[U-Boot] [PATCH] integrator: break out common config
The configuration that is common for all Integrator boards may just as well be stored in a common include file as per pattern from other boards. This eases maintenance quite a bit.
Signed-off-by: Linus Walleij linus.walleij@linaro.org --- include/configs/integrator-common.h | 114 +++++++++++++++++++++++++++++++ include/configs/integratorap.h | 61 +---------------- include/configs/integratorcp.h | 126 ++--------------------------------- 3 files changed, 122 insertions(+), 179 deletions(-) create mode 100644 include/configs/integrator-common.h
diff --git a/include/configs/integrator-common.h b/include/configs/integrator-common.h new file mode 100644 index 0000000..0ae4312 --- /dev/null +++ b/include/configs/integrator-common.h @@ -0,0 +1,114 @@ +/* + * (C) Copyright 2012 + * Linaro + * Linus Walleij linus.walleij@linaro.org + * Common ARM Integrator configuration settings + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define CONFIG_INTEGRATOR + +#define CONFIG_SYS_TEXT_BASE 0x01000000 +#define CONFIG_SYS_MEMTEST_START 0x100000 +#define CONFIG_SYS_MEMTEST_END 0x10000000 +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_TIMERBASE 0x13000100 /* Timer1 */ +#define CONFIG_SYS_LOAD_ADDR 0x7fc0 /* default load address */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "# " +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size*/ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size*/ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) /* Size of malloc() pool */ + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_MISC_INIT_R /* call misc_init_r during start up */ + +/* + * There are various dependencies on the core module (CM) fitted + * Users should refer to their CM user guide + */ +#include "armcoremodule.h" + +/* + * Initialize and remap the core module, use SPD to detect memory size + * If CONFIG_SKIP_LOWLEVEL_INIT is not defined & + * the core module has a CM_INIT register + * then the U-Boot initialisation code will + * e.g. ARM Boot Monitor or pre-loader is repeated once + * (to re-initialise any existing CM_INIT settings to safe values). + * + * This is usually not the desired behaviour since the platform + * will either reboot into the ARM monitor (or pre-loader) + * or continuously cycle thru it without U-Boot running, + * depending upon the setting of Integrator/CP switch S2-4. + * + * However it may be needed if Integrator/CP switch S2-1 + * is set OFF to boot direct into U-Boot. + * In that case comment out the line below. + */ +#define CONFIG_CM_INIT +#define CONFIG_CM_REMAP +#define CONFIG_CM_SPD_DETECT + +/* + * The ARM boot monitor initializes the board. + * However, the default U-Boot code also performs the initialization. + * If desired, this can be prevented by defining SKIP_LOWLEVEL_INIT + * - see documentation supplied with board for details of how to choose the + * image to run at reset/power up + * e.g. whether the ARM Boot Monitor runs before U-Boot + */ +/* #define CONFIG_SKIP_LOWLEVEL_INIT */ + +/* + * The ARM boot monitor does not relocate U-Boot. + * However, the default U-Boot code performs the relocation check, + * and may relocate the code if the memory map is changed. + * If necessary this can be prevented by defining SKIP_RELOCATE_UBOOT + */ +/* #define SKIP_CONFIG_RELOCATE_UBOOT */ + + +/* + * Stack sizes + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ +#define PHYS_SDRAM_1 0x00000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_SIZE PHYS_SDRAM_1_SIZE +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_SDRAM_BASE + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_GBL_DATA_OFFSET diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index 0a704cb..c94fa58 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -31,32 +31,11 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_INTEGRATOR +#include "integrator-common.h" + +/* Integrator/AP-specific configuration */ #define CONFIG_ARCH_INTEGRATOR -/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SYS_TEXT_BASE 0x01000000 -#define CONFIG_SYS_MEMTEST_START 0x100000 -#define CONFIG_SYS_MEMTEST_END 0x10000000 -#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_HZ_CLOCK 24000000 /* Timer 1 is clocked at 24Mhz */ -#define CONFIG_SYS_TIMERBASE 0x13000100 /* Timer1 */ - -#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_MISC_INIT_R 1 /* call misc_init_r during start up */ - -#define CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_CM_INIT 1 -#define CONFIG_CM_REMAP 1 -#define CONFIG_CM_SPD_DETECT - -/* - * Size of malloc() pool - */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024)
/* * PL010 Configuration @@ -91,41 +70,7 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT "Integrator-AP # " /* Monitor Command Prompt */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "# " -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_LOAD_ADDR 0x7fc0 /* default load address */ - -/*----------------------------------------------------------------------- - * Stack sizes - * - * The stack sizes are set up in start.S using the settings below - */ -#define CONFIG_STACKSIZE (128*1024) /* regular stack */ -#ifdef CONFIG_USE_IRQ -#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ -#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ -#endif - -/*----------------------------------------------------------------------- - * Physical Memory Map - */ -#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ -#define PHYS_SDRAM_1 0x00000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_RAM_SIZE PHYS_SDRAM_1_SIZE -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_SDRAM_BASE + \ - CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_FLASH_BASE 0x24000000
