[U-Boot-Users] [PATCH 1/5] OneNAND support
[PATCH] OneNAND support
This patch enables the OneNAND at U-boot
Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- diff --git a/Makefile b/Makefile index 0477cd3..d42f2ef 100644 --- a/Makefile +++ b/Makefile @@ -211,6 +211,7 @@ LIBS += drivers/libdrivers.a LIBS += drivers/bios_emulator/libatibiosemu.a LIBS += drivers/nand/libnand.a LIBS += drivers/nand_legacy/libnand_legacy.a +LIBS += drivers/onenand/libonenand.a LIBS += drivers/net/libnet.a ifeq ($(CPU),mpc83xx) LIBS += drivers/qe/qe.a diff --git a/common/Makefile b/common/Makefile index ef7d097..fde5ad9 100644 --- a/common/Makefile +++ b/common/Makefile @@ -37,13 +37,14 @@ COBJS = main.o ACEX1K.o altera.o bedbug.o circbuf.o cmd_autoscript.o \ cmd_load.o cmd_log.o \ cmd_mem.o cmd_mii.o cmd_misc.o cmd_mmc.o \ cmd_nand.o cmd_net.o cmd_nvedit.o \ + cmd_onenand.o \ cmd_pci.o cmd_pcmcia.o cmd_portio.o \ cmd_reginfo.o cmd_reiser.o cmd_sata.o cmd_scsi.o cmd_spi.o \ cmd_universe.o cmd_usb.o cmd_vfd.o \ command.o console.o cyclon2.o devices.o dlmalloc.o docecc.o \ environment.o env_common.o \ env_nand.o env_dataflash.o env_flash.o env_eeprom.o \ - env_nvram.o env_nowhere.o \ + env_onenand.o env_nvram.o env_nowhere.o \ exports.o \ fdt_support.o flash.o fpga.o ft_build.o \ hush.o kgdb.o lcd.o lists.o lynxkdi.o \ diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 1db0fc3..6770408 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -57,8 +57,9 @@ DECLARE_GLOBAL_DATA_PTR; !defined(CFG_ENV_IS_IN_FLASH) && \ !defined(CFG_ENV_IS_IN_DATAFLASH) && \ !defined(CFG_ENV_IS_IN_NAND) && \ + !defined(CFG_ENV_IS_IN_ONENAND) && \ !defined(CFG_ENV_IS_NOWHERE) -# error Define one of CFG_ENV_IS_IN_{NVRAM|EEPROM|FLASH|DATAFLASH|NOWHERE} +# error Define one of CFG_ENV_IS_IN_{NVRAM|EEPROM|FLASH|DATAFLASH|ONENAND|NOWHERE} #endif
#define XMK_STR(x) #x @@ -553,7 +554,8 @@ int getenv_r (char *name, char *buf, unsigned len)
#if defined(CFG_ENV_IS_IN_NVRAM) || defined(CFG_ENV_IS_IN_EEPROM) \ || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_FLASH)) \ - || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_NAND)) + || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_NAND)) \ + || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_ONENAND)) int do_saveenv (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { extern char * env_name_spec; @@ -608,7 +610,8 @@ U_BOOT_CMD(
#if defined(CFG_ENV_IS_IN_NVRAM) || defined(CFG_ENV_IS_IN_EEPROM) \ || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_FLASH)) \ - || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_NAND)) + || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_NAND)) \ + || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_ONENAND)) U_BOOT_CMD( saveenv, 1, 0, do_saveenv, "saveenv - save environment variables to persistent storage\n", diff --git a/common/cmd_onenand.c b/common/cmd_onenand.c new file mode 100644 index 0000000..257a614 --- /dev/null +++ b/common/cmd_onenand.c @@ -0,0 +1,201 @@ +/* + * U-Boot command for OneNAND support + * + * Copyright (C) 2005-2007 Samsung Electronics + * Kyungmin Park kyungmin.park@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#include <common.h> +#include <command.h> + +#if (CONFIG_COMMANDS & CFG_CMD_ONENAND) + +#include <linux/mtd/onenand.h> + +extern struct mtd_info onenand_mtd; +extern struct onenand_chip onenand_chip; + +int do_onenand (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) +{ + int ret = 0; + + switch (argc) { + case 0: + case 1: + printf ("Usage:\n%s\n", cmdtp->usage); + return 1; + + case 2: + if (strncmp (argv[1], "open", 4) == 0) { + onenand_init (); + return 0; + } + onenand_print_device_info (onenand_chip.device_id, 1); + return 0; + + default: + /* At least 4 args */ + if (strncmp (argv[1], "erase", 5) == 0) { + struct erase_info instr; + ulong start, end; + char *endtail; + ulong block; + + if (strncmp (argv[2], "block", 5) == 0) { + start = simple_strtoul (argv[3], NULL, 10); + endtail = strchr (argv[3], '-'); + end = simple_strtoul (endtail + 1, NULL, 10); + } else { + start = simple_strtoul (argv[2], NULL, 10); + end = simple_strtoul (argv[3], NULL, 10); + start -= (unsigned long)onenand_chip.base; + end -= (unsigned long)onenand_chip.base; + } + + if (!end || end < 0) + end = start; + + printf ("Erase block from %d to %d\n", start, end); + + for (block = start; block <= end; block++) { + instr.addr = block << onenand_chip.erase_shift; + instr.len = 1 << onenand_chip.erase_shift; + ret = onenand_erase (&onenand_mtd, &instr); + if (ret) { + printf ("erase failed %d\n", block); + break; + } + } + + return 0; + } + + if (strncmp (argv[1], "read", 4) == 0) { + ulong addr = simple_strtoul (argv[2], NULL, 16); + ulong ofs = simple_strtoul (argv[3], NULL, 16); + size_t len = simple_strtoul (argv[4], NULL, 16); + size_t retlen = 0; + int oob = strncmp (argv[1], "read.oob", 8) ? 0 : 1; + + ofs -= (unsigned long)onenand_chip.base; + + if (oob) + onenand_read_oob (&onenand_mtd, ofs, len, + &retlen, (u_char *) addr); + else + onenand_read (&onenand_mtd, ofs, len, &retlen, + (u_char *) addr); + printf ("Done\n"); + + return 0; + } + + if (strncmp (argv[1], "write", 5) == 0) { + ulong addr = simple_strtoul (argv[2], NULL, 16); + ulong ofs = simple_strtoul (argv[3], NULL, 16); + size_t len = simple_strtoul (argv[4], NULL, 16); + size_t retlen = 0; + + ofs -= (unsigned long)onenand_chip.base; + + onenand_write (&onenand_mtd, ofs, len, &retlen, + (u_char *) addr); + printf ("Done\n"); + + return 0; + } + + if (strncmp (argv[1], "block", 5) == 0) { + ulong addr = simple_strtoul (argv[2], NULL, 16); + ulong block = simple_strtoul (argv[3], NULL, 10); + ulong page = simple_strtoul (argv[4], NULL, 10); + size_t len = simple_strtol (argv[5], NULL, 10); + size_t retlen = 0; + ulong ofs; + int oob = strncmp (argv[1], "block.oob", 9) ? 0 : 1; + + ofs = block << onenand_chip.erase_shift; + if (page) + ofs += page << onenand_chip.page_shift; + + if (!len) { + if (oob) + len = 64; + else + len = 512; + } + + if (oob) + onenand_read_oob (&onenand_mtd, ofs, len, + &retlen, (u_char *) addr); + else + onenand_read (&onenand_mtd, ofs, len, &retlen, + (u_char *) addr); + return 0; + } + + if (strncmp (argv[1], "unlock", 6) == 0) { + ulong start = simple_strtoul (argv[2], NULL, 10); + ulong ofs = simple_strtoul (argv[3], NULL, 10); + + if (!ofs) + ofs = (1 << onenand_chip.erase_shift); + + start = start << onenand_chip.erase_shift; +#if 0 + printk ("start = 0x%08x, ofs = 0x%08x\n", start, ofs); +#endif + onenand_unlock (&onenand_mtd, start, start + ofs); + + return 0; + } + + if (strncmp (argv[1], "save", 4) == 0 && + strncmp (argv[2], "bootloader", 10) == 0) { + ulong addr = simple_strtoul (argv[3], NULL, 16); + struct erase_info instr; + int ofs = 0; + int len = 0x20000; + int retlen; + + printf ("save bootloader...