Please pull u-boot-dm next
Hi Tom,
This is for -next
https://source.denx.de/u-boot/custodians/u-boot-dm/-/pipelines/19131
https://dev.azure.com/simon0972/u-boot/_build/results?buildId=57&view=re...
The following changes since commit 2b28c3b871cd5d55b19f0a86cef970139f8ab952:
Merge patch series "Modernize U-Boot shell" (2023-12-28 14:38:25 -0500)
git://git.denx.de/u-boot-dm.git tags/dm-next-1124
for you to fetch changes up to e266d2731145681a55d862360f1b61690b0c6820:
bloblist: Update documentation and header comment (2023-12-31 07:21:02 -0700)
---------------------------------------------------------------- support propagating supernode properties with bootph schema align bloblist with v0.9 of Firmware Handoff spec
---------------------------------------------------------------- Heinrich Schuchardt (2): buildman: type cotaining binman: used-before-assignment in ftest.py
Simon Glass (22): x86: coral: Align bootph SPI-flash subnodes with parent fdtgrep: Tidy up a few type warnings and comments fdtgrep: Correct ordering of flags fdtgrep: Correct references to fdt_find_regions() fdtgrep: Tidy up comment for h_include() fdtgrep: Simplify code to inverting the match fdtgrep: Move property checking into a function sandbox: Correct SPL condition for building devicetree fdtgrep: Allow propagating properties up to supernodes Makefile: Use the fdtgrep -u flag bloblist: Update the tag numbering bloblist: Adjust API to align in powers of 2 bloblist: Change the magic value bloblist: Set version to 1 bloblist: Access record hdr_size and tag via a function bloblist: Drop spare value from bloblist record bloblist: Checksum the entire bloblist bloblist: Handle alignment with a void entry bloblist: Reduce blob-header size bloblist: Adjust the bloblist header bloblist: Add alignment to bloblist_new() bloblist: Update documentation and header comment
arch/x86/dts/chromebook_coral.dts | 6 ++- arch/x86/lib/tables.c | 3 +- common/bloblist.c | 205 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------------------------- doc/develop/bloblist.rst | 4 +- include/bloblist.h | 166 +++++++++++++++++++++++++++++++++++++++++++++--------------------------------- scripts/Makefile.lib | 13 ++++++- scripts/Makefile.spl | 2 +- test/bloblist.c | 105 +++++++++++++++++++++++++++----------------------- tools/binman/ftest.py | 20 +++++++--- tools/buildman/boards.py | 2 +- tools/fdtgrep.c | 123 ++++++++++++++++++++++++++++++++++++++--------------------
On Mon, Jan 01, 2024 at 10:31:57AM -0700, Simon Glass wrote:
Hi Tom,
This is for -next
