[U-Boot] Please pull u-boot-ti/master
Hello,
The following changes since commit 8bf3c322856f42d4db8acd7fa4f2a17898564064:
logo: update to the new logo for ATMEL (2013-04-05 21:49:37 +0200)
git://git.denx.de/u-boot-ti.git master
for you to fetch changes up to dd2445ec1b839a5ca61ff8438a5b7aebb21b7986:
omap5_common.h: Use fallback CONFIG_SYS_BAUDRATE_TABLE (2013-04-08 11:40:59 -0400)
---------------------------------------------------------------- Andreas Bießmann (6): omap3/cpu.h: add BCH support asm/omap_gpmc.h: consolidate common defines omap3/omap_gpmc.h: add ooblayout for BCH8 as in kernel omap_gpmc: change nandecc command omap_gpmc: add support for hw assisted BCH8 tricorder: enable hw assisted BCH8 in SPL and u-boot
Bin Liu (2): musb: am335x: disable bulk split-combine feature musb: set MUSB speed based on CONFIG
Hunter, Jon (4): omap2420-h4: Fix DRAM initialisation omap2420-h4: Fix booting from NOR flash omap2420-h4: Add device tree support omap2420-h4: Fix get_timer() and CONFIG_SYS_HZ
Lars Poeschel (1): pcm051: Enable DDR PHY dynamic power down bit
Lokesh Vutla (1): arm: omap4: Fix SDRAM AUTO DETECTION
Lubomir Popov (1): OMAP: Fix copy-paste bug that did not enable UART4 clock
Manfred Huber (1): omap3_beagle: Flush UART3 xmit on enable if TEMT is broken
Nishanth Menon (1): omap5: Allow use of a plain text env file
SRICHARAN R (4): ARM: OMAP5: Rename omap5_evm to omap5_uevm ARM: OMAP5: Set fdt_high to enable booting with Device tree ARM: OMAP4/5: Change the default boot command to work with device tree ARM: OMAP4/5: Make bootz as the default boot command
Tom Rini (5): am335x: Enable MMC1 clock doc/feature-removal-schedule.txt: Add CONFIG_SYS_(CLOCKS|PADS)_ENABLE_ALL OMAP3/4/5/AM33xx: Correct logic for checking FAT or RAW MMC omap5_uevm.h: Move uEVM-specific choices to omap5_uevm.h omap5_common.h: Use fallback CONFIG_SYS_BAUDRATE_TABLE
README | 8 - arch/arm/cpu/arm1136/omap24xx/timer.c | 8 +- arch/arm/cpu/armv7/am33xx/clock_am33xx.c | 5 + arch/arm/cpu/armv7/am33xx/elm.c | 2 +- arch/arm/cpu/armv7/omap-common/clocks-common.c | 4 +- arch/arm/cpu/armv7/omap-common/emif-common.c | 29 +- arch/arm/cpu/armv7/omap-common/lowlevel_init.S | 10 +- arch/arm/cpu/armv7/omap3/board.c | 31 +- arch/arm/cpu/armv7/omap4/emif.c | 1 - arch/arm/cpu/armv7/omap5/emif.c | 1 - arch/arm/include/asm/arch-am33xx/omap_gpmc.h | 58 +--- arch/arm/include/asm/arch-am33xx/spl.h | 3 + arch/arm/include/asm/arch-am33xx/sys_proto.h | 2 +- arch/arm/include/asm/arch-omap24xx/omap2420.h | 6 +- arch/arm/include/asm/arch-omap3/cpu.h | 6 + arch/arm/include/asm/arch-omap3/omap_gpmc.h | 68 +--- arch/arm/include/asm/arch-omap3/spl.h | 3 + arch/arm/include/asm/arch-omap3/sys_proto.h | 2 +- arch/arm/include/asm/arch-omap4/omap.h | 1 - arch/arm/include/asm/arch-omap4/spl.h | 2 + arch/arm/include/asm/arch-omap5/omap.h | 1 - arch/arm/include/asm/arch-omap5/spl.h | 2 + arch/arm/include/asm/emif.h | 1 - arch/arm/include/asm/omap_gpmc.h | 87 +++++ board/isee/igep00x0/igep00x0.c | 2 +- board/overo/overo.c | 2 +- board/phytec/pcm051/board.c | 3 +- board/ti/omap2420h4/config.mk | 4 +- board/ti/omap2420h4/mem.c | 13 - board/ti/omap2420h4/omap2420h4.c | 24 +- board/ti/{omap5_evm => omap5_uevm}/Makefile | 0 board/ti/{omap5_evm => omap5_uevm}/evm.c | 0 board/ti/{omap5_evm => omap5_uevm}/mux_data.h | 0 boards.cfg | 2 +- doc/README.omap3 | 28 ++ doc/feature-removal-schedule.txt | 16 + drivers/mtd/nand/omap_gpmc.c | 424 +++++++++++++++++------- drivers/serial/ns16550.c | 18 +- drivers/usb/musb-new/musb_core.c | 7 + drivers/usb/musb-new/musb_uboot.c | 2 +- include/configs/am335x_evm.h | 1 + include/configs/dra7xx_evm.h | 2 + include/configs/igep00x0.h | 3 - include/configs/omap2420h4.h | 5 +- include/configs/omap4_common.h | 22 +- include/configs/omap5_common.h | 51 ++- include/configs/{omap5_evm.h => omap5_uevm.h} | 18 + include/configs/tricorder.h | 13 +- lib/Makefile | 2 +- 49 files changed, 672 insertions(+), 331 deletions(-) create mode 100644 arch/arm/include/asm/omap_gpmc.h rename board/ti/{omap5_evm => omap5_uevm}/Makefile (100%) rename board/ti/{omap5_evm => omap5_uevm}/evm.c (100%) rename board/ti/{omap5_evm => omap5_uevm}/mux_data.h (100%) rename include/configs/{omap5_evm.h => omap5_uevm.h} (70%)
Andreas' changes came well before the merge window, Everything else is a bugfix of some sort or another or part of keeping platforms still useful with later kernel releases.
Hi Tom,
On Mon, 8 Apr 2013 12:33:36 -0400, Tom Rini trini@ti.com wrote:
Hello,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
