[PATCH v2 00/26] dm: Change the way sequence numbers are implemented
At present each device has two sequence numbers, with 'req_seq' being set up at bind time and 'seq' at probe time. The idea is that devices can 'request' a sequence number and then the conflicts are resolved when the device is probed.
This makes things complicated in a few cases, since we don't really know (at bind time) what the sequence number will end up being. We want to honour the bind-time requests if at all possible, but in fact the only source of these at present is the devicetree aliases.
Apart from the obvious need for sequence numbers to supports U-Boot's numbering on devices on the command line, the current scheme was designed to:
- avoid calculating the sequence number until it is needed, to save execution time - allow multiple devices to obtain a particular sequence number as they are probed and removed - retain a record of the 'requested' sequence number even if it turns out that a device could not get it (to allow debugging and retrying)
After some years using the current scheme it seems on balance that these goals don't have as much merit as first thought. The first point would be persuasive except that we end up reading the devicetree aliases at bind-time anyway. So the work of resolving the sequence numbers during probing is not that great. The second point hasn't really been an issue, as there is typically no contention for sequence numbers (boards tend to allocate them statically in the devicetree). Re the third point, we can often figure out what was requested by looking at aliases, and in the cases where we can't, it doesn't seem to matter much.
Since we have the devicetree available at bind time, we may as well just use it, in the hope that the required processing will turn out to be useful later (i.e. the device actually gets used). In addition, it is simpler to use a single sequence number, since it avoids confusion and some extra code.
This series moves U-Boot to use a single, bind-time sequence number. All uclasses assign sequence numbers to their devices, so that as soon as a device is bound, it has a sequence number. If the uclass flag DM_UC_FLAG_SEQ_ALIAS is enabled (as well as the CONFIG option), a devicetree alias provides the number. Otherwise, the next available number (after the last alias and avoiding existing devices) is used.
Apart from the simplicity gains, overall these changes seem to reduce the number of tweaks and workarounds needed to get the desired behaviour.
However there will certainly be some problems created, so board maintainers should test this out.
This series is available at u-boot-dm/seq-working
Changes in v2: - Give all devices a sequence number - Drop uclass_alloc_all_seqs() and GD_FLG_DM_NO_SEQ flag - Drop the GD_FLG_DM_NO_SEQ flag - Use the sequence number directly instead of max bus - Adjust the tests to handle the new allocation scheme - Drop the networking changes which are no-longer needed - Update for new logic - Adjust commit message - Drop pointless check for max == -1 - Adjust the tests to handle the new allocation scheme - Simplify the logic so auto_seq is positive - Update the docs to indicate all devices get a sequence number - Update the docs to explain how aliases reserve sequence numbers - Drop commit changing efi_uc_destroy()
Simon Glass (26): linker_lists: Fix alignment issue dm: Avoid accessing seq directly dm: core: Update uclass_find_next_free_req_seq() args dm: core: Add a new sequence number for devices dm: test: Check all devices have a sequence numbers dm: core: Switch binding to use new sequence numbers dm: Fix return value in dev_read_alias_seq() dm: test: Drop assumptions of no sequence numbers octeon: Don't attempt to set the sequence number i2c: Update for new sequence numbers net: Update to use new sequence numbers pci: Update to use new sequence numbers spi: Update for new sequence numbers usb: ehci-mx6: Drop assignment of sequence number usb: Update for new sequence numbers x86: Drop unnecessary mp_init logic x86: Simplify acpi_device_infer_name() gpio: Update for new sequence numbers pinctrl: Update for new sequence numbers dm: Switch over to use new sequence number for dev_seq() dm: Drop uclass_resolve_seq() dm: Drop the unused arg in uclass_find_device_by_seq() dm: core: Update uclass_find_next_free_req_seq() for new scheme cmd: Drop use of old sequence numbers in commands dm: core: Drop seq and req_seq dm: Update documentation for new sequence numbers
arch/Kconfig | 11 ++ arch/arm/include/asm/mach-imx/mxc_i2c.h | 2 +- arch/arm/mach-k3/am6_init.c | 2 +- arch/arm/mach-k3/j721e_init.c | 2 +- arch/arm/mach-k3/sysfw-loader.c | 2 +- arch/sandbox/dts/test.dts | 2 +- arch/x86/cpu/apollolake/cpu.c | 2 +- arch/x86/cpu/broadwell/cpu_full.c | 2 +- arch/x86/cpu/ivybridge/model_206ax.c | 2 +- arch/x86/cpu/mp_init.c | 23 ++-- arch/x86/include/asm/mp.h | 2 +- board/xilinx/versal/board.c | 12 +-- board/xilinx/zynqmp/zynqmp.c | 12 +-- cmd/axi.c | 6 +- cmd/cpu.c | 2 +- cmd/i2c.c | 6 +- cmd/misc.c | 2 +- cmd/osd.c | 6 +- cmd/pci.c | 7 +- cmd/pmic.c | 4 +- cmd/remoteproc.c | 2 +- cmd/w1.c | 4 +- doc/api/linker_lists.rst | 59 ++++++++++ doc/driver-model/design.rst | 54 +++++----- drivers/core/device-remove.c | 1 - drivers/core/device.c | 50 +++------ drivers/core/dump.c | 4 +- drivers/core/read.c | 4 +- drivers/core/root.c | 8 +- drivers/core/uclass.c | 86 ++++----------- drivers/gpio/imx_rgpio2p.c | 2 +- drivers/gpio/iproc_gpio.c | 2 +- drivers/gpio/mvebu_gpio.c | 2 +- drivers/gpio/mxc_gpio.c | 2 +- drivers/gpio/octeon_gpio.c | 2 +- drivers/gpio/vybrid_gpio.c | 2 +- drivers/i2c/ast_i2c.c | 4 +- drivers/i2c/davinci_i2c.c | 2 +- drivers/i2c/designware_i2c_pci.c | 16 +-- drivers/i2c/exynos_hs_i2c.c | 2 +- drivers/i2c/i2c-gpio.c | 2 +- drivers/i2c/i2c-uclass.c | 8 +- drivers/i2c/i2c-versatile.c | 5 - drivers/i2c/imx_lpi2c.c | 12 +-- drivers/i2c/intel_i2c.c | 12 +-- drivers/i2c/lpc32xx_i2c.c | 6 +- drivers/i2c/muxes/i2c-mux-uclass.c | 4 +- drivers/i2c/mvtwsi.c | 6 +- drivers/i2c/mxc_i2c.c | 10 +- drivers/i2c/nx_i2c.c | 2 +- drivers/i2c/octeon_i2c.c | 3 +- drivers/i2c/s3c24x0_i2c.c | 2 +- drivers/i2c/tegra_i2c.c | 5 +- drivers/mmc/fsl_esdhc_imx.c | 4 +- drivers/mmc/octeontx_hsmmc.c | 2 - drivers/mtd/spi/sandbox.c | 4 +- drivers/net/dwc_eth_qos.c | 2 +- drivers/net/fec_mxc.c | 7 +- drivers/net/fsl-mc/mc.c | 2 +- drivers/net/fsl_mcdmafec.c | 2 +- drivers/net/ftgmac100.c | 2 +- drivers/net/higmacv300.c | 2 +- drivers/net/mcffec.c | 2 +- drivers/net/octeontx/nicvf_main.c | 9 +- drivers/net/octeontx/smi.c | 3 +- drivers/net/octeontx2/nix.c | 2 +- drivers/net/octeontx2/rvu_pf.c | 6 +- drivers/net/xilinx_axi_emac.c | 2 +- drivers/net/xilinx_emaclite.c | 2 +- drivers/net/zynq_gem.c | 2 +- drivers/pci/pci-aardvark.c | 2 +- drivers/pci/pci-uclass.c | 42 +++----- drivers/pci/pci_auto.c | 6 +- drivers/pci/pcie_dw_mvebu.c | 6 +- drivers/pci/pcie_dw_ti.c | 6 +- drivers/pci/pcie_ecam_generic.c | 2 +- drivers/pci/pcie_fsl.c | 16 +-- drivers/pci/pcie_intel_fpga.c | 2 +- drivers/pci/pcie_layerscape_fixup.c | 4 +- drivers/pci/pcie_layerscape_gen4.c | 10 +- drivers/pci/pcie_layerscape_gen4_fixup.c | 2 +- drivers/pci/pcie_layerscape_rc.c | 12 +-- drivers/pci/pcie_mediatek.c | 2 +- drivers/pci/pcie_rockchip.c | 6 +- drivers/pinctrl/exynos/pinctrl-exynos.c | 2 +- drivers/serial/serial_mcf.c | 2 +- drivers/serial/serial_s5p.c | 2 +- drivers/spi/altera_spi.c | 2 +- drivers/spi/cf_spi.c | 12 +-- drivers/spi/fsl_dspi.c | 8 +- drivers/spi/fsl_espi.c | 2 +- drivers/spi/octeon_spi.c | 2 +- drivers/spi/pic32_spi.c | 4 +- drivers/spi/rk_spi.c | 1 - drivers/spi/sandbox_spi.c | 2 +- drivers/spi/spi-uclass.c | 4 +- drivers/spi/tegra114_spi.c | 2 +- drivers/spi/tegra20_sflash.c | 2 +- drivers/spi/tegra20_slink.c | 2 +- drivers/spi/tegra210_qspi.c | 2 +- drivers/spi/xilinx_spi.c | 2 +- drivers/spi/zynq_qspi.c | 2 +- drivers/spi/zynq_spi.c | 2 +- drivers/usb/gadget/max3420_udc.c | 2 +- drivers/usb/host/ehci-mx5.c | 2 +- drivers/usb/host/ehci-mx6.c | 14 ++- drivers/usb/host/ehci-omap.c | 2 +- drivers/usb/host/ehci-vf.c | 8 +- drivers/usb/host/usb-sandbox.c | 2 +- drivers/usb/host/usb-uclass.c | 6 +- drivers/video/vidconsole-uclass.c | 4 +- drivers/virtio/virtio-uclass.c | 2 +- drivers/watchdog/ast_wdt.c | 2 +- drivers/watchdog/at91sam9_wdt.c | 2 +- drivers/watchdog/cdns_wdt.c | 2 +- drivers/watchdog/omap_wdt.c | 2 +- drivers/watchdog/orion_wdt.c | 2 +- drivers/watchdog/sbsa_gwdt.c | 2 +- drivers/watchdog/sp805_wdt.c | 2 +- drivers/watchdog/tangier_wdt.c | 2 +- drivers/watchdog/xilinx_tb_wdt.c | 2 +- drivers/watchdog/xilinx_wwdt.c | 2 +- include/dm/device.h | 32 +++--- include/dm/uclass-internal.h | 37 +++---- include/dm/uclass.h | 15 --- include/linker_lists.h | 3 +- include/pci.h | 2 +- include/spi.h | 2 +- lib/acpi/acpi_device.c | 27 +---- lib/efi_loader/efi_device_path.c | 4 +- net/eth-uclass.c | 24 ++--- test/dm/acpi.c | 6 +- test/dm/blk.c | 3 - test/dm/bus.c | 15 +-- test/dm/core.c | 19 ++++ test/dm/i2c.c | 3 - test/dm/spi.c | 3 - test/dm/test-fdt.c | 131 +++++++++++++++-------- 138 files changed, 541 insertions(+), 571 deletions(-)
The linker script uses alphabetic sorting to group the different linker lists together. Each group has its own struct and potentially its own alignment. But when the linker packs the structs together it cannot ensure that a linker list starts on the expected alignment boundary.
For example, if the first list has a struct size of 8 and we place 3 of them in the image, that means that the next struct will start at offset 0x18 from the start of the linker_list section. If the next struct has a size of 16 then it will start at an 8-byte aligned offset, but not a 16-byte aligned offset.
With sandbox on x86_64, a reference to a linker list item using ll_entry_get() can force alignment of that particular linker_list item, if it is in the same file as the linker_list item is declared.
Consider this example, where struct driver is 0x80 bytes:
ll_entry_declare(struct driver, fred, driver)
void *p = ll_entry_get(struct driver, fred, driver)
If these two lines of code are in the same file, then the entry is forced to be aligned at the 'struct driver' alignment, which is 16 bytes. If the second line of code is in a different file, then no action is taken, since the compiler cannot update the alignment of the linker_list item.
In the first case, an 8-byte 'fill' region is added:
.u_boot_list_2_driver_2_testbus_drv 0x0000000000270018 0x80 test/built-in.o 0x0000000000270018 _u_boot_list_2_driver_2_testbus_drv .u_boot_list_2_driver_2_testfdt1_drv 0x0000000000270098 0x80 test/built-in.o 0x0000000000270098 _u_boot_list_2_driver_2_testfdt1_drv *fill* 0x0000000000270118 0x8 .u_boot_list_2_driver_2_testfdt_drv 0x0000000000270120 0x80 test/built-in.o 0x0000000000270120 _u_boot_list_2_driver_2_testfdt_drv .u_boot_list_2_driver_2_testprobe_drv 0x00000000002701a0 0x80 test/built-in.o 0x00000000002701a0 _u_boot_list_2_driver_2_testprobe_drv
With this, the linker_list no-longer works since items after testfdt1_drv are not at the expected address.
Ideally we would have a way to tell gcc not to align structs in this way. It is not clear how we could do this, and in any case it would require us to adjust every struct used by the linker_list feature.
One possible fix is to force each separate linker_list to start on the largest possible boundary that can be required by the compiler. However that does not seem to work on x86_64, which uses 16-byte alignment in this case but needs 32-byte alignment.
So add a Kconfig option to handle this. Set the default value to 4 so as to avoid changing platforms that don't need it.
Update the ll_entry_start() accordingly.
(no changes since v1)
arch/Kconfig | 11 ++++++++ doc/api/linker_lists.rst | 59 ++++++++++++++++++++++++++++++++++++++++ include/linker_lists.h | 3 +- 3 files changed, 72 insertions(+), 1 deletion(-)
diff --git a/arch/Kconfig b/arch/Kconfig index b936d2dffca..eb38ba6a782 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -7,6 +7,17 @@ config HAVE_ARCH_IOREMAP config NEEDS_MANUAL_RELOC bool
+config LINKER_LIST_ALIGN + int + default 32 if SANDBOX + default 8 if ARM64 || X86 + default 4 + help + Force the each linker list to be aligned to this boundary. This + is required if ll_entry_get() is used, since otherwise the linker + may add padding into the table, thus breaking it. + See linker_lists.rst for full details. + choice prompt "Architecture select" default SANDBOX diff --git a/doc/api/linker_lists.rst b/doc/api/linker_lists.rst index 72f514e0ac0..7063fdc8314 100644 --- a/doc/api/linker_lists.rst +++ b/doc/api/linker_lists.rst @@ -96,5 +96,64 @@ defined for the whole list and each sub-list: %u_boot_list_2_drivers_2_pci_3 %u_boot_list_2_drivers_3
+Alignment issues +---------------- + +The linker script uses alphabetic sorting to group the different linker +lists together. Each group has its own struct and potentially its own +alignment. But when the linker packs the structs together it cannot ensure +that a linker list starts on the expected alignment boundary. + +For example, if the first list has a struct size of 8 and we place 3 of +them in the image, that means that the next struct will start at offset +0x18 from the start of the linker_list section. If the next struct has +a size of 16 then it will start at an 8-byte aligned offset, but not a +16-byte aligned offset. + +With sandbox on x86_64, a reference to a linker list item using +ll_entry_get() can force alignment of that particular linker_list item, +if it is in the same file as the linker_list item is declared. + +Consider this example, where struct driver is 0x80 bytes:: + + ll_entry_declare(struct driver, fred, driver) + + ... + + void *p = ll_entry_get(struct driver, fred, driver) + +If these two lines of code are in the same file, then the entry is forced +to be aligned at the 'struct driver' alignment, which is 16 bytes. If the +second line of code is in a different file, then no action is taken, since +the compiler cannot update the alignment of the linker_list item. + +In the first case, an 8-byte 'fill' region is added:: + + .u_boot_list_2_driver_2_testbus_drv + 0x0000000000270018 0x80 test/built-in.o + 0x0000000000270018 _u_boot_list_2_driver_2_testbus_drv + .u_boot_list_2_driver_2_testfdt1_drv + 0x0000000000270098 0x80 test/built-in.o + 0x0000000000270098 _u_boot_list_2_driver_2_testfdt1_drv + *fill* 0x0000000000270118 0x8 + .u_boot_list_2_driver_2_testfdt_drv + 0x0000000000270120 0x80 test/built-in.o + 0x0000000000270120 _u_boot_list_2_driver_2_testfdt_drv + .u_boot_list_2_driver_2_testprobe_drv + 0x00000000002701a0 0x80 test/built-in.o + 0x00000000002701a0 _u_boot_list_2_driver_2_testprobe_drv + +With this, the linker_list no-longer works since items after testfdt1_drv +are not at the expected address. + +Ideally we would have a way to tell gcc not to align structs in this way. +It is not clear how we could do this, and in any case it would require us +to adjust every struct used by the linker_list feature. + +The simplest fix seems to be to force each separate linker_list to start +on the largest possible boundary that can be required by the compiler. This +is the purpose of CONFIG_LINKER_LIST_ALIGN + + .. kernel-doc:: include/linker_lists.h :internal: diff --git a/include/linker_lists.h b/include/linker_lists.h index d775d041e04..fd98ecd297c 100644 --- a/include/linker_lists.h +++ b/include/linker_lists.h @@ -124,7 +124,8 @@ */ #define ll_entry_start(_type, _list) \ ({ \ - static char start[0] __aligned(4) __attribute__((unused, \ + static char start[0] __aligned(CONFIG_LINKER_LIST_ALIGN) \ + __attribute__((unused, \ section(".u_boot_list_2_"#_list"_1"))); \ (_type *)&start; \ })
At present various drivers etc. access the device's 'seq' member directly. This makes it harder to change the meaning of that member. Change access to go through a function instead.
The drivers/i2c/lpc32xx_i2c.c file is left unchanged for now.
arch/arm/include/asm/mach-imx/mxc_i2c.h | 2 +- arch/x86/cpu/broadwell/cpu_full.c | 2 +- arch/x86/cpu/ivybridge/model_206ax.c | 2 +- board/xilinx/versal/board.c | 12 ++++---- board/xilinx/zynqmp/zynqmp.c | 12 ++++---- cmd/axi.c | 4 +-- cmd/cpu.c | 2 +- cmd/i2c.c | 4 +-- cmd/misc.c | 2 +- cmd/osd.c | 4 +-- cmd/pci.c | 7 +++-- cmd/pmic.c | 4 +-- cmd/remoteproc.c | 2 +- cmd/w1.c | 4 +-- drivers/core/device.c | 2 +- drivers/core/dump.c | 4 +-- drivers/core/uclass.c | 6 ++-- drivers/gpio/octeon_gpio.c | 2 +- drivers/i2c/ast_i2c.c | 4 +-- drivers/i2c/davinci_i2c.c | 2 +- drivers/i2c/exynos_hs_i2c.c | 2 +- drivers/i2c/i2c-gpio.c | 2 +- drivers/i2c/imx_lpi2c.c | 12 ++++---- drivers/i2c/lpc32xx_i2c.c | 6 +++- drivers/i2c/mxc_i2c.c | 10 +++---- drivers/i2c/nx_i2c.c | 2 +- drivers/i2c/octeon_i2c.c | 2 +- drivers/i2c/s3c24x0_i2c.c | 2 +- drivers/i2c/tegra_i2c.c | 5 ++-- drivers/mmc/fsl_esdhc_imx.c | 4 +-- drivers/mtd/spi/sandbox.c | 4 +-- drivers/net/fec_mxc.c | 7 +++-- drivers/net/fsl-mc/mc.c | 2 +- drivers/net/fsl_mcdmafec.c | 2 +- drivers/net/ftgmac100.c | 2 +- drivers/net/higmacv300.c | 2 +- drivers/net/mcffec.c | 2 +- drivers/net/octeontx/nicvf_main.c | 9 +++--- drivers/net/octeontx/smi.c | 2 +- drivers/net/octeontx2/nix.c | 2 +- drivers/net/octeontx2/rvu_pf.c | 6 ++-- drivers/net/xilinx_axi_emac.c | 2 +- drivers/net/xilinx_emaclite.c | 2 +- drivers/net/zynq_gem.c | 2 +- drivers/pci/pci-aardvark.c | 2 +- drivers/pci/pci-uclass.c | 36 ++++++++++++------------ drivers/pci/pci_auto.c | 6 ++-- drivers/pci/pcie_dw_mvebu.c | 6 ++-- drivers/pci/pcie_dw_ti.c | 6 ++-- drivers/pci/pcie_ecam_generic.c | 2 +- drivers/pci/pcie_fsl.c | 16 +++++------ drivers/pci/pcie_intel_fpga.c | 2 +- drivers/pci/pcie_layerscape_fixup.c | 4 +-- drivers/pci/pcie_layerscape_gen4.c | 10 +++---- drivers/pci/pcie_layerscape_gen4_fixup.c | 2 +- drivers/pci/pcie_layerscape_rc.c | 12 ++++---- drivers/pci/pcie_mediatek.c | 2 +- drivers/pci/pcie_rockchip.c | 6 ++-- drivers/serial/serial_mcf.c | 2 +- drivers/serial/serial_s5p.c | 2 +- drivers/spi/altera_spi.c | 2 +- drivers/spi/cf_spi.c | 12 ++++---- drivers/spi/fsl_dspi.c | 6 ++-- drivers/spi/fsl_espi.c | 2 +- drivers/spi/octeon_spi.c | 2 +- drivers/spi/pic32_spi.c | 4 +-- drivers/spi/sandbox_spi.c | 2 +- drivers/spi/tegra114_spi.c | 2 +- drivers/spi/tegra20_sflash.c | 2 +- drivers/spi/tegra20_slink.c | 2 +- drivers/spi/tegra210_qspi.c | 2 +- drivers/spi/xilinx_spi.c | 2 +- drivers/spi/zynq_qspi.c | 2 +- drivers/spi/zynq_spi.c | 2 +- drivers/usb/gadget/max3420_udc.c | 2 +- drivers/usb/host/ehci-mx5.c | 2 +- drivers/usb/host/ehci-mx6.c | 2 +- drivers/usb/host/ehci-omap.c | 2 +- drivers/usb/host/ehci-vf.c | 2 +- drivers/usb/host/usb-sandbox.c | 2 +- drivers/usb/host/usb-uclass.c | 2 +- drivers/video/vidconsole-uclass.c | 4 +-- drivers/virtio/virtio-uclass.c | 2 +- drivers/watchdog/ast_wdt.c | 2 +- drivers/watchdog/at91sam9_wdt.c | 2 +- drivers/watchdog/cdns_wdt.c | 2 +- drivers/watchdog/omap_wdt.c | 2 +- drivers/watchdog/orion_wdt.c | 2 +- drivers/watchdog/sbsa_gwdt.c | 2 +- drivers/watchdog/sp805_wdt.c | 2 +- drivers/watchdog/tangier_wdt.c | 2 +- drivers/watchdog/xilinx_tb_wdt.c | 2 +- drivers/watchdog/xilinx_wwdt.c | 2 +- include/dm/device.h | 5 ++++ include/pci.h | 2 +- include/spi.h | 2 +- lib/efi_loader/efi_device_path.c | 4 +-- net/eth-uclass.c | 19 +++++++------ 98 files changed, 211 insertions(+), 197 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/mxc_i2c.h b/arch/arm/include/asm/mach-imx/mxc_i2c.h index 81fd9814447..c016aa74741 100644 --- a/arch/arm/include/asm/mach-imx/mxc_i2c.h +++ b/arch/arm/include/asm/mach-imx/mxc_i2c.h @@ -42,7 +42,7 @@ struct mxc_i2c_bus { /* * board file can use this index to locate which i2c_pads_info is for * i2c_idle_bus. When pinmux is implement, this entry can be - * discarded. Here we do not use dev->seq, because we do not want to + * discarded. Here we do not use dev_seq(dev), because we do not want to * export device to board file. */ int index; diff --git a/arch/x86/cpu/broadwell/cpu_full.c b/arch/x86/cpu/broadwell/cpu_full.c index 706f68f63d6..ff066028fe6 100644 --- a/arch/x86/cpu/broadwell/cpu_full.c +++ b/arch/x86/cpu/broadwell/cpu_full.c @@ -638,7 +638,7 @@ static int broadwell_get_count(const struct udevice *dev)
static int cpu_x86_broadwell_probe(struct udevice *dev) { - if (dev->seq == 0) { + if (dev_seq(dev) == 0) { cpu_core_init(dev); return broadwell_init(dev); } diff --git a/arch/x86/cpu/ivybridge/model_206ax.c b/arch/x86/cpu/ivybridge/model_206ax.c index 55f7cc2b2ec..598ebcdf084 100644 --- a/arch/x86/cpu/ivybridge/model_206ax.c +++ b/arch/x86/cpu/ivybridge/model_206ax.c @@ -425,7 +425,7 @@ static int model_206ax_get_count(const struct udevice *dev)
static int cpu_x86_model_206ax_probe(struct udevice *dev) { - if (dev->seq == 0) + if (dev_seq(dev) == 0) model_206ax_init(dev);
return 0; diff --git a/board/xilinx/versal/board.c b/board/xilinx/versal/board.c index 912c1143a8a..2782a346f07 100644 --- a/board/xilinx/versal/board.c +++ b/board/xilinx/versal/board.c @@ -153,9 +153,9 @@ int board_late_init(void) puts("Boot from EMMC but without SD1 enabled!\n"); return -1; } - debug("mmc1 device found at %p, seq %d\n", dev, dev->seq); + debug("mmc1 device found at %p, seq %d\n", dev, dev_seq(dev)); mode = "mmc"; - bootseq = dev->seq; + bootseq = dev_seq(dev); break; case SD_MODE: puts("SD_MODE\n"); @@ -164,10 +164,10 @@ int board_late_init(void) puts("Boot from SD0 but without SD0 enabled!\n"); return -1; } - debug("mmc0 device found at %p, seq %d\n", dev, dev->seq); + debug("mmc0 device found at %p, seq %d\n", dev, dev_seq(dev));
mode = "mmc"; - bootseq = dev->seq; + bootseq = dev_seq(dev); break; case SD1_LSHFT_MODE: puts("LVL_SHFT_"); @@ -179,10 +179,10 @@ int board_late_init(void) puts("Boot from SD1 but without SD1 enabled!\n"); return -1; } - debug("mmc1 device found at %p, seq %d\n", dev, dev->seq); + debug("mmc1 device found at %p, seq %d\n", dev, dev_seq(dev));
