[PATCH u-boot 1/3] tools: imagetool: Fix error message when verify_header is undefined
Signed-off-by: Pali Rohár pali@kernel.org --- tools/imagetool.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/imagetool.c b/tools/imagetool.c index f14ca2fb979f..688169b3a813 100644 --- a/tools/imagetool.c +++ b/tools/imagetool.c @@ -105,7 +105,7 @@ static int imagetool_verify_print_header_by_type( }
} else { - fprintf(stderr, "%s: print_header undefined for %s\n", + fprintf(stderr, "%s: verify_header undefined for %s\n", params->cmdname, tparams->name); }
Signed-off-by: Pali Rohár pali@kernel.org --- tools/imagetool.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/tools/imagetool.c b/tools/imagetool.c index 688169b3a813..e1021f44f5ad 100644 --- a/tools/imagetool.c +++ b/tools/imagetool.c @@ -71,6 +71,11 @@ int imagetool_verify_print_header( } }
+ if (retval != 0) { + fprintf(stderr, "%s: cannot detect image type\n", + params->cmdname); + } + return retval; }
gpimage type requires only that two first 32-bit words of data file are non-zero. So basically every random data file can be guessed and verified as gpimage. So completely skip gpimage type from image autodetection code to prevent lot of false positive results. Data file with gpimage type can be still verified and parsed by explicitly specifying -T gpimage.
Signed-off-by: Pali Rohár pali@kernel.org --- tools/imagetool.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/tools/imagetool.c b/tools/imagetool.c index e1021f44f5ad..87eee4ad04ed 100644 --- a/tools/imagetool.c +++ b/tools/imagetool.c @@ -49,6 +49,12 @@ int imagetool_verify_print_header( return imagetool_verify_print_header_by_type(ptr, sbuf, tparams, params);
for (curr = start; curr != end; curr++) { + /* + * Basically every data file can be guessed / verified as gpimage, + * so skip autodetection of data file as gpimage as it does not work. + */ + if ((*curr)->check_image_type && (*curr)->check_image_type(IH_TYPE_GPIMAGE) == 0) + continue; if ((*curr)->verify_header) { retval = (*curr)->verify_header((unsigned char *)ptr, sbuf->st_size, params);
I see we've had problems with gpimage before too. This seems reasonable but I'm adding Nishanth here too, as the current interested person in keystone2 platforms, to see if there's any other / better ways to address this problem.
-- Tom
I do not think that there is a better solution for gpimage. Basically it is not possible to write autodetection code for gpimage due to its generic nature. So the best what we can do is to disable gpimage in autodetection code.
I would suggest to apply this patch, so people can test their build setups sooner than later.
Yes, I will pick this up before -rc2. I was wondering / hoping Nishanth might have access to further internal information that might be helpful here.
Signed-off-by: Pali Rohár pali@kernel.org Reviewed-by: Simon Glass sjg@chromium.org
commit message? Also it is good to keep subjects to under 60 chars
} else {
-- 2.20.1
Pali Rohár
