[U-Boot] [PATCH] arm: rmobile: alt: Add ethernet function B support
From: Mitsuhiro Kimura mitsuhiro.kimura.kc@renesas.com
Ethernet function of Alt board can select normal and B by DIP switch on board. But user need to set not only DIP switch but also pin function. This adds pin function of Ethernet function B. This can select from Kconfig.
Signed-off-by: Mitsuhiro Kimura mitsuhiro.kimura.kc@renesas.com Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- board/renesas/alt/Kconfig | 9 +++++++++ board/renesas/alt/alt.c | 17 ++++++++++++++++- 2 files changed, 25 insertions(+), 1 deletion(-)
diff --git a/board/renesas/alt/Kconfig b/board/renesas/alt/Kconfig index 957962d..39d53c1 100644 --- a/board/renesas/alt/Kconfig +++ b/board/renesas/alt/Kconfig @@ -9,4 +9,13 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "alt"
+config R8A7794_ETHERNET_B + bool "Use ethernet B function" + depends on TARGET_ALT + default n + help + ALT board can use default ethernet and etnernet B function. + This config set pin function of ethenet B. You also needt to change + DIP switch of board in order to use this function. + endif diff --git a/board/renesas/alt/alt.c b/board/renesas/alt/alt.c index f0010db..3501a17 100644 --- a/board/renesas/alt/alt.c +++ b/board/renesas/alt/alt.c @@ -1,7 +1,7 @@ /* * board/renesas/alt/alt.c * - * Copyright (C) 2014 Renesas Electronics Corporation + * Copyright (C) 2014, 2015 Renesas Electronics Corporation * * SPDX-License-Identifier: GPL-2.0 */ @@ -94,6 +94,20 @@ int board_init(void) r8a7794_pinmux_init();
/* Ether Enable */ +#if defined(CONFIG_R8A7794_ETHERNET_B) + gpio_request(GPIO_FN_ETH_CRS_DV_B, NULL); + gpio_request(GPIO_FN_ETH_RX_ER_B, NULL); + gpio_request(GPIO_FN_ETH_RXD0_B, NULL); + gpio_request(GPIO_FN_ETH_RXD1_B, NULL); + gpio_request(GPIO_FN_ETH_LINK_B, NULL); + gpio_request(GPIO_FN_ETH_REFCLK_B, NULL); + gpio_request(GPIO_FN_ETH_MDIO_B, NULL); + gpio_request(GPIO_FN_ETH_TXD1_B, NULL); + gpio_request(GPIO_FN_ETH_TX_EN_B, NULL); + gpio_request(GPIO_FN_ETH_MAGIC_B, NULL); + gpio_request(GPIO_FN_ETH_TXD0_B, NULL); + gpio_request(GPIO_FN_ETH_MDC_B, NULL); +#else gpio_request(GPIO_FN_ETH_CRS_DV, NULL); gpio_request(GPIO_FN_ETH_RX_ER, NULL); gpio_request(GPIO_FN_ETH_RXD0, NULL); @@ -106,6 +120,7 @@ int board_init(void) gpio_request(GPIO_FN_ETH_MAGIC, NULL); gpio_request(GPIO_FN_ETH_TXD0, NULL); gpio_request(GPIO_FN_ETH_MDC, NULL); +#endif gpio_request(GPIO_FN_IRQ8, NULL);
/* PHY reset */
Nobuhiro Iwamatsu