mode = "mmc"; - bootseq = dev->seq; + bootseq = dev_seq(dev); break; default: mode = ""; diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 731285a7367..047b0704859 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -596,10 +596,10 @@ int board_late_init(void) puts("Boot from EMMC but without SD0 enabled!\n"); return -1; } - debug("mmc0 device found at %p, seq %d\n", dev, dev->seq); + debug("mmc0 device found at %p, seq %d\n", dev, dev_seq(dev));
mode = "mmc"; - bootseq = dev->seq; + bootseq = dev_seq(dev); break; case SD_MODE: puts("SD_MODE\n"); @@ -610,10 +610,10 @@ int board_late_init(void) puts("Boot from SD0 but without SD0 enabled!\n"); return -1; } - debug("mmc0 device found at %p, seq %d\n", dev, dev->seq); + debug("mmc0 device found at %p, seq %d\n", dev, dev_seq(dev));
mode = "mmc"; - bootseq = dev->seq; + bootseq = dev_seq(dev); env_set("modeboot", "sdboot"); break; case SD1_LSHFT_MODE: @@ -628,10 +628,10 @@ int board_late_init(void) puts("Boot from SD1 but without SD1 enabled!\n"); return -1; } - debug("mmc1 device found at %p, seq %d\n", dev, dev->seq); + debug("mmc1 device found at %p, seq %d\n", dev, dev_seq(dev));
mode = "mmc"; - bootseq = dev->seq; + bootseq = dev_seq(dev); env_set("modeboot", "sdboot"); break; case NAND_MODE: diff --git a/cmd/axi.c b/cmd/axi.c index c9d53c049e8..f7e206c04a7 100644 --- a/cmd/axi.c +++ b/cmd/axi.c @@ -35,7 +35,7 @@ static void show_bus(struct udevice *bus)
printf("Bus %d:\t%s", bus->req_seq, bus->name); if (device_active(bus)) - printf(" (active %d)", bus->seq); + printf(" (active %d)", dev_seq(bus)); printf("\n"); for (device_find_first_child(bus, &dev); dev; @@ -147,7 +147,7 @@ static int do_axi_bus_num(struct cmd_tbl *cmdtp, int flag, int argc, struct udevice *bus;
if (!axi_get_cur_bus(&bus)) - bus_no = bus->seq; + bus_no = dev_seq(bus); else bus_no = -1;
diff --git a/cmd/cpu.c b/cmd/cpu.c index ff553c16c4e..af2a42a6c25 100644 --- a/cmd/cpu.c +++ b/cmd/cpu.c @@ -32,7 +32,7 @@ static int print_cpu_list(bool detail) int ret, i;
ret = cpu_get_desc(dev, buf, sizeof(buf)); - printf("%3d: %-10s %s\n", dev->seq, dev->name, + printf("%3d: %-10s %s\n", dev_seq(dev), dev->name, ret ? "<no description>" : buf); if (!detail) continue; diff --git a/cmd/i2c.c b/cmd/i2c.c index cc01119b210..f97d437af47 100644 --- a/cmd/i2c.c +++ b/cmd/i2c.c @@ -1702,7 +1702,7 @@ static void show_bus(struct udevice *bus)
printf("Bus %d:\t%s", bus->req_seq, bus->name); if (device_active(bus)) - printf(" (active %d)", bus->seq); + printf(" (active %d)", dev_seq(bus)); printf("\n"); for (device_find_first_child(bus, &dev); dev; @@ -1825,7 +1825,7 @@ static int do_i2c_bus_num(struct cmd_tbl *cmdtp, int flag, int argc, struct udevice *bus;
if (!i2c_get_cur_bus(&bus)) - bus_no = bus->seq; + bus_no = dev_seq(bus); else bus_no = -1; #else diff --git a/cmd/misc.c b/cmd/misc.c index 653deed7f57..ef540e836f2 100644 --- a/cmd/misc.c +++ b/cmd/misc.c @@ -34,7 +34,7 @@ static int do_misc_list(struct cmd_tbl *cmdtp, int flag, for (uclass_first_device(UCLASS_MISC, &dev); dev; uclass_next_device(&dev)) { - printf("%-20s %5d %10s\n", dev->name, dev->seq, + printf("%-20s %5d %10s\n", dev->name, dev_seq(dev), dev->driver->name); }
diff --git a/cmd/osd.c b/cmd/osd.c index bdad5d8e963..9b8fd5c921e 100644 --- a/cmd/osd.c +++ b/cmd/osd.c @@ -77,7 +77,7 @@ static void show_osd(struct udevice *osd) { printf("OSD %d:\t%s", osd->req_seq, osd->name); if (device_active(osd)) - printf(" (active %d)", osd->seq); + printf(" (active %d)", dev_seq(osd)); printf("\n"); }
@@ -235,7 +235,7 @@ static int do_osd_num(struct cmd_tbl *cmdtp, int flag, int argc, struct udevice *osd;
if (!osd_get_osd_cur(&osd)) - osd_no = osd->seq; + osd_no = dev_seq(osd); else osd_no = -1; printf("Current osd is %d\n", osd_no); diff --git a/cmd/pci.c b/cmd/pci.c index f91a4eb8ed0..0b08b5d76de 100644 --- a/cmd/pci.c +++ b/cmd/pci.c @@ -334,7 +334,7 @@ static void pciinfo(struct udevice *bus, bool short_listing) { struct udevice *dev;
- pciinfo_header(bus->seq, short_listing); + pciinfo_header(dev_seq(bus), short_listing);
for (device_find_first_child(bus, &dev); dev; @@ -343,11 +343,12 @@ static void pciinfo(struct udevice *bus, bool short_listing)
pplat = dev_get_parent_platdata(dev); if (short_listing) { - printf("%02x.%02x.%02x ", bus->seq, + printf("%02x.%02x.%02x ", dev_seq(bus), PCI_DEV(pplat->devfn), PCI_FUNC(pplat->devfn)); pci_header_show_brief(dev); } else { - printf("\nFound PCI device %02x.%02x.%02x:\n", bus->seq, + printf("\nFound PCI device %02x.%02x.%02x:\n", + dev_seq(bus), PCI_DEV(pplat->devfn), PCI_FUNC(pplat->devfn)); pci_header_show(dev); } diff --git a/cmd/pmic.c b/cmd/pmic.c index 3bda0534a36..0cb44d07409 100644 --- a/cmd/pmic.c +++ b/cmd/pmic.c @@ -41,7 +41,7 @@ static int do_dev(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) return CMD_RET_USAGE; }
- printf("dev: %d @ %s\n", currdev->seq, currdev->name); + printf("dev: %d @ %s\n", dev_seq(currdev), currdev->name); }
return CMD_RET_SUCCESS; @@ -66,7 +66,7 @@ static int do_list(struct cmd_tbl *cmdtp, int flag, int argc, printf("| %-*.*s| %-*.*s| %s @ %d\n", LIMIT_DEV, LIMIT_DEV, dev->name, LIMIT_PARENT, LIMIT_PARENT, dev->parent->name, - dev_get_uclass_name(dev->parent), dev->parent->seq); + dev_get_uclass_name(dev->parent), dev_seq(dev->parent)); }
if (ret) diff --git a/cmd/remoteproc.c b/cmd/remoteproc.c index e8b9178e740..c111ef21756 100644 --- a/cmd/remoteproc.c +++ b/cmd/remoteproc.c @@ -47,7 +47,7 @@ static int print_remoteproc_list(void) break; } printf("%d - Name:'%s' type:'%s' supports: %s%s%s%s%s%s\n", - dev->seq, + dev_seq(dev), uc_pdata->name, type, ops->load ? "load " : "", diff --git a/cmd/w1.c b/cmd/w1.c index 459094bf809..d0f0ee1234b 100644 --- a/cmd/w1.c +++ b/cmd/w1.c @@ -21,7 +21,7 @@ static int w1_bus(void) printf("one wire interface not found\n"); return CMD_RET_FAILURE; } - printf("Bus %d:\t%s", bus->seq, bus->name); + printf("Bus %d:\t%s", dev_seq(bus), bus->name); if (device_active(bus)) printf(" (active)"); printf("\n"); @@ -31,7 +31,7 @@ static int w1_bus(void) device_find_next_child(&dev)) { ret = device_probe(dev);
- printf("\t%s (%d) uclass %s : ", dev->name, dev->seq, + printf("\t%s (%d) uclass %s : ", dev->name, dev_seq(dev), dev->uclass->uc_drv->name);
if (ret) diff --git a/drivers/core/device.c b/drivers/core/device.c index 79afaf06290..5660310c754 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -661,7 +661,7 @@ int device_find_child_by_seq(const struct udevice *parent, int seq_or_req_seq, return -ENODEV;
list_for_each_entry(dev, &parent->child_head, sibling_node) { - if ((find_req_seq ? dev->req_seq : dev->seq) == + if ((find_req_seq ? dev->req_seq : dev_seq(dev)) == seq_or_req_seq) { *devp = dev; return 0; diff --git a/drivers/core/dump.c b/drivers/core/dump.c index 6debaf97a1d..9f440366734 100644 --- a/drivers/core/dump.c +++ b/drivers/core/dump.c @@ -67,8 +67,8 @@ static void dm_display_line(struct udevice *dev, int index) printf("%-3i %c %s @ %08lx", index, dev->flags & DM_FLAG_ACTIVATED ? '*' : ' ', dev->name, (ulong)map_to_sysmem(dev)); - if (dev->seq != -1 || dev->req_seq != -1) - printf(", seq %d, (req %d)", dev->seq, dev->req_seq); + if (dev_seq(dev) != -1 || dev->req_seq != -1) + printf(", seq %d, (req %d)", dev_seq(dev), dev->req_seq); puts("\n"); }
diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index c3f1b73cd6b..699f24843cf 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -311,8 +311,8 @@ int uclass_find_device_by_seq(enum uclass_id id, int seq_or_req_seq,
uclass_foreach_dev(dev, uc) { log_debug(" - %d %d '%s'\n", - dev->req_seq, dev->seq, dev->name); - if ((find_req_seq ? dev->req_seq : dev->seq) == + dev->req_seq, dev_seq(dev), dev->name); + if ((find_req_seq ? dev->req_seq : dev_seq(dev)) == seq_or_req_seq) { *devp = dev; log_debug(" - found\n"); @@ -695,7 +695,7 @@ int uclass_resolve_seq(struct udevice *dev) int seq = 0; int ret;
- assert(dev->seq == -1); + assert(dev_seq(dev) == -1); ret = uclass_find_device_by_seq(uc_drv->id, dev->req_seq, false, &dup); if (!ret) { dm_warn("Device '%s': seq %d is in use by '%s'\n", diff --git a/drivers/gpio/octeon_gpio.c b/drivers/gpio/octeon_gpio.c index 45acaadcdb6..f1c67fd006d 100644 --- a/drivers/gpio/octeon_gpio.c +++ b/drivers/gpio/octeon_gpio.c @@ -202,7 +202,7 @@ static int octeon_gpio_probe(struct udevice *dev)
uc_priv->bank_name = strdup(dev->name); end = strchr(uc_priv->bank_name, '@'); - end[0] = 'A' + dev->seq; + end[0] = 'A' + dev_seq(dev); end[1] = '\0';
debug("%s(%s): base address: %p, pin count: %d\n", diff --git a/drivers/i2c/ast_i2c.c b/drivers/i2c/ast_i2c.c index 2cdfb5561b7..afd4b44100b 100644 --- a/drivers/i2c/ast_i2c.c +++ b/drivers/i2c/ast_i2c.c @@ -110,7 +110,7 @@ static int ast_i2c_probe(struct udevice *dev) { struct ast2500_scu *scu;
- debug("Enabling I2C%u\n", dev->seq); + debug("Enabling I2C%u\n", dev_seq(dev));
/* * Get all I2C devices out of Reset. @@ -307,7 +307,7 @@ static int ast_i2c_set_speed(struct udevice *dev, unsigned int speed) struct ast_i2c_regs *regs = priv->regs; ulong i2c_rate, divider;
- debug("Setting speed for I2C%d to <%u>\n", dev->seq, speed); + debug("Setting speed for I2C%d to <%u>\n", dev_seq(dev), speed); if (!speed) { debug("No valid speed specified\n"); return -EINVAL; diff --git a/drivers/i2c/davinci_i2c.c b/drivers/i2c/davinci_i2c.c index a54f2151fd3..478385ad683 100644 --- a/drivers/i2c/davinci_i2c.c +++ b/drivers/i2c/davinci_i2c.c @@ -470,7 +470,7 @@ static int davinci_i2c_probe(struct udevice *dev) { struct i2c_bus *i2c_bus = dev_get_priv(dev);
- i2c_bus->id = dev->seq; + i2c_bus->id = dev_seq(dev); i2c_bus->regs = dev_read_addr_ptr(dev);
i2c_bus->speed = 100000; diff --git a/drivers/i2c/exynos_hs_i2c.c b/drivers/i2c/exynos_hs_i2c.c index 5785adedb6d..87fc9c19940 100644 --- a/drivers/i2c/exynos_hs_i2c.c +++ b/drivers/i2c/exynos_hs_i2c.c @@ -533,7 +533,7 @@ static int s3c_i2c_ofdata_to_platdata(struct udevice *dev) dev_read_u32_default(dev, "clock-frequency", I2C_SPEED_STANDARD_RATE); i2c_bus->node = node; - i2c_bus->bus_num = dev->seq; + i2c_bus->bus_num = dev_seq(dev);
exynos_pinmux_config(i2c_bus->id, PINMUX_FLAG_HS_MODE);
diff --git a/drivers/i2c/i2c-gpio.c b/drivers/i2c/i2c-gpio.c index 381938c956f..3eb31672bec 100644 --- a/drivers/i2c/i2c-gpio.c +++ b/drivers/i2c/i2c-gpio.c @@ -298,7 +298,7 @@ static int i2c_gpio_probe(struct udevice *dev, uint chip, uint chip_flags) i2c_gpio_send_stop(bus, delay);
debug("%s: bus: %d (%s) chip: %x flags: %x ret: %d\n", - __func__, dev->seq, dev->name, chip, chip_flags, ret); + __func__, dev_seq(dev), dev->name, chip, chip_flags, ret);
return ret; } diff --git a/drivers/i2c/imx_lpi2c.c b/drivers/i2c/imx_lpi2c.c index feeed1e9a2f..a4e8ab795d4 100644 --- a/drivers/i2c/imx_lpi2c.c +++ b/drivers/i2c/imx_lpi2c.c @@ -289,7 +289,7 @@ static int bus_i2c_set_bus_speed(struct udevice *bus, int speed) return clock_rate; } } else { - clock_rate = imx_get_i2cclk(bus->seq); + clock_rate = imx_get_i2cclk(dev_seq(bus)); if (!clock_rate) return -EPERM; } @@ -377,7 +377,7 @@ static int bus_i2c_init(struct udevice *bus, int speed) val = readl(®s->mcr) & ~LPI2C_MCR_MEN_MASK; writel(val | LPI2C_MCR_MEN(1), ®s->mcr);
- debug("i2c : controller bus %d, speed %d:\n", bus->seq, speed); + debug("i2c : controller bus %d, speed %d:\n", dev_seq(bus), speed);
return ret; } @@ -452,11 +452,11 @@ static int imx_lpi2c_probe(struct udevice *bus) return -EINVAL;
i2c_bus->base = addr; - i2c_bus->index = bus->seq; + i2c_bus->index = dev_seq(bus); i2c_bus->bus = bus;
/* power up i2c resource */ - ret = init_i2c_power(bus->seq); + ret = init_i2c_power(dev_seq(bus)); if (ret) { debug("init_i2c_power err = %d\n", ret); return ret; @@ -486,7 +486,7 @@ static int imx_lpi2c_probe(struct udevice *bus) } } else { /* To i.MX7ULP, only i2c4-7 can be handled by A7 core */ - ret = enable_i2c_clk(1, bus->seq); + ret = enable_i2c_clk(1, dev_seq(bus)); if (ret < 0) return ret; } @@ -496,7 +496,7 @@ static int imx_lpi2c_probe(struct udevice *bus) return ret;
debug("i2c : controller bus %d at 0x%lx , speed %d: ", - bus->seq, i2c_bus->base, + dev_seq(bus), i2c_bus->base, i2c_bus->speed);
return 0; diff --git a/drivers/i2c/lpc32xx_i2c.c b/drivers/i2c/lpc32xx_i2c.c index 6af2e975cf3..4858479b142 100644 --- a/drivers/i2c/lpc32xx_i2c.c +++ b/drivers/i2c/lpc32xx_i2c.c @@ -282,7 +282,11 @@ U_BOOT_I2C_ADAP_COMPLETE(lpc32xx_2, lpc32xx_i2c_init, NULL, static int lpc32xx_i2c_probe(struct udevice *bus) { struct lpc32xx_i2c_dev *dev = dev_get_platdata(bus); - bus->seq = dev->index; + + /* + * FIXME: This is not permitted + * dev_seq(bus) = dev->index; + */
__i2c_init(dev->base, dev->speed, 0, dev->index); return 0; diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 7609594bd01..d7f8e821aca 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -914,7 +914,7 @@ static int mxc_i2c_probe(struct udevice *bus) }
/* Enable clk */ @@ -930,7 +930,7 @@ static int mxc_i2c_probe(struct udevice *bus) return ret; } #else - ret = enable_i2c_clk(1, bus->seq); + ret = enable_i2c_clk(1, dev_seq(bus)); if (ret < 0) return ret; #endif @@ -942,7 +942,7 @@ static int mxc_i2c_probe(struct udevice *bus) ret = fdt_stringlist_search(fdt, node, "pinctrl-names", "gpio"); if (ret < 0) { debug("i2c bus %d at 0x%2lx, no gpio pinctrl state.\n", - bus->seq, i2c_bus->base); + dev_seq(bus), i2c_bus->base); } else { ret = gpio_request_by_name_nodev(offset_to_ofnode(node), "scl-gpios", 0, &i2c_bus->scl_gpio, @@ -955,7 +955,7 @@ static int mxc_i2c_probe(struct udevice *bus) ret || ret2) { dev_err(bus, "i2c bus %d at %lu, fail to request scl/sda gpio\n", - bus->seq, i2c_bus->base); + dev_seq(bus), i2c_bus->base); return -EINVAL; } } @@ -966,7 +966,7 @@ static int mxc_i2c_probe(struct udevice *bus) */
debug("i2c : controller bus %d at %lu , speed %d: ", - bus->seq, i2c_bus->base, + dev_seq(bus), i2c_bus->base, i2c_bus->speed);
return 0; diff --git a/drivers/i2c/nx_i2c.c b/drivers/i2c/nx_i2c.c index ca14a0ecac7..3f0e7124b72 100644 --- a/drivers/i2c/nx_i2c.c +++ b/drivers/i2c/nx_i2c.c @@ -240,7 +240,7 @@ static int nx_i2c_probe(struct udevice *dev) return -EINVAL; bus->regs = (struct nx_i2c_regs *)addr;
- bus->bus_num = dev->seq; + bus->bus_num = dev_seq(dev);
/* i2c node parsing */ i2c_process_node(dev); diff --git a/drivers/i2c/octeon_i2c.c b/drivers/i2c/octeon_i2c.c index 23dcb1563ea..38839e45758 100644 --- a/drivers/i2c/octeon_i2c.c +++ b/drivers/i2c/octeon_i2c.c @@ -811,7 +811,7 @@ static int octeon_i2c_probe(struct udevice *dev) if (ret) return ret;
- debug("TWSI bus %d at %p\n", dev->seq, twsi->base); + debug("TWSI bus %d at %p\n", dev_seq(dev), twsi->base);
/* Start with standard speed, real speed set via DT or cmd */ return twsi_init(twsi->base, i2c_slave_addr); diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index cb45d3c100f..29ba217e709 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -318,7 +318,7 @@ static int s3c_i2c_ofdata_to_platdata(struct udevice *dev) dev_read_u32_default(dev, "clock-frequency", I2C_SPEED_STANDARD_RATE); i2c_bus->node = node; - i2c_bus->bus_num = dev->seq; + i2c_bus->bus_num = dev_seq(dev);
exynos_pinmux_config(i2c_bus->id, 0);
diff --git a/drivers/i2c/tegra_i2c.c b/drivers/i2c/tegra_i2c.c index 65b3734348b..19212020e84 100644 --- a/drivers/i2c/tegra_i2c.c +++ b/drivers/i2c/tegra_i2c.c @@ -362,7 +362,7 @@ static int tegra_i2c_probe(struct udevice *dev) int ret; bool is_dvc;
- i2c_bus->id = dev->seq; + i2c_bus->id = dev_seq(dev); i2c_bus->type = dev_get_driver_data(dev); i2c_bus->regs = (struct i2c_ctlr *)dev_read_addr(dev); if ((ulong)i2c_bus->regs == FDT_ADDR_T_NONE) { @@ -408,7 +408,8 @@ static int tegra_i2c_probe(struct udevice *dev) } i2c_init_controller(i2c_bus); debug("%s: controller bus %d at %p, speed %d: ", - is_dvc ? "dvc" : "i2c", dev->seq, i2c_bus->regs, i2c_bus->speed); + is_dvc ? "dvc" : "i2c", dev_seq(dev), i2c_bus->regs, + i2c_bus->speed);
return 0; } diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index e5409ade1bc..7b1c1d86271 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -1558,7 +1558,7 @@ static int fsl_esdhc_probe(struct udevice *dev) * work as expected. */
- init_clk_usdhc(dev->seq); + init_clk_usdhc(dev_seq(dev));
#if CONFIG_IS_ENABLED(CLK) /* Assigned clock already set clock */ @@ -1575,7 +1575,7 @@ static int fsl_esdhc_probe(struct udevice *dev)
priv->sdhc_clk = clk_get_rate(&priv->per_clk); #else - priv->sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK + dev->seq); + priv->sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK + dev_seq(dev)); if (priv->sdhc_clk <= 0) { dev_err(dev, "Unable to get clk for %s\n", dev->name); return -EINVAL; diff --git a/drivers/mtd/spi/sandbox.c b/drivers/mtd/spi/sandbox.c index 1d0c1cb3fa2..1a362616694 100644 --- a/drivers/mtd/spi/sandbox.c +++ b/drivers/mtd/spi/sandbox.c @@ -131,7 +131,7 @@ static int sandbox_sf_probe(struct udevice *dev) int ret = 0; int cs = -1;
- debug("%s: bus %d, looking for emul=%p: ", __func__, bus->seq, dev); + debug("%s: bus %d, looking for emul=%p: ", __func__, dev_seq(bus), dev); ret = sandbox_spi_get_emul(state, bus, dev, &emul); if (ret) { printf("Error: Unknown chip select for device '%s'\n", @@ -565,7 +565,7 @@ int sandbox_spi_get_emul(struct sandbox_state *state, struct udevice **emulp) { struct sandbox_spi_info *info; - int busnum = bus->seq; + int busnum = dev_seq(bus); int cs = spi_chip_select(slave); int ret;
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index bb55be9a267..4560dd80015 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1451,7 +1451,7 @@ static int fecmxc_probe(struct udevice *dev)
fec_reg_setup(priv);
- priv->dev_id = dev->seq; + priv->dev_id = dev_seq(dev);
#ifdef CONFIG_DM_ETH_PHY bus = eth_phy_get_mdio_bus(dev); @@ -1459,9 +1459,10 @@ static int fecmxc_probe(struct udevice *dev)
if (!bus) { #ifdef CONFIG_FEC_MXC_MDIO_BASE - bus = fec_get_miibus((ulong)CONFIG_FEC_MXC_MDIO_BASE, dev->seq); + bus = fec_get_miibus((ulong)CONFIG_FEC_MXC_MDIO_BASE, + dev_seq(dev)); #else - bus = fec_get_miibus((ulong)priv->eth, dev->seq); + bus = fec_get_miibus((ulong)priv->eth, dev_seq(dev)); #endif } if (!bus) { diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index 84db6be624a..7497e9b735e 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -187,7 +187,7 @@ static int mc_fixup_mac_addr(void *blob, int nodeoffset, #ifdef CONFIG_DM_ETH struct eth_pdata *plat = dev_get_platdata(eth_dev); unsigned char *enetaddr = plat->enetaddr; - int eth_index = eth_dev->seq; + int eth_index = dev_seq(eth_dev); #else unsigned char *enetaddr = eth_dev->enetaddr; int eth_index = eth_dev->index; diff --git a/drivers/net/fsl_mcdmafec.c b/drivers/net/fsl_mcdmafec.c index e27f7e5321a..6eaa60ac187 100644 --- a/drivers/net/fsl_mcdmafec.c +++ b/drivers/net/fsl_mcdmafec.c @@ -502,7 +502,7 @@ static int mcdmafec_probe(struct udevice *dev) int retval; const u32 *val;
- info->index = dev->seq; + info->index = dev_seq(dev); info->iobase = pdata->iobase; info->miibase = pdata->iobase; info->phy_addr = -1; diff --git a/drivers/net/ftgmac100.c b/drivers/net/ftgmac100.c index 00bda24f1fd..2ed012d5dd0 100644 --- a/drivers/net/ftgmac100.c +++ b/drivers/net/ftgmac100.c @@ -171,7 +171,7 @@ static int ftgmac100_mdio_init(struct udevice *dev) bus->write = ftgmac100_mdio_write; bus->priv = priv;
- ret = mdio_register_seq(bus, dev->seq); + ret = mdio_register_seq(bus, dev_seq(dev)); if (ret) { free(bus); return ret; diff --git a/drivers/net/higmacv300.c b/drivers/net/higmacv300.c index 2aae7f4863c..00c07770290 100644 --- a/drivers/net/higmacv300.c +++ b/drivers/net/higmacv300.c @@ -528,7 +528,7 @@ static int higmac_probe(struct udevice *dev) bus->priv = priv; priv->bus = bus;
- ret = mdio_register_seq(bus, dev->seq); + ret = mdio_register_seq(bus, dev_seq(dev)); if (ret) return ret;
diff --git a/drivers/net/mcffec.c b/drivers/net/mcffec.c index f94a2d8123c..43b7dbb1a01 100644 --- a/drivers/net/mcffec.c +++ b/drivers/net/mcffec.c @@ -524,7 +524,7 @@ static int mcffec_probe(struct udevice *dev) int retval, fec_idx; const u32 *val;
- info->index = dev->seq; + info->index = dev_seq(dev); info->iobase = pdata->iobase; info->phy_addr = -1;
diff --git a/drivers/net/octeontx/nicvf_main.c b/drivers/net/octeontx/nicvf_main.c index e13c8b95569..800df8a500b 100644 --- a/drivers/net/octeontx/nicvf_main.c +++ b/drivers/net/octeontx/nicvf_main.c @@ -452,11 +452,12 @@ int nicvf_write_hwaddr(struct udevice *dev) * u-boot framework updates MAC to random address. * Use this hook to update mac address in environment. */ - if (!eth_env_get_enetaddr_by_index("eth", dev->seq, ethaddr)) { - eth_env_set_enetaddr_by_index("eth", dev->seq, pdata->enetaddr); + if (!eth_env_get_enetaddr_by_index("eth", dev_seq(dev), ethaddr)) { + eth_env_set_enetaddr_by_index("eth", dev_seq(dev), + pdata->enetaddr); debug("%s: pMAC %pM\n", __func__, pdata->enetaddr); } - eth_env_get_enetaddr_by_index("eth", dev->seq, ethaddr); + eth_env_get_enetaddr_by_index("eth", dev_seq(dev), ethaddr); if (memcmp(ethaddr, pdata->enetaddr, ARP_HLEN)) { debug("%s: pMAC %pM\n", __func__, pdata->enetaddr); nicvf_hw_set_mac_addr(nic, dev); @@ -540,7 +541,7 @@ int nicvf_initialize(struct udevice *dev)
if (is_valid_ethaddr(ethaddr)) { memcpy(pdata->enetaddr, ethaddr, ARP_HLEN); - eth_env_set_enetaddr_by_index("eth", dev->seq, ethaddr); + eth_env_set_enetaddr_by_index("eth", dev_seq(dev), ethaddr); } debug("%s enetaddr %pM ethaddr %pM\n", __func__, pdata->enetaddr, ethaddr); diff --git a/drivers/net/octeontx/smi.c b/drivers/net/octeontx/smi.c index 8e2c3ca5a30..d4baddb7ef5 100644 --- a/drivers/net/octeontx/smi.c +++ b/drivers/net/octeontx/smi.c @@ -335,7 +335,7 @@ int octeontx_smi_probe(struct udevice *dev) priv = malloc(sizeof(*priv)); if (!bus || !priv) { printf("Failed to allocate OcteonTX MDIO bus # %u\n", - dev->seq); + dev_seq(dev)); return -1; }
