[U-Boot] [PATCH] drivers/mmc: move spl_mmc.c to common/spl
The mpc85xx repuires a special layout on the memory device that is connected to the eSDHC controller interface. But the file spl_mmc.c didn't handle this specfic case, there needs a special treatmen, in the powerpc drictory. So, there is no longer to keep spl_mmc.c on mpc85xx, CONFIG_SPL_FRAMEWORK is not set.
When CONFIG_SPL_MMC_SUPPORT is set and CONFIG_SPL_FRAMEWORK is not set, there was an error in drivers/mmc/spl_mmc.c:
drivers/mmc/libmmc.o:(.got2+0x8): undefined reference to `spl_image'.
Now, the solution is to move the file "spl_mmc.c" to directory "common/spl".
Signed-off-by: Ying Zhang b40530@freescale.com --- common/spl/Makefile | 1 + common/spl/spl_mmc.c | 137 +++++++++++++++++++++++++++++++++++++++++++++++++ drivers/mmc/Makefile | 3 - drivers/mmc/spl_mmc.c | 137 ------------------------------------------------- 4 files changed, 138 insertions(+), 140 deletions(-) create mode 100644 common/spl/spl_mmc.c delete mode 100644 drivers/mmc/spl_mmc.c
diff --git a/common/spl/Makefile b/common/spl/Makefile index da2afc1..a74563c 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -20,6 +20,7 @@ COBJS-$(CONFIG_SPL_YMODEM_SUPPORT) += spl_ymodem.o COBJS-$(CONFIG_SPL_NAND_SUPPORT) += spl_nand.o COBJS-$(CONFIG_SPL_ONENAND_SUPPORT) += spl_onenand.o COBJS-$(CONFIG_SPL_NET_SUPPORT) += spl_net.o +COBJS-$(CONFIG_SPL_MMC_SUPPORT) += spl_mmc.o endif
COBJS := $(sort $(COBJS-y)) diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c new file mode 100644 index 0000000..7efdcb8 --- /dev/null +++ b/common/spl/spl_mmc.c @@ -0,0 +1,137 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <spl.h> +#include <asm/u-boot.h> +#include <asm/utils.h> +#include <mmc.h> +#include <fat.h> +#include <version.h> + +DECLARE_GLOBAL_DATA_PTR; + +static void mmc_load_image_raw(struct mmc *mmc) +{ + unsigned long err; + u32 image_size_sectors; + struct image_header *header; + + header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - + sizeof(struct image_header)); + + /* read image header to find the image size & load address */ + err = mmc->block_dev.block_read(0, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, 1, + header); + + if (err == 0) + goto end; + + spl_parse_image_header(header); + + /* convert size to sectors - round up */ + image_size_sectors = (spl_image.size + mmc->read_bl_len - 1) / + mmc->read_bl_len; + + /* Read the header too to avoid extra memcpy */ + err = mmc->block_dev.block_read(0, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, + image_size_sectors, (void *)spl_image.load_addr); + +end: + if (err == 0) { + printf("spl: mmc blk read err - %lu\n", err); + hang(); + } +} + +#ifdef CONFIG_SPL_FAT_SUPPORT +static void mmc_load_image_fat(struct mmc *mmc) +{ + int err; + struct image_header *header; + + header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - + sizeof(struct image_header)); + + err = fat_register_device(&mmc->block_dev, + CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION); + if (err) { + printf("spl: fat register err - %d\n", err); + hang(); + } + + err = file_fat_read(CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, + header, sizeof(struct image_header)); + if (err <= 0) + goto end; + + spl_parse_image_header(header); + + err = file_fat_read(CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, + (u8 *)spl_image.load_addr, 0); + +end: + if (err <= 0) { + printf("spl: error reading image %s, err - %d\n", + CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, err); + hang(); + } +} +#endif + +void spl_mmc_load_image(void) +{ + struct mmc *mmc; + int err; + u32 boot_mode; + + mmc_initialize(gd->bd); + /* We register only one device. So, the dev id is always 0 */ + mmc = find_mmc_device(0); + if (!mmc) { + puts("spl: mmc device not found!!