[PATCH] arm: spl: flush and disable cache before jumping to OPTEE
Make sure to flush, disable caches and interrupts before jumpint to OPTEE. This fixes the SDP->SPL->OPTEE boot flow on iMX6Q and most likely on some other ARM SoCs.
Signed-off-by: Ricardo Salveti ricardo@foundries.io Co-developed-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io ---
arch/arm/lib/spl.c | 11 +++++++++++ common/spl/spl.c | 11 +++++++++-- include/spl.h | 9 +++++++++ 3 files changed, 29 insertions(+), 2 deletions(-)
diff --git a/arch/arm/lib/spl.c b/arch/arm/lib/spl.c index 8e2bdf3536..16e3cd557a 100644 --- a/arch/arm/lib/spl.c +++ b/arch/arm/lib/spl.c @@ -77,3 +77,14 @@ void __noreturn jump_to_image_linux(struct spl_image_info *spl_image) } #endif /* CONFIG_ARM64 */ #endif + +#if CONFIG_IS_ENABLED(OPTEE) +void __noreturn jump_to_image_optee(struct spl_image_info *spl_image) +{ + /* flush and turn off caches before jumping to OPTEE */ + cleanup_before_linux(); + + spl_optee_entry(NULL, NULL, spl_image->fdt_addr, + (void *)spl_image->entry_point); +} +#endif diff --git a/common/spl/spl.c b/common/spl/spl.c index d55d3c2848..f3fab3c4d9 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -171,6 +171,14 @@ __weak void spl_board_prepare_for_optee(void *fdt) { }
+#if CONFIG_IS_ENABLED(OPTEE) +__weak void __noreturn jump_to_image_optee(struct spl_image_info *spl_image) +{ + spl_optee_entry(NULL, NULL, spl_image->fdt_addr, + (void *)spl_image->entry_point); +} +#endif + __weak void spl_board_prepare_for_boot(void) { /* Nothing to do! */ @@ -777,8 +785,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) case IH_OS_TEE: debug("Jumping to U-Boot via OP-TEE\n"); spl_board_prepare_for_optee(spl_image.fdt_addr); - spl_optee_entry(NULL, NULL, spl_image.fdt_addr, - (void *)spl_image.entry_point); + jump_to_image_optee(&spl_image); break; #endif #if CONFIG_IS_ENABLED(OPENSBI) diff --git a/include/spl.h b/include/spl.h index afbf39bef4..8e7173d294 100644 --- a/include/spl.h +++ b/include/spl.h @@ -460,6 +460,15 @@ int spl_board_boot_device(u32 boot_device); */ void __noreturn jump_to_image_linux(struct spl_image_info *spl_image);
+/** + * jump_to_image_linux() - Jump to OP-TEE OS from SPL + * + * This jumps into OP-TEE OS using the information in @spl_image. + * + * @spl_image: Image description to set up + */ +void __noreturn jump_to_image_optee(struct spl_image_info *spl_image); + /** * spl_start_uboot() - Check if SPL should start the kernel or U-Boot *
You have I/DCache and interrupt enabled in SPL?
Regards, Peng.
- /* flush and turn off caches before jumping to OPTEE */
- cleanup_before_linux();
- spl_optee_entry(NULL, NULL, spl_image->fdt_addr,
+} +#endif
- __weak void spl_board_prepare_for_boot(void) { /* Nothing to do! */
break; #endif #if CONFIG_IS_ENABLED(OPENSBI)jump_to_image_optee(&spl_image);
- jump_to_image_linux() - Jump to OP-TEE OS from SPL
- This jumps into OP-TEE OS using the information in @spl_image.
- @spl_image: Image description to set up
- spl_start_uboot() - Check if SPL should start the kernel or U-Boot
+} +#endif
break;jump_to_image_optee(&spl_image);
At current, this causes evb-rk3229 and evb-rk3288 to fail to build. A trivial "test on OPTEE_IMAGE" instead leads to warnings about a noreturnn function returning. Please rebase on current master and retest your use cases, thanks!
Hello Tom,
+} +#endif
Thank you for the notes! I've fixed both issues in the 2nd version of the patchset.
-- Tom
Oleksandr Suvorov
Peng Fan (OSS)
