[U-Boot] [PATCH 0/6] sbc8548 update; remaining bits for 85xx tree.
This is the remaining bits that weren't merged to 85xx, with the the requested fixes of course. Those being:
sbc8548: correct local bus SDRAM size from 64M to 128M -now uses I/O accesors on BR4/OR4
sbc8548: update PCI/PCI-e support code -redone to make use of the code de-duplification effort.
sbc8548: allow enabling PCI via a make config option -uses the "-t" to de-clutter the toplevel Makefile
New patches are as follows: fsl_pci: create a SET_STD_PCI_INFO() helper wrapper -I believe this was meant to be created, but wasn't.
sbc8548: use I/O accessors -uses the I/O accessors through the whole board file.
sbc8548: remove eTSEC3/4 voltage hack -noticed this while doing above; sbc doesn't need it.
Board still seems happy; I only noticed one cosmetic thing, that the new fsl_pci_init_port() prints "PCIE" always; even when the port is PCI and not PCI-e (see below).
Thanks, Paul.
U-Boot 2009.08-06732-g70c5c3d (Sep 20 2009 - 20:11:42)
CPU: 8548E, Version: 2.0, (0x80390020) Core: E500, Version: 2.0, (0x80210020) Clock Configuration: CPU0:990 MHz, CCB:396 MHz, DDR:198 MHz (396 MT/s data rate), LBC:99 MHz L1: D-cache 32 kB enabled I-cache 32 kB enabled Board: Wind River SBC8548 Rev. 0x2 I2C: ready DRAM: Initializing SDRAM: 128 MB DDR: 256 MB FLASH: 72 MB L2: 512 KB enabled PCI host: 64 bit, 66 MHz, sync, arbiter Scanning PCI bus 00 00 01 8086 1026 0200 00 PCIE1 on bus 00 - 00
PCIE at base address e000a000 Scanning PCI bus 02 02 00 1148 9e00 0200 00 PCIE1 on bus 01 - 02
In: serial Out: serial Err: serial Net: eTSEC0, eTSEC1 =>
Recycle the recently added PCI-e wrapper used to reduce board duplication of code by creating a similar version for plain PCI.
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- include/asm-ppc/fsl_pci.h | 12 ++++++++++++ 1 files changed, 12 insertions(+), 0 deletions(-)
diff --git a/include/asm-ppc/fsl_pci.h b/include/asm-ppc/fsl_pci.h index b9972da..2790da7 100644 --- a/include/asm-ppc/fsl_pci.h +++ b/include/asm-ppc/fsl_pci.h @@ -173,6 +173,18 @@ struct fsl_pci_info { int fsl_pci_init_port(struct fsl_pci_info *pci_info, struct pci_controller *hose, int busno);
+#define SET_STD_PCI_INFO(x, num) \ +{ \ + x.regs = CONFIG_SYS_PCI##num##_ADDR; \ + x.mem_bus = CONFIG_SYS_PCI##num##_MEM_BUS; \ + x.mem_phys = CONFIG_SYS_PCI##num##_MEM_PHYS; \ + x.mem_size = CONFIG_SYS_PCI##num##_MEM_SIZE; \ + x.io_bus = CONFIG_SYS_PCI##num##_IO_BUS; \ + x.io_phys = CONFIG_SYS_PCI##num##_IO_PHYS; \ + x.io_size = CONFIG_SYS_PCI##num##_IO_SIZE; \ + x.pci_num = num; \ +} + #define SET_STD_PCIE_INFO(x, num) \ { \ x.regs = CONFIG_SYS_PCIE##num##_ADDR; \
With only eTSEC1 and 2 being brought out to RJ-45 connectors, we aren't interested in the eTSEC3/4 voltage hack on this board
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- board/sbc8548/sbc8548.c | 6 ------ 1 files changed, 0 insertions(+), 6 deletions(-)
diff --git a/board/sbc8548/sbc8548.c b/board/sbc8548/sbc8548.c index 0316581..96a5f42 100644 --- a/board/sbc8548/sbc8548.c +++ b/board/sbc8548/sbc8548.c @@ -52,7 +52,6 @@ int board_early_init_f (void)
int checkboard (void) { - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); volatile ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR); volatile u_char *rev= (void *)CONFIG_SYS_BD_REV;
@@ -64,11 +63,6 @@ int checkboard (void) */ local_bus_init ();
- /* - * Hack TSEC 3 and 4 IO voltages. - */ - gur->tsec34ioovcr = 0xe7e0; /* 1110 0111 1110 0xxx */ - ecm->eedr = 0xffffffff; /* clear ecm errors */ ecm->eeer = 0xffffffff; /* enable ecm errors */ return 0;
Sweep throught the board specific file and replace the various register proddings with the equivalent I/O accessors.
