[PULL] u-boot-sh/master-fdt
The following changes since commit a712a54dc427708195e6405af4b072d869d0dd8f:
Merge patch series "configs: ti: Enable basic settings for SystemReady ACS" (2024-04-17 13:16:12 -0600)
https://source.denx.de/u-boot/custodians/u-boot-sh.git master-fdt
for you to fetch changes up to aad511a488c40393728156333d983c31001aac32:
ARM: dts: renesas: Switch to using upstream DT (2024-04-18 05:21:26 +0200)
---------------------------------------------------------------- Marek Vasut (4): ARM: dts: renesas: Stop using the -u-boot DTs for build ARM: dts: renesas: Replace R8A77950 with R8A77951 ARM: dts: renesas: Switch to using upstream DT on 64bit Renesas SoCs ARM: dts: renesas: Switch to using upstream DT
arch/arm/Kconfig | 1 + arch/arm/dts/Makefile | 58 +++++++++++----------- ...ch-u-boot.dts => r7s72100-gr-peach-u-boot.dtsi} | 1 - ...-boot.dts => r8a774a1-hihope-rzg2m-u-boot.dtsi} | 1 - ...-boot.dts => r8a774b1-hihope-rzg2n-u-boot.dtsi} | 1 - ...ek874-u-boot.dts => r8a774c0-ek874-u-boot.dtsi} | 1 - ...-boot.dts => r8a774e1-hihope-rzg2h-u-boot.dtsi} | 1 - ...-lager-u-boot.dts => r8a7790-lager-u-boot.dtsi} | 1 - ...-stout-u-boot.dts => r8a7790-stout-u-boot.dtsi} | 1 - ...lsch-u-boot.dts => r8a7791-koelsch-u-boot.dtsi} | 1 - ...orter-u-boot.dts => r8a7791-porter-u-boot.dtsi} | 1 - ...nche-u-boot.dts => r8a7792-blanche-u-boot.dtsi} | 1 - ...93-gose-u-boot.dts => r8a7793-gose-u-boot.dtsi} | 1 - ...7794-alt-u-boot.dts => r8a7794-alt-u-boot.dtsi} | 1 - ...94-silk-u-boot.dts => r8a7794-silk-u-boot.dtsi} | 1 - ...-u-boot.dts => r8a77951-salvator-x-u-boot.dtsi} | 3 +- .../{r8a77950-u-boot.dtsi => r8a77951-u-boot.dtsi} | 6 --- ...0-ulcb-u-boot.dts => r8a77951-ulcb-u-boot.dtsi} | 3 +- ...-u-boot.dts => r8a77960-salvator-x-u-boot.dtsi} | 1 - ...0-ulcb-u-boot.dts => r8a77960-ulcb-u-boot.dtsi} | 1 - ...-u-boot.dts => r8a77965-salvator-x-u-boot.dtsi} | 1 - ...5-ulcb-u-boot.dts => r8a77965-ulcb-u-boot.dtsi} | 1 - ...eagle-u-boot.dts => r8a77970-eagle-u-boot.dtsi} | 1 - ...v3msk-u-boot.dts => r8a77970-v3msk-u-boot.dtsi} | 1 - ...ndor-u-boot.dts => r8a77980-condor-u-boot.dtsi} | 1 - ...v3hsk-u-boot.dts => r8a77980-v3hsk-u-boot.dtsi} | 1 - ...ebisu-u-boot.dts => r8a77990-ebisu-u-boot.dtsi} | 1 - ...draak-u-boot.dts => r8a77995-draak-u-boot.dtsi} | 1 - ...lcon-u-boot.dts => r8a779a0-falcon-u-boot.dtsi} | 1 - ...ider-u-boot.dts => r8a779f0-spider-u-boot.dtsi} | 1 - ...-u-boot.dts => r8a779g0-white-hawk-u-boot.dtsi} | 1 - ...k-u-boot.dts => r8a779h0-gray-hawk-u-boot.dtsi} | 1 - arch/arm/mach-renesas/Kconfig | 1 + board/renesas/salvator-x/salvator-x.c | 6 +-- board/renesas/ulcb/ulcb.c | 6 +-- configs/alt_defconfig | 2 +- configs/blanche_defconfig | 2 +- configs/gose_defconfig | 2 +- configs/grpeach_defconfig | 2 +- configs/hihope_rzg2_defconfig | 4 +- configs/koelsch_defconfig | 2 +- configs/lager_defconfig | 2 +- configs/porter_defconfig | 2 +- configs/r8a77970_eagle_defconfig | 2 +- configs/r8a77970_v3msk_defconfig | 2 +- configs/r8a77980_condor_defconfig | 2 +- configs/r8a77980_v3hsk_defconfig | 2 +- configs/r8a77990_ebisu_defconfig | 2 +- configs/r8a77995_draak_defconfig | 2 +- configs/r8a779a0_falcon_defconfig | 2 +- configs/r8a779f0_spider_defconfig | 2 +- configs/r8a779g0_whitehawk_defconfig | 2 +- configs/r8a779h0_grayhawk_defconfig | 3 +- configs/rcar3_salvator-x_defconfig | 8 +-- configs/rcar3_ulcb_defconfig | 8 +-- configs/renesas_rzg2l_smarc_defconfig | 2 +- configs/rzg2_beacon_defconfig | 4 +- configs/rzn1_snarc_defconfig | 1 + configs/silinux_ek874_defconfig | 2 +- configs/silk_defconfig | 2 +- configs/stout_defconfig | 2 +- 61 files changed, 74 insertions(+), 105 deletions(-) rename arch/arm/dts/{r7s72100-gr-peach-u-boot.dts => r7s72100-gr-peach-u-boot.dtsi} (97%) rename arch/arm/dts/{r8a774a1-hihope-rzg2m-u-boot.dts => r8a774a1-hihope-rzg2m-u-boot.dtsi} (91%) rename arch/arm/dts/{r8a774b1-hihope-rzg2n-u-boot.dts => r8a774b1-hihope-rzg2n-u-boot.dtsi} (91%) rename arch/arm/dts/{r8a774c0-ek874-u-boot.dts => r8a774c0-ek874-u-boot.dtsi} (95%) rename arch/arm/dts/{r8a774e1-hihope-rzg2h-u-boot.dts => r8a774e1-hihope-rzg2h-u-boot.dtsi} (91%) rename arch/arm/dts/{r8a7790-lager-u-boot.dts => r8a7790-lager-u-boot.dtsi} (91%) rename arch/arm/dts/{r8a7790-stout-u-boot.dts => r8a7790-stout-u-boot.dtsi} (91%) rename arch/arm/dts/{r8a7791-koelsch-u-boot.dts => r8a7791-koelsch-u-boot.dtsi} (90%) rename arch/arm/dts/{r8a7791-porter-u-boot.dts => r8a7791-porter-u-boot.dtsi} (92%) rename arch/arm/dts/{r8a7792-blanche-u-boot.dts => r8a7792-blanche-u-boot.dtsi} (89%) rename arch/arm/dts/{r8a7793-gose-u-boot.dts => r8a7793-gose-u-boot.dtsi} (91%) rename arch/arm/dts/{r8a7794-alt-u-boot.dts => r8a7794-alt-u-boot.dtsi} (96%) rename arch/arm/dts/{r8a7794-silk-u-boot.dts => r8a7794-silk-u-boot.dtsi} (91%) rename arch/arm/dts/{r8a77950-salvator-x-u-boot.dts => r8a77951-salvator-x-u-boot.dtsi} (92%) rename arch/arm/dts/{r8a77950-u-boot.dtsi => r8a77951-u-boot.dtsi} (93%) rename arch/arm/dts/{r8a77950-ulcb-u-boot.dts => r8a77951-ulcb-u-boot.dtsi} (94%) rename arch/arm/dts/{r8a77960-salvator-x-u-boot.dts => r8a77960-salvator-x-u-boot.dtsi} (96%) rename arch/arm/dts/{r8a77960-ulcb-u-boot.dts => r8a77960-ulcb-u-boot.dtsi} (97%) rename arch/arm/dts/{r8a77965-salvator-x-u-boot.dts => r8a77965-salvator-x-u-boot.dtsi} (96%) rename arch/arm/dts/{r8a77965-ulcb-u-boot.dts => r8a77965-ulcb-u-boot.dtsi} (97%) rename arch/arm/dts/{r8a77970-eagle-u-boot.dts => r8a77970-eagle-u-boot.dtsi} (96%) rename arch/arm/dts/{r8a77970-v3msk-u-boot.dts => r8a77970-v3msk-u-boot.dtsi} (97%) rename arch/arm/dts/{r8a77980-condor-u-boot.dts => r8a77980-condor-u-boot.dtsi} (96%) rename arch/arm/dts/{r8a77980-v3hsk-u-boot.dts => r8a77980-v3hsk-u-boot.dtsi} (95%) rename arch/arm/dts/{r8a77990-ebisu-u-boot.dts => r8a77990-ebisu-u-boot.dtsi} (97%) rename arch/arm/dts/{r8a77995-draak-u-boot.dts => r8a77995-draak-u-boot.dtsi} (94%) rename arch/arm/dts/{r8a779a0-falcon-u-boot.dts => r8a779a0-falcon-u-boot.dtsi} (94%) rename arch/arm/dts/{r8a779f0-spider-u-boot.dts => r8a779f0-spider-u-boot.dtsi} (95%) rename arch/arm/dts/{r8a779g0-white-hawk-u-boot.dts => r8a779g0-white-hawk-u-boot.dtsi} (95%) rename arch/arm/dts/{r8a779h0-gray-hawk-u-boot.dts => r8a779h0-gray-hawk-u-boot.dtsi} (95%)