diff --git a/drivers/net/octeontx2/nix.c b/drivers/net/octeontx2/nix.c index 0a3e8e4af0b..54e1875ce19 100644 --- a/drivers/net/octeontx2/nix.c +++ b/drivers/net/octeontx2/nix.c @@ -736,7 +736,7 @@ int nix_lf_setup_mac(struct udevice *dev) */ if (memcmp(nix->lmac->mac_addr, pdata->enetaddr, ARP_HLEN)) { memcpy(nix->lmac->mac_addr, pdata->enetaddr, 6); - eth_env_set_enetaddr_by_index("eth", rvu->dev->seq, + eth_env_set_enetaddr_by_index("eth", dev_seq(rvu->dev), pdata->enetaddr); cgx_lmac_mac_filter_setup(nix->lmac); /* Update user given MAC address to ATF for update diff --git a/drivers/net/octeontx2/rvu_pf.c b/drivers/net/octeontx2/rvu_pf.c index 201ecf2c168..853914968bb 100644 --- a/drivers/net/octeontx2/rvu_pf.c +++ b/drivers/net/octeontx2/rvu_pf.c @@ -34,7 +34,7 @@ int rvu_pf_init(struct rvu_pf *rvu) /* to make post_probe happy */ if (is_valid_ethaddr(nix->lmac->mac_addr)) { memcpy(pdata->enetaddr, nix->lmac->mac_addr, 6); - eth_env_set_enetaddr_by_index("eth", rvu->dev->seq, + eth_env_set_enetaddr_by_index("eth", dev_seq(rvu->dev), pdata->enetaddr); }
@@ -59,7 +59,7 @@ int rvu_pf_probe(struct udevice *dev) debug("%s: name: %s\n", __func__, dev->name);
rvu->pf_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_2, PCI_REGION_MEM); - rvu->pfid = dev->seq + 1; // RVU PF's start from 1; + rvu->pfid = dev_seq(dev) + 1; // RVU PF's start from 1; rvu->dev = dev; if (!rvu_af_dev) { printf("%s: Error: Could not find RVU AF device\n", @@ -80,7 +80,7 @@ int rvu_pf_probe(struct udevice *dev) * modify device name to include index/sequence number, * for better readability, this is 1:1 mapping with eth0/1/2.. names. */ - sprintf(name, "rvu_pf#%d", dev->seq); + sprintf(name, "rvu_pf#%d", dev_seq(dev)); device_set_name(dev, name); debug("%s: name: %s\n", __func__, dev->name); return err; diff --git a/drivers/net/xilinx_axi_emac.c b/drivers/net/xilinx_axi_emac.c index 8af37112046..3fe9a617f7b 100644 --- a/drivers/net/xilinx_axi_emac.c +++ b/drivers/net/xilinx_axi_emac.c @@ -697,7 +697,7 @@ static int axi_emac_probe(struct udevice *dev) priv->bus->write = axiemac_miiphy_write; priv->bus->priv = priv;
- ret = mdio_register_seq(priv->bus, dev->seq); + ret = mdio_register_seq(priv->bus, dev_seq(dev)); if (ret) return ret;
diff --git a/drivers/net/xilinx_emaclite.c b/drivers/net/xilinx_emaclite.c index 64c18bae74b..256d073da4a 100644 --- a/drivers/net/xilinx_emaclite.c +++ b/drivers/net/xilinx_emaclite.c @@ -568,7 +568,7 @@ static int emaclite_probe(struct udevice *dev) emaclite->bus->write = emaclite_miiphy_write; emaclite->bus->priv = emaclite;
- ret = mdio_register_seq(emaclite->bus, dev->seq); + ret = mdio_register_seq(emaclite->bus, dev_seq(dev)); if (ret) return ret;
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 8afec8bbfcf..75a6f8f280b 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -705,7 +705,7 @@ static int zynq_gem_probe(struct udevice *dev) priv->bus->write = zynq_gem_miiphy_write; priv->bus->priv = priv;
- ret = mdio_register_seq(priv->bus, dev->seq); + ret = mdio_register_seq(priv->bus, dev_seq(dev)); if (ret) goto err2;
diff --git a/drivers/pci/pci-aardvark.c b/drivers/pci/pci-aardvark.c index babb84ca937..0ce60ddf7db 100644 --- a/drivers/pci/pci-aardvark.c +++ b/drivers/pci/pci-aardvark.c @@ -638,7 +638,7 @@ static int pcie_advk_probe(struct udevice *dev) dev_warn(pcie->dev, "PCIE Reset on GPIO support is missing\n"); }
- pcie->first_busno = dev->seq; + pcie->first_busno = dev_seq(dev); pcie->dev = pci_get_controller(dev);
return pcie_advk_setup_hw(pcie); diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 9230cfe88b5..99dcd342efe 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -65,7 +65,7 @@ pci_dev_t dm_pci_get_bdf(const struct udevice *dev) if (!device_active(bus)) log_err("PCI: Device '%s' on unprobed bus '%s'\n", dev->name, bus->name); - return PCI_ADD_BUS(bus->seq, pplat->devfn); + return PCI_ADD_BUS(dev_seq(bus), pplat->devfn); }
/** @@ -81,8 +81,8 @@ static int pci_get_bus_max(void)
ret = uclass_get(UCLASS_PCI, &uc); uclass_foreach_dev(bus, uc) { - if (bus->seq > ret) - ret = bus->seq; + if (dev_seq(bus) > ret) + ret = dev_seq(bus); }
debug("%s: ret=%d\n", __func__, ret); @@ -513,7 +513,7 @@ static void set_vga_bridge_bits(struct udevice *dev) struct udevice *parent = dev->parent; u16 bc;
- while (parent->seq != 0) { + while (dev_seq(parent) != 0) { dm_pci_read_config16(parent, PCI_BRIDGE_CONTROL, &bc); bc |= PCI_BRIDGE_CTL_VGA; dm_pci_write_config16(parent, PCI_BRIDGE_CONTROL, bc); @@ -529,7 +529,7 @@ int pci_auto_config_devices(struct udevice *bus) struct udevice *dev; int ret;
- sub_bus = bus->seq; + sub_bus = dev_seq(bus); debug("%s: start\n", __func__); pciauto_config_init(hose); for (ret = device_find_first_child(bus, &dev); @@ -645,9 +645,9 @@ int dm_pci_hose_probe_bus(struct udevice *bus) }
if (!ea_pos) { - if (sub_bus != bus->seq) { + if (sub_bus != dev_seq(bus)) { debug("%s: Internal error, bus '%s' got seq %d, expected %d\n", - __func__, bus->name, bus->seq, sub_bus); + __func__, bus->name, dev_seq(bus), sub_bus); return -EPIPE; } sub_bus = pci_get_bus_max(); @@ -771,7 +771,7 @@ static int pci_find_and_bind_driver(struct udevice *parent, return -EPERM;
/* Bind a generic driver so that the device can be used */ - sprintf(name, "pci_%x:%x.%x", parent->seq, PCI_DEV(bdf), + sprintf(name, "pci_%x:%x.%x", dev_seq(parent), PCI_DEV(bdf), PCI_FUNC(bdf)); str = strdup(name); if (!str) @@ -803,9 +803,9 @@ int pci_bind_bus_devices(struct udevice *bus) int ret;
found_multi = false; - end = PCI_BDF(bus->seq, PCI_MAX_PCI_DEVICES - 1, + end = PCI_BDF(dev_seq(bus), PCI_MAX_PCI_DEVICES - 1, PCI_MAX_PCI_FUNCTIONS - 1); - for (bdf = PCI_BDF(bus->seq, 0, 0); bdf <= end; + for (bdf = PCI_BDF(dev_seq(bus), 0, 0); bdf <= end; bdf += PCI_BDF(0, 0, 1)) { struct pci_child_platdata *pplat; struct udevice *dev; @@ -832,7 +832,7 @@ int pci_bind_bus_devices(struct udevice *bus) found_multi = header_type & 0x80;
debug("%s: bus %d/%s: found device %x, function %d", __func__, - bus->seq, bus->name, PCI_DEV(bdf), PCI_FUNC(bdf)); + dev_seq(bus), bus->name, PCI_DEV(bdf), PCI_FUNC(bdf)); pci_bus_read_config(bus, bdf, PCI_DEVICE_ID, &device, PCI_SIZE_16); pci_bus_read_config(bus, bdf, PCI_CLASS_REVISION, &class, @@ -1010,7 +1010,7 @@ static int pci_uclass_pre_probe(struct udevice *bus) { struct pci_controller *hose;
- debug("%s, bus=%d/%s, parent=%s\n", __func__, bus->seq, bus->name, + debug("%s, bus=%d/%s, parent=%s\n", __func__, dev_seq(bus), bus->name, bus->parent->name); hose = bus->uclass_priv;
@@ -1025,8 +1025,8 @@ static int pci_uclass_pre_probe(struct udevice *bus) hose->ctlr = parent_hose->bus; } hose->bus = bus; - hose->first_busno = bus->seq; - hose->last_busno = bus->seq; + hose->first_busno = dev_seq(bus); + hose->last_busno = dev_seq(bus); if (dev_of_valid(bus)) { hose->skip_auto_config_until_reloc = dev_read_bool(bus, @@ -1041,7 +1041,7 @@ static int pci_uclass_post_probe(struct udevice *bus) struct pci_controller *hose = dev_get_uclass_priv(bus); int ret;
- debug("%s: probing bus %d\n", __func__, bus->seq); + debug("%s: probing bus %d\n", __func__, dev_seq(bus)); ret = pci_bind_bus_devices(bus); if (ret) return ret; @@ -1068,7 +1068,7 @@ static int pci_uclass_post_probe(struct udevice *bus) * Note we only call this 1) after U-Boot is relocated, and 2) * root bus has finished probing. */ - if ((gd->flags & GD_FLG_RELOC) && bus->seq == 0 && ll_boot_init()) { + if ((gd->flags & GD_FLG_RELOC) && dev_seq(bus) == 0 && ll_boot_init()) { ret = fsp_init_phase_pci(); if (ret) return ret; @@ -1732,7 +1732,7 @@ int pci_sriov_init(struct udevice *pdev, int vf_en) &class, PCI_SIZE_16);
debug("%s: bus %d/%s: found VF %x:%x\n", __func__, - bus->seq, bus->name, PCI_DEV(bdf), PCI_FUNC(bdf)); + dev_seq(bus), bus->name, PCI_DEV(bdf), PCI_FUNC(bdf));
/* Find this device in the device tree */ ret = pci_bus_find_devfn(bus, PCI_MASK_BUS(bdf), &dev); @@ -1763,7 +1763,7 @@ int pci_sriov_init(struct udevice *pdev, int vf_en) pplat->virtid = vf * vf_stride + vf_offset;
debug("%s: bus %d/%s: found VF %x:%x %x:%x class %lx id %x\n", - __func__, dev->seq, dev->name, PCI_DEV(bdf), + __func__, dev_seq(dev), dev->name, PCI_DEV(bdf), PCI_FUNC(bdf), vendor, device, class, pplat->virtid); bdf += PCI_BDF(0, 0, vf_stride); } diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index 3f46b7697d7..4d797ec034b 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -189,8 +189,8 @@ void dm_pciauto_prescan_setup_bridge(struct udevice *dev, int sub_bus)
/* Configure bus number registers */ dm_pci_write_config8(dev, PCI_PRIMARY_BUS, - PCI_BUS(dm_pci_get_bdf(dev)) - ctlr->seq); - dm_pci_write_config8(dev, PCI_SECONDARY_BUS, sub_bus - ctlr->seq); + PCI_BUS(dm_pci_get_bdf(dev)) - dev_seq(ctlr)); + dm_pci_write_config8(dev, PCI_SECONDARY_BUS, sub_bus - dev_seq(ctlr)); dm_pci_write_config8(dev, PCI_SUBORDINATE_BUS, 0xff);
if (pci_mem) { @@ -265,7 +265,7 @@ void dm_pciauto_postscan_setup_bridge(struct udevice *dev, int sub_bus) pci_io = ctlr_hose->pci_io;
/* Configure bus number registers */ - dm_pci_write_config8(dev, PCI_SUBORDINATE_BUS, sub_bus - ctlr->seq); + dm_pci_write_config8(dev, PCI_SUBORDINATE_BUS, sub_bus - dev_seq(ctlr));
if (pci_mem) { /* Round memory allocator to 1MB boundary */ diff --git a/drivers/pci/pcie_dw_mvebu.c b/drivers/pci/pcie_dw_mvebu.c index c773f8d28d2..8fbc8fb7d0a 100644 --- a/drivers/pci/pcie_dw_mvebu.c +++ b/drivers/pci/pcie_dw_mvebu.c @@ -500,13 +500,13 @@ static int pcie_dw_mvebu_probe(struct udevice *dev) debug("PCIE Reset on GPIO support is missing\n"); #endif /* DM_GPIO */
/* Don't register host if link is down */ if (!pcie_dw_mvebu_pcie_link_up(pcie->ctrl_base, LINK_SPEED_GEN_3)) { - printf("PCIE-%d: Link down\n", dev->seq); + printf("PCIE-%d: Link down\n", dev_seq(dev)); } else { - printf("PCIE-%d: Link up (Gen%d-x%d, Bus%d)\n", dev->seq, + printf("PCIE-%d: Link up (Gen%d-x%d, Bus%d)\n", dev_seq(dev), pcie_dw_get_link_speed(pcie->ctrl_base), pcie_dw_get_link_width(pcie->ctrl_base), hose->first_busno); diff --git a/drivers/pci/pcie_dw_ti.c b/drivers/pci/pcie_dw_ti.c index 742dd93633e..e0635e07c21 100644 --- a/drivers/pci/pcie_dw_ti.c +++ b/drivers/pci/pcie_dw_ti.c @@ -634,7 +634,7 @@ static int pcie_dw_ti_probe(struct udevice *dev) generic_phy_init(&phy1); generic_phy_power_on(&phy1);
- pci->first_busno = dev->seq; + pci->first_busno = dev_seq(dev); pci->dev = dev;
pcie_dw_setup_host(pci); @@ -644,11 +644,11 @@ static int pcie_dw_ti_probe(struct udevice *dev) pcie_am654_set_mode(pci, DW_PCIE_RC_TYPE);
if (!pcie_dw_ti_pcie_link_up(pci, LINK_SPEED_GEN_2)) { - printf("PCIE-%d: Link down\n", dev->seq); + printf("PCIE-%d: Link down\n", dev_seq(dev)); return -ENODEV; }
- printf("PCIE-%d: Link up (Gen%d-x%d, Bus%d)\n", dev->seq, + printf("PCIE-%d: Link up (Gen%d-x%d, Bus%d)\n", dev_seq(dev), pcie_dw_get_link_speed(pci), pcie_dw_get_link_width(pci), hose->first_busno); diff --git a/drivers/pci/pcie_ecam_generic.c b/drivers/pci/pcie_ecam_generic.c index 890b6a8fb69..96afa4263df 100644 --- a/drivers/pci/pcie_ecam_generic.c +++ b/drivers/pci/pcie_ecam_generic.c @@ -146,7 +146,7 @@ static int pci_generic_ecam_probe(struct udevice *dev) { struct generic_ecam_pcie *pcie = dev_get_priv(dev);
return 0; } diff --git a/drivers/pci/pcie_fsl.c b/drivers/pci/pcie_fsl.c index fb50b8f5180..da6a6b15534 100644 --- a/drivers/pci/pcie_fsl.c +++ b/drivers/pci/pcie_fsl.c @@ -29,16 +29,16 @@ static int fsl_pcie_addr_valid(struct fsl_pcie *pcie, pci_dev_t bdf) if (!pcie->enabled) return -ENXIO;
- if (PCI_BUS(bdf) < bus->seq) + if (PCI_BUS(bdf) < dev_seq(bus)) return -EINVAL;
- if (PCI_BUS(bdf) > bus->seq && (!fsl_pcie_link_up(pcie) || pcie->mode)) + if (PCI_BUS(bdf) > dev_seq(bus) && (!fsl_pcie_link_up(pcie) || pcie->mode)) return -EINVAL;
- if (PCI_BUS(bdf) == bus->seq && (PCI_DEV(bdf) > 0 || PCI_FUNC(bdf) > 0)) + if (PCI_BUS(bdf) == dev_seq(bus) && (PCI_DEV(bdf) > 0 || PCI_FUNC(bdf) > 0)) return -EINVAL;
- if (PCI_BUS(bdf) == (bus->seq + 1) && (PCI_DEV(bdf) > 0)) + if (PCI_BUS(bdf) == (dev_seq(bus) + 1) && (PCI_DEV(bdf) > 0)) return -EINVAL;
return 0; @@ -57,7 +57,7 @@ static int fsl_pcie_read_config(const struct udevice *bus, pci_dev_t bdf, return 0; }
- bdf = bdf - PCI_BDF(bus->seq, 0, 0); + bdf = bdf - PCI_BDF(dev_seq(bus), 0, 0); val = bdf | (offset & 0xfc) | ((offset & 0xf00) << 16) | 0x80000000; out_be32(®s->cfg_addr, val);
@@ -93,7 +93,7 @@ static int fsl_pcie_write_config(struct udevice *bus, pci_dev_t bdf, if (fsl_pcie_addr_valid(pcie, bdf)) return 0;
@@ -123,7 +123,7 @@ static int fsl_pcie_hose_read_config(struct fsl_pcie *pcie, uint offset, int ret; struct udevice *bus = pcie->bus;
- ret = fsl_pcie_read_config(bus, PCI_BDF(bus->seq, 0, 0), + ret = fsl_pcie_read_config(bus, PCI_BDF(dev_seq(bus), 0, 0), offset, valuep, size);
return ret; @@ -134,7 +134,7 @@ static int fsl_pcie_hose_write_config(struct fsl_pcie *pcie, uint offset, { struct udevice *bus = pcie->bus;
- return fsl_pcie_write_config(bus, PCI_BDF(bus->seq, 0, 0), + return fsl_pcie_write_config(bus, PCI_BDF(dev_seq(bus), 0, 0), offset, value, size); }
diff --git a/drivers/pci/pcie_intel_fpga.c b/drivers/pci/pcie_intel_fpga.c index 9f102c64c60..cafb02195f0 100644 --- a/drivers/pci/pcie_intel_fpga.c +++ b/drivers/pci/pcie_intel_fpga.c @@ -369,7 +369,7 @@ static int pcie_intel_fpga_probe(struct udevice *dev) struct intel_fpga_pcie *pcie = dev_get_priv(dev);
pcie->bus = pci_get_controller(dev); - pcie->first_busno = dev->seq; + pcie->first_busno = dev_seq(dev);
/* clear all interrupts */ cra_writel(pcie, P2A_INT_STS_ALL, P2A_INT_STATUS); diff --git a/drivers/pci/pcie_layerscape_fixup.c b/drivers/pci/pcie_layerscape_fixup.c index c75cf26e0a5..a58e7a3892a 100644 --- a/drivers/pci/pcie_layerscape_fixup.c +++ b/drivers/pci/pcie_layerscape_fixup.c @@ -479,7 +479,7 @@ static int fdt_fixup_pci_vfs(void *blob, struct extra_iommu_entry *entry, for (bus = dev; device_is_on_pci_bus(bus);) bus = bus->parent;
- bdf = entry->bdf - PCI_BDF(bus->seq, 0, 0) + (vf_offset << 8); + bdf = entry->bdf - PCI_BDF(dev_seq(bus), 0, 0) + (vf_offset << 8);
for (i = 0; i < entry->num_vfs; i++) { if (fdt_fixup_pcie_device_ls(blob, bdf, pcie_rc) < 0) @@ -518,7 +518,7 @@ static void fdt_fixup_pcie_ls(void *blob) pcie_rc = dev_get_priv(bus);
/* the DT fixup must be relative to the hose first_busno */ - bdf = dm_pci_get_bdf(dev) - PCI_BDF(bus->seq, 0, 0); + bdf = dm_pci_get_bdf(dev) - PCI_BDF(dev_seq(bus), 0, 0);
if (fdt_fixup_pcie_device_ls(blob, bdf, pcie_rc) < 0) break; diff --git a/drivers/pci/pcie_layerscape_gen4.c b/drivers/pci/pcie_layerscape_gen4.c index 428bfcab09f..d6efdd3ed63 100644 --- a/drivers/pci/pcie_layerscape_gen4.c +++ b/drivers/pci/pcie_layerscape_gen4.c @@ -191,13 +191,13 @@ static int ls_pcie_g4_addr_valid(struct ls_pcie_g4 *pcie, pci_dev_t bdf) if (!pcie->enabled) return -ENXIO;
- if ((PCI_BUS(bdf) > bus->seq) && (!ls_pcie_g4_link_up(pcie))) + if ((PCI_BUS(bdf) > dev_seq(bus)) && (!ls_pcie_g4_link_up(pcie))) return -EINVAL;
- if (PCI_BUS(bdf) <= (bus->seq + 1) && (PCI_DEV(bdf) > 0)) + if (PCI_BUS(bdf) <= (dev_seq(bus) + 1) && (PCI_DEV(bdf) > 0)) return -EINVAL;
return 0; @@ -209,7 +209,7 @@ void *ls_pcie_g4_conf_address(struct ls_pcie_g4 *pcie, pci_dev_t bdf, struct udevice *bus = pcie->bus; u32 target;
- if (PCI_BUS(bdf) == bus->seq) { + if (PCI_BUS(bdf) == dev_seq(bus)) { if (offset < INDIRECT_ADDR_BNDRY) { ccsr_set_page(pcie, 0); return pcie->ccsr + offset; @@ -219,7 +219,7 @@ void *ls_pcie_g4_conf_address(struct ls_pcie_g4 *pcie, pci_dev_t bdf, return pcie->ccsr + OFFSET_TO_PAGE_ADDR(offset); }
- target = PAB_TARGET_BUS(PCI_BUS(bdf) - bus->seq) | + target = PAB_TARGET_BUS(PCI_BUS(bdf) - dev_seq(bus)) | PAB_TARGET_DEV(PCI_DEV(bdf)) | PAB_TARGET_FUNC(PCI_FUNC(bdf));
diff --git a/drivers/pci/pcie_layerscape_gen4_fixup.c b/drivers/pci/pcie_layerscape_gen4_fixup.c index 148b5d17ed0..e9ee15558e5 100644 --- a/drivers/pci/pcie_layerscape_gen4_fixup.c +++ b/drivers/pci/pcie_layerscape_gen4_fixup.c @@ -166,7 +166,7 @@ static void fdt_fixup_pcie_ls_gen4(void *blob) }
/* the DT fixup must be relative to the hose first_busno */ - bdf = dm_pci_get_bdf(dev) - PCI_BDF(bus->seq, 0, 0); + bdf = dm_pci_get_bdf(dev) - PCI_BDF(dev_seq(bus), 0, 0); /* map PCI b.d.f to streamID in LUT */ ls_pcie_g4_lut_set_mapping(pcie, index, bdf >> 8, streamid); /* update msi-map in device tree */ diff --git a/drivers/pci/pcie_layerscape_rc.c b/drivers/pci/pcie_layerscape_rc.c index 25c6ddebce0..241acbdc449 100644 --- a/drivers/pci/pcie_layerscape_rc.c +++ b/drivers/pci/pcie_layerscape_rc.c @@ -130,13 +130,13 @@ static int ls_pcie_addr_valid(struct ls_pcie_rc *pcie_rc, pci_dev_t bdf) if (!pcie_rc->enabled) return -ENXIO;
- if ((PCI_BUS(bdf) > bus->seq) && (!ls_pcie_link_up(pcie))) + if ((PCI_BUS(bdf) > dev_seq(bus)) && (!ls_pcie_link_up(pcie))) return -EINVAL;
return 0; @@ -152,16 +152,16 @@ int ls_pcie_conf_address(const struct udevice *bus, pci_dev_t bdf, if (ls_pcie_addr_valid(pcie_rc, bdf)) return -EINVAL;
- if (PCI_BUS(bdf) == bus->seq) { + if (PCI_BUS(bdf) == dev_seq(bus)) { *paddress = pcie->dbi + offset; return 0; }
- busdev = PCIE_ATU_BUS(PCI_BUS(bdf) - bus->seq) | + busdev = PCIE_ATU_BUS(PCI_BUS(bdf) - dev_seq(bus)) | PCIE_ATU_DEV(PCI_DEV(bdf)) | PCIE_ATU_FUNC(PCI_FUNC(bdf));
- if (PCI_BUS(bdf) == bus->seq + 1) { + if (PCI_BUS(bdf) == dev_seq(bus) + 1) { ls_pcie_cfg0_set_busdev(pcie_rc, busdev); *paddress = pcie_rc->cfg0 + offset; } else { diff --git a/drivers/pci/pcie_mediatek.c b/drivers/pci/pcie_mediatek.c index 55b6a40f254..5bd11661c3c 100644 --- a/drivers/pci/pcie_mediatek.c +++ b/drivers/pci/pcie_mediatek.c @@ -261,7 +261,7 @@ static struct mtk_pcie_port *mtk_pcie_find_port(const struct udevice *bus, return NULL; }
- while (dev->parent->seq != 0) + while (dev_seq(dev->parent) != 0) dev = dev->parent;
pplat = dev_get_parent_platdata(dev); diff --git a/drivers/pci/pcie_rockchip.c b/drivers/pci/pcie_rockchip.c index 04609f12962..96173b81cc3 100644 --- a/drivers/pci/pcie_rockchip.c +++ b/drivers/pci/pcie_rockchip.c @@ -373,7 +373,7 @@ static int rockchip_pcie_init_port(struct udevice *dev) /* Configure Address Translation. */ ret = rockchip_pcie_atr_init(priv); if (ret) { - dev_err(dev, "PCIE-%d: ATR init failed\n", dev->seq); + dev_err(dev, "PCIE-%d: ATR init failed\n", dev_seq(dev)); goto err_power_off_phy; }
@@ -528,7 +528,7 @@ static int rockchip_pcie_probe(struct udevice *dev) struct pci_controller *hose = dev_get_uclass_priv(ctlr); int ret;
- priv->first_busno = dev->seq; + priv->first_busno = dev_seq(dev); priv->dev = dev;
ret = rockchip_pcie_parse_dt(dev); @@ -544,7 +544,7 @@ static int rockchip_pcie_probe(struct udevice *dev) return ret;
dev_info(dev, "PCIE-%d: Link up (Bus%d)\n", - dev->seq, hose->first_busno); + dev_seq(dev), hose->first_busno);
return 0; } diff --git a/drivers/serial/serial_mcf.c b/drivers/serial/serial_mcf.c index 402fd5343c1..dee1706a218 100644 --- a/drivers/serial/serial_mcf.c +++ b/drivers/serial/serial_mcf.c @@ -85,7 +85,7 @@ static int coldfire_serial_probe(struct udevice *dev) { struct coldfire_serial_platdata *plat = dev->platdata;
- plat->port = dev->seq; + plat->port = dev_seq(dev);
return mcf_serial_init_common((uart_t *)plat->base, plat->port, plat->baudrate); diff --git a/drivers/serial/serial_s5p.c b/drivers/serial/serial_s5p.c index 9bb2be21e7b..57eb6963b61 100644 --- a/drivers/serial/serial_s5p.c +++ b/drivers/serial/serial_s5p.c @@ -187,7 +187,7 @@ static int s5p_serial_ofdata_to_platdata(struct udevice *dev)
plat->reg = (struct s5p_uart *)addr; plat->port_id = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), - "id", dev->seq); + "id", dev_seq(dev)); return 0; }
diff --git a/drivers/spi/altera_spi.c b/drivers/spi/altera_spi.c index 61372c52b05..1529002cac1 100644 --- a/drivers/spi/altera_spi.c +++ b/drivers/spi/altera_spi.c @@ -98,7 +98,7 @@ static int altera_spi_xfer(struct udevice *dev, unsigned int bitlen, uint32_t reg, data, start;
debug("%s: bus:%i cs:%i bitlen:%i bytes:%i flags:%lx\n", __func__, - bus->seq, slave_plat->cs, bitlen, bytes, flags); + dev_seq(bus), slave_plat->cs, bitlen, bytes, flags);
if (bitlen == 0) goto done; diff --git a/drivers/spi/cf_spi.c b/drivers/spi/cf_spi.c index 8fa6d351075..8f1c8b8c0fb 100644 --- a/drivers/spi/cf_spi.c +++ b/drivers/spi/cf_spi.c @@ -240,7 +240,7 @@ static int coldfire_spi_set_speed(struct udevice *bus, uint max_hz) cfspi->baudrate = max_hz;
/* Read current setup */ - bus_setup = readl(&dspi->ctar[bus->seq]); + bus_setup = readl(&dspi->ctar[dev_seq(bus)]);
tmp = (prescaler[3] * scaler[15]); /* Maximum and minimum baudrate it can handle */ @@ -294,7 +294,7 @@ static int coldfire_spi_set_speed(struct udevice *bus, uint max_hz)
bus_setup &= ~(DSPI_CTAR_PBR(0x03) | DSPI_CTAR_BR(0x0f)); bus_setup |= (DSPI_CTAR_PBR(best_i) | DSPI_CTAR_BR(best_j)); - writel(bus_setup, &dspi->ctar[bus->seq]); + writel(bus_setup, &dspi->ctar[dev_seq(bus)]);
return 0; } @@ -318,7 +318,7 @@ static int coldfire_spi_set_mode(struct udevice *bus, uint mode) if (cfspi->mode & SPI_MODE_MOD) { if ((cfspi->mode & SPI_MODE_XFER_SZ_MASK) == 0) bus_setup |= - readl(&dspi->ctar[bus->seq]) & MCF_FRM_SZ_16BIT; + readl(&dspi->ctar[dev_seq(bus)]) & MCF_FRM_SZ_16BIT; else bus_setup |= ((cfspi->mode & SPI_MODE_XFER_SZ_MASK) >> 1); @@ -329,14 +329,14 @@ static int coldfire_spi_set_mode(struct udevice *bus, uint mode) bus_setup |= (cfspi->mode & SPI_MODE_DLY_SCA_MASK) >> 4; } else { bus_setup |= - (readl(&dspi->ctar[bus->seq]) & MCF_CTAR_MODE_MASK); + (readl(&dspi->ctar[dev_seq(bus)]) & MCF_CTAR_MODE_MASK); }
cfspi->charbit = - ((readl(&dspi->ctar[bus->seq]) & MCF_FRM_SZ_16BIT) == + ((readl(&dspi->ctar[dev_seq(bus)]) & MCF_FRM_SZ_16BIT) == MCF_FRM_SZ_16BIT) ? 16 : 8;
- setbits_be32(&dspi->ctar[bus->seq], bus_setup); + setbits_be32(&dspi->ctar[dev_seq(bus)], bus_setup);
return 0; } diff --git a/drivers/spi/fsl_dspi.c b/drivers/spi/fsl_dspi.c index b22c9b3a09d..71b045e04cb 100644 --- a/drivers/spi/fsl_dspi.c +++ b/drivers/spi/fsl_dspi.c @@ -511,7 +511,7 @@ static int fsl_dspi_probe(struct udevice *bus) DSPI_MCR_CRXF | DSPI_MCR_CTXF; fsl_dspi_init_mcr(priv, mcr_cfg_val);
- debug("%s probe done, bus-num %d.\n", bus->name, bus->seq); + debug("%s probe done, bus-num %d.\n", bus->name, dev_seq(bus));
return 0; } @@ -527,7 +527,7 @@ static int fsl_dspi_claim_bus(struct udevice *dev) priv = dev_get_priv(bus);
/* processor special preparation work */ - cpu_dspi_claim_bus(bus->seq, slave_plat->cs); + cpu_dspi_claim_bus(dev_seq(bus), slave_plat->cs);
/* configure transfer mode */ fsl_dspi_cfg_ctar_mode(priv, slave_plat->cs, priv->mode); @@ -559,7 +559,7 @@ static int fsl_dspi_release_bus(struct udevice *dev) dspi_halt(priv, 1);
