[U-Boot] [PATCH] Fix spelling of "occurred".
Signed-off-by: Vagrant Cascadian vagrant@debian.org ---
board/bf533-ezkit/flash.c | 2 +- board/mpl/pip405/pip405.c | 2 +- board/tqc/tqm5200/cmd_stk52xx.c | 2 +- cmd/fdc.c | 8 ++++---- common/kgdb.c | 2 +- common/usb_hub.c | 2 +- drivers/ddr/marvell/a38x/ddr3_init.h | 2 +- drivers/ddr/marvell/axp/ddr3_hw_training.h | 2 +- drivers/i2c/kona_i2c.c | 2 +- drivers/mtd/nand/omap_gpmc.c | 4 ++-- drivers/net/4xx_enet.c | 4 ++-- drivers/net/enc28j60.c | 2 +- drivers/net/ne2000_base.c | 4 ++-- drivers/usb/gadget/mpc8xx_udc.c | 2 +- drivers/usb/musb/musb_hcd.c | 6 +++--- include/linux/fb.h | 4 ++-- include/test/ut.h | 12 ++++++------ include/usbdevice.h | 2 +- 18 files changed, 32 insertions(+), 32 deletions(-)
diff --git a/board/bf533-ezkit/flash.c b/board/bf533-ezkit/flash.c index 3180a76..a7b3519 100644 --- a/board/bf533-ezkit/flash.c +++ b/board/bf533-ezkit/flash.c @@ -320,7 +320,7 @@ int poll_toggle_bit(long lOffset) } timeout--; } - printf("Time out occured \n"); + printf("Time out occurred \n"); if (timeout < 0) return FLASH_FAIL; } diff --git a/board/mpl/pip405/pip405.c b/board/mpl/pip405/pip405.c index 7c7690f..1bd2fbf 100644 --- a/board/mpl/pip405/pip405.c +++ b/board/mpl/pip405/pip405.c @@ -777,7 +777,7 @@ void print_pip405_info (void) ((sysman & 0x10) == 0x10) ? "" : "not "); printf ("INIT asserts %sINT1# (NMI)\n", ((sysman & 0x20) == 0x20) ? "" : "not "); - printf ("INIT occured %d\n", (sysman >> 6) & 0x1); + printf ("INIT occurred %d\n", (sysman >> 6) & 0x1); printf ("SER1 is routed to %s\n", ((flashcom & 0x1) == 0x1) ? "RS485" : "RS232"); printf ("COM2 is routed to %s\n", diff --git a/board/tqc/tqm5200/cmd_stk52xx.c b/board/tqc/tqm5200/cmd_stk52xx.c index 9d2d5a8..dc22ee4 100644 --- a/board/tqc/tqm5200/cmd_stk52xx.c +++ b/board/tqc/tqm5200/cmd_stk52xx.c @@ -72,7 +72,7 @@ static int spi_transmit(unsigned char data) spi->dr = data; /* wait for SPI transmission completed */ while (!(spi->sr & 0x80)) { - if (spi->sr & 0x40) { /* if write collision occured */ + if (spi->sr & 0x40) { /* if write collision occurred */ int dummy;
/* do dummy read to clear status register */ diff --git a/cmd/fdc.c b/cmd/fdc.c index 058ae89..d2281ab 100644 --- a/cmd/fdc.c +++ b/cmd/fdc.c @@ -189,7 +189,7 @@ int wait_for_fdc_int(void) while((read_fdc_reg(FDC_SRA)&0x80)==0) { timeout--; udelay(10); - if(timeout==0) /* timeout occured */ + if(timeout==0) /* timeout occurred */ return false; } return true; @@ -205,7 +205,7 @@ int read_fdc_byte(void) /* direction out and ready */ udelay(10); timeout--; - if(timeout==0) /* timeout occured */ + if(timeout==0) /* timeout occurred */ return -1; } return read_fdc_reg(FDC_FIFO); @@ -235,7 +235,7 @@ int write_fdc_byte(unsigned char val) timeout--; udelay(10); fdc_need_more_output(); - if(timeout==0) /* timeout occured */ + if(timeout==0) /* timeout occurred */ return false; } write_fdc_reg(FDC_FIFO,val); @@ -395,7 +395,7 @@ int fdc_terminate(FDC_COMMAND_STRUCT *pCMD) int i; for(i=0;i<100;i++) udelay(500); /* wait 500usec for fifo overrun */ - while((read_fdc_reg(FDC_SRA)&0x80)==0x00); /* wait as long as no int has occured */ + while((read_fdc_reg(FDC_SRA)&0x80)==0x00); /* wait as long as no int has occurred */ for(i=0;i<7;i++) { pCMD->result[i]=(unsigned char)read_fdc_byte(); } diff --git a/common/kgdb.c b/common/kgdb.c index d357463..daf53be 100644 --- a/common/kgdb.c +++ b/common/kgdb.c @@ -326,7 +326,7 @@ handle_exception (struct pt_regs *regs) return (0); }
