[U-Boot] [PATCH 0/8] Convert i.MX7 WaRP7 ports to DM
This series does a minimal conversion of WaRP7 and the BL33 version of WaRP7 to the DM.
Pinctrl, GPIO, I2C, Regulators, PMIC and MMC are converted. Later patches will convert USB and UART.
Bryan O'Donoghue (8): arm: dts: imx7s-warp: Import Linux warp7 dts arm: imx7s-warp: Add DT file hooks arm: imx7s-warp: Convert to DM MMC initialization arm: dts: imx7s-warp: Create alias for mmc0 to &usdhc3 warp7: defconfig: Switch on IMX7 pinctrl for both ports warp7: defconfig: Switch on DM GPIO for both warp7 ports warp7: defconfig: Switch to DM for I2C arm: imx7s-warp: Convert to DM PMIC
arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx7s-warp.dts | 416 +++++++++++++++++++++++++++++++++++ board/warp7/warp7.c | 85 +------ configs/warp7_bl33_defconfig | 14 +- configs/warp7_defconfig | 14 +- include/configs/warp7.h | 8 - 6 files changed, 455 insertions(+), 85 deletions(-) create mode 100644 arch/arm/dts/imx7s-warp.dts
This patch imports the Linux kernel warp7 dts as at upstream kernel commit cf76c364a1e1.
The following was dropped from the incoming kernel DTS file
-&wdog1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_wdog>; - fsl,ext-reset-output; - status = "okay"; -}; - - -&iomuxc_lpsr { - pinctrl_wdog: wdoggrp { - fsl,pins = < - MX7D_PAD_LPSR_GPIO1_IO00__WDOG1_WDOG_B 0x74 - >; - }; -};
it causes a DTC compile error for me and isn't needed for u-boot in any case.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Peng Fan peng.fan@nxp.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/dts/imx7s-warp.dts | 423 ++++++++++++++++++++++++++++++++++++ 1 file changed, 423 insertions(+) create mode 100644 arch/arm/dts/imx7s-warp.dts
diff --git a/arch/arm/dts/imx7s-warp.dts b/arch/arm/dts/imx7s-warp.dts new file mode 100644 index 0000000000..c44db20734 --- /dev/null +++ b/arch/arm/dts/imx7s-warp.dts @@ -0,0 +1,423 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2016 NXP Semiconductors. + * Author: Fabio Estevam fabio.estevam@nxp.com + */ + +/dts-v1/; + +#include <dt-bindings/input/input.h> +#include "imx7s.dtsi" + +/ { + model = "Warp i.MX7 Board"; + compatible = "warp,imx7s-warp", "fsl,imx7s"; + + memory@80000000 { + reg = <0x80000000 0x20000000>; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-0 = <&pinctrl_gpio>; + autorepeat; + + back { + label = "Back"; + gpios = <&gpio7 1 GPIO_ACTIVE_HIGH>; + linux,code = <KEY_BACK>; + wakeup-source; + }; + }; + + reg_brcm: regulator-brcm { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio5 10 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_brcm_reg>; + regulator-name = "brcm_reg"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <200000>; + }; + + reg_bt: regulator-bt { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_bt_reg>; + enable-active-high; + gpio = <&gpio5 17 GPIO_ACTIVE_HIGH>; + regulator-name = "bt_reg"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "imx7-sgtl5000"; + simple-audio-card,format = "i2s"; + simple-audio-card,bitclock-master = <&dailink_master>; + simple-audio-card,frame-master = <&dailink_master>; + simple-audio-card,cpu { + sound-dai = <&sai1>; + }; + + dailink_master: simple-audio-card,codec { + sound-dai = <&codec>; + clocks = <&clks IMX7D_AUDIO_MCLK_ROOT_CLK>; + }; + }; +}; + +&clks { + assigned-clocks = <&clks IMX7D_PLL_AUDIO_POST_DIV>; + assigned-clock-rates = <884736000>; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + pmic: pfuze3000@8 { + compatible = "fsl,pfuze3000"; + reg = <0x08>; + + regulators { + sw1a_reg: sw1a { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1475000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + /* use sw1c_reg to align with pfuze100/pfuze200 */ + sw1c_reg: sw1b { + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1475000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw2_reg: sw2 { + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1850000>; + regulator-boot-on; + regulator-always-on; + }; + + sw3a_reg: sw3 { + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <1650000>; + regulator-boot-on; + regulator-always-on; + }; + + swbst_reg: swbst { + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + }; + + vgen1_reg: vldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen2_reg: vldo2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen3_reg: vccsd { + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen4_reg: v33 { + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen5_reg: vldo3 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + vgen6_reg: vldo4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&i2c3 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; +}; + +&i2c4 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + status = "okay"; + + codec: sgtl5000@a { + #sound-dai-cells = <0>; + reg = <0x0a>; + compatible = "fsl,sgtl5000"; + clocks = <&clks IMX7D_AUDIO_MCLK_ROOT_CLK>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai1_mclk>; + VDDA-supply = <&vgen4_reg>; + VDDIO-supply = <&vgen4_reg>; + VDDD-supply = <&vgen2_reg>; + }; + + mpl3115@60 { + compatible = "fsl,mpl3115"; + reg = <0x60>; + }; +}; + +&sai1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai1>; + assigned-clocks = <&clks IMX7D_SAI1_ROOT_SRC>, + <&clks IMX7D_SAI1_ROOT_CLK>; + assigned-clock-parents = <&clks IMX7D_PLL_AUDIO_POST_DIV>; + assigned-clock-rates = <0>, <36864000>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + assigned-clocks = <&clks IMX7D_UART1_ROOT_SRC>; + assigned-clock-parents = <&clks IMX7D_PLL_SYS_MAIN_240M_CLK>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + assigned-clocks = <&clks IMX7D_UART3_ROOT_SRC>; + assigned-clock-parents = <&clks IMX7D_PLL_SYS_MAIN_240M_CLK>; + uart-has-rtscts; + status = "okay"; +}; + +&uart6 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart6>; + assigned-clocks = <&clks IMX7D_UART6_ROOT_SRC>; + assigned-clock-parents = <&clks IMX7D_PLL_SYS_MAIN_240M_CLK>; + fsl,dte-mode; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "peripheral"; + status = "okay"; +}; + +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1>; + bus-width = <4>; + keep-power-in-suspend; + no-1-8-v; + non-removable; + vmmc-supply = <®_brcm>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + assigned-clocks = <&clks IMX7D_USDHC3_ROOT_CLK>; + assigned-clock-rates = <400000000>; + bus-width = <8>; + no-1-8-v; + fsl,tuning-step = <2>; + non-removable; + status = "okay"; +}; + +&iomuxc { + pinctrl_brcm_reg: brcmreggrp { + fsl,pins = < + MX7D_PAD_SD2_WP__GPIO5_IO10 0x14 /* WL_REG_ON */ + >; + }; + + pinctrl_bt_reg: btreggrp { + fsl,pins = < + MX7D_PAD_SD2_DATA3__GPIO5_IO17 0x14 /* BT_REG_ON */ + >; + }; + + pinctrl_gpio: gpiogrp { + fsl,pins = < + MX7D_PAD_ENET1_RGMII_RD1__GPIO7_IO1 0x14 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX7D_PAD_I2C1_SDA__I2C1_SDA 0x4000007f + MX7D_PAD_I2C1_SCL__I2C1_SCL 0x4000007f + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX7D_PAD_I2C2_SDA__I2C2_SDA 0x4000007f + MX7D_PAD_I2C2_SCL__I2C2_SCL 