/* processor special release work */ - cpu_dspi_release_bus(bus->seq, slave_plat->cs); + cpu_dspi_release_bus(dev_seq(bus), slave_plat->cs);
return 0; } diff --git a/drivers/spi/fsl_espi.c b/drivers/spi/fsl_espi.c index 5c76fd962e9..5cd6577b85a 100644 --- a/drivers/spi/fsl_espi.c +++ b/drivers/spi/fsl_espi.c @@ -527,7 +527,7 @@ static int fsl_espi_probe(struct udevice *bus) fsl->max_transfer_length = ESPI_MAX_DATA_TRANSFER_LEN; fsl->speed_hz = plat->speed_hz;
return 0; } diff --git a/drivers/spi/octeon_spi.c b/drivers/spi/octeon_spi.c index 7e88e5580f7..249b9690bea 100644 --- a/drivers/spi/octeon_spi.c +++ b/drivers/spi/octeon_spi.c @@ -593,7 +593,7 @@ static int octeon_spi_probe(struct udevice *dev) if (ret) return ret;
- debug("SPI bus %s %d at %p\n", dev->name, dev->seq, priv->base); + debug("SPI bus %s %d at %p\n", dev->name, dev_seq(dev), priv->base);
return 0; } diff --git a/drivers/spi/pic32_spi.c b/drivers/spi/pic32_spi.c index 52e9eff743c..97c2f939c0f 100644 --- a/drivers/spi/pic32_spi.c +++ b/drivers/spi/pic32_spi.c @@ -247,7 +247,7 @@ static int pic32_spi_xfer(struct udevice *slave, unsigned int bitlen, slave_plat = dev_get_parent_platdata(slave);
debug("spi_xfer: bus:%i cs:%i flags:%lx\n", - bus->seq, slave_plat->cs, flags); + dev_seq(bus), slave_plat->cs, flags); debug("msg tx %p, rx %p submitted of %d byte(s)\n", tx_buf, rx_buf, len);
@@ -384,7 +384,7 @@ static int pic32_spi_probe(struct udevice *bus) fdt_size_t size; int ret;
- debug("%s: %d, bus: %i\n", __func__, __LINE__, bus->seq); + debug("%s: %d, bus: %i\n", __func__, __LINE__, dev_seq(bus)); addr = fdtdec_get_addr_size(gd->fdt_blob, node, "reg", &size); if (addr == FDT_ADDR_T_NONE) return -EINVAL; diff --git a/drivers/spi/sandbox_spi.c b/drivers/spi/sandbox_spi.c index 755f1768614..3c780bae71b 100644 --- a/drivers/spi/sandbox_spi.c +++ b/drivers/spi/sandbox_spi.c @@ -72,7 +72,7 @@ static int sandbox_spi_xfer(struct udevice *slave, unsigned int bitlen, return -EINVAL; }
- busnum = bus->seq; + busnum = dev_seq(bus); cs = spi_chip_select(slave); if (busnum >= CONFIG_SANDBOX_SPI_MAX_BUS || cs >= CONFIG_SANDBOX_SPI_MAX_CS) { diff --git a/drivers/spi/tegra114_spi.c b/drivers/spi/tegra114_spi.c index 0e8198c5a02..0c99dfde201 100644 --- a/drivers/spi/tegra114_spi.c +++ b/drivers/spi/tegra114_spi.c @@ -231,7 +231,7 @@ static int tegra114_spi_xfer(struct udevice *dev, unsigned int bitlen, int ret;
debug("%s: slave %u:%u dout %p din %p bitlen %u\n", - __func__, bus->seq, spi_chip_select(dev), dout, din, bitlen); + __func__, dev_seq(bus), spi_chip_select(dev), dout, din, bitlen); if (bitlen % 8) return -1; num_bytes = bitlen / 8; diff --git a/drivers/spi/tegra20_sflash.c b/drivers/spi/tegra20_sflash.c index 771744dfe43..722a1203462 100644 --- a/drivers/spi/tegra20_sflash.c +++ b/drivers/spi/tegra20_sflash.c @@ -217,7 +217,7 @@ static int tegra20_sflash_xfer(struct udevice *dev, unsigned int bitlen, int ret;
debug("%s: slave %u:%u dout %p din %p bitlen %u\n", - __func__, bus->seq, spi_chip_select(dev), dout, din, bitlen); + __func__, dev_seq(bus), spi_chip_select(dev), dout, din, bitlen); if (bitlen % 8) return -1; num_bytes = bitlen / 8; diff --git a/drivers/spi/tegra20_slink.c b/drivers/spi/tegra20_slink.c index f9846ee3665..d051e93c533 100644 --- a/drivers/spi/tegra20_slink.c +++ b/drivers/spi/tegra20_slink.c @@ -211,7 +211,7 @@ static int tegra30_spi_xfer(struct udevice *dev, unsigned int bitlen, int ret;
debug("%s: slave %u:%u dout %p din %p bitlen %u\n", - __func__, bus->seq, spi_chip_select(dev), dout, din, bitlen); + __func__, dev_seq(bus), spi_chip_select(dev), dout, din, bitlen); if (bitlen % 8) return -1; num_bytes = bitlen / 8; diff --git a/drivers/spi/tegra210_qspi.c b/drivers/spi/tegra210_qspi.c index ae16b45dcb4..ce08637c711 100644 --- a/drivers/spi/tegra210_qspi.c +++ b/drivers/spi/tegra210_qspi.c @@ -223,7 +223,7 @@ static int tegra210_qspi_xfer(struct udevice *dev, unsigned int bitlen, int num_bytes, tm, ret;
debug("%s: slave %u:%u dout %p din %p bitlen %u\n", - __func__, bus->seq, spi_chip_select(dev), dout, din, bitlen); + __func__, dev_seq(bus), spi_chip_select(dev), dout, din, bitlen); if (bitlen % 8) return -1; num_bytes = bitlen / 8; diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index 47a5571aecd..5b630073401 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -255,7 +255,7 @@ static int xilinx_spi_xfer(struct udevice *dev, unsigned int bitlen, int ret;
debug("spi_xfer: bus:%i cs:%i bitlen:%i bytes:%i flags:%lx\n", - bus->seq, slave_plat->cs, bitlen, bytes, flags); + dev_seq(bus), slave_plat->cs, bitlen, bytes, flags);
if (bitlen == 0) goto done; diff --git a/drivers/spi/zynq_qspi.c b/drivers/spi/zynq_qspi.c index f2eddec950a..7e2d4e088ee 100644 --- a/drivers/spi/zynq_qspi.c +++ b/drivers/spi/zynq_qspi.c @@ -568,7 +568,7 @@ static int zynq_qspi_xfer(struct udevice *dev, unsigned int bitlen, priv->len = bitlen / 8;
debug("zynq_qspi_xfer: bus:%i cs:%i bitlen:%i len:%i flags:%lx\n", - bus->seq, slave_plat->cs, bitlen, priv->len, flags); + dev_seq(bus), slave_plat->cs, bitlen, priv->len, flags);
/* * Festering sore. diff --git a/drivers/spi/zynq_spi.c b/drivers/spi/zynq_spi.c index cb911c34f68..ad7cec86e44 100644 --- a/drivers/spi/zynq_spi.c +++ b/drivers/spi/zynq_spi.c @@ -242,7 +242,7 @@ static int zynq_spi_xfer(struct udevice *dev, unsigned int bitlen, u32 ts, status;
debug("spi_xfer: bus:%i cs:%i bitlen:%i len:%i flags:%lx\n", - bus->seq, slave_plat->cs, bitlen, len, flags); + dev_seq(bus), slave_plat->cs, bitlen, len, flags);
if (bitlen % 8) { debug("spi_xfer: Non byte aligned SPI transfer\n"); diff --git a/drivers/usb/gadget/max3420_udc.c b/drivers/usb/gadget/max3420_udc.c index b38b9dc68f7..156bb1ebebd 100644 --- a/drivers/usb/gadget/max3420_udc.c +++ b/drivers/usb/gadget/max3420_udc.c @@ -821,7 +821,7 @@ static int max3420_udc_probe(struct udevice *dev) struct max3420_udc *udc = dev_get_priv(dev); struct dm_spi_slave_platdata *slave_pdata; struct udevice *bus = dev->parent; - int busnum = bus->seq; + int busnum = dev_seq(bus); unsigned int cs; uint speed, mode; struct udevice *spid; diff --git a/drivers/usb/host/ehci-mx5.c b/drivers/usb/host/ehci-mx5.c index caafa688993..51377487d4b 100644 --- a/drivers/usb/host/ehci-mx5.c +++ b/drivers/usb/host/ehci-mx5.c @@ -321,7 +321,7 @@ static int ehci_usb_probe(struct udevice *dev) mdelay(1);
priv->ehci = ehci; - priv->portnr = dev->seq; + priv->portnr = dev_seq(dev); priv->init_type = type;
ret = device_get_supply_regulator(dev, "vbus-supply", diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 37b59758bb3..8fa136f4eeb 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -596,7 +596,7 @@ static int ehci_usb_probe(struct udevice *dev) }
#if CONFIG_IS_ENABLED(DM_REGULATOR) diff --git a/drivers/usb/host/ehci-omap.c b/drivers/usb/host/ehci-omap.c index 82b99eeef1e..a2c0caf1bcc 100644 --- a/drivers/usb/host/ehci-omap.c +++ b/drivers/usb/host/ehci-omap.c @@ -383,7 +383,7 @@ static int omap_ehci_probe(struct udevice *dev) struct ehci_hcor *hcor;
priv->ehci = dev_read_addr_ptr(dev); - priv->portnr = dev->seq; + priv->portnr = dev_seq(dev); priv->init_type = plat->init_type;
hccr = (struct ehci_hccr *)&priv->ehci->hccapbase; diff --git a/drivers/usb/host/ehci-vf.c b/drivers/usb/host/ehci-vf.c index 2768d409749..92b70ba1b30 100644 --- a/drivers/usb/host/ehci-vf.c +++ b/drivers/usb/host/ehci-vf.c @@ -222,7 +222,7 @@ static int vf_usb_ofdata_to_platdata(struct udevice *dev) int node = dev_of_offset(dev); const char *mode;
priv->ehci = dev_read_addr_ptr(dev); mode = fdt_getprop(dt_blob, node, "dr_mode", NULL); diff --git a/drivers/usb/host/usb-sandbox.c b/drivers/usb/host/usb-sandbox.c index beb62ebc0c2..cc357d9ef40 100644 --- a/drivers/usb/host/usb-sandbox.c +++ b/drivers/usb/host/usb-sandbox.c @@ -23,7 +23,7 @@ static void usbmon_trace(struct udevice *bus, ulong pipe, type = (pipe & USB_PIPE_TYPE_MASK) >> USB_PIPE_TYPE_SHIFT; debug("0 0 S %c%c:%d:%03ld:%ld", types[type], pipe & USB_DIR_IN ? 'i' : 'o', - bus->seq, + dev_seq(bus), (pipe & USB_PIPE_DEV_MASK) >> USB_PIPE_DEV_SHIFT, (pipe & USB_PIPE_EP_MASK) >> USB_PIPE_EP_SHIFT); if (setup) { diff --git a/drivers/usb/host/usb-uclass.c b/drivers/usb/host/usb-uclass.c index 2f8c9037c12..453c2bbb0b6 100644 --- a/drivers/usb/host/usb-uclass.c +++ b/drivers/usb/host/usb-uclass.c @@ -701,7 +701,7 @@ int usb_scan_device(struct udevice *parent, int port, return ret; ret = usb_find_and_bind_driver(parent, &udev->descriptor, iface, - udev->controller_dev->seq, + dev_seq(udev->controller_dev), udev->devnum, port, &dev); if (ret) return ret; diff --git a/drivers/video/vidconsole-uclass.c b/drivers/video/vidconsole-uclass.c index 3a07f36ce27..9fa124b3c03 100644 --- a/drivers/video/vidconsole-uclass.c +++ b/drivers/video/vidconsole-uclass.c @@ -606,9 +606,9 @@ static int vidconsole_post_probe(struct udevice *dev) if (!priv->tab_width_frac) priv->tab_width_frac = VID_TO_POS(priv->x_charsize) * 8;
- if (dev->seq) { + if (dev_seq(dev)) { snprintf(sdev->name, sizeof(sdev->name), "vidconsole%d", - dev->seq); + dev_seq(dev)); } else { strcpy(sdev->name, "vidconsole"); } diff --git a/drivers/virtio/virtio-uclass.c b/drivers/virtio/virtio-uclass.c index 2636cbedfe2..53c17429725 100644 --- a/drivers/virtio/virtio-uclass.c +++ b/drivers/virtio/virtio-uclass.c @@ -240,7 +240,7 @@ static int virtio_uclass_post_probe(struct udevice *udev) }
snprintf(dev_name, sizeof(dev_name), "%s#%d", - virtio_drv_name[uc_priv->device], udev->seq); + virtio_drv_name[uc_priv->device], dev_seq(udev)); str = strdup(dev_name); if (!str) return -ENOMEM; diff --git a/drivers/watchdog/ast_wdt.c b/drivers/watchdog/ast_wdt.c index 9b83d2ad442..c9c4a1fdc5f 100644 --- a/drivers/watchdog/ast_wdt.c +++ b/drivers/watchdog/ast_wdt.c @@ -113,7 +113,7 @@ static const struct udevice_id ast_wdt_ids[] = {
static int ast_wdt_probe(struct udevice *dev) { - debug("%s() wdt%u\n", __func__, dev->seq); + debug("%s() wdt%u\n", __func__, dev_seq(dev)); ast_wdt_stop(dev);
return 0; diff --git a/drivers/watchdog/at91sam9_wdt.c b/drivers/watchdog/at91sam9_wdt.c index 33f5c351d5b..3455a80228d 100644 --- a/drivers/watchdog/at91sam9_wdt.c +++ b/drivers/watchdog/at91sam9_wdt.c @@ -108,7 +108,7 @@ static int at91_wdt_probe(struct udevice *dev) if (!priv->regs) return -EINVAL;
- debug("%s: Probing wdt%u\n", __func__, dev->seq); + debug("%s: Probing wdt%u\n", __func__, dev_seq(dev));
return 0; } diff --git a/drivers/watchdog/cdns_wdt.c b/drivers/watchdog/cdns_wdt.c index 2abd5524f61..1e703f07f70 100644 --- a/drivers/watchdog/cdns_wdt.c +++ b/drivers/watchdog/cdns_wdt.c @@ -223,7 +223,7 @@ static int cdns_wdt_stop(struct udevice *dev) */ static int cdns_wdt_probe(struct udevice *dev) { - debug("%s: Probing wdt%u\n", __func__, dev->seq); + debug("%s: Probing wdt%u\n", __func__, dev_seq(dev));
return 0; } diff --git a/drivers/watchdog/omap_wdt.c b/drivers/watchdog/omap_wdt.c index 9059a4c6105..8c87b50c5d2 100644 --- a/drivers/watchdog/omap_wdt.c +++ b/drivers/watchdog/omap_wdt.c @@ -242,7 +242,7 @@ static int omap3_wdt_probe(struct udevice *dev) return -EINVAL;
priv->wdt_trgr_pattern = 0x1234; - debug("%s: Probing wdt%u\n", __func__, dev->seq); + debug("%s: Probing wdt%u\n", __func__, dev_seq(dev)); return 0; }
diff --git a/drivers/watchdog/orion_wdt.c b/drivers/watchdog/orion_wdt.c index d33e2ac3dc1..c3576916d32 100644 --- a/drivers/watchdog/orion_wdt.c +++ b/drivers/watchdog/orion_wdt.c @@ -158,7 +158,7 @@ static int orion_wdt_probe(struct udevice *dev) struct orion_wdt_priv *priv = dev_get_priv(dev); int ret;
- debug("%s: Probing wdt%u\n", __func__, dev->seq); + debug("%s: Probing wdt%u\n", __func__, dev_seq(dev)); orion_wdt_stop(dev);
ret = clk_get_by_name(dev, "fixed", &priv->clk); diff --git a/drivers/watchdog/sbsa_gwdt.c b/drivers/watchdog/sbsa_gwdt.c index 96285c1a9b4..6136994b041 100644 --- a/drivers/watchdog/sbsa_gwdt.c +++ b/drivers/watchdog/sbsa_gwdt.c @@ -88,7 +88,7 @@ static int sbsa_gwdt_expire_now(struct udevice *dev, ulong flags)
static int sbsa_gwdt_probe(struct udevice *dev) { - debug("%s: Probing wdt%u (sbsa-gwdt)\n", __func__, dev->seq); + debug("%s: Probing wdt%u (sbsa-gwdt)\n", __func__, dev_seq(dev));
return 0; } diff --git a/drivers/watchdog/sp805_wdt.c b/drivers/watchdog/sp805_wdt.c index 23fef2147f8..aaf93d545e4 100644 --- a/drivers/watchdog/sp805_wdt.c +++ b/drivers/watchdog/sp805_wdt.c @@ -105,7 +105,7 @@ static int sp805_wdt_expire_now(struct udevice *dev, ulong flags)
static int sp805_wdt_probe(struct udevice *dev) { - debug("%s: Probing wdt%u (sp805-wdt)\n", __func__, dev->seq); + debug("%s: Probing wdt%u (sp805-wdt)\n", __func__, dev_seq(dev));
return 0; } diff --git a/drivers/watchdog/tangier_wdt.c b/drivers/watchdog/tangier_wdt.c index 358a9b90fdd..bdc65597dcf 100644 --- a/drivers/watchdog/tangier_wdt.c +++ b/drivers/watchdog/tangier_wdt.c @@ -80,7 +80,7 @@ static const struct udevice_id tangier_wdt_ids[] = {
static int tangier_wdt_probe(struct udevice *dev) { - debug("%s: Probing wdt%u\n", __func__, dev->seq); + debug("%s: Probing wdt%u\n", __func__, dev_seq(dev)); return 0; }
diff --git a/drivers/watchdog/xilinx_tb_wdt.c b/drivers/watchdog/xilinx_tb_wdt.c index ea4311c8ce1..721ccdb0f6d 100644 --- a/drivers/watchdog/xilinx_tb_wdt.c +++ b/drivers/watchdog/xilinx_tb_wdt.c @@ -85,7 +85,7 @@ static int xlnx_wdt_start(struct udevice *dev, u64 timeout, ulong flags)
static int xlnx_wdt_probe(struct udevice *dev) { - debug("%s: Probing wdt%u\n", __func__, dev->seq); + debug("%s: Probing wdt%u\n", __func__, dev_seq(dev));
return 0; } diff --git a/drivers/watchdog/xilinx_wwdt.c b/drivers/watchdog/xilinx_wwdt.c index d8a585a4830..df55e088bbf 100644 --- a/drivers/watchdog/xilinx_wwdt.c +++ b/drivers/watchdog/xilinx_wwdt.c @@ -128,7 +128,7 @@ static int xlnx_wwdt_probe(struct udevice *dev) struct xlnx_wwdt_platdata *platdata = dev_get_platdata(dev); struct xlnx_wwdt_priv *wdt = dev_get_priv(dev);
- dev_dbg(dev, "%s: Probing wdt%u\n", __func__, dev->seq); + dev_dbg(dev, "%s: Probing wdt%u\n", __func__, dev_seq(dev));
ret = regmap_init_mem(dev_ofnode(dev), &wdt->regs); if (ret) { diff --git a/include/dm/device.h b/include/dm/device.h index 25a77d08b9d..9a171e523f3 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -182,6 +182,11 @@ static inline bool dev_has_of_node(struct udevice *dev) return ofnode_valid(dev->node); }
+static inline int dev_seq(const struct udevice *dev) +{ + return dev->seq; +} + /** * struct udevice_id - Lists the compatible strings supported by a driver * @compatible: Compatible string diff --git a/include/pci.h b/include/pci.h index d1ccf6c9636..f8dadf9d5ad 100644 --- a/include/pci.h +++ b/include/pci.h @@ -934,7 +934,7 @@ struct dm_pci_ops { * PCI buses must support reading and writing configuration values * so that the bus can be scanned and its devices configured. * - * Normally PCI_BUS(@bdf) is the same as @bus->seq, but not always. + * Normally PCI_BUS(@bdf) is the same as @dev_seq(bus), but not always. * If bridges exist it is possible to use the top-level bus to * access a sub-bus. In that case @bus will be the top-level bus * and PCI_BUS(bdf) will be a different (higher) value diff --git a/include/spi.h b/include/spi.h index ef8c1f6692e..e90110dd13c 100644 --- a/include/spi.h +++ b/include/spi.h @@ -116,7 +116,7 @@ enum spi_polarity { * claimed. * @bus: ID of the bus that the slave is attached to. For * driver model this is the sequence number of the SPI - * bus (bus->seq) so does not need to be stored + * bus (dev_seq(bus)) so does not need to be stored * @cs: ID of the chip select connected to the slave. * @mode: SPI mode to use for this slave (see SPI mode flags) * @wordlen: Size of SPI word in number of bits diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index 8a5c13c4241..2726c5e42fd 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -624,7 +624,7 @@ __maybe_unused static void *dp_fill(void *buf, struct udevice *dev) DEVICE_PATH_SUB_TYPE_MSG_SD : DEVICE_PATH_SUB_TYPE_MSG_MMC; sddp->dp.length = sizeof(*sddp); - sddp->slot_number = dev->seq; + sddp->slot_number = dev_seq(dev); return &sddp[1]; } #endif @@ -677,7 +677,7 @@ __maybe_unused static void *dp_fill(void *buf, struct udevice *dev) DEVICE_PATH_SUB_TYPE_MSG_SD : DEVICE_PATH_SUB_TYPE_MSG_MMC; sddp->dp.length = sizeof(*sddp); - sddp->slot_number = dev->seq; + sddp->slot_number = dev_seq(dev);
return &sddp[1]; } diff --git a/net/eth-uclass.c b/net/eth-uclass.c index e14695c0f16..e6a3cd1ee6a 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -137,7 +137,7 @@ struct udevice *eth_get_dev_by_name(const char *devname) continue; /* Check for the name or the sequence number to match */ if (strcmp(it->name, devname) == 0 || - (endp > startp && it->seq == seq)) + (endp > startp && dev_seq(it) == seq)) return it; }
@@ -189,7 +189,7 @@ void eth_halt_state_only(void) int eth_get_dev_index(void) { if (eth_get_dev()) - return eth_get_dev()->seq; + return dev_seq(eth_get_dev()); return -1; }
@@ -202,7 +202,7 @@ static int eth_write_hwaddr(struct udevice *dev) return -EINVAL;
/* seq is valid since the device is active */ - if (eth_get_ops(dev)->write_hwaddr && !eth_mac_skip(dev->seq)) { + if (eth_get_ops(dev)->write_hwaddr && !eth_mac_skip(dev_seq(dev))) { pdata = dev->platdata; if (!is_valid_ethaddr(pdata->enetaddr)) { printf("\nError: %s address %pM illegal value\n", @@ -434,11 +434,11 @@ int eth_initialize(void)
bootstage_mark(BOOTSTAGE_ID_NET_ETH_INIT); do { - if (dev->seq != -1) { + if (dev_seq(dev) != -1) { if (num_devices) printf(", ");
- printf("eth%d: %s", dev->seq, dev->name); + printf("eth%d: %s", dev_seq(dev), dev->name);
if (ethprime && dev == prime_dev) printf(" [PRIME]"); @@ -446,7 +446,7 @@ int eth_initialize(void)
eth_write_hwaddr(dev);
- if (dev->seq != -1) + if (dev_seq(dev) != -1) num_devices++; uclass_next_device_check(&dev); } while (dev); @@ -547,7 +547,7 @@ static int eth_post_probe(struct udevice *dev) eth_get_ops(dev)->read_rom_hwaddr(dev); }
- eth_env_get_enetaddr_by_index("eth", dev->seq, env_enetaddr); + eth_env_get_enetaddr_by_index("eth", dev_seq(dev), env_enetaddr); if (!is_zero_ethaddr(env_enetaddr)) { if (!is_zero_ethaddr(pdata->enetaddr) && memcmp(pdata->enetaddr, env_enetaddr, ARP_HLEN)) { @@ -562,13 +562,14 @@ static int eth_post_probe(struct udevice *dev) /* Override the ROM MAC address */ memcpy(pdata->enetaddr, env_enetaddr, ARP_HLEN); } else if (is_valid_ethaddr(pdata->enetaddr)) { - eth_env_set_enetaddr_by_index("eth", dev->seq, pdata->enetaddr); + eth_env_set_enetaddr_by_index("eth", dev_seq(dev), + pdata->enetaddr); } else if (is_zero_ethaddr(pdata->enetaddr) || !is_valid_ethaddr(pdata->enetaddr)) { #ifdef CONFIG_NET_RANDOM_ETHADDR net_random_ethaddr(pdata->enetaddr); printf("\nWarning: %s (eth%d) using random MAC address - %pM\n", - dev->name, dev->seq, pdata->enetaddr); + dev->name, dev_seq(dev), pdata->enetaddr); #else printf("\nError: %s address not set.\n", dev->name);
At present this is passed a uclass ID and it has to do a lookup. The callers all have the uclass pointer, except for the I2C uclass where the code will soon be deleted.
Update the argument to a uclass * instead of an ID since it is more efficient.
(no changes since v1)
drivers/core/device.c | 4 ++-- drivers/core/uclass.c | 8 +------- drivers/i2c/designware_i2c_pci.c | 8 +++++++- include/dm/uclass-internal.h | 4 ++-- 4 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/core/device.c b/drivers/core/device.c index 5660310c754..5febdb67503 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -89,10 +89,10 @@ static int device_bind_common(struct udevice *parent, const struct driver *drv, #if CONFIG_IS_ENABLED(OF_PRIOR_STAGE) if (dev->req_seq == -1) dev->req_seq = - uclass_find_next_free_req_seq(drv->id); + uclass_find_next_free_req_seq(uc); #endif } else { - dev->req_seq = uclass_find_next_free_req_seq(drv->id); + dev->req_seq = uclass_find_next_free_req_seq(uc); } }
diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index 699f24843cf..cdf0674cd82 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -272,17 +272,11 @@ int uclass_find_device_by_name(enum uclass_id id, const char *name, return -ENODEV; }
-int uclass_find_next_free_req_seq(enum uclass_id id) +int uclass_find_next_free_req_seq(struct uclass *uc) { - struct uclass *uc; struct udevice *dev; - int ret; int max = -1;
- ret = uclass_get(id, &uc); - if (ret) - return ret; - list_for_each_entry(dev, &uc->dev_head, uclass_node) { if ((dev->req_seq != -1) && (dev->req_seq > max)) max = dev->req_seq; diff --git a/drivers/i2c/designware_i2c_pci.c b/drivers/i2c/designware_i2c_pci.c index d0d869c81a1..04921a304ac 100644 --- a/drivers/i2c/designware_i2c_pci.c +++ b/drivers/i2c/designware_i2c_pci.c @@ -90,7 +90,9 @@ static int designware_i2c_pci_probe(struct udevice *dev)
static int designware_i2c_pci_bind(struct udevice *dev) { + struct uclass *uc; char name[20]; + int ret;
if (dev_of_valid(dev)) return 0; @@ -108,7 +110,11 @@ static int designware_i2c_pci_bind(struct udevice *dev) * be possible. We cannot use static data in drivers since they may be * used in SPL or before relocation. */ - dev->req_seq = uclass_find_next_free_req_seq(UCLASS_I2C); + ret = uclass_get(UCLASS_I2C, &uc); + if (ret) + return ret; + + dev->req_seq = uclass_find_next_free_req_seq(uc); sprintf(name, "i2c_designware#%u", dev->req_seq); device_set_name(dev, name);
diff --git a/include/dm/uclass-internal.h b/include/dm/uclass-internal.h index 6e3f15c2b08..2c21871e0fd 100644 --- a/include/dm/uclass-internal.h +++ b/include/dm/uclass-internal.h @@ -19,10 +19,10 @@ * maximum req_seq of the uclass + 1. * This allows assiging req_seq number in the binding order. * - * @id: Id number of the uclass + * @uc: uclass to check * @return The next free req_seq number */ -int uclass_find_next_free_req_seq(enum uclass_id id); +int uclass_find_next_free_req_seq(struct uclass *uc);
/** * uclass_get_device_tail() - handle the end of a get_device call
At present each device has two sequence numbers, with 'req_seq' being set up at bind time and 'seq' at probe time. The idea is that devices can 'request' a sequence number and then the conflicts are resolved when the device is probed.
