[U-Boot] [PATCH v2 5/6] x86: Change coreboot default build configuration to QEMU
QEMU is much easier for us test booting U-Boot as a coreboot payload than having a real board like chromebook_link.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
board/coreboot/coreboot/Kconfig | 6 +++--- configs/coreboot-x86_defconfig | 1 + 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/board/coreboot/coreboot/Kconfig b/board/coreboot/coreboot/Kconfig index 6a04158..69e3437 100644 --- a/board/coreboot/coreboot/Kconfig +++ b/board/coreboot/coreboot/Kconfig @@ -16,21 +16,21 @@ comment "coreboot-specific options"
config SYS_CONFIG_NAME string "Board configuration file" - default "chromebook_link" + default "qemu-x86" help This option selects the board configuration file in include/configs/ directory to be used to build U-Boot for coreboot.
config DEFAULT_DEVICE_TREE string "Board Device Tree Source (dts) file" - default "chromebook_link" + default "qemu-x86" help This option selects the board Device Tree Source (dts) file in arch/x86/dts/ directory to be used to build U-Boot for coreboot.
config SYS_CAR_ADDR hex "Board specific Cache-As-RAM (CAR) address" - default 0x19200000 + default 0x01920000 help This option specifies the board specific Cache-As-RAM (CAR) address.
diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index 799853f..4af38f5 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -3,3 +3,4 @@ CONFIG_VENDOR_COREBOOT=y CONFIG_TARGET_COREBOOT=y CONFIG_OF_CONTROL=y CONFIG_DM_PCI=y +CONFIG_TSC_CALIBRATION_BYPASS=y
Changes in v2: None
Applied to u-boot-x86, thanks!
Bin Meng
