Re: [U-Boot] [PATCH v4 2/5] dts: cadence_spi: Sync DT bindings with Linux
Jason Rush wrote: Adopt the Linux DT bindings and clean-up duplicate and unused values.
Changes for v4:
- Rebased
Reviewed-by: Simon Goldschmidt sgoldschmidt@de.pepperl-fuchs.com
arch/arm/dts/keystone-k2g-evm.dts | 8 ++++---- arch/arm/dts/keystone-k2g.dtsi | 5 +++-- arch/arm/dts/socfpga.dtsi | 5 +++-- arch/arm/dts/socfpga_arria10.dtsi | 4 ++-- arch/arm/dts/socfpga_arria5_socdk.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_is1.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_socdk.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_sockit.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_socrates.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_sr1500.dts | 9 ++++----- arch/arm/dts/socfpga_cyclone5_vining_fpga.dts | 18 ++++++++---------- arch/arm/dts/stv0991.dts | 12 +++++++----- 12 files changed, 51 insertions(+), 55 deletions(-)
diff --git a/arch/arm/dts/keystone-k2g-evm.dts b/arch/arm/dts/keystone-k2g- evm.dts index de208b3..ba566a4 100644 --- a/arch/arm/dts/keystone-k2g-evm.dts +++ b/arch/arm/dts/keystone-k2g-evm.dts @@ -76,10 +76,10 @@ spi-max-frequency = <96000000>; #address-cells = <1>; #size-cells = <1>;
tshsl-ns = <392>;
tsd2d-ns = <392>;
tchsh-ns = <100>;
tslch-ns = <100>;
cdns,tshsl-ns = <392>;
cdns,tsd2d-ns = <392>;
cdns,tchsh-ns = <100>;
block-size = <18>;cdns,tslch-ns = <100>;
diff --git a/arch/arm/dts/keystone-k2g.dtsi b/arch/arm/dts/keystone-k2g.dtsi index 7b2fae6..9bcfea6 100644 --- a/arch/arm/dts/keystone-k2g.dtsi +++ b/arch/arm/dts/keystone-k2g.dtsi @@ -92,8 +92,9 @@ <0x24000000 0x4000000>; interrupts = <GIC_SPI 198 IRQ_TYPE_EDGE_RISING>; num-cs = <4>;
fifo-depth = <256>;
sram-size = <256>;
cdns,fifo-depth = <256>;
cdns,fifo-width = <4>;
};cdns,trigger-address = <0x24000000>; status = "disabled";
diff --git a/arch/arm/dts/socfpga.dtsi b/arch/arm/dts/socfpga.dtsi index 8588221..7557aa0 100644 --- a/arch/arm/dts/socfpga.dtsi +++ b/arch/arm/dts/socfpga.dtsi @@ -644,8 +644,9 @@ clocks = <&qspi_clk>; ext-decoder = <0>; /* external decoder */ num-cs = <4>;
fifo-depth = <128>;
sram-size = <128>;
cdns,fifo-depth = <128>;
};cdns,trigger-address = <0x00000000>; bus-num = <2>; status = "disabled";
diff --git a/arch/arm/dts/socfpga_arria10.dtsi b/arch/arm/dts/socfpga_arria10.dtsi index 377700d..abfd0bc 100644 --- a/arch/arm/dts/socfpga_arria10.dtsi +++ b/arch/arm/dts/socfpga_arria10.dtsi @@ -734,8 +734,8 @@ clocks = <&l4_main_clk>; ext-decoder = <0>; /* external decoder */ num-chipselect = <4>;
fifo-depth = <128>;
sram-size = <512>;
};cdns,fifo-width = <4>; bus-num = <2>; status = "disabled";
diff --git a/arch/arm/dts/socfpga_arria5_socdk.dts b/arch/arm/dts/socfpga_arria5_socdk.dts index 7265058..1e91a65 100644 --- a/arch/arm/dts/socfpga_arria5_socdk.dts +++ b/arch/arm/dts/socfpga_arria5_socdk.dts @@ -94,10 +94,9 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */
read-delay = <4>; /* delay value in read data capture register */
tshsl-ns = <50>;