- /* probably should check which exception occured as well */ + /* probably should check which exception occurred as well */ if (longjmp_on_fault) { longjmp_on_fault = 0; kgdb_longjmp(error_jmp_buf, KGDBERR_MEMFAULT); diff --git a/common/usb_hub.c b/common/usb_hub.c index e6a2cdb..4f59802 100644 --- a/common/usb_hub.c +++ b/common/usb_hub.c @@ -475,7 +475,7 @@ static int usb_scan_port(struct usb_device_scan *usb_scan) return 0;
/* Otherwise the device will get removed */ - printf("Port %d over-current occured %d times\n", i + 1, + printf("Port %d over-current occurred %d times\n", i + 1, hub->overcurrent_count[i]); }
diff --git a/drivers/ddr/marvell/a38x/ddr3_init.h b/drivers/ddr/marvell/a38x/ddr3_init.h index cb3fb24..8cb0886 100644 --- a/drivers/ddr/marvell/a38x/ddr3_init.h +++ b/drivers/ddr/marvell/a38x/ddr3_init.h @@ -120,7 +120,7 @@ #define MV_NO_RESOURCE (0x13) /* Resource not available (memory ...) */ #define MV_FULL (0x14) /* Item is full (Queue or table etc...) */ #define MV_EMPTY (0x15) /* Item is empty (Queue or table etc...) */ -#define MV_INIT_ERROR (0x16) /* Error occured while INIT process */ +#define MV_INIT_ERROR (0x16) /* Error occurred while INIT process */ #define MV_HW_ERROR (0x17) /* Hardware error */ #define MV_TX_ERROR (0x18) /* Transmit operation not succeeded */ #define MV_RX_ERROR (0x19) /* Recieve operation not succeeded */ diff --git a/drivers/ddr/marvell/axp/ddr3_hw_training.h b/drivers/ddr/marvell/axp/ddr3_hw_training.h index cffa7c4..343a6b6 100644 --- a/drivers/ddr/marvell/axp/ddr3_hw_training.h +++ b/drivers/ddr/marvell/axp/ddr3_hw_training.h @@ -41,7 +41,7 @@ #define MV_NO_RESOURCE (0x13) /* Resource not available (memory ...) */ #define MV_FULL (0x14) /* Item is full (Queue or table etc...) */ #define MV_EMPTY (0x15) /* Item is empty (Queue or table etc...) */ -#define MV_INIT_ERROR (0x16) /* Error occured while INIT process */ +#define MV_INIT_ERROR (0x16) /* Error occurred while INIT process */ #define MV_HW_ERROR (0x17) /* Hardware error */ #define MV_TX_ERROR (0x18) /* Transmit operation not succeeded */ #define MV_RX_ERROR (0x19) /* Recieve operation not succeeded */ diff --git a/drivers/i2c/kona_i2c.c b/drivers/i2c/kona_i2c.c index 9af496b..11f29d9 100644 --- a/drivers/i2c/kona_i2c.c +++ b/drivers/i2c/kona_i2c.c @@ -381,7 +381,7 @@ static int bcm_kona_i2c_write_fifo_single(struct bcm_kona_i2c_dev *dev, return -EREMOTEIO; }
- /* Check if a timeout occured */ + /* Check if a timeout occurred */ if (!time_left) { printf("completion timed out\n"); return -EREMOTEIO; diff --git a/drivers/mtd/nand/omap_gpmc.c b/drivers/mtd/nand/omap_gpmc.c index 4814fa2..6a45d28 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -106,7 +106,7 @@ static uint32_t gen_true_ecc(uint8_t *ecc_buf)