This makes things complicated in a few cases, since we don't really know what the sequence number will end up being. We want to honour the bind-time requests if at all possible, but in fact the only source of these at present is the devicetree aliases. Since we have the devicetree available at bind time, we may as well just use it, in the hope that the required processing will turn out to be useful later (i.e. the device actually gets used).
Add a new 'sqq' member, the bind-time sequence number. It operates in parallel to the old values for now. All devices get a valid sqq value, i.e. it is never -1.
Drop an #ifdef while we are here.
Changes in v2: - Give all devices a sequence number - Drop uclass_alloc_all_seqs() and GD_FLG_DM_NO_SEQ flag
drivers/core/device.c | 22 ++++++++++++++++------ drivers/core/root.c | 8 +++++--- include/dm/device.h | 8 ++++++++ 3 files changed, 29 insertions(+), 9 deletions(-)
diff --git a/drivers/core/device.c b/drivers/core/device.c index 5febdb67503..a417bbc0964 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -41,6 +41,7 @@ static int device_bind_common(struct udevice *parent, const struct driver *drv, struct udevice *dev; struct uclass *uc; int size, ret = 0; + bool auto_seq = true;
if (devp) *devp = NULL; @@ -73,6 +74,7 @@ static int device_bind_common(struct udevice *parent, const struct driver *drv,
dev->seq = -1; dev->req_seq = -1; + dev->sqq = -1; if (CONFIG_IS_ENABLED(DM_SEQ_ALIAS) && (uc->uc_drv->flags & DM_UC_FLAG_SEQ_ALIAS)) { /* @@ -84,17 +86,25 @@ static int device_bind_common(struct udevice *parent, const struct driver *drv, */ if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) { - if (uc->uc_drv->name && ofnode_valid(node)) + if (uc->uc_drv->name && ofnode_valid(node)) { + dev_read_alias_seq(dev, &dev->sqq); dev_read_alias_seq(dev, &dev->req_seq); -#if CONFIG_IS_ENABLED(OF_PRIOR_STAGE) - if (dev->req_seq == -1) - dev->req_seq = - uclass_find_next_free_req_seq(uc); -#endif + auto_seq = false; + } + if (CONFIG_IS_ENABLED(OF_PRIOR_STAGE)) { + if (dev->req_seq == -1) { + auto_seq = true; + dev->req_seq = + uclass_find_next_free_req_seq( + uc); + } + } } else { dev->req_seq = uclass_find_next_free_req_seq(uc); } } + if (auto_seq) + dev->sqq = uclass_find_next_free_req_seq(uc);
if (drv->platdata_auto_alloc_size) { bool alloc = !platdata; diff --git a/drivers/core/root.c b/drivers/core/root.c index 6f8168bb92d..8426b8e96b4 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -311,22 +311,24 @@ int dm_init_and_scan(bool pre_reloc_only) ret = dm_scan_platdata(pre_reloc_only); if (ret) { debug("dm_scan_platdata() failed: %d\n", ret); - return ret; + goto fail; }
if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) { ret = dm_extended_scan(pre_reloc_only); if (ret) { debug("dm_extended_scan() failed: %d\n", ret); - return ret; + goto fail; } }
ret = dm_scan_other(pre_reloc_only); if (ret) - return ret; + goto fail;
return 0; +fail: + return ret; }
#ifdef CONFIG_ACPIGEN diff --git a/include/dm/device.h b/include/dm/device.h index 9a171e523f3..80cd0955362 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -131,6 +131,13 @@ enum { * @child_head: List of children of this device * @sibling_node: Next device in list of all devices * @flags: Flags for this device DM_FLAG_... + * @sqq: Allocated sequence number for this device (-1 = none). This is set up + * when the device is bound and is unique within the device's uclass. If the + * device has an alias in the devicetree then that is used to set the sequence + * number. Otherwise, the next available number is used. Sequence numbers are + * used by certain commands that need device to be numbered (e.g. 'mmc dev') + * + * The following two fields are deprecated: * @req_seq: Requested sequence number for this device (-1 = any) * @seq: Allocated sequence number for this device (-1 = none). This is set up * when the device is probed and will be unique within the device's uclass. @@ -156,6 +163,7 @@ struct udevice { struct list_head child_head; struct list_head sibling_node; uint32_t flags; + int sqq; int req_seq; int seq; #ifdef CONFIG_DEVRES
Add a test that the new sequence numbers work as expected. Every device should get one.
Changes in v2: - Drop the GD_FLG_DM_NO_SEQ flag
test/dm/core.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/test/dm/core.c b/test/dm/core.c index 71ebb36d88b..0514813b817 100644 --- a/test/dm/core.c +++ b/test/dm/core.c @@ -1066,3 +1066,22 @@ static int dm_test_inactive_child(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_inactive_child, UT_TESTF_SCAN_PDATA); + +/* Make sure all bound devices have a sequence number */ +static int dm_test_all_have_seq(struct unit_test_state *uts) +{ + struct udevice *dev; + struct uclass *uc; + + list_for_each_entry(uc, &gd->uclass_root, sibling_node) { + list_for_each_entry(dev, &uc->dev_head, uclass_node) { + if (dev->sqq == -1) + printf("Device '%s' has no seq (%d)\n", + dev->name, dev->sqq); + ut_assert(dev->sqq != -1); + } + } + + return 0; +} +DM_TEST(dm_test_all_have_seq, UT_TESTF_SCAN_PDATA);
Update the core logic to use the new approach. For now the old code is left as is. Update one test so it still passes.
drivers/core/device.c | 5 +---- test/dm/bus.c | 3 ++- 2 files changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/core/device.c b/drivers/core/device.c index a417bbc0964..89abc0021c8 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -667,12 +667,9 @@ int device_find_child_by_seq(const struct udevice *parent, int seq_or_req_seq, struct udevice *dev;
*devp = NULL; - if (seq_or_req_seq == -1) - return -ENODEV;
list_for_each_entry(dev, &parent->child_head, sibling_node) { - if ((find_req_seq ? dev->req_seq : dev_seq(dev)) == - seq_or_req_seq) { + if (dev->sqq == seq_or_req_seq) { *devp = dev; return 0; } diff --git a/test/dm/bus.c b/test/dm/bus.c index 27b72666457..e1fa67d91e1 100644 --- a/test/dm/bus.c +++ b/test/dm/bus.c @@ -160,9 +160,10 @@ static int dm_test_bus_children_funcs(struct unit_test_state *uts) ut_asserteq(-ENODEV, device_find_child_by_seq(bus, -1, true, &dev)); ut_assertok(device_find_child_by_seq(bus, 0, true, &dev)); ut_assert(!(dev->flags & DM_FLAG_ACTIVATED)); - ut_asserteq(-ENODEV, device_find_child_by_seq(bus, 0, false, &dev)); + ut_asserteq(0, device_find_child_by_seq(bus, 0, false, &dev)); ut_assertok(device_get_child_by_seq(bus, 0, &dev)); ut_assert(dev->flags & DM_FLAG_ACTIVATED); + ut_asserteq(0, device_find_child_by_seq(bus, 0, false, &dev));
/* There is no device with sequence number 2 */ ut_asserteq(-ENODEV, device_find_child_by_seq(bus, 2, false, &dev));
This should return 0 on success but currently does not. Fix it.
drivers/core/read.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/core/read.c b/drivers/core/read.c index 076125824ca..fc74d64814f 100644 --- a/drivers/core/read.c +++ b/drivers/core/read.c @@ -281,8 +281,10 @@ int dev_read_alias_seq(const struct udevice *dev, int *devnump)
if (ofnode_is_np(node)) { ret = of_alias_get_id(ofnode_to_np(node), uc_name); - if (ret >= 0) + if (ret >= 0) { *devnump = ret; + ret = 0; + } } else { #if CONFIG_IS_ENABLED(OF_CONTROL) ret = fdtdec_get_alias_seq(gd->fdt_blob, uc_name,
Drop code in a few tests which assumes that sequence numbers are only valid when a device is probed.
test/dm/blk.c | 3 --- test/dm/i2c.c | 3 --- test/dm/spi.c | 3 --- 3 files changed, 9 deletions(-)
diff --git a/test/dm/blk.c b/test/dm/blk.c index f34c13f7511..ea5e0955d98 100644 --- a/test/dm/blk.c +++ b/test/dm/blk.c @@ -19,9 +19,6 @@ static int dm_test_blk_base(struct unit_test_state *uts) { struct udevice *blk1, *blk3, *dev;
- /* Make sure there are no block devices */ - ut_asserteq(-ENODEV, uclass_get_device_by_seq(UCLASS_BLK, 0, &dev)); - /* Create two, one the parent of the other */ ut_assertok(blk_create_device(gd->dm_root, "sandbox_host_blk", "test", IF_TYPE_HOST, 1, 512, 2, &blk1)); diff --git a/test/dm/i2c.c b/test/dm/i2c.c index 681ce45107c..d74f5f9fbc7 100644 --- a/test/dm/i2c.c +++ b/test/dm/i2c.c @@ -28,9 +28,6 @@ static int dm_test_i2c_find(struct unit_test_state *uts) struct udevice *bus, *dev; const int no_chip = 0x10;
- ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_I2C, busnum, - false, &bus)); - /* * The post_bind() method will bind devices to chip selects. Check * this then remove the emulation and the slave device. diff --git a/test/dm/spi.c b/test/dm/spi.c index fb180aed1f0..b767cf9c4a0 100644 --- a/test/dm/spi.c +++ b/test/dm/spi.c @@ -26,9 +26,6 @@ static int dm_test_spi_find(struct unit_test_state *uts) struct spi_cs_info info; ofnode node;
- ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_SPI, busnum, - false, &bus)); - /* * The post_bind() method will bind devices to chip selects. Check * this then remove the emulation and the slave device.
Several Octeon drivers operate by setting the sequence number of their device. This should not be needed with the new sequence number setup. Also it is not permitted. Drop it.
drivers/i2c/octeon_i2c.c | 1 - drivers/mmc/octeontx_hsmmc.c | 2 -- drivers/net/octeontx/smi.c | 1 - 3 files changed, 4 deletions(-)
diff --git a/drivers/i2c/octeon_i2c.c b/drivers/i2c/octeon_i2c.c index 38839e45758..85ad357eca9 100644 --- a/drivers/i2c/octeon_i2c.c +++ b/drivers/i2c/octeon_i2c.c @@ -791,7 +791,6 @@ static int octeon_i2c_probe(struct udevice *dev) pci_dev_t bdf = dm_pci_get_bdf(dev);
debug("TWSI PCI device: %x\n", bdf); - dev->req_seq = PCI_FUNC(bdf);
twsi->base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, PCI_REGION_MEM); diff --git a/drivers/mmc/octeontx_hsmmc.c b/drivers/mmc/octeontx_hsmmc.c index 38ca3736841..a91aaf31461 100644 --- a/drivers/mmc/octeontx_hsmmc.c +++ b/drivers/mmc/octeontx_hsmmc.c @@ -3731,7 +3731,6 @@ U_BOOT_DRIVER(octeontx_hsmmc_slot) = { */ static int octeontx_mmc_host_probe(struct udevice *dev) { - pci_dev_t bdf = dm_pci_get_bdf(dev); struct octeontx_mmc_host *host = dev_get_priv(dev); union mio_emm_int emm_int; u8 rev; @@ -3757,7 +3756,6 @@ static int octeontx_mmc_host_probe(struct udevice *dev) return -1; } host->node = dev->node; - dev->req_seq = PCI_FUNC(bdf); host->last_slotid = -1; if (otx_is_platform(PLATFORM_ASIM)) host->is_asim = true; diff --git a/drivers/net/octeontx/smi.c b/drivers/net/octeontx/smi.c index d4baddb7ef5..d1582b968bf 100644 --- a/drivers/net/octeontx/smi.c +++ b/drivers/net/octeontx/smi.c @@ -319,7 +319,6 @@ int octeontx_smi_probe(struct udevice *dev) pci_dev_t bdf = dm_pci_get_bdf(dev);
debug("SMI PCI device: %x\n", bdf); - dev->req_seq = PCI_FUNC(bdf); if (!dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, PCI_REGION_MEM)) { printf("Failed to map PCI region for bdf %x\n", bdf); return -1;
Use the new sequence number in all cases. Drop the logic to check for a valid number in designware_i2c, since it will always be valid.
drivers/i2c/designware_i2c_pci.c | 22 +--------------------- drivers/i2c/i2c-uclass.c | 8 +------- drivers/i2c/i2c-versatile.c | 5 ----- drivers/i2c/intel_i2c.c | 12 +----------- drivers/i2c/muxes/i2c-mux-uclass.c | 4 ++-- drivers/i2c/mvtwsi.c | 6 +++--- 6 files changed, 8 insertions(+), 49 deletions(-)
diff --git a/drivers/i2c/designware_i2c_pci.c b/drivers/i2c/designware_i2c_pci.c index 04921a304ac..9237726b475 100644 --- a/drivers/i2c/designware_i2c_pci.c +++ b/drivers/i2c/designware_i2c_pci.c @@ -90,32 +90,12 @@ static int designware_i2c_pci_probe(struct udevice *dev)
static int designware_i2c_pci_bind(struct udevice *dev) { - struct uclass *uc; char name[20]; - int ret;
- /* - * Create a unique device name for PCI type devices - * ToDo: - * Setting req_seq in the driver is probably not recommended. - * But without a DT alias the number is not configured. And - * using this driver is impossible for PCIe I2C devices. - * This can be removed, once a better (correct) way for this - * is found and implemented. - * - * TODO(sjg@chromium.org): Perhaps if uclasses had platdata this would - * be possible. We cannot use static data in drivers since they may be - * used in SPL or before relocation. - */ - ret = uclass_get(UCLASS_I2C, &uc); - if (ret) - return ret; - - dev->req_seq = uclass_find_next_free_req_seq(uc); - sprintf(name, "i2c_designware#%u", dev->req_seq); + sprintf(name, "i2c_designware#%u", dev_seq(dev)); device_set_name(dev, name);
return 0; diff --git a/drivers/i2c/i2c-uclass.c b/drivers/i2c/i2c-uclass.c index 5c4626b0442..2625bd72dc8 100644 --- a/drivers/i2c/i2c-uclass.c +++ b/drivers/i2c/i2c-uclass.c @@ -700,13 +700,7 @@ static int i2c_post_bind(struct udevice *dev) if (!priv) return -ENOMEM;
- debug("%s: %s, req_seq=%d\n", __func__, dev->name, dev->req_seq); - - /* if there is no alias ID, use the first free */ - if (dev->req_seq == -1) - dev->req_seq = ++priv->max_id; - - debug("%s: %s, new req_seq=%d\n", __func__, dev->name, dev->req_seq); + debug("%s: %s, seq=%d\n", __func__, dev->name, dev_seq(dev));
#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) ret = dm_scan_fdt_dev(dev); diff --git a/drivers/i2c/i2c-versatile.c b/drivers/i2c/i2c-versatile.c index 62831522bd3..69042d54205 100644 --- a/drivers/i2c/i2c-versatile.c +++ b/drivers/i2c/i2c-versatile.c @@ -252,11 +252,6 @@ static int versatile_i2c_probe(struct udevice *dev)
priv->base = (phys_addr_t)dev_read_addr(dev); priv->delay = 25; /* 25us * 4 = 100kHz */ - /* - * U-Boot still doesn't assign automatically - * sequence numbers to devices - */ - dev->req_seq = 1;
return 0; } diff --git a/drivers/i2c/intel_i2c.c b/drivers/i2c/intel_i2c.c index 3b79cb40cd3..66d017a2615 100644 --- a/drivers/i2c/intel_i2c.c +++ b/drivers/i2c/intel_i2c.c @@ -269,21 +269,11 @@ static int intel_i2c_probe(struct udevice *dev)
static int intel_i2c_bind(struct udevice *dev) { - static int num_cards __attribute__ ((section(".data"))); char name[20];
/* Create a unique device name for PCI type devices */ if (device_is_on_pci_bus(dev)) { - /* - * ToDo: - * Setting req_seq in the driver is probably not recommended. - * But without a DT alias the number is not configured. And - * using this driver is impossible for PCIe I2C devices. - * This can be removed, once a better (correct) way for this - * is found and implemented. - */ - dev->req_seq = num_cards; - sprintf(name, "intel_i2c#%u", num_cards++); + sprintf(name, "intel_i2c#%u", dev_seq(dev)); device_set_name(dev, name); }
diff --git a/drivers/i2c/muxes/i2c-mux-uclass.c b/drivers/i2c/muxes/i2c-mux-uclass.c index 26897554b0f..9a8cf8fb172 100644 --- a/drivers/i2c/muxes/i2c-mux-uclass.c +++ b/drivers/i2c/muxes/i2c-mux-uclass.c @@ -87,8 +87,8 @@ static int i2c_mux_post_bind(struct udevice *mux)
ret = device_bind_driver_to_node(mux, "i2c_mux_bus_drv", full_name, node, &dev); - debug(" - bind ret=%d, %s, req_seq %d\n", ret, - dev ? dev->name : NULL, dev->req_seq); + debug(" - bind ret=%d, %s, seq %d\n", ret, + dev ? dev->name : NULL, dev_seq(dev)); if (ret) return ret; } diff --git a/drivers/i2c/mvtwsi.c b/drivers/i2c/mvtwsi.c index 14c594d648b..875893af6b0 100644 --- a/drivers/i2c/mvtwsi.c +++ b/drivers/i2c/mvtwsi.c @@ -823,9 +823,9 @@ static int mvtwsi_i2c_bind(struct udevice *bus) struct mvtwsi_registers *twsi = dev_read_addr_ptr(bus);
/* Disable the hidden slave in i2c0 of these platforms */ - if ((IS_ENABLED(CONFIG_ARMADA_38X) || IS_ENABLED(CONFIG_ARCH_KIRKWOOD) - || IS_ENABLED(CONFIG_ARMADA_8K)) - && bus->req_seq == 0) + if ((IS_ENABLED(CONFIG_ARMADA_38X) || + IS_ENABLED(CONFIG_ARCH_KIRKWOOD) || + IS_ENABLED(CONFIG_ARMADA_8K)) && !dev_seq(bus)) twsi_disable_i2c_slave(twsi);
Checking for seq == -1 is effectively checking that the device is activated. The new sequence numbers are never -1 for a bound device, so update the check.
Also drop the note about valid sequence numbers so it is accurate with the new approach.
drivers/net/dwc_eth_qos.c | 2 +- net/eth-uclass.c | 7 ++----- 2 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/net/dwc_eth_qos.c b/drivers/net/dwc_eth_qos.c index db1102562f6..74893f5e8b1 100644 --- a/drivers/net/dwc_eth_qos.c +++ b/drivers/net/dwc_eth_qos.c @@ -1155,7 +1155,7 @@ static int eqos_read_rom_hwaddr(struct udevice *dev) struct eth_pdata *pdata = dev_get_platdata(dev);
#ifdef CONFIG_ARCH_IMX8M - imx_get_mac_from_fuse(dev->req_seq, pdata->enetaddr); + imx_get_mac_from_fuse(dev_seq(dev), pdata->enetaddr); #endif return !is_valid_ethaddr(pdata->enetaddr); } diff --git a/net/eth-uclass.c b/net/eth-uclass.c index e6a3cd1ee6a..5c1ee57fb59 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -126,9 +126,6 @@ struct udevice *eth_get_dev_by_name(const char *devname)
uclass_foreach_dev(it, uc) { /* - * We need the seq to be valid, so try to probe it. - * If the probe fails, the seq will not match since it will be - * -1 instead of what we are looking for. * We don't care about errors from probe here. Either they won't * match an alias or it will match a literal name and we'll pick * up the error when we try to probe again in eth_set_dev(). @@ -434,7 +431,7 @@ int eth_initialize(void)
bootstage_mark(BOOTSTAGE_ID_NET_ETH_INIT); do { - if (dev_seq(dev) != -1) { + if (device_active(dev)) { if (num_devices) printf(", ");
@@ -446,7 +443,7 @@ int eth_initialize(void)
- if (dev_seq(dev) != -1) + if (device_active(dev)) num_devices++; uclass_next_device_check(&dev); } while (dev);
Now that we know the sequence number at bind time, there is no need for special-case code in dm_pci_hose_probe_bus().
Note: the PCI_CAP_ID_EA code may need a look, but there are no test failures so I have left it as is.
Changes in v2: - Use the sequence number directly instead of max bus
drivers/pci/pci-uclass.c | 10 +--------- 1 file changed, 1 insertion(+), 9 deletions(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 99dcd342efe..abc3de84db3 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -632,7 +632,7 @@ int dm_pci_hose_probe_bus(struct udevice *bus) ®); sub_bus = reg; } else { - sub_bus = pci_get_bus_max() + 1; + sub_bus = dev_seq(bus); } debug("%s: bus = %d/%s\n", __func__, sub_bus, bus->name); dm_pciauto_prescan_setup_bridge(bus, sub_bus); @@ -644,14 +644,6 @@ int dm_pci_hose_probe_bus(struct udevice *bus) return ret; }
- if (!ea_pos) { - if (sub_bus != dev_seq(bus)) { - debug("%s: Internal error, bus '%s' got seq %d, expected %d\n", - __func__, bus->name, dev_seq(bus), sub_bus); - return -EPIPE; - } - sub_bus = pci_get_bus_max(); - } dm_pciauto_postscan_setup_bridge(bus, sub_bus);
return sub_bus;
Use the new sequence number in all cases. Drop the rockchip case because the sequence number should be 0 anyway, and assigning to the sequence number is not permitted.
drivers/spi/fsl_dspi.c | 2 +- drivers/spi/rk_spi.c | 1 - 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/spi/fsl_dspi.c b/drivers/spi/fsl_dspi.c index 71b045e04cb..67807b2e109 100644 --- a/drivers/spi/fsl_dspi.c +++ b/drivers/spi/fsl_dspi.c @@ -569,7 +569,7 @@ static int fsl_dspi_release_bus(struct udevice *dev) */ static int fsl_dspi_bind(struct udevice *bus) { - debug("%s assigned req_seq %d.\n", bus->name, bus->req_seq); + debug("%s assigned seq %d.\n", bus->name, dev_seq(bus)); return 0; }
diff --git a/drivers/spi/rk_spi.c b/drivers/spi/rk_spi.c index c5363c24190..3f71ec99b11 100644 --- a/drivers/spi/rk_spi.c +++ b/drivers/spi/rk_spi.c @@ -186,7 +186,6 @@ static int conv_of_platdata(struct udevice *dev) ret = clk_get_by_driver_info(dev, dtplat->clocks, &priv->clk); if (ret < 0) return ret; - dev->req_seq = 0;
return 0; }
This hack cannot work in the new sequence-numbering scheme. Remove it while we wait for the maintainer to complete DM conversion as noted in the existing comment.
drivers/usb/host/ehci-mx6.c | 12 +++++++++--- 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 8fa136f4eeb..d7a6ee6d0e6 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -569,10 +569,16 @@ static int ehci_usb_bind(struct udevice *dev) * With these changes in place, the ad-hoc indexing goes away and * the driver is fully converted to DT probing. */ - u32 controller_spacing = is_mx7() ? 0x10000 : 0x200; - fdt_addr_t addr = devfdt_get_addr_index(dev, 0);
- dev->req_seq = (addr - USB_BASE_ADDR) / controller_spacing; + /* + * FIXME: This cannot work with the new sequence numbers. + * Please complete the DM conversion. + * + * u32 controller_spacing = is_mx7() ? 0x10000 : 0x200; + * fdt_addr_t addr = devfdt_get_addr_index(dev, 0); + * + * dev->req_seq = (addr - USB_BASE_ADDR) / controller_spacing; + */
return 0; }
Use the new sequence number in all cases. Since all devices are assigned a number when bound, this hack should not be needed.
drivers/usb/host/ehci-vf.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/host/ehci-vf.c b/drivers/usb/host/ehci-vf.c index 92b70ba1b30..dd82669b284 100644 --- a/drivers/usb/host/ehci-vf.c +++ b/drivers/usb/host/ehci-vf.c @@ -296,16 +296,14 @@ static const struct ehci_ops vf_ehci_ops = {
static int vf_usb_bind(struct udevice *dev) { - static int num_controllers; - /* * Without this hack, if we return ENODEV for USB Controller 0, on * probe for the next controller, USB Controller 1 will be given a * sequence number of 0. This conflicts with our requirement of * sequence numbers while initialising the peripherals. + * + * FIXME: Check that this still works OK with the new sequence numbers */ - dev->req_seq = num_controllers; - num_controllers++;
return 0; }
Now that sequence numbers are set up when devices are bound, this code is not needed. Also, we should use dev_seq() instead of req_seq. Update the whole file accordingly.