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- board/sbc8548/sbc8548.c | 91 +++++++++++++++++++++++------------------------ 1 files changed, 45 insertions(+), 46 deletions(-)
diff --git a/board/sbc8548/sbc8548.c b/board/sbc8548/sbc8548.c index 96a5f42..ce998e1 100644 --- a/board/sbc8548/sbc8548.c +++ b/board/sbc8548/sbc8548.c @@ -56,15 +56,15 @@ int checkboard (void) volatile u_char *rev= (void *)CONFIG_SYS_BD_REV;
printf ("Board: Wind River SBC8548 Rev. 0x%01x\n", - (*rev) >> 4); + in_8(rev) >> 4);
/* * Initialize local bus. */ local_bus_init ();
- ecm->eedr = 0xffffffff; /* clear ecm errors */ - ecm->eeer = 0xffffffff; /* enable ecm errors */ + out_be32(&ecm->eedr, 0xffffffff); /* clear ecm errors */ + out_be32(&ecm->eeer, 0xffffffff); /* enable ecm errors */ return 0; }
@@ -86,7 +86,7 @@ initdram(int board_type)
- gur->ddrdllcr = 0x81000000; + out_be32(&gur->ddrdllcr, 0x81000000); asm("sync;isync;msync"); udelay(200); } @@ -123,24 +123,24 @@ local_bus_init(void) sys_info_t sysinfo;
get_sys_info(&sysinfo); - clkdiv = (lbc->lcrr & LCRR_CLKDIV) * 2; + clkdiv = (in_be32(&lbc->lcrr) & LCRR_CLKDIV) * 2; lbc_hz = sysinfo.freqSystemBus / 1000000 / clkdiv;
- gur->lbiuiplldcr1 = 0x00078080; + out_be32(&gur->lbiuiplldcr1, 0x00078080); if (clkdiv == 16) { - gur->lbiuiplldcr0 = 0x7c0f1bf0; + out_be32(&gur->lbiuiplldcr0, 0x7c0f1bf0); } else if (clkdiv == 8) { - gur->lbiuiplldcr0 = 0x6c0f1bf0; + out_be32(&gur->lbiuiplldcr0, 0x6c0f1bf0); } else if (clkdiv == 4) { - gur->lbiuiplldcr0 = 0x5c0f1bf0; + out_be32(&gur->lbiuiplldcr0, 0x5c0f1bf0); }
- lbc->lcrr |= 0x00030000; + setbits_be32(&lbc->lcrr, 0x00030000);
- lbc->ltesr = 0xffffffff; /* Clear LBC error interrupts */ - lbc->lteir = 0xffffffff; /* Enable LBC error interrupts */ + out_be32(&lbc->ltesr, 0xffffffff); /* Clear LBC error IRQs */ + out_be32(&lbc->lteir, 0xffffffff); /* Enable LBC error IRQs */ }
/* @@ -163,18 +163,18 @@ sdram_init(void) /* * Setup SDRAM Base and Option Registers */ - lbc->or3 = CONFIG_SYS_OR3_PRELIM; + out_be32(&lbc->or3, CONFIG_SYS_OR3_PRELIM); asm("msync");
- lbc->br3 = CONFIG_SYS_BR3_PRELIM; + out_be32(&lbc->br3, CONFIG_SYS_BR3_PRELIM); asm("msync");
- lbc->lbcr = CONFIG_SYS_LBC_LBCR; + out_be32(&lbc->lbcr, CONFIG_SYS_LBC_LBCR); asm("msync");
- lbc->lsrt = CONFIG_SYS_LBC_LSRT; - lbc->mrtpr = CONFIG_SYS_LBC_MRTPR; + out_be32(&lbc->lsrt, CONFIG_SYS_LBC_LSRT); + out_be32(&lbc->mrtpr, CONFIG_SYS_LBC_MRTPR); asm("msync");