0x4000007f + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX7D_PAD_I2C3_SDA__I2C3_SDA 0x4000007f + MX7D_PAD_I2C3_SCL__I2C3_SCL 0x4000007f + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX7D_PAD_I2C4_SCL__I2C4_SCL 0x4000007f + MX7D_PAD_I2C4_SDA__I2C4_SDA 0x4000007f + >; + }; + + pinctrl_sai1: sai1grp { + fsl,pins = < + MX7D_PAD_SAI1_RX_DATA__SAI1_RX_DATA0 0x1f + MX7D_PAD_SAI1_TX_BCLK__SAI1_TX_BCLK 0x1f + MX7D_PAD_SAI1_TX_SYNC__SAI1_TX_SYNC 0x1f + MX7D_PAD_SAI1_TX_DATA__SAI1_TX_DATA0 0x30 + >; + }; + + pinctrl_sai1_mclk: sai1mclkgrp { + fsl,pins = < + MX7D_PAD_SAI1_MCLK__SAI1_MCLK 0x1f + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX7D_PAD_UART1_TX_DATA__UART1_DCE_TX 0x79 + MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX 0x79 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX7D_PAD_UART3_TX_DATA__UART3_DCE_TX 0x79 + MX7D_PAD_UART3_RX_DATA__UART3_DCE_RX 0x79 + MX7D_PAD_UART3_CTS_B__UART3_DCE_CTS 0x79 + MX7D_PAD_UART3_RTS_B__UART3_DCE_RTS 0x79 + >; + }; + + pinctrl_uart6: uart6grp { + fsl,pins = < + MX7D_PAD_ECSPI1_MOSI__UART6_DTE_RX 0x79 + MX7D_PAD_ECSPI1_SCLK__UART6_DTE_TX 0x79 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX7D_PAD_SD1_CMD__SD1_CMD 0x59 + MX7D_PAD_SD1_CLK__SD1_CLK 0x19 + MX7D_PAD_SD1_DATA0__SD1_DATA0 0x59 + MX7D_PAD_SD1_DATA1__SD1_DATA1 0x59 + MX7D_PAD_SD1_DATA2__SD1_DATA2 0x59 + MX7D_PAD_SD1_DATA3__SD1_DATA3 0x59 + MX7D_PAD_SD2_RESET_B__GPIO5_IO11 0x14 /* WL_HOST_WAKE */ + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX7D_PAD_SD3_CMD__SD3_CMD 0x59 + MX7D_PAD_SD3_CLK__SD3_CLK 0x19 + MX7D_PAD_SD3_DATA0__SD3_DATA0 0x59 + MX7D_PAD_SD3_DATA1__SD3_DATA1 0x59 + MX7D_PAD_SD3_DATA2__SD3_DATA2 0x59 + MX7D_PAD_SD3_DATA3__SD3_DATA3 0x59 + MX7D_PAD_SD3_DATA4__SD3_DATA4 0x59 + MX7D_PAD_SD3_DATA5__SD3_DATA5 0x59 + MX7D_PAD_SD3_DATA6__SD3_DATA6 0x59 + MX7D_PAD_SD3_DATA7__SD3_DATA7 0x59 + MX7D_PAD_SD3_RESET_B__SD3_RESET_B 0x19 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp_100mhz { + fsl,pins = < + MX7D_PAD_SD3_CMD__SD3_CMD 0x5a + MX7D_PAD_SD3_CLK__SD3_CLK 0x1a + MX7D_PAD_SD3_DATA0__SD3_DATA0 0x5a + MX7D_PAD_SD3_DATA1__SD3_DATA1 0x5a + MX7D_PAD_SD3_DATA2__SD3_DATA2 0x5a + MX7D_PAD_SD3_DATA3__SD3_DATA3 0x5a + MX7D_PAD_SD3_DATA4__SD3_DATA4 0x5a + MX7D_PAD_SD3_DATA5__SD3_DATA5 0x5a + MX7D_PAD_SD3_DATA6__SD3_DATA6 0x5a + MX7D_PAD_SD3_DATA7__SD3_DATA7 0x5a + MX7D_PAD_SD3_RESET_B__SD3_RESET_B 0x1a + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp_200mhz { + fsl,pins = < + MX7D_PAD_SD3_CMD__SD3_CMD 0x5b + MX7D_PAD_SD3_CLK__SD3_CLK 0x1b + MX7D_PAD_SD3_DATA0__SD3_DATA0 0x5b + MX7D_PAD_SD3_DATA1__SD3_DATA1 0x5b + MX7D_PAD_SD3_DATA2__SD3_DATA2 0x5b + MX7D_PAD_SD3_DATA3__SD3_DATA3 0x5b + MX7D_PAD_SD3_DATA4__SD3_DATA4 0x5b + MX7D_PAD_SD3_DATA5__SD3_DATA5 0x5b + MX7D_PAD_SD3_DATA6__SD3_DATA6 0x5b + MX7D_PAD_SD3_DATA7__SD3_DATA7 0x5b + MX7D_PAD_SD3_RESET_B__SD3_RESET_B 0x1b + >; + }; +};
Hi Bryan,
-&wdog1 {
status = "okay";
-&iomuxc_lpsr {
fsl,pins = <
This is caused by a typo in arch/arm/dts/imx7d-pinfunc.h, which lists it as MX7D_PAD_LPSR_GPIO1_IO00__WDOD1_WDOG_B (WDOD instead of WDOG). I am not familiar with the imx7s-warp, but other imx7 boards use the external reset of the watchdog timer to reset the system.
Thanks, Lukas
diff --git a/arch/arm/dts/imx7s-warp.dts b/arch/arm/dts/imx7s- warp.dts new file mode 100644 index 0000000000..c44db20734 --- /dev/null +++ b/arch/arm/dts/imx7s-warp.dts @@ -0,0 +1,423 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
- Copyright (C) 2016 NXP Semiconductors.
