[PATCH] arm64: zynqmp: Disable WDT_CDNS driver by default
Do not enable watchdog driver in default zynqmp configuration. The reason is that not all distributions are handling watchdog properly and then expires and system resets. If someone needs watchdog in their design please enable it by hand.
configs/xilinx_zynqmp_virt_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index d3d38015e2c0..4f305198420b 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -194,7 +194,6 @@ CONFIG_BMP_16BPP=y CONFIG_BMP_24BPP=y CONFIG_BMP_32BPP=y CONFIG_WDT=y -CONFIG_WDT_CDNS=y CONFIG_PANIC_HANG=y CONFIG_TPM=y CONFIG_SPL_GZIP=y
pá 6. 8. 2021 v 9:21 odesílatel Michal Simek michal.simek@xilinx.com napsal:
diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index d3d38015e2c0..4f305198420b 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -194,7 +194,6 @@ CONFIG_BMP_16BPP=y CONFIG_BMP_24BPP=y CONFIG_BMP_32BPP=y CONFIG_WDT=y -CONFIG_WDT_CDNS=y CONFIG_PANIC_HANG=y CONFIG_TPM=y CONFIG_SPL_GZIP=y -- 2.32.0
Applied. M
Michal Simek
Michal Simek
