[U-Boot] U-boot doesn't work on OMAP4430 ES2.0
Following with the issue on http://comments.gmane.org/gmane.comp.boot-loaders.u-boot/111922
Looks like the 23e9f0723e48615332119de4f4ec7a833a282628 commit was supposed to fix this, but it doesn't, the problem is still present.
Steve Sakoman's git tree has a different patch: http://www.sakoman.com/cgi-bin/gitweb.cgi?p=u-boot.git;a=commitdiff;h=edb614...
Indeed applying the patch in his tree makes it work. After talking with him he guessed that maybe the fix was supposed to touch efuse_2 and not efuse_1 like in the original patch.
Thanks
Steve Sakoman's git tree has a different patch: http://www.sakoman.com/cgi-bin/gitweb.cgi?p=u-boot.git;a=commitdiff;h=edb61 4543dbd007f5b9873e022b8f5aaefe65ba5;hp=1ffe0d2865184336d9e7176dbaf8bb4781f8 719a
Thanks
Please Cc the omap custodian with this. Also, if you have a patch, please submit it too.
M
Thanks
Note that I've seen this but I'm on vacation this week so I've seen this. Tested on a few boards patches greatly appreciated otherwise I'll see what I can get going early next week (and I might have to hunt up someone with ES2.0 silicon). Thanks!
Hi Raul,
Yes, this is a mix-up. I shall send a new patch. Will you be able to test it for me. I don't have an ES2.0 Panda with me anymore. This issue is not there on ES2.0 SDP.
regards, Aneesh
Hi Aneesh
On 12/29/2011 07:31 PM, Aneesh V wrote:
Hi Raul,
regards, Aneesh
Sure, feel free to send a patch and i'll test it.
Thanks!
Fix boot issue on ES2.0 Panda by tuning some IO settings. The CONTROL_EFUSE_2 register has to be over-ridden in software for 4430 boards.
Commit 23e9f0723e48615332119de4f4ec7a833a282628 wrongly did this for CONTROL_EFUSE_1. Reverting this and doing it for CONTROL_EFUSE_2.
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/hwinit.c | 4 ++-- arch/arm/include/asm/arch-omap4/omap.h | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/hwinit.c b/arch/arm/cpu/armv7/omap4/hwinit.c index 37a86b4..91f8320 100644 --- a/arch/arm/cpu/armv7/omap4/hwinit.c +++ b/arch/arm/cpu/armv7/omap4/hwinit.c @@ -110,10 +110,10 @@ void do_io_settings(void) * i. unconditionally for all 4430 * ii. only if un-trimmed for 4460 */ - if ((omap4_rev < OMAP4460_ES1_0) || !readl(&ctrl->control_efuse_1)) + if (!readl(&ctrl->control_efuse_1)) writel(CONTROL_EFUSE_1_OVERRIDE, &ctrl->control_efuse_1);
- if (!readl(&ctrl->control_efuse_2)) + if ((omap4_rev < OMAP4460_ES1_0) || !readl(&ctrl->control_efuse_2)) writel(CONTROL_EFUSE_2_OVERRIDE, &ctrl->control_efuse_2); } #endif diff --git a/arch/arm/include/asm/arch-omap4/omap.h b/arch/arm/include/asm/arch-omap4/omap.h index 4d8c89f..416c6de 100644 --- a/arch/arm/include/asm/arch-omap4/omap.h +++ b/arch/arm/include/asm/arch-omap4/omap.h @@ -116,7 +116,7 @@ #define LDOSRAM_ACTMODE_VSET_IN_MASK (0x1F << 5) #define LDOSRAM_VOLT_CTRL_OVERRIDE 0x0401040f #define CONTROL_EFUSE_1_OVERRIDE 0x1C4D0110 -#define CONTROL_EFUSE_2_OVERRIDE 0x00084000 +#define CONTROL_EFUSE_2_OVERRIDE 0x99084000
/* LPDDR2 IO regs */ #define CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN 0x1C1C1C1C
[snip]
works fine:
U-Boot SPL 2011.12-00046-gbfcc40b-dirty (Dec 31 2011 - 12:14:09) Texas Instruments OMAP4430 ES2.0 OMAP SD/MMC: 0 reading u-boot.img reading u-boot.img
U-Boot 2011.12-00046-gbfcc40b-dirty (Dec 31 2011 - 12:14:09)
CPU : OMAP4430 ES2.0 Board: OMAP4 Panda I2C: ready DRAM: 1 GiB MMC: OMAP SD/MMC: 0 Using default environment
Thanks!
Tested-by: Raúl Porcel armin76@gentoo.org
On 12/31/2011 01:27 PM, asad wrote: [snip]
Jeez, obviously this is me...
Thanks and sorry
[snip]
works fine:
Thanks!
Applied to u-boot-ti/master, thanks!
participants (5)
Aneesh V
asad
Raúl Porcel