\n"); + + if (!addr) + break; + + onenand_unlock (&onenand_mtd, ofs, len); + + instr.addr = 0 << onenand_chip.erase_shift; + instr.len = 1 << onenand_chip.erase_shift; + onenand_erase (&onenand_mtd, &instr); + + onenand_write (&onenand_mtd, ofs, len, &retlen, + (u_char *) addr); + onenand_unlock (&onenand_mtd, CFG_ENV_ADDR, + onenand_mtd.size - CFG_ENV_ADDR); + return 0; + } + + break; + } + + return 0; +} + +U_BOOT_CMD (onenand, 6, 1, do_onenand, + "onenand - OneNAND sub-system\n", + "info - show available OneNAND devices\n" + "onenand read[.oob] addr ofs len - read data at ofs with len to addr\n" + "onenand write addr ofs len - write data at ofs with len from addr\n" + "onenand erase block start-end - erase block from start to end\n" + "onenand erase saddr eaddr - erase block start addr to end addr\n" + "onenand block[.oob] addr block [page] [len] - " + "read data with (block [, page]) to addr\n" + "onenand unlock start-end - unlock block from start to end\n" + "onenand save bootloader addr - save bootloader at addr\n"); + +#endif /* (CONFIG_COMMANDS & CFG_CMD_ONENAND) */ diff --git a/common/env_onenand.c b/common/env_onenand.c new file mode 100644 index 0000000..2597d1e --- /dev/null +++ b/common/env_onenand.c @@ -0,0 +1,133 @@ +/* + * (C) Copyright 2005-2007 Samsung Electronics + * Kyungmin Park kyungmin.park@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> + +#if defined(CFG_ENV_IS_IN_ONENAND) /* Environment is in OneNAND */ + +#include <command.h> +#include <environment.h> +#include <linux/stddef.h> +#include <malloc.h> + +#include <linux/mtd/onenand.h> + +extern struct mtd_info onenand_mtd; +extern struct onenand_chip onenand_chip; + +/* References to names in env_common.c */ +extern uchar default_environment[]; + +#define ONENAND_ENV_SIZE(mtd) (mtd.oobblock - ENV_HEADER_SIZE) + +char *env_name_spec = "OneNAND"; + +#ifdef ENV_IS_EMBEDDED +extern uchar environment[]; +env_t *env_ptr = (env_t *) (&environment[0]); +#else /* ! ENV_IS_EMBEDDED */ +static unsigned char onenand_env[MAX_ONENAND_PAGESIZE]; +env_t *env_ptr = (env_t *) onenand_env; +#endif /* ENV_IS_EMBEDDED */ + +uchar env_get_char_spec (int index) +{ + DECLARE_GLOBAL_DATA_PTR; + + return (*((uchar *) (gd->env_addr + index))); +} + +void env_relocate_spec (void) +{ + DECLARE_GLOBAL_DATA_PTR; + unsigned long env_addr; + int use_default = 0; + int retlen; + + env_addr = CFG_ENV_ADDR; + env_addr -= (unsigned long)onenand_chip.base; + + /* Check OneNAND exist */ + if (onenand_mtd.oobblock) + /* Ignore read fail */ + onenand_read (&onenand_mtd, env_addr, onenand_mtd.oobblock, + &retlen, (u_char *) env_ptr); + else + onenand_mtd.oobblock = MAX_ONENAND_PAGESIZE; + + if (crc32 (0, env_ptr->data, ONENAND_ENV_SIZE (onenand_mtd)) != + env_ptr->crc) + use_default = 1; + + if (use_default) { + memcpy (env_ptr->data, default_environment, + ONENAND_ENV_SIZE (onenand_mtd)); + env_ptr->crc = + crc32 (0, env_ptr->data, ONENAND_ENV_SIZE (onenand_mtd)); + } + + gd->env_addr = (ulong) & env_ptr->data; + gd->env_valid = 1; +} + +int saveenv (void) +{ + unsigned long env_addr = CFG_ENV_ADDR; + struct erase_info instr; + int retlen; + + instr.len = CFG_ENV_SIZE; + instr.addr = env_addr; + instr.addr -= (unsigned long)onenand_chip.base; + if (onenand_erase (&onenand_mtd, &instr)) { + printf ("OneNAND: erase failed at 0x%08x\n", env_addr); + return 1; + } + + /* update crc */ + env_ptr->crc = + crc32 (0, env_ptr->data, onenand_mtd.oobblock - ENV_HEADER_SIZE); + + env_addr -= (unsigned long)onenand_chip.base; + if (onenand_write + (&onenand_mtd, env_addr, onenand_mtd.oobblock, &retlen, + (u_char *) env_ptr)) { + printf ("OneNAND: write failed at 0x%08x\n", instr.addr); + return 2; + } + + return 0; +} + +int env_init (void) +{ + DECLARE_GLOBAL_DATA_PTR; + + /* use default */ + gd->env_addr = (ulong) & default_environment[0]; + gd->env_valid = 1; + + return 0; +} + +#endif /* CFG_ENV_IS_IN_ONENAND */
I cannot comment much on this code as I have no access to any hardware with such a device, but here are a few formal comments:
This line is probably missing some additional indentation?
I'm not happy with the parameter format of the "erase" and "unlock" commands - using an address specification of "start-end" breaks existing conventions in U-Boot. Please use two separate arguments instead.
Also, I don;t see what the difference between "erase block" and "erase" is - can we avoid "erase block" all together? If not, I recommend to change it into "eraseblock" (which could then be shortened to "eraseb") to avoid too different command formats.
After changing this, you have my ACK.
Thanks a lot.
After committing the OneNAND patch, I will post the Apollon board patches which uses the OneNAND.
Yes, I add the tap indentation as nand does
At code writing time, there are no strict rules to use address scheme, block scheme. No problem, which one is used. Now temporally I removed it
Thank you, Kyungmin Park
P.S. Now I just send the modified parts, after full comments, I will send it at once.
+U_BOOT_CMD( + onenand, 6, 1, do_onenand, + "onenand - OneNAND sub-system\n", + "info - show available OneNAND devices\n" + "onenand read[.oob] addr ofs len - read data at ofs with len to addr\n" + "onenand write addr ofs len - write data at ofs with len from addr\n" + "onenand erase saddr eaddr - erase block start addr to end addr\n" + "onenand block[.oob] addr block [page] [len] - " + "read data with (block [, page]) to addr\n" +);
Hello,
in message 002201c7f344$539d6c60$e1ac580a@swcenter.sec.samsung.co.kr you wrote:
OK - thanks!
+U_BOOT_CMD(
- onenand, 6, 1, do_onenand,
- "onenand - OneNAND sub-system\n",
- "info - show available OneNAND devices\n"
- "onenand read[.oob] addr ofs len - read data at ofs with len to addr\n"
- "onenand write addr ofs len - write data at ofs with len from addr\n"
- "onenand erase saddr eaddr - erase block start addr to end addr\n"
- "onenand block[.oob] addr block [page] [len] - "
- "read data with (block [, page]) to addr\n"
Sorry for the nitpicking, but I recommend to make this:
so it's clearly visible what that will look like. You may even use an explicit continuation mark (trailing backslash) on the line before, even though it's not necessary - just as a reminder for the reader.
Kyungmin Park