- Author: Fabio Estevam fabio.estevam@nxp.com
+/dts-v1/;
- model = "Warp i.MX7 Board";
- compatible = "warp,imx7s-warp", "fsl,imx7s";
- memory@80000000 {
- gpio-keys {
autorepeat;
back {
label = "Back";
wakeup-source;
- reg_brcm: regulator-brcm {
enable-active-high;
- reg_bt: regulator-bt {
enable-active-high;
- sound {
+&clks {
- assigned-clocks = <&clks IMX7D_PLL_AUDIO_POST_DIV>;
- assigned-clock-rates = <884736000>;
+&i2c1 {
- pinctrl-0 = <&pinctrl_i2c1>;
- status = "okay";
- pmic: pfuze3000@8 {
reg = <0x08>;
regulators {
sw1a_reg: sw1a {
regulator-boot-on;
sw1c_reg: sw1b {
regulator-boot-on;
sw2_reg: sw2 {
regulator-boot-on;
sw3a_reg: sw3 {
regulator-boot-on;
swbst_reg: swbst {
snvs_reg: vsnvs {
regulator-boot-on;
vref_reg: vrefddr {
regulator-boot-on;
vgen1_reg: vldo1 {
vgen2_reg: vldo2 {
vgen3_reg: vccsd {
vgen4_reg: v33 {
vgen5_reg: vldo3 {
vgen6_reg: vldo4 {
+&i2c2 {
- clock-frequency = <100000>;
- pinctrl-0 = <&pinctrl_i2c2>;
- status = "okay";
+&i2c3 {
- pinctrl-0 = <&pinctrl_i2c3>;
- status = "okay";
+&i2c4 {
- pinctrl-0 = <&pinctrl_i2c4>;
- status = "okay";
- codec: sgtl5000@a {
reg = <0x0a>;
- mpl3115@60 {
reg = <0x60>;
+&sai1 {
- pinctrl-0 = <&pinctrl_sai1>;
- assigned-clocks = <&clks IMX7D_SAI1_ROOT_SRC>,
- assigned-clock-parents = <&clks IMX7D_PLL_AUDIO_POST_DIV>;
- assigned-clock-rates = <0>, <36864000>;
- status = "okay";
+&uart1 {
- pinctrl-0 = <&pinctrl_uart1>;
- assigned-clocks = <&clks IMX7D_UART1_ROOT_SRC>;
- assigned-clock-parents = <&clks IMX7D_PLL_SYS_MAIN_240M_CLK>;
- status = "okay";
+&uart3 {
- pinctrl-0 = <&pinctrl_uart3>;
- assigned-clocks = <&clks IMX7D_UART3_ROOT_SRC>;
- uart-has-rtscts;
- status = "okay";
+&uart6 {
- pinctrl-0 = <&pinctrl_uart6>;
- assigned-clocks = <&clks IMX7D_UART6_ROOT_SRC>;
- fsl,dte-mode;
- status = "okay";
+&usbotg1 {
- dr_mode = "peripheral";
- status = "okay";
+&usdhc1 {
- pinctrl-0 = <&pinctrl_usdhc1>;
- bus-width = <4>;
- keep-power-in-suspend;
- no-1-8-v;
- non-removable;
- vmmc-supply = <®_brcm>;
- status = "okay";
+&usdhc3 {
- pinctrl-names = "default", "state_100mhz", "state_200mhz";
- pinctrl-0 = <&pinctrl_usdhc3>;
- pinctrl-1 = <&pinctrl_usdhc3_100mhz>;
- pinctrl-2 = <&pinctrl_usdhc3_200mhz>;
- assigned-clocks = <&clks IMX7D_USDHC3_ROOT_CLK>;
- assigned-clock-rates = <400000000>;
- bus-width = <8>;
- no-1-8-v;
- fsl,tuning-step = <2>;
- non-removable;
- status = "okay";
+&iomuxc {
- pinctrl_brcm_reg: brcmreggrp {
fsl,pins = <
WL_REG_ON */
- pinctrl_bt_reg: btreggrp {
fsl,pins = <
BT_REG_ON */
- pinctrl_gpio: gpiogrp {
fsl,pins = <
- pinctrl_i2c1: i2c1grp {
fsl,pins = <
0007f
0007f
- pinctrl_i2c2: i2c2grp {
fsl,pins = <
- pinctrl_i2c3: i2c3grp {
fsl,pins = <
- pinctrl_i2c4: i2c4grp {
fsl,pins = <
- pinctrl_sai1: sai1grp {
fsl,pins = <
- pinctrl_sai1_mclk: sai1mclkgrp {
fsl,pins = <
- pinctrl_uart1: uart1grp {
fsl,pins = <
- pinctrl_uart3: uart3grp {
fsl,pins = <
- pinctrl_uart6: uart6grp {
fsl,pins = <
- pinctrl_usdhc1: usdhc1grp {
fsl,pins = <
WL_HOST_WAKE */
- pinctrl_usdhc3: usdhc3grp {
fsl,pins = <
- pinctrl_usdhc3_100mhz: usdhc3grp_100mhz {
fsl,pins = <
- pinctrl_usdhc3_200mhz: usdhc3grp_200mhz {
fsl,pins = <
ah good catch
let me go fix that and we can import the DT wholesale
Hi Bryan,
-----Original Message----- From: Bryan O'Donoghue [mailto:bryan.odonoghue@linaro.org] Sent: 2019年1月3日 9:45 To: u-boot@lists.denx.de Cc: Fabio Estevam fabio.estevam@nxp.com; Peng Fan peng.fan@nxp.com; Bryan O'Donoghue bryan.odonoghue@linaro.org; Albert Aribaud albert.u.boot@aribaud.net; Stefano Babic sbabic@denx.de Subject: [PATCH 1/8] arm: dts: imx7s-warp: Import Linux warp7 dts
U-Boot dts synced from Linux Kernel DTS file. If there is issue, it should be fixed in Linux side and imported to U-Boot.