\n"); + hang(); + } + + err = mmc_init(mmc); + if (err) { + printf("spl: mmc init failed: err - %d\n", err); + hang(); + } + boot_mode = spl_boot_mode(); + if (boot_mode == MMCSD_MODE_RAW) { + debug("boot mode - RAW\n"); + mmc_load_image_raw(mmc); +#ifdef CONFIG_SPL_FAT_SUPPORT + } else if (boot_mode == MMCSD_MODE_FAT) { + debug("boot mode - FAT\n"); + mmc_load_image_fat(mmc); +#endif + } else { + puts("spl: wrong MMC boot mode\n"); + hang(); + } +} diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index fb6b502..196ef9b 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -25,9 +25,6 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libmmc.o
-ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_MMC_SUPPORT) += spl_mmc.o -endif
COBJS-$(CONFIG_BFIN_SDH) += bfin_sdh.o COBJS-$(CONFIG_DAVINCI_MMC) += davinci_mmc.o diff --git a/drivers/mmc/spl_mmc.c b/drivers/mmc/spl_mmc.c deleted file mode 100644 index 7efdcb8..0000000 --- a/drivers/mmc/spl_mmc.c +++ /dev/null @@ -1,137 +0,0 @@ -/* - * (C) Copyright 2010 - * Texas Instruments, <www.ti.com> - * - * Aneesh V aneesh@ti.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#include <common.h> -#include <spl.h> -#include <asm/u-boot.h> -#include <asm/utils.h> -#include <mmc.h> -#include <fat.h> -#include <version.h> - -DECLARE_GLOBAL_DATA_PTR; - -static void mmc_load_image_raw(struct mmc *mmc) -{ - unsigned long err; - u32 image_size_sectors; - struct image_header *header; - - header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - - sizeof(struct image_header)); - - /* read image header to find the image size & load address */ - err = mmc->block_dev.block_read(0, - CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, 1, - header); - - if (err == 0) - goto end; - - spl_parse_image_header(header); - - /* convert size to sectors - round up */ - image_size_sectors = (spl_image.size + mmc->read_bl_len - 1) / - mmc->read_bl_len; - - /* Read the header too to avoid extra memcpy */ - err = mmc->block_dev.block_read(0, - CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, - image_size_sectors, (void *)spl_image.load_addr); - -end: - if (err == 0) { - printf("spl: mmc blk read err - %lu\n", err); - hang(); - } -} - -#ifdef CONFIG_SPL_FAT_SUPPORT -static void mmc_load_image_fat(struct mmc *mmc) -{ - int err; - struct image_header *header; - - header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - - sizeof(struct image_header)); - - err = fat_register_device(&mmc->block_dev, - CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION); - if (err) { - printf("spl: fat register err - %d\n", err); - hang(); - } - - err = file_fat_read(CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, - header, sizeof(struct image_header)); - if (err <= 0) - goto end; - - spl_parse_image_header(header); - - err = file_fat_read(CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, - (u8 *)spl_image.load_addr, 0); - -end: - if (err <= 0) { - printf("spl: error reading image %s, err - %d\n", - CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, err); - hang(); - } -} -#endif - -void spl_mmc_load_image(void) -{ - struct mmc *mmc; - int err; - u32 boot_mode; - - mmc_initialize(gd->bd); - /* We register only one device. So, the dev id is always 0 */ - mmc = find_mmc_device(0); - if (!mmc) { - puts("spl: mmc device not found!!\n"); - hang(); - } - - err = mmc_init(mmc); - if (err) { - printf("spl: mmc init failed: err - %d\n", err); - hang(); - } - boot_mode = spl_boot_mode(); - if (boot_mode == MMCSD_MODE_RAW) { - debug("boot mode - RAW\n"); - mmc_load_image_raw(mmc); -#ifdef CONFIG_SPL_FAT_SUPPORT - } else if (boot_mode == MMCSD_MODE_FAT) { - debug("boot mode - FAT\n"); - mmc_load_image_fat(mmc); -#endif - } else { - puts("spl: wrong MMC boot mode\n"); - hang(); - } -}
