[U-Boot] [PATCH] fsl-lsch3: Add FSPI address space in immap_lsch3
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com ---
depends upon: http://patchwork.ozlabs.org/patch/962357/
arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index b0cec74db0..56f2222596 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -19,7 +19,11 @@ #define CONFIG_SYS_FSL_CH3_CLK_GRPA_ADDR (CONFIG_SYS_IMMR + 0x00300000) #define CONFIG_SYS_FSL_CH3_CLK_GRPB_ADDR (CONFIG_SYS_IMMR + 0x00310000) #define CONFIG_SYS_FSL_CH3_CLK_CTRL_ADDR (CONFIG_SYS_IMMR + 0x00370000) +#ifndef CONFIG_NXP_LSCH3_2 #define SYS_FSL_QSPI_ADDR (CONFIG_SYS_IMMR + 0x010c0000) +#else +#define SYS_FSL_FSPI_ADDR (CONFIG_SYS_IMMR + 0x010c0000) +#endif #define CONFIG_SYS_FSL_ESDHC_ADDR (CONFIG_SYS_IMMR + 0x01140000) #define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x01240000) #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x011C0500)
Enable AHB support for flexspi controller interface meaning memory can be accessed via md command using absolute addresses
Signed-off-by: Yogesh Gaur yogeshnarayan.gaur@nxp.com Signed-off-by: Rajat Srivastava rajat.srivastava@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 10 ++++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 42 +++++++++++++++++++++++ 2 files changed, 52 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 5280d33ec8..8d66783b7c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -327,6 +327,16 @@ config SYS_FSPI_AHB_INIT performed. Default LUT programmed in AHB mode is Fast Read command with 4-byte addressing enabled.
+config FSPI_AHB_EN_4BYTE + bool "Enable 4-byte Fast Read cmd for AHB mode" + depends on NXP_FSPI + default n + help + The default setting for FSPI AHB bus just supports 3-byte addressing. + But some FSPI flash sizes are up to 64MBytes. + This flag enables fast read cmd for AHB mode and modifies required + LUT to support full FSPI flash. + config SYS_CCI400_OFFSET hex "Offset for CCI400 base" depends on SYS_FSL_HAS_CCI400 diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 3f15cb08ff..60beb0dc96 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -640,6 +640,45 @@ void fsl_lsch2_early_init_f(void) } #endif
+#ifdef CONFIG_FSPI_AHB_EN_4BYTE +int fspi_ahb_init(void) +{ + /* Enable 4bytes address support and fast read */ + u32 *fspi_lut, lut_key, *fspi_key; + + fspi_key = (void *)SYS_FSL_FSPI_ADDR + 0x18; + fspi_lut = (void *)SYS_FSL_FSPI_ADDR + 0x200; + + lut_key = in_be32(fspi_key); + + if (lut_key == 0x5af05af0) { + /* That means the register is BE */ + out_be32(fspi_key, 0x5af05af0); + /* Unlock the lut table */ + out_be32(fspi_key + 1, 0x00000002); + out_be32(fspi_lut, 0x0820040c); + out_be32(fspi_lut + 1, 0x24003008); + out_be32(fspi_lut + 2, 0x00000000); + /* Lock the lut table */ + out_be32(fspi_key, 0x5af05af0); + out_be32(fspi_key + 1, 0x00000001); + } else { + /* That means the register is LE */ + out_le32(fspi_key, 0x5af05af0); + /* Unlock the lut table */ + out_le32(fspi_key + 1, 0x00000002); + out_le32(fspi_lut, 0x0820040c); + out_le32(fspi_lut + 1, 0x24003008); + out_le32(fspi_lut + 2, 0x00000000); + /* Lock the lut table */ + out_le32(fspi_key, 0x5af05af0); + out_le32(fspi_key + 1, 0x00000001); + } + + return 0; +} +#endif + #ifdef CONFIG_QSPI_AHB_INIT /* Enable 4bytes address support and fast read */ int qspi_ahb_init(void) @@ -688,6 +727,9 @@ int board_late_init(void) #ifdef CONFIG_QSPI_AHB_INIT qspi_ahb_init(); #endif +#ifdef CONFIG_FSPI_AHB_EN_4BYTE + fspi_ahb_init(); +#endif
return 0; }
- bool "Enable 4-byte Fast Read cmd for AHB mode"
s/cmd/command
- depends on NXP_FSPI
- default n
- help
It is FlexSPI, not FSPI, nor flexspi. Please use consistent term for FlexSPI in subject, commit message, document and comment. If you have to use FSPI in macro names, make sure it it has clear meaning.
- /* Enable 4bytes address support and fast read */
- u32 *fspi_lut, lut_key, *fspi_key;
- fspi_key = (void *)SYS_FSL_FSPI_ADDR + 0x18;
- fspi_lut = (void *)SYS_FSL_FSPI_ADDR + 0x200;
- lut_key = in_be32(fspi_key);
- if (lut_key == 0x5af05af0) {
- } else {
Is there anyway you can make the magic numbers more meaningful?
York
Hello York,
-----Original Message----- From: York Sun Sent: Tuesday, September 25, 2018 10:20 PM To: Ashish Kumar ashish.kumar@nxp.com; u-boot@lists.denx.de Cc: Rajat Srivastava rajat.srivastava@nxp.com; Yogesh Narayan Gaur yogeshnarayan.gaur@nxp.com Subject: Re: [PATCH] fsl-lsch3: soc: Enable AHB support flexspi controller
command
s/cmd/command
While take care in v2
- default n
- help
In description and comment it will be replaced by FlexSPI, but in macro/config/variables names can I use FSPI and fspi ?
- } else {
How about adding comments above each magic number, explaining meaning?
Regards Ashish
York
Ashish Kumar
Ashish Kumar
York Sun
