[U-Boot] [PATCH] powerpc/t4240: Adding workaround errata A-005871
When CoreNet Fabric (CCF) internal resources are consumed by the cores, inbound SRIO messaging traffic through RMan can put the device into a deadlock condition.
This errata workaround forces internal resources to be reserved for upstream transactions. This ensures resources exist on the device for upstream transactions and removes the deadlock condition.
The Workaround is for the T4240 silicon rev 1.0.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- based on master branch upstream tree.
arch/powerpc/cpu/mpc85xx/cmd_errata.c | 4 ++++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 14 ++++++++++++++ arch/powerpc/include/asm/config_mpc85xx.h | 1 + 3 files changed, 19 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index e5ecf5d..5d72f4c 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -240,6 +240,10 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_A_004934 puts("Work-around for Erratum A004934 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A005871 + if (IS_SVR_REV(svr, 1, 0)) + puts("Work-around for Erratum A005871 enabled\n"); +#endif #ifdef CONFIG_SYS_FSL_ERRATUM_A004849 /* This work-around is implemented in PBI, so just check for it */ check_erratum_a4849(svr); diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index d1155e8..d4e67db 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -534,6 +534,20 @@ skip_l2: /* needs to be in ram since code uses global static vars */ fsl_serdes_init();
+#ifdef CONFIG_SYS_FSL_ERRATUM_A005871 + if (IS_SVR_REV(svr, 1, 0)) { + int i; + __be32 *p = (void __iomem *)CONFIG_SYS_DCSRBAR + 0xb004c; + + for (i = 0; i < 12; i++) { + p += i + (i > 5 ? 11 : 0); + out_be32(p, 0x2); + } + p = (void __iomem *)CONFIG_SYS_DCSRBAR + 0xb0108; + out_be32(p, 0x34); + } +#endif + #ifdef CONFIG_SYS_SRIO srio_init(); #ifdef CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 0b9638b..7d3920c 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -523,6 +523,7 @@ #define CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY #define CONFIG_SYS_FSL_ERRATUM_A004468 #define CONFIG_SYS_FSL_ERRATUM_A_004934 +#define CONFIG_SYS_FSL_ERRATUM_A005871 #define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000
#elif defined(CONFIG_PPC_B4860)
Shengzhou Liu
