[PATCH 0/2] Add basic window watchdog mode support
In this patch series fixed below things. - Window watchdog is using generic watchdog mode so far. Looks like this signal cannot be used to trigger any reset inside PLM. So, change it to basic window watchdog mode. - Wdt has a expire command, this was not implemented earlier. Implement it by loading mininum possible count in wdt window so that it expires immediately.
Ashok Reddy Soma (2): watchdog: versal: Add support for basic window watchdog watchdog: versal: Add support for expire now
drivers/watchdog/xilinx_wwdt.c | 100 +++++++++++++++++++++------------ 1 file changed, 64 insertions(+), 36 deletions(-)
Existing driver uses generic watchdog mode which generates a signal to PLM firmware, but the signal cannot be used to reset the system.
Change driver to use window watchdog basic mode. This window watchdog mode generates a signal to PLM firmware which decides what action to take upon expiry of watchdog.
Timeout value for xlnx_wwdt_start will come in milli seconds from wdt framework. Make changes to load count value accordingly.
Add checks before loading the timer for min and max possible values.
Fix authour email id of Ashok Reddy Soma to long email id.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com ---
drivers/watchdog/xilinx_wwdt.c | 98 +++++++++++++++++++++------------- 1 file changed, 60 insertions(+), 38 deletions(-)
diff --git a/drivers/watchdog/xilinx_wwdt.c b/drivers/watchdog/xilinx_wwdt.c index c8e6c60cdd..d8b2ae7248 100644 --- a/drivers/watchdog/xilinx_wwdt.c +++ b/drivers/watchdog/xilinx_wwdt.c @@ -3,7 +3,7 @@ * Xilinx window watchdog timer driver. * * Author(s): Michal Simek michal.simek@xilinx.com - * Ashok Reddy Soma ashokred@xilinx.com + * Ashok Reddy Soma ashok.reddy.soma@xilinx.com * * Copyright (c) 2020, Xilinx Inc. */ @@ -23,13 +23,22 @@ /* Generic Control/Status Register Masks */ #define XWT_WWCSR_GWEN_MASK BIT(0) /* Enable Bit */
-/* Register offsets for the Wdt device */ -#define XWT_WWREF_OFFSET 0x1000 /* Refresh Register */ -#define XWT_WWCSR_OFFSET 0x2000 /* Control/Status Register */ -#define XWT_WWOFF_OFFSET 0x2008 /* Offset Register */ -#define XWT_WWCMP0_OFFSET 0x2010 /* Compare Value Register0 */ -#define XWT_WWCMP1_OFFSET 0x2014 /* Compare Value Register1 */ -#define XWT_WWWRST_OFFSET 0x2FD0 /* Warm Reset Register */ +/* Register offsets for the WWDT device */ +#define XWT_WWDT_MWR_OFFSET 0x00 +#define XWT_WWDT_ESR_OFFSET 0x04 +#define XWT_WWDT_FCR_OFFSET 0x08 +#define XWT_WWDT_FWR_OFFSET 0x0c +#define XWT_WWDT_SWR_OFFSET 0x10 +#define XWT_WWDT_CNT_MIN 1 +#define XWT_WWDT_CNT_MAX 0xffffffff + +/* Master Write Control Register Masks */ +#define XWT_WWDT_MWR_MASK BIT(0) + +/* Enable and Status Register Masks */ +#define XWT_WWDT_ESR_WINT_MASK BIT(16) +#define XWT_WWDT_ESR_WSW_MASK BIT(8) +#define XWT_WWDT_ESR_WEN_MASK BIT(0)
struct xlnx_wwdt_priv { bool enable_once; @@ -43,16 +52,23 @@ struct xlnx_wwdt_plat {
static int xlnx_wwdt_reset(struct udevice *dev) { + u32 esr; struct xlnx_wwdt_priv *wdt = dev_get_priv(dev);
- regmap_write(wdt->regs, XWT_WWREF_OFFSET, XWT_WWREF_GWRR_MASK); + regmap_write(wdt->regs, XWT_WWDT_MWR_OFFSET, XWT_WWDT_MWR_MASK); + regmap_read(wdt->regs, XWT_WWDT_ESR_OFFSET, &esr); + esr |= XWT_WWDT_ESR_WINT_MASK; + esr &= ~XWT_WWDT_ESR_WSW_MASK; + regmap_write(wdt->regs, XWT_WWDT_ESR_OFFSET, esr); + regmap_read(wdt->regs, XWT_WWDT_ESR_OFFSET, &esr); + esr |= XWT_WWDT_ESR_WSW_MASK; + regmap_write(wdt->regs, XWT_WWDT_ESR_OFFSET, esr);
return 0; }
static int xlnx_wwdt_stop(struct udevice *dev) { - u32 csr; struct xlnx_wwdt_priv *wdt = dev_get_priv(dev);
if (wdt->enable_once) { @@ -60,10 +76,9 @@ static int xlnx_wwdt_stop(struct udevice *dev) return -EBUSY; }
