[U-Boot] [PATCH] rockchip: fix rk3036 SPL build
Commit c7db6abf534d ("ARM64: rockchip: add support for rk3399 SoC based evb") moved the SPL Kconfig selects into the individual soc-specific options. But it only did it for the rk3288 and not for the rk3036 thus disabling SPL builds for it. Add the necessary options for the rk3036 as well.
Fixes: c7db6abf534d ("ARM64: rockchip: add support for rk3399 SoC based evb") Signed-off-by: Heiko Stuebner heiko@sntech.de --- arch/arm/mach-rockchip/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 2817c0f..c47e16c 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -8,6 +8,8 @@ config ROCKCHIP_RK3036 including NEON and GPU, Mali-400 graphics, several DDR3 options and video codec support. Peripherals include Gigabit Ethernet, USB2 host and OTG, SDIO, I2S, UART, SPI, I2C and PWMs. + select SUPPORT_SPL + select SPL
config ROCKCHIP_RK3188 bool "Support Rockchip RK3188"
Hi Heiko,
Simon apply my V4 patch which still have some problem, he said that he will rebase with a new patch set either if I send a new version or send fixes, but he won't be available till next week.
I have send out my V5 patch which including the code of this patch.
select SUPPORT_SPL
select SPL
Hi Heiko,
On 20 July 2016 at 19:47, Kever Yang kever.yang@rock-chips.com wrote:
Hi Heiko,
Please can you check u-boot-rockchip and see if this looks OK now?
Thanks,
- Kever
select SUPPORT_SPL
config ROCKCHIP_RK3188 bool "Support Rockchip RK3188"select SPL
Hi Simon,
Am Freitag, 22. Juli 2016, 20:31:36 schrieb Simon Glass:
yep, I've rebased on top of your master branch from just now, and everything still builds and runs just fine (rk3036, rk3188 and rk3288).
Heiko
Heiko Stuebner
Heiko Stübner
Kever Yang