Also fix up APL cpu while we are here.
arch/x86/cpu/apollolake/cpu.c | 2 +- arch/x86/cpu/mp_init.c | 23 +++++++---------------- arch/x86/include/asm/mp.h | 2 +- 3 files changed, 9 insertions(+), 18 deletions(-)
diff --git a/arch/x86/cpu/apollolake/cpu.c b/arch/x86/cpu/apollolake/cpu.c index d37f91d1ce1..328f79255f8 100644 --- a/arch/x86/cpu/apollolake/cpu.c +++ b/arch/x86/cpu/apollolake/cpu.c @@ -63,7 +63,7 @@ static int apl_get_info(const struct udevice *dev, struct cpu_info *info)
static int acpi_cpu_fill_ssdt(const struct udevice *dev, struct acpi_ctx *ctx) { - uint core_id = dev->req_seq; + uint core_id = dev_seq(dev); int cores_per_package; int ret;
diff --git a/arch/x86/cpu/mp_init.c b/arch/x86/cpu/mp_init.c index d2f1ee38cf0..5bb7abdf873 100644 --- a/arch/x86/cpu/mp_init.c +++ b/arch/x86/cpu/mp_init.c @@ -87,7 +87,7 @@ DECLARE_GLOBAL_DATA_PTR; * intel,apic-id = <2>; * }; * - * Here the 'reg' property is the CPU number and then is placed in dev->req_seq + * Here the 'reg' property is the CPU number and then is placed in dev_seq(cpu) * so that we can index into ap_callbacks[] using that. The APIC ID is different * and may not be sequential (it typically is if hyperthreading is supported). * @@ -135,7 +135,7 @@ struct mp_flight_plan { * * @func: Function to run * @arg: Argument to pass to the function - * @logical_cpu_number: Either a CPU number (i.e. dev->req_seq) or a special + * @logical_cpu_number: Either a CPU number (i.e. dev_seq(cpu) or a special * value like MP_SELECT_BSP. It tells the AP whether it should process this * callback */ @@ -152,7 +152,7 @@ static struct mp_flight_plan mp_info; * ap_callbacks - Callback mailbox array * * Array of callback, one entry for each available CPU, indexed by the CPU - * number, which is dev->req_seq. The entry for the main CPU is never used. + * number, which is dev_seq(cpu). The entry for the main CPU is never used. * When this is NULL, there is no pending work for the CPU to run. When * non-NULL it points to the mp_callback structure. This is shared between all * CPUs, so should only be written by the main CPU. @@ -562,7 +562,7 @@ static int get_bsp(struct udevice **devp, int *cpu_countp) if (cpu_countp) *cpu_countp = ret;
- return dev->req_seq >= 0 ? dev->req_seq : 0; + return dev_seq(dev) >= 0 ? dev_seq(dev) : 0; }
/** @@ -614,7 +614,7 @@ static void store_callback(struct mp_callback **slot, struct mp_callback *val) static int run_ap_work(struct mp_callback *callback, struct udevice *bsp, int num_cpus, uint expire_ms) { - int cur_cpu = bsp->req_seq; + int cur_cpu = dev_seq(bsp); int num_aps = num_cpus - 1; /* number of non-BSPs to get this message */ int cpus_accepted; ulong start; @@ -679,7 +679,7 @@ static int ap_wait_for_instruction(struct udevice *cpu, void *unused) if (!IS_ENABLED(CONFIG_SMP_AP_WORK)) return 0;
- per_cpu_slot = &ap_callbacks[cpu->req_seq]; + per_cpu_slot = &ap_callbacks[dev_seq(cpu)];
while (1) { struct mp_callback *cb = read_callback(per_cpu_slot); @@ -694,7 +694,7 @@ static int ap_wait_for_instruction(struct udevice *cpu, void *unused) mfence(); if (lcb.logical_cpu_number == MP_SELECT_ALL || lcb.logical_cpu_number == MP_SELECT_APS || - cpu->req_seq == lcb.logical_cpu_number) + dev_seq(cpu) == lcb.logical_cpu_number) lcb.func(lcb.arg);
/* Indicate we are finished */ @@ -839,7 +839,6 @@ int mp_init(void) int num_aps, num_cpus; atomic_t *ap_count; struct udevice *cpu; - struct uclass *uc; int ret;
if (IS_ENABLED(CONFIG_QFW)) { @@ -848,14 +847,6 @@ int mp_init(void) return ret; }
- /* - * Multiple APs are brought up simultaneously and they may get the same - * seq num in the uclass_resolve_seq() during device_probe(). To avoid - * this, set req_seq to the reg number in the device tree in advance. - */ - uclass_id_foreach_dev(UCLASS_CPU, cpu, uc) - cpu->req_seq = dev_read_u32_default(cpu, "reg", -1); - ret = get_bsp(&cpu, &num_cpus); if (ret < 0) { debug("Cannot init boot CPU: err=%d\n", ret); diff --git a/arch/x86/include/asm/mp.h b/arch/x86/include/asm/mp.h index 5f9b8c65643..1e4e35321de 100644 --- a/arch/x86/include/asm/mp.h +++ b/arch/x86/include/asm/mp.h @@ -114,7 +114,7 @@ typedef void (*mp_run_func)(void *arg); * Running on anything other than the boot CPU is only supported if * CONFIG_SMP_AP_WORK is enabled * - * @cpu_select: CPU to run on (its dev->req_seq value), or MP_SELECT_ALL for + * @cpu_select: CPU to run on (its dev_seq() value), or MP_SELECT_ALL for * all, or MP_SELECT_BSP for BSP * @func: Function to run * @arg: Argument to pass to the function
There is no-longer any need to check if sequence numbers are valid, since this is ensured by driver model. Drop the unwanted logic.
lib/acpi/acpi_device.c | 27 +++------------------------ test/dm/acpi.c | 6 +----- 2 files changed, 4 insertions(+), 29 deletions(-)
diff --git a/lib/acpi/acpi_device.c b/lib/acpi/acpi_device.c index c3439a59883..ba0e6bf9ea8 100644 --- a/lib/acpi/acpi_device.c +++ b/lib/acpi/acpi_device.c @@ -784,16 +784,6 @@ static const char *acpi_name_from_id(enum uclass_id id) } }
-static int acpi_check_seq(const struct udevice *dev) -{ - if (dev->req_seq == -1) { - log_warning("Device '%s' has no seq\n", dev->name); - return log_msg_ret("no seq", -ENXIO); - } - - return dev->req_seq; -} - /* If you change this function, add test cases to dm_test_acpi_get_name() */ int acpi_device_infer_name(const struct udevice *dev, char *out_name) { @@ -826,29 +816,18 @@ int acpi_device_infer_name(const struct udevice *dev, char *out_name) } } if (!name) { - int num; - switch (id) { /* DSDT: acpi/lpss.asl */ case UCLASS_SERIAL: - num = acpi_check_seq(dev); - if (num < 0) - return num; - sprintf(out_name, "URT%d", num); + sprintf(out_name, "URT%d", dev_seq(dev)); name = out_name; break; case UCLASS_I2C: - num = acpi_check_seq(dev); - if (num < 0) - return num; - sprintf(out_name, "I2C%d", num); + sprintf(out_name, "I2C%d", dev_seq(dev)); name = out_name; break; case UCLASS_SPI: - num = acpi_check_seq(dev); - if (num < 0) - return num; - sprintf(out_name, "SPI%d", num); + sprintf(out_name, "SPI%d", dev_seq(dev)); name = out_name; break; default: diff --git a/test/dm/acpi.c b/test/dm/acpi.c index f5eddac10d0..021f776845e 100644 --- a/test/dm/acpi.c +++ b/test/dm/acpi.c @@ -123,7 +123,7 @@ UCLASS_DRIVER(testacpi) = { static int dm_test_acpi_get_name(struct unit_test_state *uts) { char name[ACPI_NAME_MAX]; - struct udevice *dev, *dev2, *i2c, *spi, *serial, *timer, *sound; + struct udevice *dev, *dev2, *i2c, *spi, *timer, *sound; struct udevice *pci, *root;
/* Test getting the name from the driver */ @@ -146,10 +146,6 @@ static int dm_test_acpi_get_name(struct unit_test_state *uts) ut_assertok(acpi_get_name(spi, name)); ut_asserteq_str("SPI0", name);
- /* The uart has no sequence number, so this should fail */ - ut_assertok(uclass_first_device(UCLASS_SERIAL, &serial)); - ut_asserteq(-ENXIO, acpi_get_name(serial, name)); - /* ACPI doesn't know about the timer */ ut_assertok(uclass_first_device(UCLASS_TIMER, &timer)); ut_asserteq(-ENOENT, acpi_get_name(timer, name));
Use the dev_seq() sequence number in all cases.
drivers/gpio/imx_rgpio2p.c | 2 +- drivers/gpio/iproc_gpio.c | 2 +- drivers/gpio/mvebu_gpio.c | 2 +- drivers/gpio/mxc_gpio.c | 2 +- drivers/gpio/vybrid_gpio.c | 2 +- 5 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/gpio/imx_rgpio2p.c b/drivers/gpio/imx_rgpio2p.c index 1e876f69147..428844db0cc 100644 --- a/drivers/gpio/imx_rgpio2p.c +++ b/drivers/gpio/imx_rgpio2p.c @@ -183,7 +183,7 @@ static int imx_rgpio2p_bind(struct udevice *dev) return -ENOMEM;
plat->regs = (struct gpio_regs *)addr; - plat->bank_index = dev->req_seq; + plat->bank_index = dev_seq(dev); dev->platdata = plat;
return 0; diff --git a/drivers/gpio/iproc_gpio.c b/drivers/gpio/iproc_gpio.c index cc26a1306b6..2371d0d0d77 100644 --- a/drivers/gpio/iproc_gpio.c +++ b/drivers/gpio/iproc_gpio.c @@ -252,7 +252,7 @@ static int iproc_gpio_ofdata_to_platdata(struct udevice *dev) return ret; }
- snprintf(name, sizeof(name), "GPIO%d", dev->req_seq); + snprintf(name, sizeof(name), "GPIO%d", dev_seq(dev)); plat->name = strdup(name); if (!plat->name) return -ENOMEM; diff --git a/drivers/gpio/mvebu_gpio.c b/drivers/gpio/mvebu_gpio.c index 65eaa71c201..3639388e2f7 100644 --- a/drivers/gpio/mvebu_gpio.c +++ b/drivers/gpio/mvebu_gpio.c @@ -92,7 +92,7 @@ static int mvebu_gpio_probe(struct udevice *dev)
priv->regs = dev_read_addr_ptr(dev); uc_priv->gpio_count = MVEBU_GPIOS_PER_BANK; - priv->name[0] = 'A' + dev->req_seq; + priv->name[0] = 'A' + dev_seq(dev); uc_priv->bank_name = priv->name;
return 0; diff --git a/drivers/gpio/mxc_gpio.c b/drivers/gpio/mxc_gpio.c index 88b920a0746..28ca57149c1 100644 --- a/drivers/gpio/mxc_gpio.c +++ b/drivers/gpio/mxc_gpio.c @@ -318,7 +318,7 @@ static int mxc_gpio_ofdata_to_platdata(struct udevice *dev)
plat->regs = (struct gpio_regs *)addr; } - plat->bank_index = dev->req_seq; + plat->bank_index = dev_seq(dev);
return 0; } diff --git a/drivers/gpio/vybrid_gpio.c b/drivers/gpio/vybrid_gpio.c index 4efff5c3643..0474d2df2da 100644 --- a/drivers/gpio/vybrid_gpio.c +++ b/drivers/gpio/vybrid_gpio.c @@ -114,7 +114,7 @@ static int vybrid_gpio_odata_to_platdata(struct udevice *dev) return -EINVAL;
plat->base = base_addr; - plat->chip = dev->req_seq; + plat->chip = dev_seq(dev); plat->port_name = fdt_get_name(gd->fdt_blob, dev_of_offset(dev), NULL);
drivers/pinctrl/exynos/pinctrl-exynos.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/exynos/pinctrl-exynos.c b/drivers/pinctrl/exynos/pinctrl-exynos.c index 4cdc071d559..64d78213a86 100644 --- a/drivers/pinctrl/exynos/pinctrl-exynos.c +++ b/drivers/pinctrl/exynos/pinctrl-exynos.c @@ -133,7 +133,7 @@ int exynos_pinctrl_probe(struct udevice *dev)
priv->base = base; priv->pin_ctrl = (struct samsung_pin_ctrl *)dev_get_driver_data(dev) + - dev->req_seq; + dev_seq(dev);
return 0; }
Update this function to use the new sequence number and fix up the test that deals with this.
Changes in v2: - Adjust the tests to handle the new allocation scheme - Drop the networking changes which are no-longer needed
arch/sandbox/dts/test.dts | 2 +- drivers/core/uclass.c | 6 ++-- include/dm/device.h | 2 +- test/dm/test-fdt.c | 65 ++++++++++++++++++++++----------------- 4 files changed, 40 insertions(+), 35 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index f3b766271d3..fb838049be5 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -33,7 +33,7 @@ testfdt6 = "/e-test"; testbus3 = "/some-bus"; testfdt0 = "/some-bus/c-test@0"; - testfdt1 = "/some-bus/c-test@1"; + testfdt12 = "/some-bus/c-test@1"; testfdt3 = "/b-test"; testfdt5 = "/some-bus/c-test@5"; testfdt8 = "/a-test"; diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index cdf0674cd82..452599b87e8 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -306,8 +306,7 @@ int uclass_find_device_by_seq(enum uclass_id id, int seq_or_req_seq, uclass_foreach_dev(dev, uc) { log_debug(" - %d %d '%s'\n", dev->req_seq, dev_seq(dev), dev->name); - if ((find_req_seq ? dev->req_seq : dev_seq(dev)) == - seq_or_req_seq) { + if (dev_seq(dev) == seq_or_req_seq) { *devp = dev; log_debug(" - found\n"); return 0; @@ -692,8 +691,7 @@ int uclass_resolve_seq(struct udevice *dev) assert(dev_seq(dev) == -1); ret = uclass_find_device_by_seq(uc_drv->id, dev->req_seq, false, &dup); if (!ret) { - dm_warn("Device '%s': seq %d is in use by '%s'\n", - dev->name, dev->req_seq, dup->name); + /* Do nothing here for now */ } else if (ret == -ENODEV) { /* Our requested sequence number is available */ if (dev->req_seq != -1) diff --git a/include/dm/device.h b/include/dm/device.h index 80cd0955362..3362569dc98 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -192,7 +192,7 @@ static inline bool dev_has_of_node(struct udevice *dev)
static inline int dev_seq(const struct udevice *dev) { - return dev->seq; + return dev->sqq; }
/** diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index 673ffb4de94..bc7fbbc50ac 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -333,20 +333,28 @@ static int dm_test_fdt_uclass_seq(struct unit_test_state *uts) /* A few basic santiy tests */ ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_FDT, 3, true, &dev)); ut_asserteq_str("b-test", dev->name); + ut_asserteq(3, dev_seq(dev));
ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_FDT, 8, true, &dev)); ut_asserteq_str("a-test", dev->name); + ut_asserteq(8, dev_seq(dev));
- ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 5, - true, &dev)); + /* + * This device has no alias so gets the next value after all available + * aliases. The last alias is testfdt12 + */ + ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_FDT, 13, true, &dev)); + ut_asserteq_str("d-test", dev->name); + ut_asserteq(13, dev_seq(dev)); + + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 9, true, + &dev)); ut_asserteq_ptr(NULL, dev);
/* Test aliases */ ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 6, &dev)); ut_asserteq_str("e-test", dev->name); - - ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 7, - true, &dev)); + ut_asserteq(6, dev_seq(dev));
/* * Note that c-test nodes are not probed since it is not a top-level @@ -354,6 +362,7 @@ static int dm_test_fdt_uclass_seq(struct unit_test_state *uts) */ ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 3, &dev)); ut_asserteq_str("b-test", dev->name); + ut_asserteq(3, dev_seq(dev));
/* * d-test wants sequence number 3 also, but it can't have it because @@ -361,31 +370,29 @@ static int dm_test_fdt_uclass_seq(struct unit_test_state *uts) */ ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 2, &dev)); ut_asserteq_str("d-test", dev->name); - - /* - * d-test actually gets 9, because thats the next free one after the - * aliases. - */ - ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 9, &dev)); - ut_asserteq_str("d-test", dev->name); - - /* initially no one wants seq 10 */ - ut_asserteq(-ENODEV, uclass_get_device_by_seq(UCLASS_TEST_FDT, 10, - &dev)); - ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 0, &dev)); - ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 4, &dev)); - - /* But now that it is probed, we can find it */ - ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 10, &dev)); - ut_asserteq_str("f-test", dev->name); - - /* - * And we should still have holes in our sequence numbers, that is 2 - * and 4 should not be used. - */ - ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 2, + ut_asserteq(13, dev_seq(dev)); + + /* g-test gets the next value after f-test */ + ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 15, &dev)); + ut_asserteq_str("g-test", dev->name); + ut_asserteq(15, dev_seq(dev)); + + /* And we should still have holes in our sequence numbers */ + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 0, true, + &dev)); + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 1, true, + &dev)); + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 2, true, + &dev)); + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 4, true, + &dev)); + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 7, true, + &dev)); + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 9, true, + &dev)); + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 10, true, &dev)); - ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 4, + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 11, true, &dev));
This function is not needed anymore. Drop it.
drivers/core/device.c | 8 -------- drivers/core/uclass.c | 39 --------------------------------------- include/dm/uclass.h | 15 --------------- 3 files changed, 62 deletions(-)
diff --git a/drivers/core/device.c b/drivers/core/device.c index 89abc0021c8..37b181cf332 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -427,7 +427,6 @@ int device_probe(struct udevice *dev) { const struct driver *drv; int ret; - int seq;
if (!dev) return -EINVAL; @@ -458,13 +457,6 @@ int device_probe(struct udevice *dev) return 0; }
- seq = uclass_resolve_seq(dev); - if (seq < 0) { - ret = seq; - goto fail; - } - dev->seq = seq; - dev->flags |= DM_FLAG_ACTIVATED;
/* diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index 452599b87e8..7993ea807d4 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -680,45 +680,6 @@ int uclass_unbind_device(struct udevice *dev) } #endif
-int uclass_resolve_seq(struct udevice *dev) -{ - struct uclass *uc = dev->uclass; - struct uclass_driver *uc_drv = uc->uc_drv; - struct udevice *dup; - int seq = 0; - int ret; - - assert(dev_seq(dev) == -1); - ret = uclass_find_device_by_seq(uc_drv->id, dev->req_seq, false, &dup); - if (!ret) { - /* Do nothing here for now */ - } else if (ret == -ENODEV) { - /* Our requested sequence number is available */ - if (dev->req_seq != -1) - return dev->req_seq; - } else { - return ret; - } - - if (CONFIG_IS_ENABLED(OF_CONTROL) && CONFIG_IS_ENABLED(DM_SEQ_ALIAS) && - (uc_drv->flags & DM_UC_FLAG_SEQ_ALIAS)) { - /* - * dev_read_alias_highest_id() will return -1 if there no - * alias. Thus we can always add one. - */ - seq = dev_read_alias_highest_id(uc_drv->name) + 1; - } - - for (; seq < DM_MAX_SEQ; seq++) { - ret = uclass_find_device_by_seq(uc_drv->id, seq, false, &dup); - if (ret == -ENODEV) - break; - if (ret) - return ret; - } - return seq; -} - int uclass_pre_probe_device(struct udevice *dev) { struct uclass_driver *uc_drv; diff --git a/include/dm/uclass.h b/include/dm/uclass.h index 71883043046..dab5b5b03a9 100644 --- a/include/dm/uclass.h +++ b/include/dm/uclass.h @@ -365,21 +365,6 @@ int uclass_next_device_check(struct udevice **devp); int uclass_first_device_drvdata(enum uclass_id id, ulong driver_data, struct udevice **devp);
-/** - * uclass_resolve_seq() - Resolve a device's sequence number - * - * On entry dev->seq is -1, and dev->req_seq may be -1 (to allocate a - * sequence number automatically, or >= 0 to select a particular number. - * If the requested sequence number is in use, then this device will - * be allocated another one. - * - * Note that the device's seq value is not changed by this function. - * - * @dev: Device for which to allocate sequence number - * @return sequence number allocated, or -ve on error - */ -int uclass_resolve_seq(struct udevice *dev); - /** * uclass_id_foreach_dev() - Helper function to iteration through devices *
Now that there is only one sequence number (rather than both requested and assigned ones) we can simplify this function. Also update its caller to simplify the logic.
arch/arm/mach-k3/am6_init.c | 2 +- arch/arm/mach-k3/j721e_init.c | 2 +- arch/arm/mach-k3/sysfw-loader.c | 2 +- drivers/core/device.c | 16 ++++------ drivers/core/uclass.c | 22 +++++--------- drivers/spi/spi-uclass.c | 4 +-- drivers/usb/host/usb-uclass.c | 4 +-- include/dm/device.h | 18 ++++-------- include/dm/uclass-internal.h | 18 ++++-------- net/eth-uclass.c | 2 +- test/dm/bus.c | 16 +++++----- test/dm/test-fdt.c | 52 ++++++++++++++++----------------- 12 files changed, 64 insertions(+), 94 deletions(-)
diff --git a/arch/arm/mach-k3/am6_init.c b/arch/arm/mach-k3/am6_init.c index 603834e5078..0fed5aec59d 100644 --- a/arch/arm/mach-k3/am6_init.c +++ b/arch/arm/mach-k3/am6_init.c @@ -208,7 +208,7 @@ void board_init_f(ulong dummy) * firmware (SYSFW) image for various purposes and SYSFW depends on us * to initialize its pin settings. */ - ret = uclass_find_device_by_seq(UCLASS_SERIAL, 0, true, &dev); + ret = uclass_find_device_by_seq(UCLASS_SERIAL, 0, &dev); if (!ret) pinctrl_select_state(dev, "default");
diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index a36e4ed603b..0201690f93c 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -167,7 +167,7 @@ void board_init_f(ulong dummy) * firmware (SYSFW) image for various purposes and SYSFW depends on us * to initialize its pin settings. */ - ret = uclass_find_device_by_seq(UCLASS_SERIAL, 0, true, &dev); + ret = uclass_find_device_by_seq(UCLASS_SERIAL, 0, &dev); if (!ret) pinctrl_select_state(dev, "default");
diff --git a/arch/arm/mach-k3/sysfw-loader.c b/arch/arm/mach-k3/sysfw-loader.c index 78c158c63f7..708d9c8508e 100644 --- a/arch/arm/mach-k3/sysfw-loader.c +++ b/arch/arm/mach-k3/sysfw-loader.c @@ -223,7 +223,7 @@ static void *k3_sysfw_get_spi_addr(void) int ret;
ret = uclass_find_device_by_seq(UCLASS_SPI, CONFIG_SF_DEFAULT_BUS, - true, &dev); + &dev); if (ret) return NULL;
diff --git a/drivers/core/device.c b/drivers/core/device.c index 37b181cf332..fe4a08d1eb6 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -653,15 +653,15 @@ int device_get_child_count(const struct udevice *parent) return count; }
-int device_find_child_by_seq(const struct udevice *parent, int seq_or_req_seq, - bool find_req_seq, struct udevice **devp) +int device_find_child_by_seq(const struct udevice *parent, int seq, + struct udevice **devp) { struct udevice *dev;
*devp = NULL;
list_for_each_entry(dev, &parent->child_head, sibling_node) { - if (dev->sqq == seq_or_req_seq) { + if (dev->sqq == seq) { *devp = dev; return 0; } @@ -677,14 +677,8 @@ int device_get_child_by_seq(const struct udevice *parent, int seq, int ret;
*devp = NULL; - ret = device_find_child_by_seq(parent, seq, false, &dev); - if (ret == -ENODEV) { - /* - * We didn't find it in probed devices. See if there is one - * that will request this seq if probed. - */ - ret = device_find_child_by_seq(parent, seq, true, &dev); - } + ret = device_find_child_by_seq(parent, seq, &dev); + return device_get_device_tail(dev, ret, devp); }
diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index 7993ea807d4..b981042f7e6 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -288,25 +288,23 @@ int uclass_find_next_free_req_seq(struct uclass *uc) return max + 1; }
-int uclass_find_device_by_seq(enum uclass_id id, int seq_or_req_seq, - bool find_req_seq, struct udevice **devp) +int uclass_find_device_by_seq(enum uclass_id id, int seq, struct udevice **devp) { struct uclass *uc; struct udevice *dev; int ret;
*devp = NULL; - log_debug("%d %d\n", find_req_seq, seq_or_req_seq); - if (seq_or_req_seq == -1) + log_debug("%d\n", seq); + if (seq == -1) return -ENODEV; ret = uclass_get(id, &uc); if (ret) return ret;
uclass_foreach_dev(dev, uc) { - log_debug(" - %d %d '%s'\n", - dev->req_seq, dev_seq(dev), dev->name); - if (dev_seq(dev) == seq_or_req_seq) { + log_debug(" - %d '%s'\n", dev->sqq, dev->name); + if (dev->sqq == seq) { *devp = dev; log_debug(" - found\n"); return 0; @@ -466,14 +464,8 @@ int uclass_get_device_by_seq(enum uclass_id id, int seq, struct udevice **devp) int ret;
*devp = NULL; - ret = uclass_find_device_by_seq(id, seq, false, &dev); - if (ret == -ENODEV) { - /* - * We didn't find it in probed devices. See if there is one - * that will request this seq if probed. - */ - ret = uclass_find_device_by_seq(id, seq, true, &dev); - } + ret = uclass_find_device_by_seq(id, seq, &dev); + return uclass_get_device_tail(dev, ret, devp); }
diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index 55a8eed8901..08f165837d2 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -273,7 +273,7 @@ int spi_cs_is_valid(unsigned int busnum, unsigned int cs) struct udevice *bus; int ret;
- ret = uclass_find_device_by_seq(UCLASS_SPI, busnum, false, &bus); + ret = uclass_find_device_by_seq(UCLASS_SPI, busnum, &bus); if (ret) { debug("%s: No bus %d\n", __func__, busnum); return ret; @@ -302,7 +302,7 @@ int spi_find_bus_and_cs(int busnum, int cs, struct udevice **busp, struct udevice *bus, *dev; int ret;
- ret = uclass_find_device_by_seq(UCLASS_SPI, busnum, false, &bus); + ret = uclass_find_device_by_seq(UCLASS_SPI, busnum, &bus); if (ret) { debug("%s: No bus %d\n", __func__, busnum); return ret; diff --git a/drivers/usb/host/usb-uclass.c b/drivers/usb/host/usb-uclass.c index 453c2bbb0b6..de8a244625e 100644 --- a/drivers/usb/host/usb-uclass.c +++ b/drivers/usb/host/usb-uclass.c @@ -394,7 +394,7 @@ int usb_setup_ehci_gadget(struct ehci_ctrl **ctlrp) int ret;
/* Find the old device and remove it */ - ret = uclass_find_device_by_seq(UCLASS_USB, 0, true, &dev); + ret = uclass_find_device_by_seq(UCLASS_USB, 0, &dev); if (ret) return ret; ret = device_remove(dev, DM_REMOVE_NORMAL); @@ -417,7 +417,7 @@ int usb_remove_ehci_gadget(struct ehci_ctrl **ctlrp) int ret;
/* Find the old device and remove it */ - ret = uclass_find_device_by_seq(UCLASS_USB, 0, true, &dev); + ret = uclass_find_device_by_seq(UCLASS_USB, 0, &dev); if (ret) return ret; ret = device_remove(dev, DM_REMOVE_NORMAL); diff --git a/include/dm/device.h b/include/dm/device.h index 3362569dc98..073c5438fc2 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -452,24 +452,16 @@ int device_get_child_count(const struct udevice *parent); /** * device_find_child_by_seq() - Find a child device based on a sequence * - * This searches for a device with the given seq or req_seq. - * - * For seq, if an active device has this sequence it will be returned. - * If there is no such device then this will return -ENODEV. - * - * For req_seq, if a device (whether activated or not) has this req_seq - * value, that device will be returned. This is a strong indication that - * the device will receive that sequence when activated. + * This searches for a device with the given seq. * * @parent: Parent device - * @seq_or_req_seq: Sequence number to find (0=first) - * @find_req_seq: true to find req_seq, false to find seq + * @seq: Sequence number to find (0=first) * @devp: Returns pointer to device (there is only one per for each seq). * Set to NULL if none is found - * @return 0 if OK, -ve on error + * @return 0 if OK, -ENODEV if not found */ -int device_find_child_by_seq(const struct udevice *parent, int seq_or_req_seq, - bool find_req_seq, struct udevice **devp); +int device_find_child_by_seq(const struct udevice *parent, int seq, + struct udevice **devp);
/** * device_get_child_by_seq() - Get a child device based on a sequence diff --git a/include/dm/uclass-internal.h b/include/dm/uclass-internal.h index 2c21871e0fd..9c23d3f223e 100644 --- a/include/dm/uclass-internal.h +++ b/include/dm/uclass-internal.h @@ -103,25 +103,17 @@ int uclass_find_device_by_name(enum uclass_id id, const char *name, /** * uclass_find_device_by_seq() - Find uclass device based on ID and sequence * - * This searches for a device with the given seq or req_seq. - * - * For seq, if an active device has this sequence it will be returned. - * If there is no such device then this will return -ENODEV. - * - * For req_seq, if a device (whether activated or not) has this req_seq - * value, that device will be returned. This is a strong indication that - * the device will receive that sequence when activated. + * This searches for a device with the given seq. * * The device is NOT probed, it is merely returned. * * @id: ID to look up - * @seq_or_req_seq: Sequence number to find (0=first) - * @find_req_seq: true to find req_seq, false to find seq + * @seq: Sequence number to find (0=first) * @devp: Returns pointer to device (there is only one per for each seq) - * @return 0 if OK, -ve on error + * @return 0 if OK, -ENODEV if not found */ -int uclass_find_device_by_seq(enum uclass_id id, int seq_or_req_seq, - bool find_req_seq, struct udevice **devp); +int uclass_find_device_by_seq(enum uclass_id id, int seq, + struct udevice **devp);
/** * uclass_find_device_by_of_offset() - Find a uclass device by device tree node diff --git a/net/eth-uclass.c b/net/eth-uclass.c index 5c1ee57fb59..4b4aaecf366 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -232,7 +232,7 @@ static int on_ethaddr(const char *name, const char *value, enum env_op op, /* look for an index after "eth" */ index = simple_strtoul(name + 3, NULL, 10);
- retval = uclass_find_device_by_seq(UCLASS_ETH, index, false, &dev); + retval = uclass_find_device_by_seq(UCLASS_ETH, index, &dev); if (!retval) { struct eth_pdata *pdata = dev->platdata; switch (op) { diff --git a/test/dm/bus.c b/test/dm/bus.c index e1fa67d91e1..27dd066350e 100644 --- a/test/dm/bus.c +++ b/test/dm/bus.c @@ -157,17 +157,17 @@ static int dm_test_bus_children_funcs(struct unit_test_state *uts) ut_asserteq_str("c-test@5", dev->name);
/* Device with sequence number 0 should be accessible */ - ut_asserteq(-ENODEV, device_find_child_by_seq(bus, -1, true, &dev)); - ut_assertok(device_find_child_by_seq(bus, 0, true, &dev)); + ut_asserteq(-ENODEV, device_find_child_by_seq(bus, -1, &dev)); + ut_assertok(device_find_child_by_seq(bus, 0, &dev)); ut_assert(!(dev->flags & DM_FLAG_ACTIVATED)); - ut_asserteq(0, device_find_child_by_seq(bus, 0, false, &dev)); + ut_asserteq(0, device_find_child_by_seq(bus, 0, &dev)); ut_assertok(device_get_child_by_seq(bus, 0, &dev)); ut_assert(dev->flags & DM_FLAG_ACTIVATED); - ut_asserteq(0, device_find_child_by_seq(bus, 0, false, &dev)); + ut_asserteq(0, device_find_child_by_seq(bus, 0, &dev));
/* There is no device with sequence number 2 */ - ut_asserteq(-ENODEV, device_find_child_by_seq(bus, 2, false, &dev)); - ut_asserteq(-ENODEV, device_find_child_by_seq(bus, 2, true, &dev)); + ut_asserteq(-ENODEV, device_find_child_by_seq(bus, 2, &dev)); + ut_asserteq(-ENODEV, device_find_child_by_seq(bus, 2, &dev)); ut_asserteq(-ENODEV, device_get_child_by_seq(bus, 2, &dev));
/* Looking for something that is not a child */ @@ -221,7 +221,7 @@ static int dm_test_bus_children_iterators(struct unit_test_state *uts) ut_asserteq_ptr(dev, NULL);
/* Move to the next child without using device_find_first_child() */ - ut_assertok(device_find_child_by_seq(bus, 5, true, &dev)); + ut_assertok(device_find_child_by_seq(bus, 5, &dev)); ut_asserteq_str("c-test@5", dev->name); ut_assertok(device_find_next_child(&dev)); ut_asserteq_str("c-test@0", dev->name); @@ -246,7 +246,7 @@ static int test_bus_parent_data(struct unit_test_state *uts) ut_assertok(uclass_get_device(UCLASS_TEST_BUS, 0, &bus));
/* Check that parent data is allocated */ - ut_assertok(device_find_child_by_seq(bus, 0, true, &dev)); + ut_assertok(device_find_child_by_seq(bus, 0, &dev)); ut_asserteq_ptr(NULL, dev_get_parent_priv(dev)); ut_assertok(device_get_child_by_seq(bus, 0, &dev)); parent_data = dev_get_parent_priv(dev); diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index bc7fbbc50ac..1b364ca2943 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -331,11 +331,11 @@ static int dm_test_fdt_uclass_seq(struct unit_test_state *uts) struct udevice *dev;
/* A few basic santiy tests */ - ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_FDT, 3, true, &dev)); + ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_FDT, 3, &dev)); ut_asserteq_str("b-test", dev->name); ut_asserteq(3, dev_seq(dev));
- ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_FDT, 8, true, &dev)); + ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_FDT, 8, &dev)); ut_asserteq_str("a-test", dev->name); ut_asserteq(8, dev_seq(dev));
@@ -343,11 +343,11 @@ static int dm_test_fdt_uclass_seq(struct unit_test_state *uts) * This device has no alias so gets the next value after all available * aliases. The last alias is testfdt12 */ - ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_FDT, 13, true, &dev)); + ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_FDT, 13, &dev)); ut_asserteq_str("d-test", dev->name); ut_asserteq(13, dev_seq(dev));
- ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 9, true, + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 9, &dev)); ut_asserteq_ptr(NULL, dev);
@@ -378,22 +378,22 @@ static int dm_test_fdt_uclass_seq(struct unit_test_state *uts) ut_asserteq(15, dev_seq(dev));
/* And we should still have holes in our sequence numbers */ - ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 0, true, + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 0, &dev)); - ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 1, true, + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 1, &dev)); - ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 2, true, + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 2, &dev)); - ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 4, true, + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 4, &dev)); - ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 7, true, + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 7, &dev)); - ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 9, true, + ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 9, &dev)); ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 10, - true, &dev)); + &dev)); ut_asserteq(-ENODEV, uclass_find_device_by_seq(UCLASS_TEST_FDT, 11, - true, &dev)); + &dev));
return 0; } @@ -594,30 +594,30 @@ static int dm_test_fdt_translation(struct unit_test_state *uts) fdt32_t dma_addr[2];
/* Some simple translations */ - ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 0, true, &dev)); + ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 0, &dev)); ut_asserteq_str("dev@0,0", dev->name); ut_asserteq(0x8000, dev_read_addr(dev));
- ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 1, true, &dev)); + ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 1, &dev)); ut_asserteq_str("dev@1,100", dev->name); ut_asserteq(0x9000, dev_read_addr(dev));
- ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 2, true, &dev)); + ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 2, &dev)); ut_asserteq_str("dev@2,200", dev->name); ut_asserteq(0xA000, dev_read_addr(dev));
/* No translation for busses with #size-cells == 0 */ - ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 3, true, &dev)); + ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 3, &dev)); ut_asserteq_str("dev@42", dev->name); ut_asserteq(0x42, dev_read_addr(dev));
/* dma address translation */ - ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 0, true, &dev)); + ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 0, &dev)); dma_addr[0] = cpu_to_be32(0); dma_addr[1] = cpu_to_be32(0); ut_asserteq(0x10000000, dev_translate_dma_address(dev, dma_addr));
- ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 1, true, &dev)); + ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 1, &dev)); dma_addr[0] = cpu_to_be32(1); dma_addr[1] = cpu_to_be32(0x100); ut_asserteq(0x20000000, dev_translate_dma_address(dev, dma_addr)); @@ -635,7 +635,7 @@ static int dm_test_fdt_get_addr_ptr_flat(struct unit_test_state *uts) ut_assertok(uclass_first_device_err(UCLASS_GPIO, &gpio)); ut_assertnull(devfdt_get_addr_ptr(gpio));
- ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 0, true, &dev)); + ut_assertok(uclass_find_device_by_seq(UCLASS_TEST_DUMMY, 0, &dev)); ptr = devfdt_get_addr_ptr(dev); ut_asserteq_ptr((void *)0x8000, ptr);
@@ -650,7 +650,7 @@ static int dm_test_fdt_remap_addr_flat(struct unit_test_state *uts) fdt_addr_t addr; void *paddr;
addr = devfdt_get_addr(dev); ut_asserteq(0x8000, addr); @@ -671,7 +671,7 @@ static int dm_test_fdt_remap_addr_index_flat(struct unit_test_state *uts) fdt_size_t size; void *paddr;
addr = devfdt_get_addr_size_index(dev, 0, &size); ut_asserteq(0x8000, addr); @@ -693,7 +693,7 @@ static int dm_test_fdt_remap_addr_name_flat(struct unit_test_state *uts) fdt_size_t size; void *paddr;
addr = devfdt_get_addr_size_name(dev, "sandbox-dummy-0", &size); ut_asserteq(0x8000, addr); @@ -714,7 +714,7 @@ static int dm_test_fdt_remap_addr_live(struct unit_test_state *uts) fdt_addr_t addr; void *paddr;
addr = dev_read_addr(dev); ut_asserteq(0x8000, addr); @@ -735,7 +735,7 @@ static int dm_test_fdt_remap_addr_index_live(struct unit_test_state *uts) fdt_size_t size; void *paddr;
addr = dev_read_addr_size_index(dev, 0, &size); ut_asserteq(0x8000, addr); @@ -757,7 +757,7 @@ static int dm_test_fdt_remap_addr_name_live(struct unit_test_state *uts) fdt_size_t size; void *paddr;
addr = dev_read_addr_size_name(dev, "sandbox-dummy-0", &size); ut_asserteq(0x8000, addr); @@ -792,7 +792,7 @@ static int dm_test_fdt_livetree_writing(struct unit_test_state *uts)
device_bind_driver_to_node(dm_root(), "usb_sandbox", "usb@2", node, &dev); - ut_assertok(uclass_find_device_by_seq(UCLASS_USB, 2, true, &dev)); + ut_assertok(uclass_find_device_by_seq(UCLASS_USB, 2, &dev));
/* Test string property setting */
This function current deals with req_seq which is deprecated. Update it to use the new sequence numbers, putting them above existing aliases. Rename the function to make this clear.
