[PATCH] ARM: imx: Get rid of only i.MX8M SMCCC arch call
This is the only place where i.MX8M code does SMCCC call, remove it. The output has little value as it prints some part of commit ID, and worse, if there is no SMC handler installed, the code outright hangs or crashes the system.
By removing this one instance of SMCCC call, U-Boot no longer depends on SMC handlers and can boot without hanging in any case. If there is a need to dump this commit ID, use CMD_SMC instead and do 'smc' call from U-Boot shell or scripts instead of hard-coding SMCCC dependency into architecture code. This particular code can be replaced by: => smc 0xc2000003 0 0 0 0 0 0
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- NOTE: This could also be hidden behind ARM_PSCI_FW , but I would rather just remove this hard dependency, it makes U-Boot porting easier. --- arch/arm/mach-imx/imx8m/soc.c | 20 -------------------- 1 file changed, 20 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 1a5a391443d..45c5476bbc7 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -27,7 +27,6 @@ #include <fdt_support.h> #include <fsl_wdog.h> #include <imx_sip.h> -#include <linux/arm-smccc.h> #include <linux/bitops.h>
DECLARE_GLOBAL_DATA_PTR; @@ -1191,27 +1190,8 @@ void reset_cpu(void) #endif
#if defined(CONFIG_ARCH_MISC_INIT) -static void acquire_buildinfo(void) -{ - u64 atf_commit = 0; - struct arm_smccc_res res; - - /* Get ARM Trusted Firmware commit id */ - arm_smccc_smc(IMX_SIP_BUILDINFO, IMX_SIP_BUILDINFO_GET_COMMITHASH, - 0, 0, 0, 0, 0, 0, &res); - atf_commit = res.a0; - if (atf_commit == 0xffffffff) { - debug("ATF does not support build info\n"); - atf_commit = 0x30; /* Display 0, 0 ascii is 0x30 */ - } - - printf("\n BuildInfo:\n - ATF %s\n\n", (char *)&atf_commit); -} - int arch_misc_init(void) { - acquire_buildinfo(); - return 0; } #endif
This should be ok, since ATF could print out log itself during boot.
Reviewed-by: Peng Fan peng.fan@nxp.com
Peng Fan (OSS)