Regards, Peng
-&wdog1 {
status = "okay";
-&iomuxc_lpsr {
fsl,pins = <
- Author: Fabio Estevam fabio.estevam@nxp.com */
+/dts-v1/;
- memory@80000000 {
- gpio-keys {
autorepeat;
back {
label = "Back";
wakeup-source;
enable-active-high;
enable-active-high;
- sound {
+&clks {
+&i2c1 {
- status = "okay";
reg = <0x08>;
regulators {
sw1a_reg: sw1a {
regulator-boot-on;
sw1c_reg: sw1b {
regulator-boot-on;
sw2_reg: sw2 {
regulator-boot-on;
sw3a_reg: sw3 {
regulator-boot-on;
swbst_reg: swbst {
snvs_reg: vsnvs {
regulator-boot-on;
vref_reg: vrefddr {
regulator-boot-on;
vgen1_reg: vldo1 {
vgen2_reg: vldo2 {
vgen3_reg: vccsd {
vgen4_reg: v33 {
vgen5_reg: vldo3 {
vgen6_reg: vldo4 {
+&i2c2 {
- status = "okay";
+&i2c3 {
- status = "okay";
+&i2c4 {
- status = "okay";
reg = <0x0a>;
- mpl3115@60 {
reg = <0x60>;
+&sai1 {
- status = "okay";
+&uart1 {
- status = "okay";
+&uart3 {
- uart-has-rtscts;
- status = "okay";
+&uart6 {
- fsl,dte-mode;
- status = "okay";
+&usbotg1 {
- status = "okay";
+&usdhc1 {
- bus-width = <4>;
- no-1-8-v;
- non-removable;
- status = "okay";
+&usdhc3 {
- bus-width = <8>;
- no-1-8-v;
- non-removable;
- status = "okay";
+&iomuxc {
fsl,pins = <
fsl,pins = <
BT_REG_ON */
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
fsl,pins = <
WL_HOST_WAKE */
fsl,pins = <
fsl,pins = <
fsl,pins = <
2.20.0
This patch adds DT file hooks for imx7s-warp.dtb to the warp7 and warp7_bl33 builds.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Peng Fan peng.fan@nxp.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/dts/Makefile | 3 ++- configs/warp7_bl33_defconfig | 3 ++- configs/warp7_defconfig | 3 ++- 3 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index dda4e59491..4fe7e90902 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -460,7 +460,8 @@ dtb-$(CONFIG_MX6ULL) += imx6ull-14x14-evk.dtb
dtb-$(CONFIG_MX7) += imx7-colibri.dtb \ imx7d-sdb.dtb \ - imx7d-sdb-qspi.dtb + imx7d-sdb-qspi.dtb \ + imx7s-warp.dtb
dtb-$(CONFIG_ARCH_MX7ULP) += imx7ulp-evk.dtb
diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index a568c6d10e..12141fedd3 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -20,6 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DFU_MMC=y @@ -37,5 +38,5 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" -CONFIG_OF_LIBFDT=y CONFIG_OPTEE_TZDRAM_SIZE=0x2000000 +CONFIG_DEFAULT_DEVICE_TREE="imx7s-warp" diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 4d443295ba..fee98dfbbe 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -29,6 +29,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DFU_MMC=y @@ -47,8 +48,8 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" -CONFIG_OF_LIBFDT=y CONFIG_OPTEE_LOAD_ADDR=0x84000000 CONFIG_OPTEE_TZDRAM_SIZE=0x3000000 CONFIG_OPTEE_TZDRAM_BASE=0x9d000000 CONFIG_BOOTM_OPTEE=y +CONFIG_DEFAULT_DEVICE_TREE="imx7s-warp"
-----Original Message----- From: Bryan O'Donoghue [mailto:bryan.odonoghue@linaro.org] Sent: 2019年1月3日 9:45 To: u-boot@lists.denx.de Cc: Fabio Estevam fabio.estevam@nxp.com; Peng Fan peng.fan@nxp.com; Bryan O'Donoghue bryan.odonoghue@linaro.org; Albert Aribaud albert.u.boot@aribaud.net; Stefano Babic sbabic@denx.de Subject: [PATCH 2/8] arm: imx7s-warp: Add DT file hooks
- imx7d-sdb-qspi.dtb \
- imx7s-warp.dtb
Reviewed-by: Peng Fan peng.fan@nxp.com
-- 2.20.0
Converts from fixed initialization of MMC to DM initialization of MMC.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Peng Fan peng.fan@nxp.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/dts/imx7s-warp.dts | 11 ----------- board/warp7/warp7.c | 34 ---------------------------------- configs/warp7_bl33_defconfig | 1 + configs/warp7_defconfig | 1 + 4 files changed, 2 insertions(+), 45 deletions(-)
diff --git a/arch/arm/dts/imx7s-warp.dts b/arch/arm/dts/imx7s-warp.dts index c44db20734..615ed7ed80 100644 --- a/arch/arm/dts/imx7s-warp.dts +++ b/arch/arm/dts/imx7s-warp.dts @@ -251,17 +251,6 @@ status = "okay"; };
