[U-Boot] [PATCH] AM3517_EVM: Fix Environmental location
The am3517-evm boards stores the environment in NAND, but after merging various configs, the board was trying to load environment variables from FAT which would ultimately fail and cause some chatter.
This patch removes the ENV_IS_IN_FAT flag to eliminate the noise.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 8a94fd3ce0..6643f93e33 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -30,6 +30,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(MLO),1920k(u-boot),256k(u-boot-env),8m(kernel),512k(dtb),-(rootfs)" CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y +# CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y
Adam Ford