Changes in v2: - Update for new logic - Adjust commit message - Drop pointless check for max == -1
drivers/core/device.c | 8 ++------ drivers/core/uclass.c | 19 +++++++++++++------ include/dm/uclass-internal.h | 17 ++++++++++------- 3 files changed, 25 insertions(+), 19 deletions(-)
diff --git a/drivers/core/device.c b/drivers/core/device.c index fe4a08d1eb6..11ae89cf4ad 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -93,18 +93,14 @@ static int device_bind_common(struct udevice *parent, const struct driver *drv, } if (CONFIG_IS_ENABLED(OF_PRIOR_STAGE)) { if (dev->req_seq == -1) { - auto_seq = true; dev->req_seq = - uclass_find_next_free_req_seq( - uc); + uclass_find_next_free_seq(uc); } } - } else { - dev->req_seq = uclass_find_next_free_req_seq(uc); } } if (auto_seq) - dev->sqq = uclass_find_next_free_req_seq(uc); + dev->sqq = uclass_find_next_free_seq(uc);
if (drv->platdata_auto_alloc_size) { bool alloc = !platdata; diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index b981042f7e6..92edac55ca6 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -272,18 +272,25 @@ int uclass_find_device_by_name(enum uclass_id id, const char *name, return -ENODEV; }
-int uclass_find_next_free_req_seq(struct uclass *uc) +int uclass_find_next_free_seq(struct uclass *uc) { struct udevice *dev; int max = -1;
+ /* If using aliases, start with the highest alias value */ + if (CONFIG_IS_ENABLED(DM_SEQ_ALIAS) && + (uc->uc_drv->flags & DM_UC_FLAG_SEQ_ALIAS)) + max = dev_read_alias_highest_id(uc->uc_drv->name); + + /* Avoid conflict with existing devices */ list_for_each_entry(dev, &uc->dev_head, uclass_node) { - if ((dev->req_seq != -1) && (dev->req_seq > max)) - max = dev->req_seq; + if (dev->sqq > max) + max = dev->sqq; } - - if (max == -1) - return 0; + /* + * At this point, max will be -1 if there are no existing aliases or + * devices + */
return max + 1; } diff --git a/include/dm/uclass-internal.h b/include/dm/uclass-internal.h index 9c23d3f223e..3e052f95d32 100644 --- a/include/dm/uclass-internal.h +++ b/include/dm/uclass-internal.h @@ -12,17 +12,20 @@ #include <dm/ofnode.h>
/** - * uclass_find_next_free_req_seq() - Get the next free req_seq number + * uclass_find_next_free_seq() - Get the next free sequence number * - * This returns the next free req_seq number. This is useful only if - * OF_CONTROL is not used. The next free req_seq number is simply the - * maximum req_seq of the uclass + 1. - * This allows assiging req_seq number in the binding order. + * This returns the next free sequence number. This is useful only if + * OF_CONTROL is not used. The next free sequence number is simply the + * maximum sequence number used by all devices in the uclass + 1. The value + * returned is always greater than the largest alias, if DM_SEQ_ALIAS is enabled + * and the uclass has the DM_UC_FLAG_SEQ_ALIAS flag. + * + * This allows assigning the sequence number in the binding order. * * @uc: uclass to check - * @return The next free req_seq number + * @return The next free sequence number */ -int uclass_find_next_free_req_seq(struct uclass *uc); +int uclass_find_next_free_seq(struct uclass *uc);
/** * uclass_get_device_tail() - handle the end of a get_device call
Several commands use sequence numbers. Update them to use the new ones.
(no changes since v1)
cmd/axi.c | 4 ++-- cmd/i2c.c | 2 +- cmd/osd.c | 4 ++-- drivers/core/dump.c | 4 ++-- 4 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/cmd/axi.c b/cmd/axi.c index f7e206c04a7..c72197ee82b 100644 --- a/cmd/axi.c +++ b/cmd/axi.c @@ -33,9 +33,9 @@ static void show_bus(struct udevice *bus) { struct udevice *dev;
- printf("Bus %d:\t%s", bus->req_seq, bus->name); + printf("Bus %d:\t%s", dev_seq(bus), bus->name); if (device_active(bus)) - printf(" (active %d)", dev_seq(bus)); + printf(" (active)"); printf("\n"); for (device_find_first_child(bus, &dev); dev; diff --git a/cmd/i2c.c b/cmd/i2c.c index f97d437af47..c5cace6a9c6 100644 --- a/cmd/i2c.c +++ b/cmd/i2c.c @@ -1700,7 +1700,7 @@ static void show_bus(struct udevice *bus) { struct udevice *dev;
- printf("Bus %d:\t%s", bus->req_seq, bus->name); + printf("Bus %d:\t%s", dev_seq(bus), bus->name); if (device_active(bus)) printf(" (active %d)", dev_seq(bus)); printf("\n"); diff --git a/cmd/osd.c b/cmd/osd.c index 9b8fd5c921e..703d640b04e 100644 --- a/cmd/osd.c +++ b/cmd/osd.c @@ -75,9 +75,9 @@ static int osd_get_osd_cur(struct udevice **osdp) */ static void show_osd(struct udevice *osd) { - printf("OSD %d:\t%s", osd->req_seq, osd->name); + printf("OSD %d:\t%s", dev_seq(osd), osd->name); if (device_active(osd)) - printf(" (active %d)", dev_seq(osd)); + printf(" (active)"); printf("\n"); }
diff --git a/drivers/core/dump.c b/drivers/core/dump.c index 9f440366734..83456d7e6e8 100644 --- a/drivers/core/dump.c +++ b/drivers/core/dump.c @@ -67,8 +67,8 @@ static void dm_display_line(struct udevice *dev, int index) printf("%-3i %c %s @ %08lx", index, dev->flags & DM_FLAG_ACTIVATED ? '*' : ' ', dev->name, (ulong)map_to_sysmem(dev)); - if (dev_seq(dev) != -1 || dev->req_seq != -1) - printf(", seq %d, (req %d)", dev_seq(dev), dev->req_seq); + if (dev->sqq != -1) + printf(", seq %d", dev_seq(dev)); puts("\n"); }
Now that migration to the new sequence numbers is complete, drop the old fields. Add a test that covers the new behaviour.
Also drop the check for OF_PRIOR_STAGE since we always assign sequence numbers now.
Changes in v2: - Adjust the tests to handle the new allocation scheme - Simplify the logic so auto_seq is positive
drivers/core/device-remove.c | 1 - drivers/core/device.c | 17 ++------------- include/dm/device.h | 9 +------- test/dm/test-fdt.c | 40 ++++++++++++++++++++++++++++++++++++ 4 files changed, 43 insertions(+), 24 deletions(-)
diff --git a/drivers/core/device-remove.c b/drivers/core/device-remove.c index 0924a575f53..79e888e1eb7 100644 --- a/drivers/core/device-remove.c +++ b/drivers/core/device-remove.c @@ -207,7 +207,6 @@ int device_remove(struct udevice *dev, uint flags) if (flags_remove(flags, drv->flags)) { device_free(dev);
- dev->seq = -1; dev->flags &= ~DM_FLAG_ACTIVATED; }
diff --git a/drivers/core/device.c b/drivers/core/device.c index 11ae89cf4ad..cbec657c0ec 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -72,30 +72,18 @@ static int device_bind_common(struct udevice *parent, const struct driver *drv, dev->driver = drv; dev->uclass = uc;
- dev->seq = -1; - dev->req_seq = -1; dev->sqq = -1; if (CONFIG_IS_ENABLED(DM_SEQ_ALIAS) && (uc->uc_drv->flags & DM_UC_FLAG_SEQ_ALIAS)) { /* * Some devices, such as a SPI bus, I2C bus and serial ports * are numbered using aliases. - * - * This is just a 'requested' sequence, and will be - * resolved (and ->seq updated) when the device is probed. */ if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) { if (uc->uc_drv->name && ofnode_valid(node)) { - dev_read_alias_seq(dev, &dev->sqq); - dev_read_alias_seq(dev, &dev->req_seq); - auto_seq = false; - } - if (CONFIG_IS_ENABLED(OF_PRIOR_STAGE)) { - if (dev->req_seq == -1) { - dev->req_seq = - uclass_find_next_free_seq(uc); - } + if (!dev_read_alias_seq(dev, &dev->sqq)) + auto_seq = false; } } } @@ -515,7 +503,6 @@ fail_uclass: fail: dev->flags &= ~DM_FLAG_ACTIVATED;
- dev->seq = -1; device_free(dev);
return ret; diff --git a/include/dm/device.h b/include/dm/device.h index 073c5438fc2..b95aa346820 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -131,16 +131,11 @@ enum { * @child_head: List of children of this device * @sibling_node: Next device in list of all devices * @flags: Flags for this device DM_FLAG_... - * @sqq: Allocated sequence number for this device (-1 = none). This is set up + * @seq: Allocated sequence number for this device (-1 = none). This is set up * when the device is bound and is unique within the device's uclass. If the * device has an alias in the devicetree then that is used to set the sequence * number. Otherwise, the next available number is used. Sequence numbers are * used by certain commands that need device to be numbered (e.g. 'mmc dev') - * - * The following two fields are deprecated: - * @req_seq: Requested sequence number for this device (-1 = any) - * @seq: Allocated sequence number for this device (-1 = none). This is set up - * when the device is probed and will be unique within the device's uclass. * @devres_head: List of memory allocations associated with this device. * When CONFIG_DEVRES is enabled, devm_kmalloc() and friends will * add to this list. Memory so-allocated will be freed @@ -164,8 +159,6 @@ struct udevice { struct list_head sibling_node; uint32_t flags; int sqq; - int req_seq; - int seq; #ifdef CONFIG_DEVRES struct list_head devres_head; #endif diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index 1b364ca2943..cb8655fda52 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -399,6 +399,46 @@ static int dm_test_fdt_uclass_seq(struct unit_test_state *uts) } DM_TEST(dm_test_fdt_uclass_seq, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
+/* More tests for sequence numbers */ +static int dm_test_fdt_uclass_seq_more(struct unit_test_state *uts) +{ + struct udevice *dev; + ofnode node; + + /* Check creating a device with an alias */ + node = ofnode_path("/some-bus/c-test@1"); + ut_assertok(device_bind(dm_root(), DM_GET_DRIVER(testfdt_drv), + "c-test@1", NULL, node, &dev)); + ut_asserteq(12, dev_seq(dev)); + ut_assertok(uclass_get_device_by_seq(UCLASS_TEST_FDT, 12, &dev)); + ut_asserteq_str("c-test@1", dev->name); + + /* + * Now bind a device without an alias. It should not get the next + * sequence number after all aliases, and existing bound devices. The + * last alias is 12, so we have: + * + * 13 d-test + * 14 f-test + * 15 g-test + * 16 h-test + * 17 another-test + * 18 chosen-test + * + * So next available is 19 + */ + ut_assertok(device_bind(dm_root(), DM_GET_DRIVER(testfdt_drv), + "fred", NULL, ofnode_null(), &dev)); + ut_asserteq(19, dev_seq(dev)); + + ut_assertok(device_bind(dm_root(), DM_GET_DRIVER(testfdt_drv), + "fred2", NULL, ofnode_null(), &dev)); + ut_asserteq(20, dev_seq(dev)); + + return 0; +} +DM_TEST(dm_test_fdt_uclass_seq_more, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + /* Test that we can find a device by device tree offset */ static int dm_test_fdt_offset(struct unit_test_state *uts) {
Update the driver model documention to describe how sequence numbers now work.
Changes in v2: - Update the docs to indicate all devices get a sequence number - Update the docs to explain how aliases reserve sequence numbers - Drop commit changing efi_uc_destroy()
doc/driver-model/design.rst | 54 ++++++++++++++++++++----------------- 1 file changed, 29 insertions(+), 25 deletions(-)
diff --git a/doc/driver-model/design.rst b/doc/driver-model/design.rst index 96525b6ccc5..93afca58b1b 100644 --- a/doc/driver-model/design.rst +++ b/doc/driver-model/design.rst @@ -515,11 +515,23 @@ cases. While it might be tempting to automatically renumber the devices where there are gaps in the sequence, this can lead to confusion and is not the way that U-Boot works.
-Each device can request a sequence number. If none is required then the -device will be automatically allocated the next available sequence number. +Where a device gets its sequence number is controlled by the DM_SEQ_ALIAS +Kconfig option, which can have a different value in U-Boot proper and SPL. +If this option is not set, aliases are ignored.
-To specify the sequence number in the device tree an alias is typically -used. Make sure that the uclass has the DM_UC_FLAG_SEQ_ALIAS flag set. +Even if CONFIG_DM_SEQ_ALIAS is enabled, the uclass must still have the +DM_UC_FLAG_SEQ_ALIAS flag set, for its devices to be sequenced by aliases. + +With those options set, devices with an alias (e.g. "serial2") will get that +sequence number (e.g. 2). Other devices get the next available number after all +aliases and all existing numbers. This means that if there is just a single +alias "serial2", unaliased serial devices will be assigned 3 or more, with 0 and +1 being unused. + +If CONFIG_DM_SEQ_ALIAS or DM_UC_FLAG_SEQ_ALIAS are not set, all devices will get +sequence numbers in a simple ordering starting from 0. To find the next number +to allocate, driver model scans through to find the maximum existing number, +then uses the next one. It does not attempt to fill in gaps.
.. code-block:: none
@@ -546,12 +558,11 @@ More commonly you can use node references, which expand to the full path: The alias resolves to the same string in this case, but this version is easier to read.
-Device sequence numbers are resolved when a device is probed. Before then -the sequence number is only a request which may or may not be honoured, -depending on what other devices have been probed. However the numbering is -entirely under the control of the board author so a conflict is generally -an error. +Device sequence numbers are resolved when a device is bound and the number does +not change for the life of the device.
+Note that changing the sequence number for a device (e.g. in a driver) is not +permitted. If it is felt to be necessary, ask on the mailing list.
Bus Drivers ----------- @@ -673,6 +684,10 @@ platdata will be NULL, but of_offset will be the offset of the device tree node that caused the device to be created. The uclass is set correctly for the device.
+The device's sequence number is assigned, either the requested one or the next +available one (after all aliases are processed) if nothing particular is +requested. + The device's bind() method is permitted to perform simple actions, but should not scan the device tree node, not initialise hardware, nor set up structures or allocate memory. All of these tasks should be left for @@ -735,7 +750,7 @@ The steps are: that U-Boot will cache platform data for devices which are regularly de/activated).
- 5. The device is marked 'platdata valid'. + 6. The device is marked 'platdata valid'.
Note that ofdata reading is always done (for a child and all its parents) before probing starts. Thus devices go through two distinct states when @@ -780,11 +795,7 @@ as above and then following these steps (see device_probe()): This means (for example) that an I2C driver will require that its bus be activated.
- 2. The device's sequence number is assigned, either the requested one - (assuming no conflicts) or the next available one if there is a conflict - or nothing particular is requested. - - 4. The device's probe() method is called. This should do anything that + 2. The device's probe() method is called. This should do anything that is required by the device to get it going. This could include checking that the hardware is actually present, setting up clocks for the hardware and setting up hardware registers to initial values. The code @@ -799,9 +810,9 @@ as above and then following these steps (see device_probe()): allocate the priv space here yourself. The same applies also to platdata_auto_alloc_size. Remember to free them in the remove() method.
- 5. The device is marked 'activated' + 3. The device is marked 'activated'
- 10. The uclass's post_probe() method is called, if one exists. This may + 4. The uclass's post_probe() method is called, if one exists. This may cause the uclass to do some housekeeping to record the device as activated and 'known' by the uclass.
@@ -850,14 +861,7 @@ remove it. This performs the probe steps in reverse: or preferably ofdata_to_platdata()) and the deallocation in remove() are the responsibility of the driver author.
- 5. The device sequence number is set to -1, meaning that it no longer - has an allocated sequence. If the device is later reactivated and that - sequence number is still free, it may well receive the name sequence - number again. But from this point, the sequence number previously used - by this device will no longer exist (think of SPI bus 2 being removed - and bus 2 is no longer available for use). - - 6. The device is marked inactive. Note that it is still bound, so the + 5. The device is marked inactive. Note that it is still bound, so the device structure itself is not freed at this point. Should the device be activated again, then the cycle starts again at step 2 above.
Hi Simon,
Am 2020-12-11 02:31, schrieb Simon Glass:
At present each device has two sequence numbers, with 'req_seq' being set up at bind time and 'seq' at probe time. The idea is that devices can 'request' a sequence number and then the conflicts are resolved when the device is probed.
This makes things complicated in a few cases, since we don't really know (at bind time) what the sequence number will end up being. We want to honour the bind-time requests if at all possible, but in fact the only source of these at present is the devicetree aliases.
Apart from the obvious need for sequence numbers to supports U-Boot's numbering on devices on the command line, the current scheme was designed to:
- avoid calculating the sequence number until it is needed, to save execution time
- allow multiple devices to obtain a particular sequence number as they are probed and removed
- retain a record of the 'requested' sequence number even if it turns
out that a device could not get it (to allow debugging and retrying)
After some years using the current scheme it seems on balance that these goals don't have as much merit as first thought. The first point would be persuasive except that we end up reading the devicetree aliases at bind-time anyway. So the work of resolving the sequence numbers during probing is not that great. The second point hasn't really been an issue, as there is typically no contention for sequence numbers (boards tend to allocate them statically in the devicetree). Re the third point, we can often figure out what was requested by looking at aliases, and in the cases where we can't, it doesn't seem to matter much.
Since we have the devicetree available at bind time, we may as well just use it, in the hope that the required processing will turn out to be useful later (i.e. the device actually gets used). In addition, it is simpler to use a single sequence number, since it avoids confusion and some extra code.
This series moves U-Boot to use a single, bind-time sequence number. All uclasses assign sequence numbers to their devices, so that as soon as a device is bound, it has a sequence number. If the uclass flag DM_UC_FLAG_SEQ_ALIAS is enabled (as well as the CONFIG option), a devicetree alias provides the number. Otherwise, the next available number (after the last alias and avoiding existing devices) is used.
Apart from the simplicity gains, overall these changes seem to reduce the number of tweaks and workarounds needed to get the desired behaviour.
However there will certainly be some problems created, so board maintainers should test this out.
This series is available at u-boot-dm/seq-working
Changes in v2:
- Give all devices a sequence number
- Drop uclass_alloc_all_seqs() and GD_FLG_DM_NO_SEQ flag
- Drop the GD_FLG_DM_NO_SEQ flag
Sequence numbers looks good, but PCI still doesnt work on my board.
-michael
Hi Michael,
On Fri, 11 Dec 2020 at 01:55, Michael Walle michael@walle.cc wrote:
Hi Simon,
Changes in v2:
- Use the sequence number directly instead of max bus
Thanks for trying this out.
I suppose you have a different problem from what I found in v1. Can you please send the output of these things before and after the change?
dm tree dm uc pci pci 1 (e.g. for other buses) pci 0 long
Which board is it? I suppose there is a chance I have one.