-&usdhc1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usdhc1>; - bus-width = <4>; - keep-power-in-suspend; - no-1-8-v; - non-removable; - vmmc-supply = <®_brcm>; - status = "okay"; -}; - &usdhc3 { pinctrl-names = "default", "state_100mhz", "state_200mhz"; pinctrl-0 = <&pinctrl_usdhc3>; diff --git a/board/warp7/warp7.c b/board/warp7/warp7.c index 3d32b3eb52..146d722b15 100644 --- a/board/warp7/warp7.c +++ b/board/warp7/warp7.c @@ -30,8 +30,6 @@ DECLARE_GLOBAL_DATA_PTR;
#define UART_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_PUS_PU100KOHM | \ PAD_CTL_HYS) -#define USDHC_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ - PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU47KOHM)
#define I2C_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU100KOHM) @@ -74,43 +72,11 @@ static iomux_v3_cfg_t const uart1_pads[] = { MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), };
-static iomux_v3_cfg_t const usdhc3_pads[] = { - MX7D_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_DATA7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX7D_PAD_SD3_RESET_B__SD3_RESET_B | MUX_PAD_CTRL(USDHC_PAD_CTRL), -}; - static void setup_iomux_uart(void) { imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); };
-static struct fsl_esdhc_cfg usdhc_cfg[1] = { - {USDHC3_BASE_ADDR}, -}; - -int board_mmc_getcd(struct mmc *mmc) -{ - /* Assume uSDHC3 emmc is always present */ - return 1; -} - -int board_mmc_init(bd_t *bis) -{ - imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - - return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); -} - int board_early_init_f(void) { setup_iomux_uart(); diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index 12141fedd3..b2f943c775 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -24,6 +24,7 @@ CONFIG_OF_CONTROL=y CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DFU_MMC=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index fee98dfbbe..65d801ffe2 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -33,6 +33,7 @@ CONFIG_OF_CONTROL=y CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DFU_MMC=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_OPTEE=y CONFIG_USB=y
Hi Bryan,
-----Original Message----- From: Bryan O'Donoghue [mailto:bryan.odonoghue@linaro.org] Sent: 2019年1月3日 9:45 To: u-boot@lists.denx.de Cc: Fabio Estevam fabio.estevam@nxp.com; Peng Fan peng.fan@nxp.com; Bryan O'Donoghue bryan.odonoghue@linaro.org; Albert Aribaud albert.u.boot@aribaud.net; Stefano Babic sbabic@denx.de Subject: [PATCH 3/8] arm: imx7s-warp: Convert to DM MMC initialization
-&usdhc1 {
- bus-width = <4>;
- no-1-8-v;
- non-removable;
- status = "okay";
Why drop this node? Seems this is for SDIO wifi, Is there any issue if keep this node?
Regards, Peng.
return 1;
int board_early_init_f(void) { setup_iomux_uart(); diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index 12141fedd3..b2f943c775 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -24,6 +24,7 @@ CONFIG_OF_CONTROL=y CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DFU_MMC=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index fee98dfbbe..65d801ffe2 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -33,6 +33,7 @@ CONFIG_OF_CONTROL=y CONFIG_CMD_FS_GENERIC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DFU_MMC=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_OPTEE=y CONFIG_USB=y -- 2.20.0
On 08/01/2019 13:22, Peng Fan wrote:
Hi Bryan,
-&usdhc1 {
- bus-width = <4>;
- no-1-8-v;
- non-removable;
- status = "okay";
Actually no, we can keep it since we use an alias to conjoin usdhc3 to mmc0 later on.
I'll do that.
This patch sets up an alias for mmc0 to usdhc3.
Before the DM conversion only usdhc3 was enabled and therefore it appeared as MMC 0 to u-boot. After enabling MMC DM though usdhc3 defaults to MMC 2, which left unattended would drive changes to existing warp7 bootscripts and environment variables that rely on mmc 0.