/* * omap_correct_data - Compares the ecc read from nand spare area with ECC - * registers values and corrects one bit error if it has occured + * registers values and corrects one bit error if it has occurred * Further details can be had from OMAP TRM and the following selected links: * http://en.wikipedia.org/wiki/Hamming_code * http://www.cs.utexas.edu/users/plaxton/c/337/05f/slides/ErrorCorrection-4.pd... @@ -479,7 +479,7 @@ static void omap_reverse_list(u8 *list, unsigned int length)
/* * omap_correct_data_bch - Compares the ecc read from nand spare area - * with ECC registers values and corrects one bit error if it has occured + * with ECC registers values and corrects one bit error if it has occurred * * @mtd: MTD device structure * @dat: page data diff --git a/drivers/net/4xx_enet.c b/drivers/net/4xx_enet.c index 3c30f42..bc52ed3 100644 --- a/drivers/net/4xx_enet.c +++ b/drivers/net/4xx_enet.c @@ -1726,7 +1726,7 @@ static void mal_err (struct eth_device *dev, unsigned long isr, mtdcr (MAL0_RXDEIR, 0x80000000);
#ifdef INFO_4XX_ENET - printf("\nMAL error occured.... ISR = %lx UIC = = %lx MAL_DEF = %lx MAL_ERR= %lx\n", + printf("\nMAL error occurred.... ISR = %lx UIC = = %lx MAL_DEF = %lx MAL_ERR= %lx\n", isr, uic, maldef, mal_errr); #endif
@@ -1740,7 +1740,7 @@ static void emac_err (struct eth_device *dev, unsigned long isr) { EMAC_4XX_HW_PST hw_p = dev->priv;
- printf ("EMAC%d error occured.... ISR = %lx\n", hw_p->devnum, isr); + printf ("EMAC%d error occurred.... ISR = %lx\n", hw_p->devnum, isr); out_be32((void *)EMAC0_ISR + hw_p->hw_addr, isr); }
diff --git a/drivers/net/enc28j60.c b/drivers/net/enc28j60.c index 59ea11c..611eabb 100644 --- a/drivers/net/enc28j60.c +++ b/drivers/net/enc28j60.c @@ -381,7 +381,7 @@ static int enc_phy_link_wait(enc_dev_t *enc) udelay(1000); }
- /* timeout occured */ + /* timeout occurred */ printf("%s: link down\n", enc->dev->name); return 1; } diff --git a/drivers/net/ne2000_base.c b/drivers/net/ne2000_base.c index 71d133c..67bf140 100644 --- a/drivers/net/ne2000_base.c +++ b/drivers/net/ne2000_base.c @@ -582,7 +582,7 @@ dp83902a_Overflow(void) /* * Read in as many packets as we can and acknowledge any and receive * interrupts. Since the buffer has overflowed, a receive event of - * some kind will have occured. + * some kind will have occurred. */ dp83902a_RxEvent(); DP_OUT(base, DP_ISR, DP_ISR_RxP|DP_ISR_RxE); @@ -592,7 +592,7 @@ dp83902a_Overflow(void) DP_OUT(base, DP_TCR, DP_TCR_NORMAL);
/* - * If a transmit command was issued, but no transmit event has occured, + * If a transmit command was issued, but no transmit event has occurred, * restart it here. */ DP_IN(base, DP_ISR, isr); diff --git a/drivers/usb/gadget/mpc8xx_udc.c b/drivers/usb/gadget/mpc8xx_udc.c index b3e178a..ad5ea7a 100644 --- a/drivers/usb/gadget/mpc8xx_udc.c +++ b/drivers/usb/gadget/mpc8xx_udc.c @@ -170,7 +170,7 @@ int udc_init (void)
/* udc_irq * - * Poll for whatever events may have occured + * Poll for whatever events may have occurred */ void udc_irq (void) { diff --git a/drivers/usb/musb/musb_hcd.c b/drivers/usb/musb/musb_hcd.c index 9a3b61a..4947936 100644 --- a/drivers/usb/musb/musb_hcd.c +++ b/drivers/usb/musb/musb_hcd.c @@ -73,9 +73,9 @@ static void write_toggle(struct usb_device *dev, u8 ep, u8 dir_out) }