Thanks, Simon
Hi Simon,
Am 2020-12-12 16:39, schrieb Simon Glass:
before:
U-Boot SPL 2021.01-rc3-00035-gec79f5ce22 (Dec 11 2020 - 14:20:36 +0100) Trying to boot from SPI
U-Boot 2021.01-rc3-00035-gec79f5ce22 (Dec 11 2020 - 14:20:36 +0100)
SoC: LS1028A Rev1.0 (0x870b0110) Clock Configuration: CPU0(A72):1300 MHz CPU1(A72):1300 MHz Bus: 400 MHz DDR: 1600 MT/s Reset Configuration Word (RCW): 00000000: 34004010 00000030 00000000 00000000 00000010: 00000000 008f0000 0030c000 00000000 00000020: 06200000 00002580 00000000 00019016 00000030: 00000000 00000048 00000000 00000000 00000040: 00000000 00000000 00000000 00000000 00000050: 00000000 00000000 00000000 00000000 00000060: 00000103 00000000 100e7026 00000000 00000070: bb580000 00020000 Model: Kontron SMARC-sAL28 (Single PHY) EL: 3 DRAM: 4 GiB DDR 4 GiB (DDR3, 32-bit, CL=11, ECC on) SEC0: RNG instantiated CPU: 2 cores online Using SERDES1 Protocol: 47960 (0xbb58) MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from SPIFlash... SF: Detected w25q32dw with page size 256 Bytes, erase size 64 KiB, total 4 MiB OK PCIe0: pcie@3400000 Root Complex: no link PCIe1: pcie@3500000 Root Complex: x1 gen1 In: serial Out: serial Err: serial Net: e1000: 68:05:ca:63:c7:79
Warning: e1000#0 MAC addresses don't match: Address in ROM is 68:05:ca:63:c7:79 Address in environment is 00:de:ad:be:ef:04 eth4: e1000#0, eth0: enetc-0 Hit any key to stop autoboot: 0 => dm tree Class Index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver spi 0 [ + ] nxp_fspi |-- flexspi@20c0000 spi_flash 0 [ ] jedec_spi_nor | `-- flash@0 pci 0 [ + ] pci_layerscape |-- pcie@3400000 pci 3 [ + ] pci_bridge_drv | `-- pci_0:0.0 pci 1 [ + ] pci_layerscape |-- pcie@3500000 pci 4 [ + ] pci_bridge_drv | `-- pci_2:0.0 eth 0 [ + ] eth_e1000 | `-- e1000#0 pci 2 [ + ] pci_generic_ecam |-- pcie@1f0000000 eth 1 [ + ] enetc_eth | |-- enetc-0 mdio 0 [ + ] enetc_mdio | |-- emdio-3 pci_generi 0 [ ] pci_generic_drv | |-- pci_4:0.4 pci_generi 1 [ ] pci_generic_drv | |-- pci_4:0.5 pci_generi 2 [ ] pci_generic_drv | `-- pci_4:1f.0 i2c 0 [ ] i2c_mxc |-- i2c@2000000 rtc 0 [ ] rtc-rv8803 | `-- rtc@32 i2c 1 [ ] i2c_mxc |-- i2c@2030000 i2c 2 [ ] i2c_mxc |-- i2c@2040000 usb 0 [ ] xhci_fsl |-- usb3@3100000 usb 1 [ ] xhci_fsl |-- usb3@3110000 spi 1 [ ] fsl_dspi |-- dspi@2120000 mmc 0 [ + ] fsl-esdhc-mmc |-- esdhc@2140000 blk 0 [ ] mmc_blk | `-- esdhc@2140000.blk mmc 1 [ + ] fsl-esdhc-mmc `-- esdhc@2150000 blk 1 [ ] mmc_blk `-- esdhc@2150000.blk => dm uc uclass 0: root 0 * root_driver @ ffd3b050, seq 0, (req -1)
uclass 18: ahci uclass 21: blk 0 esdhc@2140000.blk @ ffd3bf20 1 esdhc@2150000.blk @ ffd3c2a0
EFI: Initializing UCLASS_EFI uclass 31: efi uclass 32: eth 0 * e1000#0 @ ffd41040, seq 4, (req -1) 1 * enetc-0 @ ffd412a0, seq 0, (req 0)
uclass 36: gpio uclass 38: i2c 0 i2c@2000000 @ ffd3b610, seq -1, (req 0) 1 i2c@2030000 @ ffd3b7f0, seq -1, (req 1) 2 i2c@2040000 @ ffd3b8b0, seq -1, (req 2)
uclass 40: i2c_generic uclass 41: i2c_mux uclass 49: usb_mass_storage uclass 50: mdio 0 * emdio-3 @ ffd41420, seq 0, (req -1)
uclass 53: mmc 0 * esdhc@2140000 @ ffd3bcb0, seq 0, (req 0) 1 * esdhc@2150000 @ ffd3c070, seq 1, (req 1)
uclass 57: nop uclass 59: nvme uclass 64: pci 0 * pcie@3400000 @ ffd3b370, seq 0, (req -1) 1 * pcie@3500000 @ ffd3b430, seq 2, (req -1) 2 * pcie@1f0000000 @ ffd3b4f0, seq 4, (req -1) 3 * pci_0:0.0 @ ffd40af0, seq 1, (req -1) 4 * pci_2:0.0 @ ffd40ed0, seq 3, (req -1)
uclass 66: pci_generic 0 pci_4:0.4 @ ffd41590 1 pci_4:0.5 @ ffd416a0 2 pci_4:1f.0 @ ffd417b0
uclass 78: rng 0 caam-rng @ ffd3c510
uclass 79: rtc 0 rtc@32 @ ffd3b710
uclass 81: scsi uclass 83: simple_bus uclass 87: spi 0 * flexspi@20c0000 @ ffd3b150, seq 0, (req 0) 1 dspi@2120000 @ ffd3bb90, seq -1, (req 1)
uclass 88: spi_flash 0 flash@0 @ ffd3b250
uclass 89: spi_generic uclass 99: usb 0 usb3@3100000 @ ffd3b9d0 1 usb3@3110000 @ ffd3bab0
uclass 100: usb_dev_generic uclass 101: usb_hub => pci Scanning PCI devices on bus 0 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 00.00.00 0x1957 0x82c1 Bridge device 0x04 => pci 1 Scanning PCI devices on bus 1 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ => pci 2 Scanning PCI devices on bus 2 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 02.00.00 0x1957 0x82c1 Bridge device 0x04 => pci 3 Scanning PCI devices on bus 3 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 03.00.00 0x8086 0x1533 Network controller 0x00 => pci 4 Scanning PCI devices on bus 4 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 04.00.00 0x1957 0xe100 Network controller 0x00 04.00.03 0x1957 0xee01 Base system peripheral 0x80 04.00.04 0x1957 0xee02 Base system peripheral 0x80 04.00.05 0x1957 0xeef0 Network controller 0x08 04.1f.00 0x1957 0xe001 Base system peripheral 0x07 => pci 0 long Scanning PCI devices on bus 0
Found PCI device 00.00.00: vendor ID = 0x1957 device ID = 0x82c1 command register ID = 0x0007 status register = 0x0010 revision ID = 0x10 class code = 0x06 (Bridge device) sub class code = 0x04 programming interface = 0x00 cache line = 0x08 latency time = 0x00 header type = 0x01 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 primary bus number = 0x00 secondary bus number = 0x01 subordinate bus number = 0x01 secondary latency timer = 0x00 IO base = 0x11 IO limit = 0x01 secondary status = 0x0000 memory base = 0x4000 memory limit = 0x3ff0 prefetch memory base = 0x1001 prefetch memory limit = 0x0001 prefetch memory base upper = 0x00000000 prefetch memory limit upper = 0x00000000 IO base upper 16 bits = 0x0000 IO limit upper 16 bits = 0x0000 expansion ROM base address = 0x00000000 interrupt line = 0xff interrupt pin = 0x01 bridge control = 0x0000 => pci 1 long Scanning PCI devices on bus 1 => pci 2 long Scanning PCI devices on bus 2
Found PCI device 02.00.00: vendor ID = 0x1957 device ID = 0x82c1 command register ID = 0x0007 status register = 0x0010 revision ID = 0x10 class code = 0x06 (Bridge device) sub class code = 0x04 programming interface = 0x00 cache line = 0x08 latency time = 0x00 header type = 0x01 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 primary bus number = 0x00 secondary bus number = 0x01 subordinate bus number = 0x01 secondary latency timer = 0x00 IO base = 0x11 IO limit = 0x01 secondary status = 0x0000 memory base = 0x4000 memory limit = 0x4020 prefetch memory base = 0x1001 prefetch memory limit = 0x0001 prefetch memory base upper = 0x00000000 prefetch memory limit upper = 0x00000000 IO base upper 16 bits = 0x0000 IO limit upper 16 bits = 0x0000 expansion ROM base address = 0x00000000 interrupt line = 0xff interrupt pin = 0x01 bridge control = 0x0000 => pci 3 long Scanning PCI devices on bus 3
Found PCI device 03.00.00: vendor ID = 0x8086 device ID = 0x1533 command register ID = 0x0006 status register = 0x0010 revision ID = 0x03 class code = 0x02 (Network controller) sub class code = 0x00 programming interface = 0x00 cache line = 0x08 latency time = 0x00 header type = 0x00 BIST = 0x00 base address 0 = 0x40000000 base address 1 = 0x00000000 base address 2 = 0x00000000 base address 3 = 0x40100000 base address 4 = 0x00000000 base address 5 = 0x00000000 cardBus CIS pointer = 0x00000000 sub system vendor ID = 0x103c sub system ID = 0x0003 expansion ROM base address = 0x40200000 interrupt line = 0x00 interrupt pin = 0x01 min Grant = 0x00 max Latency = 0x00 => pci 4 long Scanning PCI devices on bus 4
Found PCI device 04.00.00: vendor ID = 0x1957 device ID = 0xe100 command register ID = 0x0406 status register = 0x0010 revision ID = 0x01 class code = 0x02 (Network controller) sub class code = 0x00 programming interface = 0x01 cache line = 0x08 latency time = 0x00 header type = 0x80 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 base address 2 = 0x00000000 base address 3 = 0x00000000 base address 4 = 0x00000000 base address 5 = 0x00000000 cardBus CIS pointer = 0x00000000 sub system vendor ID = 0x1957 sub system ID = 0xe100 expansion ROM base address = 0x00000000 interrupt line = 0x00 interrupt pin = 0x00 min Grant = 0x00 max Latency = 0x00
Found PCI device 04.00.03: vendor ID = 0x1957 device ID = 0xee01 command register ID = 0x0406 status register = 0x0010 revision ID = 0x01 class code = 0x08 (Base system peripheral) sub class code = 0x80 programming interface = 0x01 cache line = 0x08 latency time = 0x00 header type = 0x80 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 base address 2 = 0x00000000 base address 3 = 0x00000000 base address 4 = 0x00000000 base address 5 = 0x00000000 cardBus CIS pointer = 0x00000000 sub system vendor ID = 0x1957 sub system ID = 0xee01 expansion ROM base address = 0x00000000 interrupt line = 0x00 interrupt pin = 0x00 min Grant = 0x00 max Latency = 0x00
Found PCI device 04.00.04: vendor ID = 0x1957 device ID = 0xee02 command register ID = 0x0404 status register = 0x0010 revision ID = 0x01 class code = 0x08 (Base system peripheral) sub class code = 0x80 programming interface = 0x01 cache line = 0x08 latency time = 0x00 header type = 0x80 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 base address 2 = 0x00000000 base address 3 = 0x00000000 base address 4 = 0x00000000 base address 5 = 0x00000000 cardBus CIS pointer = 0x00000000 sub system vendor ID = 0x1957 sub system ID = 0xee02 expansion ROM base address = 0x00000000 interrupt line = 0x00 interrupt pin = 0x00 min Grant = 0x00 max Latency = 0x00
Found PCI device 04.00.05: vendor ID = 0x1957 device ID = 0xeef0 command register ID = 0x0404 status register = 0x0010 revision ID = 0x01 class code = 0x02 (Network controller) sub class code = 0x08 programming interface = 0x01 cache line = 0x08 latency time = 0x00 header type = 0x80 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 base address 2 = 0x00000000 base address 3 = 0x00000000 base address 4 = 0x00000000 base address 5 = 0x00000000 cardBus CIS pointer = 0x00000000 sub system vendor ID = 0x1957 sub system ID = 0xeef0 expansion ROM base address = 0x00000000 interrupt line = 0x00 interrupt pin = 0x02 min Grant = 0x00 max Latency = 0x00
Found PCI device 04.1f.00: vendor ID = 0x1957 device ID = 0xe001 command register ID = 0x0400 status register = 0x0010 revision ID = 0x01 class code = 0x08 (Base system peripheral) sub class code = 0x07 programming interface = 0x00 cache line = 0x08 latency time = 0x00 header type = 0x00 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 base address 2 = 0x00000000 base address 3 = 0x00000000 base address 4 = 0x00000000 base address 5 = 0x00000000 cardBus CIS pointer = 0x00000000 sub system vendor ID = 0x1957 sub system ID = 0xe001 expansion ROM base address = 0x00000000 interrupt line = 0x00 interrupt pin = 0x01 min Grant = 0x00 max Latency = 0x00 =>
After:
U-Boot SPL 2021.01-rc3-00131-g9aeeb6de34 (Dec 12 2020 - 18:49:38 +0100) Trying to boot from SPI
U-Boot 2021.01-rc3-00131-g9aeeb6de34 (Dec 12 2020 - 18:49:38 +0100)
SoC: LS1028A Rev1.0 (0x870b0110) Clock Configuration: CPU0(A72):1300 MHz CPU1(A72):1300 MHz Bus: 400 MHz DDR: 1600 MT/s Reset Configuration Word (RCW): 00000000: 34004010 00000030 00000000 00000000 00000010: 00000000 008f0000 0030c000 00000000 00000020: 06200000 00002580 00000000 00019016 00000030: 00000000 00000048 00000000 00000000 00000040: 00000000 00000000 00000000 00000000 00000050: 00000000 00000000 00000000 00000000 00000060: 00000103 00000000 100e7026 00000000 00000070: bb580000 00020000 Model: Kontron SMARC-sAL28 (Single PHY) EL: 3 DRAM: 4 GiB DDR 4 GiB (DDR3, 32-bit, CL=11, ECC on) SEC0: RNG instantiated CPU: 2 cores online Using SERDES1 Protocol: 47960 (0xbb58) MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from SPIFlash... SF: Detected w25q32dw with page size 256 Bytes, erase size 64 KiB, total 4 MiB OK PCIe0: pcie@3400000 Root Complex: no link PCIe1: pcie@3500000 Root Complex: x1 gen1 In: serial Out: serial Err: serial Net: eth0: enetc-0 Hit any key to stop autoboot: 0 => dm tree Class Index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver spi 0 [ + ] nxp_fspi |-- flexspi@20c0000 spi_flash 0 [ ] jedec_spi_nor | `-- flash@0 pci 0 [ + ] pci_layerscape |-- pcie@3400000 pci 3 [ + ] pci_bridge_drv | `-- pci_0:0.0 pci 1 [ + ] pci_layerscape |-- pcie@3500000 pci 4 [ + ] pci_bridge_drv | `-- pci_1:0.0 pci 2 [ + ] pci_generic_ecam |-- pcie@1f0000000 eth 0 [ + ] enetc_eth | |-- enetc-0 mdio 0 [ + ] enetc_mdio | |-- emdio-3 pci_generi 0 [ ] pci_generic_drv | |-- pci_2:0.4 pci_generi 1 [ ] pci_generic_drv | |-- pci_2:0.5 pci_generi 2 [ ] pci_generic_drv | `-- pci_2:1f.0 i2c 0 [ ] i2c_mxc |-- i2c@2000000 rtc 0 [ ] rtc-rv8803 | `-- rtc@32 i2c 1 [ ] i2c_mxc |-- i2c@2030000 i2c 2 [ ] i2c_mxc |-- i2c@2040000 usb 0 [ ] xhci_fsl |-- usb3@3100000 usb 1 [ ] xhci_fsl |-- usb3@3110000 spi 1 [ ] fsl_dspi |-- dspi@2120000 mmc 0 [ + ] fsl-esdhc-mmc |-- esdhc@2140000 blk 0 [ ] mmc_blk | `-- esdhc@2140000.blk mmc 1 [ + ] fsl-esdhc-mmc `-- esdhc@2150000 blk 1 [ ] mmc_blk `-- esdhc@2150000.blk => dm uc uclass 0: root 0 * root_driver @ ffd3b050, seq 0
uclass 18: ahci uclass 21: blk 0 esdhc@2140000.blk @ ffd3be40, seq 0 1 esdhc@2150000.blk @ ffd3c1a0, seq 1
EFI: Initializing UCLASS_EFI uclass 31: efi uclass 32: eth 0 * enetc-0 @ ffd41000, seq 0
uclass 36: gpio uclass 38: i2c 0 i2c@2000000 @ ffd3b5b0, seq 0 1 i2c@2030000 @ ffd3b770, seq 1 2 i2c@2040000 @ ffd3b820, seq 2
uclass 40: i2c_generic uclass 41: i2c_mux uclass 49: usb_mass_storage uclass 50: mdio 0 * emdio-3 @ ffd41170, seq 0
uclass 53: mmc 0 * esdhc@2140000 @ ffd3bbe0, seq 0 1 * esdhc@2150000 @ ffd3bf80, seq 1
uclass 57: nop uclass 59: nvme uclass 64: pci 0 * pcie@3400000 @ ffd3b340, seq 0 1 * pcie@3500000 @ ffd3b3f0, seq 1 2 * pcie@1f0000000 @ ffd3b4a0, seq 2 3 * pci_0:0.0 @ ffd409b0, seq 3 4 * pci_1:0.0 @ ffd40db0, seq 4
uclass 66: pci_generic 0 pci_2:0.4 @ ffd412d0, seq 0 1 pci_2:0.5 @ ffd413d0, seq 1 2 pci_2:1f.0 @ ffd414d0, seq 2
uclass 78: rng 0 caam-rng @ ffd3c3d0, seq 0
uclass 79: rtc 0 rtc@32 @ ffd3b6a0, seq 0
uclass 81: scsi uclass 83: simple_bus uclass 87: spi 0 * flexspi@20c0000 @ ffd3b140, seq 0 1 dspi@2120000 @ ffd3bad0, seq 1
uclass 88: spi_flash 0 flash@0 @ ffd3b230, seq 0
uclass 89: spi_generic uclass 99: usb 0 usb3@3100000 @ ffd3b930, seq 0 1 usb3@3110000 @ ffd3ba00, seq 1
uclass 100: usb_dev_generic uclass 101: usb_hub => pci 0 Scanning PCI devices on bus 0 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 00.00.00 0x1957 0x82c1 Bridge device 0x04 => pci 1 Scanning PCI devices on bus 1 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 01.00.00 0x1957 0x82c1 Bridge device 0x04 => pci 2 Scanning PCI devices on bus 2 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 02.00.00 0x1957 0xe100 Network controller 0x00 02.00.03 0x1957 0xee01 Base system peripheral 0x80 02.00.04 0x1957 0xee02 Base system peripheral 0x80 02.00.05 0x1957 0xeef0 Network controller 0x08 02.1f.00 0x1957 0xe001 Base system peripheral 0x07 => pci 3 Scanning PCI devices on bus 3 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ => pci 4 Scanning PCI devices on bus 4 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ => pci 0 long Scanning PCI devices on bus 0
Found PCI device 00.00.00: vendor ID = 0x1957 device ID = 0x82c1 command register ID = 0x0007 status register = 0x0010 revision ID = 0x10 class code = 0x06 (Bridge device) sub class code = 0x04 programming interface = 0x00 cache line = 0x08 latency time = 0x00 header type = 0x01 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 primary bus number = 0x00 secondary bus number = 0x03 subordinate bus number = 0x03 secondary latency timer = 0x00 IO base = 0x11 IO limit = 0x01 secondary status = 0x0000 memory base = 0x4000 memory limit = 0x3ff0 prefetch memory base = 0x1001 prefetch memory limit = 0x0001 prefetch memory base upper = 0x00000000 prefetch memory limit upper = 0x00000000 IO base upper 16 bits = 0x0000 IO limit upper 16 bits = 0x0000 expansion ROM base address = 0x00000000 interrupt line = 0xff interrupt pin = 0x01 bridge control = 0x0000 => pci 1 long Scanning PCI devices on bus 1
Found PCI device 01.00.00: vendor ID = 0x1957 device ID = 0x82c1 command register ID = 0x0007 status register = 0x0010 revision ID = 0x10 class code = 0x06 (Bridge device) sub class code = 0x04 programming interface = 0x00 cache line = 0x08 latency time = 0x00 header type = 0x01 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 primary bus number = 0x00 secondary bus number = 0x03 subordinate bus number = 0x03 secondary latency timer = 0x00 IO base = 0x11 IO limit = 0x01 secondary status = 0x2000 memory base = 0x4000 memory limit = 0x3ff0 prefetch memory base = 0x1001 prefetch memory limit = 0x0001 prefetch memory base upper = 0x00000000 prefetch memory limit upper = 0x00000000 IO base upper 16 bits = 0x0000 IO limit upper 16 bits = 0x0000 expansion ROM base address = 0x00000000 interrupt line = 0xff interrupt pin = 0x01 bridge control = 0x0000 => pci 2 long Scanning PCI devices on bus 2
Found PCI device 02.00.00: vendor ID = 0x1957 device ID = 0xe100 command register ID = 0x0406 status register = 0x0010 revision ID = 0x01 class code = 0x02 (Network controller) sub class code = 0x00 programming interface = 0x01 cache line = 0x08 latency time = 0x00 header type = 0x80 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 base address 2 = 0x00000000 base address 3 = 0x00000000 base address 4 = 0x00000000 base address 5 = 0x00000000 cardBus CIS pointer = 0x00000000 sub system vendor ID = 0x1957 sub system ID = 0xe100 expansion ROM base address = 0x00000000 interrupt line = 0x00 interrupt pin = 0x00 min Grant = 0x00 max Latency = 0x00
Found PCI device 02.00.03: vendor ID = 0x1957 device ID = 0xee01 command register ID = 0x0406 status register = 0x0010 revision ID = 0x01 class code = 0x08 (Base system peripheral) sub class code = 0x80 programming interface = 0x01 cache line = 0x08 latency time = 0x00 header type = 0x80 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 base address 2 = 0x00000000 base address 3 = 0x00000000 base address 4 = 0x00000000 base address 5 = 0x00000000 cardBus CIS pointer = 0x00000000 sub system vendor ID = 0x1957 sub system ID = 0xee01 expansion ROM base address = 0x00000000 interrupt line = 0x00 interrupt pin = 0x00 min Grant = 0x00 max Latency = 0x00
Found PCI device 02.00.04: vendor ID = 0x1957 device ID = 0xee02 command register ID = 0x0404 status register = 0x0010 revision ID = 0x01 class code = 0x08 (Base system peripheral) sub class code = 0x80 programming interface = 0x01 cache line = 0x08 latency time = 0x00 header type = 0x80 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 base address 2 = 0x00000000 base address 3 = 0x00000000 base address 4 = 0x00000000 base address 5 = 0x00000000 cardBus CIS pointer = 0x00000000 sub system vendor ID = 0x1957 sub system ID = 0xee02 expansion ROM base address = 0x00000000 interrupt line = 0x00 interrupt pin = 0x00 min Grant = 0x00 max Latency = 0x00
Found PCI device 02.00.05: vendor ID = 0x1957 device ID = 0xeef0 command register ID = 0x0404 status register = 0x0010 revision ID = 0x01 class code = 0x02 (Network controller) sub class code = 0x08 programming interface = 0x01 cache line = 0x08 latency time = 0x00 header type = 0x80 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 base address 2 = 0x00000000 base address 3 = 0x00000000 base address 4 = 0x00000000 base address 5 = 0x00000000 cardBus CIS pointer = 0x00000000 sub system vendor ID = 0x1957 sub system ID = 0xeef0 expansion ROM base address = 0x00000000 interrupt line = 0x00 interrupt pin = 0x02 min Grant = 0x00 max Latency = 0x00
Found PCI device 02.1f.00: vendor ID = 0x1957 device ID = 0xe001 command register ID = 0x0400 status register = 0x0010 revision ID = 0x01 class code = 0x08 (Base system peripheral) sub class code = 0x07 programming interface = 0x00 cache line = 0x08 latency time = 0x00 header type = 0x00 BIST = 0x00 base address 0 = 0x00000000 base address 1 = 0x00000000 base address 2 = 0x00000000 base address 3 = 0x00000000 base address 4 = 0x00000000 base address 5 = 0x00000000 cardBus CIS pointer = 0x00000000 sub system vendor ID = 0x1957 sub system ID = 0xe001 expansion ROM base address = 0x00000000 interrupt line = 0x00 interrupt pin = 0x01 min Grant = 0x00 max Latency = 0x00 => pci 3 long Scanning PCI devices on bus 3 => pci 4 long Scanning PCI devices on bus 4 =>
Kontron SMARC-sAL28 (kontron_sl28 defconfig) (a LS1028A SoC)
-michael
Hi Michael,
On Sat, 12 Dec 2020 at 10:53, Michael Walle michael@walle.cc wrote:
Hi Simon,
Thanks for the info. I was worried that the renumbering might cause problems but saw no issues on my x86 board.
If you look at the sequence numbers for PCI they have changed. They also correspond to the bus numbers, and PCI uses the sub bus number to route access to sub bus, so I suspect one of your buses is not getting traffic.
At present the only fix is to add all buses into the DT. I'll take a look and see what else I can do.
Hi Michael,
On Sat, 12 Dec 2020 at 11:38, Simon Glass sjg@chromium.org wrote:
Hi Michael,
Hi Simon,
I've pushed an experimental tree to u-boot-dm/seq3-working
Are you able to take a look and send the same output as last time? I am trying to change how PCI allocation happens, so that it follows the PCI rules. Hopefully the change makes sense to you but I would appreciate any insights you may have.
Hi Simon,
Am 2020-12-15 05:28, schrieb Simon Glass:
While it seems to work better now; this looks strange
PCIe0: pcie@3400000 Root Complex: no link PCIe1: pcie@3500000 Root Complex: x1 gen1 PCIe0: pcie@3400000 Root Complex: no link PCIe1: pcie@3500000 Root Complex: x1 gen1
Sorry I haven't found time to look into this, yet.
U-Boot SPL 2021.01-rc3-00027-gecab2d3f52 (Dec 15 2020 - 09:23:43 +0100) Trying to boot from SPI
U-Boot 2021.01-rc3-00027-gecab2d3f52 (Dec 15 2020 - 09:23:43 +0100)
SoC: LS1028A Rev1.0 (0x870b0110) Clock Configuration: CPU0(A72):1300 MHz CPU1(A72):1300 MHz Bus: 400 MHz DDR: 1600 MT/s Reset Configuration Word (RCW): 00000000: 34004010 00000030 00000000 00000000 00000010: 00000000 008f0000 0030c000 00000000 00000020: 06200000 00002580 00000000 00019016 00000030: 00000000 00000048 00000000 00000000 00000040: 00000000 00000000 00000000 00000000 00000050: 00000000 00000000 00000000 00000000 00000060: 00000103 00000000 100e7026 00000000 00000070: bb580000 00020000 Model: Kontron SMARC-sAL28 (Single PHY) EL: 3 DRAM: 4 GiB DDR 4 GiB (DDR3, 32-bit, CL=11, ECC on) SEC0: RNG instantiated CPU: 2 cores online Using SERDES1 Protocol: 47960 (0xbb58) MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from SPIFlash... SF: Detected w25q32dw with page size 256 Bytes, erase size 64 KiB, total 4 MiB OK PCIe0: pcie@3400000 Root Complex: no link PCIe1: pcie@3500000 Root Complex: x1 gen1 PCIe0: pcie@3400000 Root Complex: no link PCIe1: pcie@3500000 Root Complex: x1 gen1 In: serial Out: serial Err: serial Net: e1000: 68:05:ca:63:c7:79
Warning: e1000#0 MAC addresses don't match: Address in ROM is 68:05:ca:63:c7:79 Address in environment is 00:de:ad:be:ef:04 eth4: e1000#0, eth0: enetc-0 Hit any key to stop autoboot: 0 => dm tree Class Index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver spi 0 [ + ] nxp_fspi |-- flexspi@20c0000 spi_flash 0 [ ] jedec_spi_nor | `-- flash@0 pci 0 [ + ] pci_layerscape |-- pcie@3400000 pci 3 [ + ] pci_bridge_drv | `-- pci_0:0.0 pci 1 [ + ] pci_layerscape |-- pcie@3500000 pci 4 [ + ] pci_bridge_drv | `-- pci_2:0.0 eth 0 [ + ] eth_e1000 | `-- e1000#0 pci 2 [ + ] pci_generic_ecam |-- pcie@1f0000000 eth 1 [ + ] enetc_eth | |-- enetc-0 mdio 0 [ + ] enetc_mdio | |-- emdio-3 pci_generi 0 [ ] pci_generic_drv | |-- pci_4:0.4 pci_generi 1 [ ] pci_generic_drv | |-- pci_4:0.5 pci_generi 2 [ ] pci_generic_drv | `-- pci_4:1f.0 i2c 0 [ ] i2c_mxc |-- i2c@2000000 rtc 0 [ ] rtc-rv8803 | `-- rtc@32 i2c 1 [ ] i2c_mxc |-- i2c@2030000 i2c 2 [ ] i2c_mxc |-- i2c@2040000 usb 0 [ ] xhci_fsl |-- usb3@3100000 usb 1 [ ] xhci_fsl |-- usb3@3110000 spi 1 [ ] fsl_dspi |-- dspi@2120000 mmc 0 [ + ] fsl-esdhc-mmc |-- esdhc@2140000 blk 0 [ ] mmc_blk | `-- esdhc@2140000.blk mmc 1 [ + ] fsl-esdhc-mmc `-- esdhc@2150000 blk 1 [ ] mmc_blk `-- esdhc@2150000.blk => dm uclass uclass 0: root 0 * root_driver @ ffd3b050, seq 0
uclass 31: efi uclass 32: eth 0 * e1000#0 @ ffd40dd0, seq 4 1 * enetc-0 @ ffd40f20, seq 0
uclass 40: i2c_generic uclass 41: i2c_mux uclass 49: usb_mass_storage uclass 50: mdio 0 * emdio-3 @ ffd41090, seq 0
uclass 57: nop uclass 59: nvme uclass 64: pci 0 * pcie@3400000 @ ffd3b340, seq 0 1 * pcie@3500000 @ ffd3b3f0, seq 2 2 * pcie@1f0000000 @ ffd3b4a0, seq 4 3 * pci_0:0.0 @ ffd409b0, seq 1 4 * pci_2:0.0 @ ffd40c70, seq 3
uclass 66: pci_generic 0 pci_4:0.4 @ ffd411f0, seq 0 1 pci_4:0.5 @ ffd412f0, seq 1 2 pci_4:1f.0 @ ffd413f0, seq 2
uclass 100: usb_dev_generic uclass 101: usb_hub => pci 0 Scanning PCI devices on bus 0 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 00.00.00 0x1957 0x82c1 Bridge device 0x04 => pci 1 Scanning PCI devices on bus 1 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ => pci 2 Scanning PCI devices on bus 2 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 02.00.00 0x1957 0x82c1 Bridge device 0x04 => pci 3 Scanning PCI devices on bus 3 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 03.00.00 0x8086 0x1533 Network controller 0x00 => pci 4 Scanning PCI devices on bus 4 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 04.00.00 0x1957 0xe100 Network controller 0x00 04.00.03 0x1957 0xee01 Base system peripheral 0x80 04.00.04 0x1957 0xee02 Base system peripheral 0x80 04.00.05 0x1957 0xeef0 Network controller 0x08 04.1f.00 0x1957 0xe001 Base system peripheral 0x07 => pci 0 long Scanning PCI devices on bus 0
-michael
Hi Michael,
On Tue, 15 Dec 2020 at 01:58, Michael Walle michael@walle.cc wrote:
Hi Simon,
From what I can tell, ls_pcie_probe() is being called twice for each PCIe bus.
This can normally only happen if, when probing a device, the uclass /child pre/post--probe itself probes the same device.
But I'm not sure what has changed about the PCI init sequence to cause this.
Michael Walle