diff --git a/include/configs/integratorcp.h b/include/configs/integratorcp.h index 57610a6..9bc9e9b 100644 --- a/include/configs/integratorcp.h +++ b/include/configs/integratorcp.h @@ -31,32 +31,11 @@ #ifndef __CONFIG_H #define __CONFIG_H
-/* Integrator-specific configuration */ -#define CONFIG_INTEGRATOR -#define CONFIG_ARCH_CINTEGRATOR -#define CONFIG_CM_INIT -#define CONFIG_CM_REMAP -#define CONFIG_CM_SPD_DETECT +#include "integrator-common.h"
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SYS_TEXT_BASE 0x01000000 -#define CONFIG_SYS_MEMTEST_START 0x100000 -#define CONFIG_SYS_MEMTEST_END 0x10000000 -#define CONFIG_SYS_HZ 1000 +/* Integrator CP-specific configuration */ +#define CONFIG_ARCH_CINTEGRATOR #define CONFIG_SYS_HZ_CLOCK 1000000 /* Timer 1 is clocked at 1Mhz */ -#define CONFIG_SYS_TIMERBASE 0x13000100 - -#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_MISC_INIT_R 1 /* call misc_init_r during start up */ - -/* - * Size of malloc() pool - */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024)
/* * Hardware drivers @@ -66,9 +45,7 @@ #define CONFIG_SMC91111_BASE 0xC8000000 #undef CONFIG_SMC91111_EXT_PHY
-/* - * NS16550 Configuration - */ +/* PL011 configuration */ #define CONFIG_PL011_SERIAL #define CONFIG_PL011_CLOCK 14745600 #define CONFIG_PL01x_PORTS { (void *)CONFIG_SYS_SERIAL0, (void *)CONFIG_SYS_SERIAL1 } @@ -78,16 +55,6 @@ #define CONFIG_SYS_SERIAL0 0x16000000 #define CONFIG_SYS_SERIAL1 0x17000000
- -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - /* * Command line configuration. */ @@ -103,43 +70,10 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_PROMPT "Integrator-CP # " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size*/ -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size*/ - -#define CONFIG_SYS_LOAD_ADDR 0x7fc0 /* default load address */
-/*----------------------------------------------------------------------- - * Stack sizes - * - * The stack sizes are set up in start.S using the settings below - */ -#define CONFIG_STACKSIZE (128*1024) /* regular stack */ -#ifdef CONFIG_USE_IRQ -#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ -#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ -#endif - -/*----------------------------------------------------------------------- - * Physical Memory Map - */ -#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ -#define PHYS_SDRAM_1 0x00000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_RAM_SIZE PHYS_SDRAM_1_SIZE -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_SDRAM_BASE + \ - CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- +/* * FLASH and environment organization - * Top varies according to amount fitted * Reserve top 4 blocks of flash * - ARM Boot Monitor @@ -148,7 +82,6 @@ * - U-Boot environment * * Base is always 0x24000000 - */ #define CONFIG_SYS_FLASH_BASE 0x24000000 #define CONFIG_SYS_FLASH_CFI 1 @@ -190,53 +123,4 @@ #define CONFIG_ENV_SECT_SIZE 0x40000 /* 256KB */ #define CONFIG_ENV_SIZE 8192 /* 8KB */
-/* - * The ARM boot monitor initializes the board. - * However, the default U-Boot code also performs the initialization. - * If desired, this can be prevented by defining SKIP_LOWLEVEL_INIT - * - see documentation supplied with board for details of how to choose the - * image to run at reset/power up - * e.g. whether the ARM Boot Monitor runs before U-Boot - -#define CONFIG_SKIP_LOWLEVEL_INIT - - */ - -/* - * The ARM boot monitor does not relocate U-Boot. - * However, the default U-Boot code performs the relocation check, - * and may relocate the code if the memory map is changed. - * If necessary this can be prevented by defining SKIP_RELOCATE_UBOOT - -#define SKIP_CONFIG_RELOCATE_UBOOT - - */ -/*----------------------------------------------------------------------- - * There are various dependencies on the core module (CM) fitted - * Users should refer to their CM user guide - * - when porting adjust u-boot/Makefile accordingly - * to define the necessary CONFIG_ s for the CM involved - * see e.g. cp_926ejs_config - */ - -#include "armcoremodule.h" - -/* - * If CONFIG_SKIP_LOWLEVEL_INIT is not defined & - * the core module has a CM_INIT register - * then the U-Boot initialisation code will - * e.g. ARM Boot Monitor or pre-loader is repeated once - * (to re-initialise any existing CM_INIT settings to safe values). - * - * This is usually not the desired behaviour since the platform - * will either reboot into the ARM monitor (or pre-loader) - * or continuously cycle thru it without U-Boot running, - * depending upon the setting of Integrator/CP switch S2-4. - * - * However it may be needed if Integrator/CP switch S2-1 - * is set OFF to boot direct into U-Boot. - * In that case comment out the line below. -#undef CONFIG_CM_INIT - */ - #endif /* __CONFIG_H */
On Tue, May 22, 2012 at 10:53 PM, Linus Walleij linus.walleij@linaro.org wrote:
Albert, is this patch OK?
It's available here in patchwork: http://patchwork.ozlabs.org/patch/160740/
Yours, Linus Walleij
On Wed, Jun 13, 2012 at 3:37 PM, Linus Walleij linus.walleij@linaro.org wrote:
Ping on this, tell me if I'm doing something wrong, it's been floating for 2 months now...
Hi Linus,
On Mon, 23 Jul 2012 12:35:05 +0200, Linus Walleij linus.walleij@linaro.org wrote:
No, it's just that it went below my radar (and then, I was below the radar myself for the past week).
I'm afraid it will have to go in next now.
Amicalement,
Hi Linus,
On Sun, 29 Jul 2012 11:14:34 +0200, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Linus,
Just tried to git am it, seems it does not apply cleanly. Can you rebase and submit a new version? Sorry for the inconvenience.
Amicalement,
On Sun, Jul 29, 2012 at 11:23 AM, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Linus,
Sure no problem, I'll rebase onto your tree then.
Albert ARIBAUD
Linus Walleij
