[U-Boot] [PATCH] davinci: omapl138_lcdk: keep booting even when MAC address is invalid
If the MAC address specified on the EEPROM is invalid (multicast or zero address), then u-boot fails to boot. Having a bad MAC address in the EEPROM should not prevent the system from booting.
This commit changes the error path to just print an error messages in case of bad MAC address.
Signed-off-by: Fabien Parent fparent@baylibre.com --- board/davinci/da8xxevm/omapl138_lcdk.c | 14 ++++++++------ 1 file changed, 8 insertions(+), 6 deletions(-)
diff --git a/board/davinci/da8xxevm/omapl138_lcdk.c b/board/davinci/da8xxevm/omapl138_lcdk.c index 9783b2a..9c1a483 100644 --- a/board/davinci/da8xxevm/omapl138_lcdk.c +++ b/board/davinci/da8xxevm/omapl138_lcdk.c @@ -333,15 +333,17 @@ int misc_init_r(void) get_mac_addr(addr); }
- if (is_multicast_ethaddr(addr) || is_zero_ethaddr(addr)) { + if (!is_multicast_ethaddr(addr) && !is_zero_ethaddr(addr)) { + sprintf((char *)tmp, "%02x:%02x:%02x:%02x:%02x:%02x", + addr[0], addr[1], addr[2], addr[3], addr[4], + addr[5]); + + setenv("ethaddr", (char *)tmp); + } else { printf("Invalid MAC address read.\n"); - return -EINVAL; } - sprintf((char *)tmp, "%02x:%02x:%02x:%02x:%02x:%02x", addr[0], - addr[1], addr[2], addr[3], addr[4], addr[5]); - - setenv("ethaddr", (char *)tmp); } + #ifdef CONFIG_DRIVER_TI_EMAC_USE_RMII /* Select RMII fucntion through the expander */ if (rmii_hw_init())
Signed-off-by: Fabien Parent fparent@baylibre.com Reviewed-by: Tom Rini trini@konsulko.com
Fabien Parent
