[U-Boot] [PATCH v4 4/5] usb: Add multiple controllers support for EHCI PCI
Use the ability to have several active EHCI controller on a system in the PCI EHCI controller implementation.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v4: - Add errno.h header file to ehci-pci
Changes in v3: None Changes in v2: - Add blank line before function return
drivers/usb/host/ehci-pci.c | 53 ++++++++++++++++++++++++++++++++++++++++----- 1 file changed, 47 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/host/ehci-pci.c b/drivers/usb/host/ehci-pci.c index 29af02d..c1ff8fc 100644 --- a/drivers/usb/host/ehci-pci.c +++ b/drivers/usb/host/ehci-pci.c @@ -19,6 +19,7 @@ */
#include <common.h> +#include <errno.h> #include <pci.h> #include <usb.h>
@@ -32,30 +33,70 @@ static struct pci_device_id ehci_pci_ids[] = { {0x12D8, 0x400F}, /* Pericom */ {0, 0} }; +#else +static pci_dev_t ehci_find_class(int index) +{ + int bus; + int devnum; + pci_dev_t bdf; + uint32_t class; + + for (bus = 0; bus <= pci_last_busno(); bus++) { + for (devnum = 0; devnum < PCI_MAX_PCI_DEVICES-1; devnum++) { + pci_read_config_dword(PCI_BDF(bus, devnum, 0), + PCI_CLASS_REVISION, &class); + if (class >> 16 == 0xffff) + continue; + + for (bdf = PCI_BDF(bus, devnum, 0); + bdf <= PCI_BDF(bus, devnum, + PCI_MAX_PCI_FUNCTIONS - 1); + bdf += PCI_BDF(0, 0, 1)) { + pci_read_config_dword(bdf, PCI_CLASS_REVISION, + &class); + if ((class >> 8 == PCI_CLASS_SERIAL_USB_EHCI) + && !index--) + return bdf; + } + } + } + + return -ENODEV; +} #endif
/* * Create the appropriate control structures to manage * a new EHCI host controller. */ -int ehci_hcd_init(int index, struct ehci_hccr **hccr, struct ehci_hcor **hcor) +int ehci_hcd_init(int index, struct ehci_hccr **ret_hccr, + struct ehci_hcor **ret_hcor) { pci_dev_t pdev; + struct ehci_hccr *hccr; + struct ehci_hcor *hcor;
+#ifdef CONFIG_PCI_EHCI_DEVICE pdev = pci_find_devices(ehci_pci_ids, CONFIG_PCI_EHCI_DEVICE); +#else + pdev = ehci_find_class(index); +#endif if (pdev == -1) { printf("EHCI host controller not found\n"); return -1; }
- *hccr = (struct ehci_hccr *)pci_map_bar(pdev, + hccr = (struct ehci_hccr *)pci_map_bar(pdev, PCI_BASE_ADDRESS_0, PCI_REGION_MEM); - *hcor = (struct ehci_hcor *)((uint32_t) *hccr + - HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase))); + hcor = (struct ehci_hcor *)((uint32_t) hccr + + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
debug("EHCI-PCI init hccr 0x%x and hcor 0x%x hc_length %d\n", - (uint32_t)*hccr, (uint32_t)*hcor, - (uint32_t)HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase))); + (uint32_t)hccr, (uint32_t)hcor, + (uint32_t)HC_LENGTH(ehci_readl(&hccr->cr_capbase))); + + *ret_hccr = hccr; + *ret_hcor = hcor;
return 0; }