/* - * This function checks if RxStall has occured on the endpoint. If a RxStall - * has occured, the RxStall is cleared and 1 is returned. If RxStall has - * not occured, 0 is returned. + * This function checks if RxStall has occurred on the endpoint. If a RxStall + * has occurred, the RxStall is cleared and 1 is returned. If RxStall has + * not occurred, 0 is returned. */ static u8 check_stall(u8 ep, u8 dir_out) { diff --git a/include/linux/fb.h b/include/linux/fb.h index 652cf3b..fcf331b 100644 --- a/include/linux/fb.h +++ b/include/linux/fb.h @@ -388,14 +388,14 @@ struct fb_cursor_user { #define FB_EVENT_GET_CONSOLE_MAP 0x07 /* CONSOLE-SPECIFIC: set console to framebuffer mapping */ #define FB_EVENT_SET_CONSOLE_MAP 0x08 -/* A hardware display blank change occured */ +/* A hardware display blank change occurred */ #define FB_EVENT_BLANK 0x09 /* Private modelist is to be replaced */ #define FB_EVENT_NEW_MODELIST 0x0A /* The resolution of the passed in fb_info about to change and all vc's should be changed */ #define FB_EVENT_MODE_CHANGE_ALL 0x0B -/* A software display blank change occured */ +/* A software display blank change occurred */ #define FB_EVENT_CONBLANK 0x0C /* Get drawing requirements */ #define FB_EVENT_GET_REQ 0x0D diff --git a/include/test/ut.h b/include/test/ut.h index da7c1a9..85434d7 100644 --- a/include/test/ut.h +++ b/include/test/ut.h @@ -17,9 +17,9 @@ struct unit_test_state; * ut_fail() - Record failure of a unit test * * @uts: Test state - * @fname: Filename where the error occured - * @line: Line number where the error occured - * @func: Function name where the error occured + * @fname: Filename where the error occurred + * @line: Line number where the error occurred + * @func: Function name where the error occurred * @cond: The condition that failed */ void ut_fail(struct unit_test_state *uts, const char *fname, int line, @@ -29,9 +29,9 @@ void ut_fail(struct unit_test_state *uts, const char *fname, int line, * ut_failf() - Record failure of a unit test * * @uts: Test state - * @fname: Filename where the error occured - * @line: Line number where the error occured - * @func: Function name where the error occured + * @fname: Filename where the error occurred + * @line: Line number where the error occurred + * @func: Function name where the error occurred * @cond: The condition that failed * @fmt: printf() format string for the error, followed by args */ diff --git a/include/usbdevice.h b/include/usbdevice.h index da5af6e..f27e17f 100644 --- a/include/usbdevice.h +++ b/include/usbdevice.h @@ -438,7 +438,7 @@ typedef enum usb_device_event { DEVICE_HUB_RESET, /* bi - bus has been unplugged */ DEVICE_DESTROY, /* bi - device instance should be destroyed */
- DEVICE_HOTPLUG, /* bi - a hotplug event has occured */ + DEVICE_HOTPLUG, /* bi - a hotplug event has occurred */
DEVICE_FUNCTION_PRIVATE, /* function - private */
On 30 April 2016 at 20:18, Vagrant Cascadian vagrant@debian.org wrote:
Please can you add a commit message?