Setup the alias of mmc0 and usdhc3 so that existing warp7 boot code will work unmodified.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Peng Fan peng.fan@nxp.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/dts/imx7s-warp.dts | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/imx7s-warp.dts b/arch/arm/dts/imx7s-warp.dts index 615ed7ed80..279f02ecef 100644 --- a/arch/arm/dts/imx7s-warp.dts +++ b/arch/arm/dts/imx7s-warp.dts @@ -17,6 +17,10 @@ reg = <0x80000000 0x20000000>; };
+ aliases { + mmc0 = &usdhc3; + }; + gpio-keys { compatible = "gpio-keys"; pinctrl-0 = <&pinctrl_gpio>;
Switches on the IMX7 pinctrl driver for the warp7 and warp7_bl33 ports, necessary to convert over to DM for this board.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Peng Fan peng.fan@nxp.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- configs/warp7_bl33_defconfig | 2 ++ configs/warp7_defconfig | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index b2f943c775..a2c2555315 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -41,3 +41,5 @@ CONFIG_USB_ETH_CDC=y CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" CONFIG_OPTEE_TZDRAM_SIZE=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="imx7s-warp" +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX7=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 65d801ffe2..8691d00491 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -54,3 +54,5 @@ CONFIG_OPTEE_TZDRAM_SIZE=0x3000000 CONFIG_OPTEE_TZDRAM_BASE=0x9d000000 CONFIG_BOOTM_OPTEE=y CONFIG_DEFAULT_DEVICE_TREE="imx7s-warp" +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX7=y
-----Original Message----- From: Bryan O'Donoghue [mailto:bryan.odonoghue@linaro.org] Sent: 2019年1月3日 9:45 To: u-boot@lists.denx.de Cc: Fabio Estevam fabio.estevam@nxp.com; Peng Fan peng.fan@nxp.com; Bryan O'Donoghue bryan.odonoghue@linaro.org; Stefano Babic sbabic@denx.de Subject: [PATCH 5/8] warp7: defconfig: Switch on IMX7 pinctrl for both ports
-- 2.20.0
Just have a follow up question, in patch 4/8, DM MMC is enabled, but in 5/8 pinctrl DM is enabled. This might be not correct, the DM MMC/PINCTRL/GPIO needs to be in one patch. The fsl_esdhc DM support does not support DM MMC with legacy iomux code.
Regards, Peng.
-- 2.20.0
U-Boot mailing list U-Boot@lists.denx.de https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists. denx.de%2Flistinfo%2Fu-boot&data=02%7C01%7CPeng.Fan%40nxp.co m%7Cf6fbfc5331eb4328683308d6756c7489%7C686ea1d3bc2b4c6fa92cd99c 5c301635%7C0%7C0%7C636825506006750873&sdata=iXlXGGewCrW% 2B4srkP4d%2BWnZ7UX2AyCK8Tgx93g3SpF8%3D&reserved=0
Hmm.
OK, then I'll squash these.
This patch switches on DM_GPIO for both WaRP7 ports.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Peng Fan peng.fan@nxp.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- configs/warp7_bl33_defconfig | 1 + configs/warp7_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index a2c2555315..7f21bb4f53 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -43,3 +43,4 @@ CONFIG_OPTEE_TZDRAM_SIZE=0x2000000 CONFIG_DEFAULT_DEVICE_TREE="imx7s-warp" CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y +CONFIG_DM_GPIO=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 8691d00491..2d3171e42a 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -56,3 +56,4 @@ CONFIG_BOOTM_OPTEE=y CONFIG_DEFAULT_DEVICE_TREE="imx7s-warp" CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y +CONFIG_DM_GPIO=y
This commit switches to DM I2C for warp7 and warp7_bl33 defconfigs.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Peng Fan peng.fan@nxp.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- board/warp7/warp7.c | 24 ------------------------ configs/warp7_bl33_defconfig | 1 + configs/warp7_defconfig | 1 + include/configs/warp7.h | 2 -- 4 files changed, 2 insertions(+), 26 deletions(-)
diff --git a/board/warp7/warp7.c b/board/warp7/warp7.c index 146d722b15..19f0df4d09 100644 --- a/board/warp7/warp7.c +++ b/board/warp7/warp7.c @@ -31,26 +31,6 @@ DECLARE_GLOBAL_DATA_PTR; #define UART_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_PUS_PU100KOHM | \ PAD_CTL_HYS)
-#define I2C_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ - PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU100KOHM) - -#ifdef CONFIG_SYS_I2C_MXC -#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) -/* I2C1 for PMIC */ -static struct i2c_pads_info i2c_pad_info1 = { - .scl = { - .i2c_mode = MX7D_PAD_I2C1_SCL__I2C1_SCL | PC, - .gpio_mode = MX7D_PAD_I2C1_SCL__GPIO4_IO8 | PC, - .gp = IMX_GPIO_NR(4, 8), - }, - .sda = { - .i2c_mode = MX7D_PAD_I2C1_SDA__I2C1_SDA | PC, - .gpio_mode = MX7D_PAD_I2C1_SDA__GPIO4_IO9 | PC, - .gp = IMX_GPIO_NR(4, 9), - }, -}; -#endif - int dram_init(void) { gd->ram_size = PHYS_SDRAM_SIZE; @@ -130,10 +110,6 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- #ifdef CONFIG_SYS_I2C_MXC - setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); - #endif - return 0; }
diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index 7f21bb4f53..2e80011cbc 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -44,3 +44,4 @@ CONFIG_DEFAULT_DEVICE_TREE="imx7s-warp" CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 2d3171e42a..9f7dc73a11 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -57,3 +57,4 @@ CONFIG_DEFAULT_DEVICE_TREE="imx7s-warp" CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y diff --git a/include/configs/warp7.h b/include/configs/warp7.h index a391dfb5c1..41eb8d7e1d 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -126,9 +126,7 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* I2C configs */ -#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 #define CONFIG_SYS_I2C_SPEED 100000
/* PMIC */
-----Original Message----- From: Bryan O'Donoghue [mailto:bryan.odonoghue@linaro.org] Sent: 2019年1月3日 9:45 To: u-boot@lists.denx.de Cc: Fabio Estevam fabio.estevam@nxp.com; Peng Fan peng.fan@nxp.com; Bryan O'Donoghue bryan.odonoghue@linaro.org; Stefano Babic sbabic@denx.de Subject: [PATCH 7/8] warp7: defconfig: Switch to DM for I2C
- .scl = {
- .sda = {
-}; -#endif
- #endif
/* PMIC */
2.20.0
This patch converts the warp7 and warp7_bl33 board ports over to using the DM PMIC model.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Peng Fan peng.fan@nxp.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- board/warp7/warp7.c | 27 +++++++++++---------------- configs/warp7_bl33_defconfig | 6 ++++++ configs/warp7_defconfig | 6 ++++++ include/configs/warp7.h | 6 ------ 4 files changed, 23 insertions(+), 22 deletions(-)
diff --git a/board/warp7/warp7.c b/board/warp7/warp7.c index 19f0df4d09..6ebeb08e33 100644 --- a/board/warp7/warp7.c +++ b/board/warp7/warp7.c @@ -64,29 +64,24 @@ int board_early_init_f(void) return 0; }
-#ifdef CONFIG_POWER -#define I2C_PMIC 0 -static struct pmic *pfuze; +#ifdef CONFIG_DM_PMIC int power_init_board(void) { - int ret; - unsigned int reg, rev_id; + struct udevice *dev; + int ret, dev_id, rev_id;
- ret = power_pfuze3000_init(I2C_PMIC); - if (ret) + ret = pmic_get("pfuze3000", &dev); + if (ret == -ENODEV) + return 0; + if (ret != 0) return ret;
- pfuze = pmic_get("PFUZE3000"); - ret = pmic_probe(pfuze); - if (ret) - return ret; - - pmic_reg_read(pfuze, PFUZE3000_DEVICEID, ®); - pmic_reg_read(pfuze, PFUZE3000_REVID, &rev_id); - printf("PMIC: PFUZE3000 DEV_ID=0x%x REV_ID=0x%x\n", reg, rev_id); + dev_id = pmic_reg_read(dev, PFUZE3000_DEVICEID); + rev_id = pmic_reg_read(dev, PFUZE3000_REVID); + printf("PMIC: PFUZE3000 DEV_ID=0x%x REV_ID=0x%x\n", dev_id, rev_id);
/* disable Low Power Mode during standby mode */ - pmic_reg_write(pfuze, PFUZE3000_LDOGCTL, 0x1); + pmic_clrsetbits(dev, PFUZE3000_LDOGCTL, 0, 1);
return 0; } diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index 2e80011cbc..7b40bfbd6d 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -45,3 +45,9 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 9f7dc73a11..d1c8e403a7 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -58,3 +58,9 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 41eb8d7e1d..043f2861b6 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -129,12 +129,6 @@ #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_SPEED 100000
-/* PMIC */ -#define CONFIG_POWER -#define CONFIG_POWER_I2C -#define CONFIG_POWER_PFUZE3000 -#define CONFIG_POWER_PFUZE3000_I2C_ADDR 0x08 - /* environment organization */ #define CONFIG_ENV_SIZE SZ_8K
-----Original Message----- From: Bryan O'Donoghue [mailto:bryan.odonoghue@linaro.org] Sent: 2019年1月3日 9:45 To: u-boot@lists.denx.de Cc: Fabio Estevam fabio.estevam@nxp.com; Peng Fan peng.fan@nxp.com; Bryan O'Donoghue bryan.odonoghue@linaro.org; Stefano Babic sbabic@denx.de Subject: [PATCH 8/8] arm: imx7s-warp: Convert to DM PMIC
- int ret;
- struct udevice *dev;
- int ret, dev_id, rev_id;
- if (ret)
- ret = pmic_get("pfuze3000", &dev);
- if (ret == -ENODEV)
- if (ret != 0) return ret;
- if (ret)
return ret;
- dev_id = pmic_reg_read(dev, PFUZE3000_DEVICEID);
- rev_id = pmic_reg_read(dev, PFUZE3000_REVID);
- printf("PMIC: PFUZE3000 DEV_ID=0x%x REV_ID=0x%x\n", dev_id,
rev_id);
-- 2.20.0
Auer, Lukas
Bryan O'Donoghue
Peng Fan