tsd2d-ns = <50>;
tchsh-ns = <4>;
tslch-ns = <4>;
cdns,tshsl-ns = <50>;
cdns,tsd2d-ns = <50>;
cdns,tchsh-ns = <4>;
};cdns,tslch-ns = <4>;
}; diff --git a/arch/arm/dts/socfpga_cyclone5_is1.dts b/arch/arm/dts/socfpga_cyclone5_is1.dts index 16a3283..2e2b71f 100644 --- a/arch/arm/dts/socfpga_cyclone5_is1.dts +++ b/arch/arm/dts/socfpga_cyclone5_is1.dts @@ -93,11 +93,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */
tshsl-ns = <50>;
tsd2d-ns = <50>;
tchsh-ns = <4>;
tslch-ns = <4>;
diff --git a/arch/arm/dts/socfpga_cyclone5_socdk.dts b/arch/arm/dts/socfpga_cyclone5_socdk.dts index f175ef2..95a8e65 100644 --- a/arch/arm/dts/socfpga_cyclone5_socdk.dts +++ b/arch/arm/dts/socfpga_cyclone5_socdk.dts @@ -104,11 +104,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */
tshsl-ns = <50>;
tsd2d-ns = <50>;
tchsh-ns = <4>;
tslch-ns = <4>;
diff --git a/arch/arm/dts/socfpga_cyclone5_sockit.dts b/arch/arm/dts/socfpga_cyclone5_sockit.dts index e45c2ab..6f42b88 100644 --- a/arch/arm/dts/socfpga_cyclone5_sockit.dts +++ b/arch/arm/dts/socfpga_cyclone5_sockit.dts @@ -84,11 +84,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */
tshsl-ns = <50>;
tsd2d-ns = <50>;
tchsh-ns = <4>;
tslch-ns = <4>;
diff --git a/arch/arm/dts/socfpga_cyclone5_socrates.dts b/arch/arm/dts/socfpga_cyclone5_socrates.dts index bdd9324..e3ae8a8 100644 --- a/arch/arm/dts/socfpga_cyclone5_socrates.dts +++ b/arch/arm/dts/socfpga_cyclone5_socrates.dts @@ -74,11 +74,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */
tshsl-ns = <50>;
tsd2d-ns = <50>;
tchsh-ns = <4>;
tslch-ns = <4>;
diff --git a/arch/arm/dts/socfpga_cyclone5_sr1500.dts b/arch/arm/dts/socfpga_cyclone5_sr1500.dts index 739bbb7..e24830a 100644 --- a/arch/arm/dts/socfpga_cyclone5_sr1500.dts +++ b/arch/arm/dts/socfpga_cyclone5_sr1500.dts @@ -92,10 +92,9 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */
tshsl-ns = <50>;
tsd2d-ns = <50>;
tchsh-ns = <4>;
tslch-ns = <4>;
}; diff --git a/arch/arm/dts/socfpga_cyclone5_vining_fpga.dts b/arch/arm/dts/socfpga_cyclone5_vining_fpga.dts index f168e4f..a0febe9 100644 --- a/arch/arm/dts/socfpga_cyclone5_vining_fpga.dts +++ b/arch/arm/dts/socfpga_cyclone5_vining_fpga.dts @@ -79,11 +79,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */
tshsl-ns = <50>;
tsd2d-ns = <50>;
tchsh-ns = <4>;
tslch-ns = <4>;
flash1: n25q00@1 {
@@ -96,11 +95,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */
tshsl-ns = <50>;
tsd2d-ns = <50>;
tchsh-ns = <4>;
tslch-ns = <4>;
diff --git a/arch/arm/dts/stv0991.dts b/arch/arm/dts/stv0991.dts index fa3fd64..bceac09 100644 --- a/arch/arm/dts/stv0991.dts +++ b/arch/arm/dts/stv0991.dts @@ -32,7 +32,9 @@ reg = <0x80203000 0x100>, <0x40000000 0x1000000>; clocks = <3750000>;
sram-size = <256>;
cdns,trigger-address = <0x40000000>; status = "okay"; flash0: n25q32@0 {
@@ -44,10 +46,10 @@ m25p,fast-read; page-size = <256>; block-size = <16>; /* 2^16, 64KB */
tshsl-ns = <50>;
tsd2d-ns = <50>;
tchsh-ns = <4>;
tslch-ns = <4>;
};cdns,tslch-ns = <4>; };
2.1.4
Goldschmidt Simon