nit below.
Can you drop the space before \n ?
I don't understand these "empty/missing commit message" remarks when there's a one-line changelog (in the subject). Do you seriously want the same line repeated twice in the git commit, just so something shows up in the body of the e-mail? It's one thing if the commit warrants more than a single line (though it's still not accurate to say that the changelog is completely absent), but a spelling fix is about as trivial as it gets... -Scott
Hi Scott,
It only takes a few seconds to add a commit message and I think it is good practice.
But if you want to allow commits with no message (other than merge/release tag), then we should document it here: http://www.denx.de/wiki/U-Boot/Patches
On Mon, 2016-05-02 at 12:57 -0600, Simon Glass wrote:
Hi Scott,
There is a commit message. It is 'Fix spelling of "occurred"'.
And that wiki link explicitly says, "Put a detailed description after the summary and blank line. If the summary line is sufficient to describe the change, you can omit the blank line and detailed description."
-Scott
Hi Scott,
Hi Scott,
OK I made a little update to make it more limited:
"Put a detailed description after the summary and blank line. If the summary line is sufficient to describe the change (e.g. it is a trivial spelling correction or whitespace update), you can omit the blank line and detailed description."
Does that seem reasonable?
We should avoid submitting new drivers and forgetting a commit message. Also some fixes are trivial (e.g. adding 1 to a result) but the reason for them needs to be explained. I'd rather have a hard and fast rule but I agree in some cases it doesn't make sense and it needs to be flexible.
Sorry if I'm being picky on this. I've spent a *lot* of time over the past few years digging into code and finding changes that are not self-explanatory. That's why I am keen on people adding comments to header files for API functions and struct members
I think it helps for people to answer the question 'why should this code be submitted?' when writing a commit message. For the record. in this case, I would have added a message something like 'Occurred is spelled incorrectly in a number of places. Fix these up to provide consistency'.
On Mon, 2016-05-02 at 13:26 -0600, Simon Glass wrote:
Hi Scott,
Hi Scott,
It's an example so it doesn't really limit anything -- if it did, I think that'd be way too specific. The criteria should be whether the single line adequately describes the patch (including justification, etc. if non-obvious). If it doesn't, then ask for a more detailed changelog, the same as you would if it contained more than one line but still didn't adequately describe the patch.
I could see a new driver sometimes reasonably having a one-line commit message (which is not the same as "forgetting a commit message"). It's a driver for hardware <foo>. If there's nothing unusual to be noted about the driver, known limitations, etc. then what else is there to say?
Yes, but simply mandating text beyond the summary line is likely to get you stuff like:
foo: Add 1 to result of blah()
Add one to the result of blah().
Signed-off-by: whoever
The problem there is not brevity, it's that important information is missing.
Yes, we could definitely use more API/struct documentation. I have no problem with pushing for better changelogs in cases where more information would be helpful. But we shouldn't mandate the changelog equivalent of:
i++; /* add one to i */
OK, but "fix spelling" followed by a diff showing the misspellings conveys the same information quite clearly.
-Scott
On Sat, Apr 30, 2016 at 07:18:00PM -0700, Vagrant Cascadian wrote:
Signed-off-by: Vagrant Cascadian vagrant@debian.org Reviewed-by: Simon Glass sjg@chromium.org
Scott Wood
Vagrant Cascadian
