[U-Boot-Users] cpu/mips/start.S relocate_code problem
in t he relocate_code function, i set src, dest,end addess correctly,and the copy loop end do not give eror,but the sdram have not the code, does this caused by cache?
In message 50c9a2250511130043t19cd2d62r274c6eb4ffdb4e72@mail.gmail.com you wrote:
No. More likely it's caused by bad SDRAM initialization. Read the FAQ.
i do some copy befor mips_cache_lock in cpu/mips/start.S(and after mips_cache_reset), it works well. but if a do copy in relocate_code function, for every 16 bytes, only last 4 bytes is copy correctly. i think it maybe caused by cache operate,because cache line size is 16 byte,and between these two copy test, there is only mips_cache_lock operate the cache.
and for the mips_cache_lock, i think it only affect sp,but someone said it affect the gp?
so if mips_cache_lock only affect sp, i can remove it ,because i have init sdram in lowlevel_init.S, and i can give sp a sdram address.
So my question: 1. does mips_cache_lock affect the copy from flash to sdram? 2.does mips_cache_lock only affect sp?
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de I can't understand it. I can't even understand the people who can understand it. - Queen Juliana of the Netherlands.
zhuzhenhua