- /* Disable the generic watchdog timer */ - regmap_read(wdt->regs, XWT_WWCSR_OFFSET, &csr); - csr &= ~(XWT_WWCSR_GWEN_MASK); - regmap_write(wdt->regs, XWT_WWCSR_OFFSET, csr); + /* Disable the window watchdog timer */ + regmap_write(wdt->regs, XWT_WWDT_MWR_OFFSET, XWT_WWDT_MWR_MASK); + regmap_write(wdt->regs, XWT_WWDT_ESR_OFFSET, ~(u32)XWT_WWDT_ESR_WEN_MASK);
clk_disable(&wdt->clk);
@@ -72,11 +87,11 @@ static int xlnx_wwdt_stop(struct udevice *dev) return 0; }
-static int xlnx_wwdt_start(struct udevice *dev, u64 timeout, ulong flags) +static int xlnx_wwdt_start(struct udevice *dev, u64 timeout_ms, ulong flags) { int ret; - u32 csr; - u64 count; + u32 esr; + u64 count, timeout; unsigned long clock_f; struct xlnx_wwdt_priv *wdt = dev_get_priv(dev);
@@ -88,36 +103,43 @@ static int xlnx_wwdt_start(struct udevice *dev, u64 timeout, ulong flags)
dev_dbg(dev, "%s: CLK %ld\n", __func__, clock_f);
+ /* Convert timeout from msec to sec */ + timeout = timeout_ms / 1000; + /* Calculate timeout count */ count = timeout * clock_f;
+ /* Count should be at least 1 */ + if (count < XWT_WWDT_CNT_MIN) { + debug("%s: watchdog won't fire with 0 ticks\n", __func__); + count = XWT_WWDT_CNT_MIN; + } + + /* Limit the count to maximum possible value */ + if (count > XWT_WWDT_CNT_MAX) { + debug("%s: maximum watchdog timeout exceeded\n", __func__); + count = XWT_WWDT_CNT_MAX; + } + ret = clk_enable(&wdt->clk); if (ret) { dev_err(dev, "failed to enable clock\n"); return ret; }
- /* - * Timeout count is half as there are two windows - * first window overflow is ignored (interrupt), - * reset is only generated at second window overflow - */ - count = count >> 1; - - /* Disable the generic watchdog timer */ - regmap_read(wdt->regs, XWT_WWCSR_OFFSET, &csr); - csr &= ~(XWT_WWCSR_GWEN_MASK); - regmap_write(wdt->regs, XWT_WWCSR_OFFSET, csr); - - /* Set compare and offset registers for generic watchdog timeout */ - regmap_write(wdt->regs, XWT_WWCMP0_OFFSET, (u32)count); - regmap_write(wdt->regs, XWT_WWCMP1_OFFSET, 0); - regmap_write(wdt->regs, XWT_WWOFF_OFFSET, (u32)count); - - /* Enable the generic watchdog timer */ - regmap_read(wdt->regs, XWT_WWCSR_OFFSET, &csr); - csr |= (XWT_WWCSR_GWEN_MASK); - regmap_write(wdt->regs, XWT_WWCSR_OFFSET, csr); + /* Disable the window watchdog timer */ + regmap_write(wdt->regs, XWT_WWDT_MWR_OFFSET, XWT_WWDT_MWR_MASK); + regmap_write(wdt->regs, XWT_WWDT_ESR_OFFSET, ~(u32)XWT_WWDT_ESR_WEN_MASK); + + /* Set first window and second window registers with timeout */ + regmap_write(wdt->regs, XWT_WWDT_FWR_OFFSET, 0); /* No pre-timeout */ + regmap_write(wdt->regs, XWT_WWDT_SWR_OFFSET, (u32)count); + regmap_write(wdt->regs, XWT_WWDT_FCR_OFFSET, 0); + + /* Enable the window watchdog timer */ + regmap_read(wdt->regs, XWT_WWDT_ESR_OFFSET, &esr); + esr |= XWT_WWDT_ESR_WEN_MASK; + regmap_write(wdt->regs, XWT_WWDT_ESR_OFFSET, esr);
return 0; }
Wdt expire command makes the wdt to count least possible ticks(1) and expires immediately. Add expire_now option to the xlnx_wwdt_ops and implement it by calling xlnx_wwdt_start() with minimum possible count(1).
drivers/watchdog/xilinx_wwdt.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/watchdog/xilinx_wwdt.c b/drivers/watchdog/xilinx_wwdt.c index d8b2ae7248..d582e3cc8f 100644 --- a/drivers/watchdog/xilinx_wwdt.c +++ b/drivers/watchdog/xilinx_wwdt.c @@ -144,6 +144,11 @@ static int xlnx_wwdt_start(struct udevice *dev, u64 timeout_ms, ulong flags) return 0; }
+static int xlnx_wwdt_expire_now(struct udevice *dev, ulong flags) +{ + return xlnx_wwdt_start(dev, XWT_WWDT_CNT_MIN, flags); +} + static int xlnx_wwdt_probe(struct udevice *dev) { int ret; @@ -182,6 +187,7 @@ static const struct wdt_ops xlnx_wwdt_ops = { .start = xlnx_wwdt_start, .reset = xlnx_wwdt_reset, .stop = xlnx_wwdt_stop, + .expire_now = xlnx_wwdt_expire_now, };
static const struct udevice_id xlnx_wwdt_ids[] = {
Applied. M
Ashok Reddy Soma
Michal Simek
