[U-Boot] is it necessary to set "gd->env_valid = 0" in getenv_default()?
still wandering through the bowels of u-boot environment manipulation code, and i see this in common/env_common.c:
/* * Look up the variable from the default environment */ char *getenv_default(const char *name) { char *ret_val; unsigned long really_valid = gd->env_valid; unsigned long real_gd_flags = gd->flags;
/* Pretend that the image is bad. */ gd->flags &= ~GD_FLG_ENV_READY; gd->env_valid = 0; <--- ????? ret_val = getenv(name); gd->env_valid = really_valid; gd->flags = real_gd_flags; return ret_val; }
fair enough ... in order to read a variable explicitly from the (default) environment, temporarily fake that there is nothing in the hash table, so this statement makes sense:
but is this one immediately afterwards also necessary?
gd->env_valid = 0;
because once you get to getenv() as defined in cmd/nvedit.c:
char *getenv(const char *name) { if (gd->flags & GD_FLG_ENV_READY) { /* after import into hashtable */ ENTRY e, *ep;
WATCHDOG_RESET();
e.key = name; e.data = NULL; hsearch_r(e, FIND, &ep, &env_htab, 0);
return ep ? ep->data : NULL; }
/* restricted capabilities before import */ if (getenv_f(name, (char *)(gd->env_buf), sizeof(gd->env_buf)) > 0) return (char *)(gd->env_buf);
return NULL; }
it seems that the only test is for GD_ENV_FLG_READY, so setting gd->env_valid=0 seems unnecessary. but perhaps i'm not reading far enough.
rday
p.s. just to be clear, the meanings of those two gd members is:
gd->flags & GD_FLG_ENV_READY means the environment has been imported into a hash table, and
gd->env_valid means the CRC for the environment in persistent storage is correct.
do i understand that correctly?
Robert P. J. Day
