020e05cc 0x00000030 +DATA 4 0x020e05d4 0x00000030 +DATA 4 0x020e05d8 0x00000030 +DATA 4 0x020e05ac 0x00000030 +DATA 4 0x020e05c8 0x00000030 +DATA 4 0x020e05b0 0x00020000 +DATA 4 0x020e05b4 0x00000000 +DATA 4 0x020e05c0 0x00020000 +DATA 4 0x020e05d0 0x00080000 + +DATA 4 0x021b001c 0x00008000 +DATA 4 0x021b085c 0x1b4700c7 +DATA 4 0x021b0800 0xa1390003 +DATA 4 0x021b0890 0x00300000 +DATA 4 0x021b08b8 0x00000800 +DATA 4 0x021b081c 0x33333333 +DATA 4 0x021b0820 0x33333333 +DATA 4 0x021b0824 0x33333333 +DATA 4 0x021b0828 0x33333333 +DATA 4 0x021b082c 0xf3333333 +DATA 4 0x021b0830 0xf3333333 +DATA 4 0x021b0834 0xf3333333 +DATA 4 0x021b0838 0xf3333333 +DATA 4 0x021b0848 0x4241444a +DATA 4 0x021b0850 0x3030312b +DATA 4 0x021b083c 0x20000000 +DATA 4 0x021b0840 0x00000000 +DATA 4 0x021b08c0 0x24911492 +DATA 4 0x021b08b8 0x00000800 +DATA 4 0x021b000c 0x33374133 +DATA 4 0x021b0004 0x00020024 +DATA 4 0x021b0010 0x00100A82 +DATA 4 0x021b0014 0x00000093 +DATA 4 0x021b0018 0x00001688 +DATA 4 0x021b002c 0x0f9f26d2 +DATA 4 0x021b0030 0x0000020e +DATA 4 0x021b0038 0x00190778 +DATA 4 0x021b0008 0x00000000 +DATA 4 0x021b0040 0x0000004f +DATA 4 0x021b0000 0xc3110000 +DATA 4 0x021b001c 0x003f8030 +DATA 4 0x021b001c 0xff0a8030 +DATA 4 0x021b001c 0x82018030 +DATA 4 0x021b001c 0x04028030 +DATA 4 0x021b001c 0x02038030 +DATA 4 0x021b001c 0xff0a8038 +DATA 4 0x021b001c 0x82018038 +DATA 4 0x021b001c 0x04028038 +DATA 4 0x021b001c 0x02038038 +DATA 4 0x021b0800 0xa1310003 +DATA 4 0x021b0020 0x00001800 +DATA 4 0x021b0818 0x00000000 +DATA 4 0x021b08b8 0x00000800 +DATA 4 0x021b0004 0x00025564 +DATA 4 0x021b0404 0x00011006 +DATA 4 0x021b001c 0x00000000 diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c new file mode 100644 index 0000000..fc6353e --- /dev/null +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -0,0 +1,102 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + */ + +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/io.h> +#include <asm/sizes.h> +#include <common.h> +#include <fsl_esdhc.h> +#include <mmc.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_UART1_TXD__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RXD__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc2_pads[] = { + MX6_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT0__USDHC2_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT1__USDHC2_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT2__USDHC2_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT3__USDHC2_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC2_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + return 1; /* Assume boot SD always present */ +} + +int board_mmc_init(bd_t *bis) +{ + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +} + +int board_early_init_f(void) +{ + setup_iomux_uart(); + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +u32 get_board_rev(void) +{ + return get_cpu_rev(); +} + +int checkboard(void) +{ + puts("Board: MX6SLEVK\n"); + + return 0; +} diff --git a/boards.cfg b/boards.cfg index 7725a15..9e213ad 100644 --- a/boards.cfg +++ b/boards.cfg @@ -257,6 +257,7 @@ mx6qarm2 arm armv7 mx6qarm2 freesca mx6qsabreauto arm armv7 mx6qsabreauto freescale mx6 mx6qsabreauto:IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg mx6qsabrelite arm armv7 mx6qsabrelite freescale mx6 mx6qsabrelite:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg mx6qsabresd arm armv7 mx6qsabresd freescale mx6 mx6qsabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg +mx6slevk arm armv7 mx6slevk freescale mx6 mx6slevk:IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL eco5pk arm armv7 eco5pk 8dtech omap3 nitrogen6dl arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 nitrogen6dl2g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048 diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h new file mode 100644 index 0000000..67b63f4 --- /dev/null +++ b/include/configs/mx6slevk.h @@ -0,0 +1,189 @@ +/* + * Copyright 2013 Freescale Semiconductor, Inc. + * + * Configuration settings for the Freescale i.MX6SL EVK board. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/imx-regs.h> +#include <asm/sizes.h> + +#define CONFIG_MX6 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define MACH_TYPE_MX6SLEVK 4307 +#define CONFIG_MACH_TYPE MACH_TYPE_MX6SLEVK + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (3 * SZ_1M) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR + +/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_LOADADDR 0x80800000 +#define CONFIG_SYS_TEXT_BASE 0x87800000 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "uimage=uImage\0" \ + "console=ttymxc0\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=imx6sl-evk.dtb\0" \ + "fdt_addr=0x81000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev=0\0" \ + "mmcpart=2\0" \ + "mmcroot=/dev/mmcblk0p3 rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev};" \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 256 * SZ_1M) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING +#define CONFIG_STACKSIZE SZ_128K + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define PHYS_SDRAM_SIZE SZ_512M + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_OFFSET (6 * SZ_64K) +#define CONFIG_ENV_SIZE SZ_8K +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +#endif /* __CONFIG_H */
On Tue, Apr 9, 2013 at 3:55 PM, Fabio Estevam fabio.estevam@freescale.com wrote:
This fixes the build failure.
Acked-by: Otavio Salvador otavio@ossystems.com.br
-- Otavio Salvador O.S. Systems E-mail: otavio@ossystems.com.br http://www.ossystems.com.br Mobile: +55 53 9981-7854 http://projetos.ossystems.com.br
Fabio Estevam
Otavio Salvador
