[PATCH] board: gateworks: venice: add print for GPY111 PHY name
Due to supply chain issues Venice boards use either a DP83867 or a GPY111 RGMII PHY. We already print an identifier for the DP83867 so add one for the GPY111 to better identify what PHY is on a board:
Example: Net: GPY111 eth0: ethernet@30be0000 [PRIME] Net: DP83867 eth0: ethernet@30be0000 [PRIME]
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/venice/venice.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/gateworks/venice/venice.c b/board/gateworks/venice/venice.c index 5b105d7659e4..3080ff20cb02 100644 --- a/board/gateworks/venice/venice.c +++ b/board/gateworks/venice/venice.c @@ -75,6 +75,9 @@ int board_phy_config(struct phy_device *phydev) val |= 0xb << 8; /* LED2(Green;Link/Act): blink for TX/RX act */ phy_write(phydev, MDIO_DEVAD_NONE, 24, val); break; + case 0xd565a401: /* MaxLinear GPY111 */ + puts("GPY111 "); + break; }
if (phydev->drv->config)
Tim Harvey
