[U-Boot] [PATCH] ARM: rmobile: Enable CONFIG_ARCH_FIXUP_FDT_MEMORY on Gen3
Enable CONFIG_ARCH_FIXUP_FDT_MEMORY to let U-Boot patch the Linux DT memory entries.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/r8a7795_salvator-x_defconfig | 1 - configs/r8a7795_ulcb_defconfig | 1 - configs/r8a77965_salvator-x_defconfig | 1 - configs/r8a77965_ulcb_defconfig | 1 - configs/r8a7796_salvator-x_defconfig | 1 - configs/r8a7796_ulcb_defconfig | 1 - configs/r8a77970_eagle_defconfig | 1 - configs/r8a77990_ebisu_defconfig | 1 - configs/r8a77995_draak_defconfig | 1 - 9 files changed, 9 deletions(-)
diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index dc6ac02b7e..2ae24dc324 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -7,7 +7,6 @@ CONFIG_TARGET_SALVATOR_X=y CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_FIT=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/r8a7795_ulcb_defconfig b/configs/r8a7795_ulcb_defconfig index ecd93cf80f..0229c6dbbb 100644 --- a/configs/r8a7795_ulcb_defconfig +++ b/configs/r8a7795_ulcb_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_ULCB=y CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_FIT=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/r8a77965_salvator-x_defconfig b/configs/r8a77965_salvator-x_defconfig index e620edad37..916f0f6b1b 100644 --- a/configs/r8a77965_salvator-x_defconfig +++ b/configs/r8a77965_salvator-x_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_SALVATOR_X=y CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_FIT=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/r8a77965_ulcb_defconfig b/configs/r8a77965_ulcb_defconfig index 6494842da3..2ffa232dd5 100644 --- a/configs/r8a77965_ulcb_defconfig +++ b/configs/r8a77965_ulcb_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_ULCB=y CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_FIT=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index 8089523700..ebbe123cfa 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_SALVATOR_X=y CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_FIT=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/r8a7796_ulcb_defconfig b/configs/r8a7796_ulcb_defconfig index 28795a7113..5843b65fe0 100644 --- a/configs/r8a7796_ulcb_defconfig +++ b/configs/r8a7796_ulcb_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_ULCB=y CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6338000 CONFIG_FIT=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/r8a77970_eagle_defconfig b/configs/r8a77970_eagle_defconfig index 9225771c11..15108c35ad 100644 --- a/configs/r8a77970_eagle_defconfig +++ b/configs/r8a77970_eagle_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_EAGLE=y CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6318000 CONFIG_FIT=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index 093b64c9e0..1bdef3bc0f 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_EBISU=y CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6318000 CONFIG_FIT=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index c5acd684a0..d30185f96a 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -8,7 +8,6 @@ CONFIG_TARGET_DRAAK=y CONFIG_SMBIOS_PRODUCT_NAME="" CONFIG_SPL_TEXT_BASE=0xe6318000 CONFIG_FIT=y -# CONFIG_ARCH_FIXUP_FDT_MEMORY is not set CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/nfs rw nfsroot=192.168.0.1:/export/rfs ip=192.168.0.20" CONFIG_SUPPORT_RAW_INITRD=y
