[U-Boot] RAM burst mode problem
Hello, I am working on a board similar to the EP88xC and am having trouble getting the sdram_table[] setup with the correct values (at least I think that's the problem). The board words fine if i burst-inhibit memc_or1 so I know single read/write works, but if I remove burst-inhibit, it results in a crash when U-Boot transfers itself from flash to RAM and jumps to the relocated code.
My board uses the MPC875 processor and MT48LC16M16A2 for the RAM. The following is my current SDRAM table:
static uint sdram_table[] = { /* Single read (offset 0x00 in UPM RAM) */ 0x0F03C004, 0x0FFFC004, 0x00FCC004, 0x0FFFC000, 0x0FF30004, 0x0FFFC004, 0xFFFFC005, 0xFFFFC005, /* Burst read (offset 0x08 in UPM RAM) */ 0x0F03C004, 0x0FFFC004, 0x00FCC004, 0x00FFC000, 0x00FFC000, 0x00FFC000, 0x00FFC000, 0x00FFC000, 0x00FFC000, 0x00FFC000, 0x0FF30000, 0x0FFFC004, 0xFFFFC005, 0xFFFFC005, 0xFFFFC005, 0xFFFFC005, /* Single write (offset 0x18 in UPM RAM) */ 0x0F03C004, 0x0FFFC004, 0x00FC0004, 0x0FFFC002, 0x0FF30004, 0X0FFFC004, 0xFFFFC005, 0xFFFFC005, /* Burst write (offset 0x20 in UPM RAM) */ 0x0F03C004, 0x0FFFC004, 0x00FC0004, 0X00FFC000, 0x00FFC000, 0x00FFC000, 0x00FFC000, 0X00FFC000, 0x00FFC000, 0x00FFC000, 0x0FF30002, 0x0FFFC004, 0xFFFFC005, 0xFFFFC005, 0xFFFFC005, 0xFFFFC005, /* Refresh (offset 0x30 in UPM RAM) */ 0x0FF0C004, 0x0FFFC004, 0x0FFFC004, 0x0FFFC004, 0xFFFFC005, 0x0FA30004, 0x0FFFC004, 0x0FF0C084, 0x0FFFC004, 0x0FFFC004, 0x0FFFC004, 0x0FFFC084, /* Exception (offset 0x3C in UPM RAM) */ 0x0FFFC004, 0x0FF00004, 0x0FFFC004, 0xFFFFC005 };
And the following is my ram init function:
phys_size_t initdram (int board_type) { long int msize; volatile immap_t *immap = (volatile immap_t *)CONFIG_SYS_IMMR; volatile memctl8xx_t *memctl = &immap->im_memctl; upmconfig(UPMA, sdram_table, sizeof(sdram_table) / sizeof(uint)); /* Configure SDRAM refresh */ memctl->memc_mptpr = MPTPR_PTP_DIV2; /* BRGCLK/2 */ memctl->memc_mamr = (65 << 24) | CONFIG_SYS_MAMR; /* No refresh */ udelay(100); /* Run MRS pattern from location 0x35 */ // MZ - was 0x36 memctl->memc_mar = 0x46; // MZ - was 0x88 memctl->memc_mcr = 0x80002235; // MZ - was 0x80002236 udelay(100); memctl->memc_mamr |= MAMR_PTAE; /* Enable refresh */ memctl->memc_or1 = ~(CONFIG_SYS_SDRAM_MAX_SIZE - 1) | OR_CSNT_SAM; // memctl->memc_or1 = ~(CONFIG_SYS_SDRAM_MAX_SIZE - 1) | OR_CSNT_SAM | OR_BI; // MZ - temp, burst inhibit memctl->memc_br1 = CONFIG_SYS_SDRAM_BASE | BR_PS_16 | BR_MS_UPMA | BR_V; msize = get_ram_size(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_MAX_SIZE); memctl->memc_or1 |= ~(msize - 1); return msize; }
Also attached is a spreadsheet which illustrates the RAM timing.
Is there something wrong with my RAM table? Am I missing any flags? Something else wrong?
Any ideas/suggestions are appreciated.
Thank you, Mikhail Zaturenskiy
Dear Mikhail Zaturenskiy,
In message 97dd5fd20908251235ic0e64eela7c75fb138143dc4@mail.gmail.com you wrote:
Nice formatting.
That's even better. Do you suppose anybody will bother to read any code after you formatted it like this?
Note that this is the U-Boot mailing list, not the submission of entries for the IOCCC.
For one, your style of formatting and posting is terribly wrong.
Please see http://www.catb.org/~esr/faqs/smart-questions.html
Oh wow, my apologies! The formatting looked nice an clean on my end, not like that garbage, I probably sent it in HTML instead of plain-text. Here's a second attempt, plain-text this time, I hope it looks better:
return msize; }
Any ideas/suggestions are appreciated. Again, sorry for the first poorly-formatted post.
return msize; }
Anyone?
Hi Mikhail, Burst mode UPM setup is not trivial, and it is quite amount of work to go through your table, so I'm not surprised nobody has replied.
I assume you've verified the generated waveforms using a logic analyzer/scope, and compared them to the DRAMs datasheet (?). If you have access to a Windows machine, you could try an ancient Motorola tool called UPM860. It might be helpful when verifying your UPM program.
Unless someone has experience with this certain DRAM I guess you're on your own. Or.. you could try to hire one of the engineers at Denx to do the job for you.
Good luck! - Frank
On Wed, Sep 2, 2009 at 11:58 PM, Mikhail Zaturenskiymzaturenskiy.st@gmail.com wrote:
return msize; }
Anyone? _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
We finally solved our DRAM timing problem so I wanted to follow up on my question.
On Fri, Sep 4, 2009 at 1:41 AM, Frank Svendsbøe frank.svendsboe@gmail.com wrote:
I know, I'm not too surprised either :)
Unfortunately we do not have access to a decent scope nor a logic analyzer, that would certainly have been helpful.
Did take a look at that, though it did not appear to be as helpful as I hoped.
Good luck!
- Frank
Thanks for your suggestions Frank, They did provide me with some food for thought.
What the issue ended up being was us incorrectly setting the amx0/amx1 bits of the "Exception" RAM word. After we fixed that we also found a nice document from Micron on DRAM timings which had slightly more efficient read/write section values than what we came up with, for those interested here is the link http://download.micron.com/pdf/technotes/TN4812.pdf . Now RAM burst reads/writes are finally working properly :)
Mikhail Zaturenskiy
On Thu, Sep 17, 2009 at 5:42 PM, Mikhail Zaturenskiy mzaturenskiy.st@gmail.com wrote:
Good luck!
- Frank
Mikhail Zaturenskiy
I'm impressed! You've solved your burst problem working in blind ;-) Next time, consider buying/renting an analyzer/MSO.
It's strange you mentioned this certain Micron datasheet. It was the same document that finally made me understand how address multiplexing works on the 8xx. Far easier to understand than the Freescale ref. manual.
Now, consider supporting the community by commiting a patch containing the working UPM table for this SDRAM ;-)
- Frank
Frank Svendsbøe
Mikhail Zaturenskiy