/* @@ -186,7 +186,7 @@ sdram_init(void) /* * Issue PRECHARGE ALL command. */ - lbc->lsdmr = lsdmr_common | LSDMR_OP_PCHALL; + out_be32(&lbc->lsdmr, lsdmr_common | LSDMR_OP_PCHALL); asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -196,7 +196,7 @@ sdram_init(void) * Issue 8 AUTO REFRESH commands. */ for (idx = 0; idx < 8; idx++) { - lbc->lsdmr = lsdmr_common | LSDMR_OP_ARFRSH; + out_be32(&lbc->lsdmr, lsdmr_common | LSDMR_OP_ARFRSH); asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -206,7 +206,7 @@ sdram_init(void) /* * Issue 8 MODE-set command. */ - lbc->lsdmr = lsdmr_common | LSDMR_OP_MRW; + out_be32(&lbc->lsdmr, lsdmr_common | LSDMR_OP_MRW); asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -215,7 +215,7 @@ sdram_init(void) /* * Issue NORMAL OP command. */ - lbc->lsdmr = lsdmr_common | LSDMR_OP_NORMAL; + out_be32(&lbc->lsdmr, lsdmr_common | LSDMR_OP_NORMAL); asm("sync;msync"); *sdram_addr = 0xff; ppcDcbf((unsigned long) sdram_addr); @@ -263,45 +263,44 @@ testdram(void) } #endif
-#if !defined(CONFIG_SPD_EEPROM) +#if !defined(CONFIG_SPD_EEPROM) +#define CONFIG_SYS_DDR_CONTROL 0xc300c000 /************************************************************************* * fixed_sdram init -- doesn't use serial presence detect. * assumes 256MB DDR2 SDRAM SODIMM, without ECC, running at DDR400 speed. ************************************************************************/ long int fixed_sdram (void) { - #define CONFIG_SYS_DDR_CONTROL 0xc300c000 - volatile ccsr_ddr_t *ddr = (void *)(CONFIG_SYS_MPC85xx_DDR_ADDR);
- ddr->cs0_bnds = 0x0000007f; - ddr->cs1_bnds = 0x008000ff; - ddr->cs2_bnds = 0x00000000; - ddr->cs3_bnds = 0x00000000; - ddr->cs0_config = 0x80010101; - ddr->cs1_config = 0x80010101; - ddr->cs2_config = 0x00000000; - ddr->cs3_config = 0x00000000; - ddr->timing_cfg_3 = 0x00000000; - ddr->timing_cfg_0 = 0x00220802; - ddr->timing_cfg_1 = 0x38377322; - ddr->timing_cfg_2 = 0x0fa044C7; - ddr->sdram_cfg = 0x4300C000; - ddr->sdram_cfg_2 = 0x24401000; - ddr->sdram_mode = 0x23C00542; - ddr->sdram_mode_2 = 0x00000000; - ddr->sdram_interval = 0x05080100; - ddr->sdram_md_cntl = 0x00000000; - ddr->sdram_data_init = 0x00000000; - ddr->sdram_clk_cntl = 0x03800000; + out_be32(&ddr->cs0_bnds, 0x0000007f); + out_be32(&ddr->cs1_bnds, 0x008000ff); + out_be32(&ddr->cs2_bnds, 0x00000000); + out_be32(&ddr->cs3_bnds, 0x00000000); + out_be32(&ddr->cs0_config, 0x80010101); + out_be32(&ddr->cs1_config, 0x80010101); + out_be32(&ddr->cs2_config, 0x00000000); + out_be32(&ddr->cs3_config, 0x00000000); + out_be32(&ddr->timing_cfg_3, 0x00000000); + out_be32(&ddr->timing_cfg_0, 0x00220802); + out_be32(&ddr->timing_cfg_1, 0x38377322); + out_be32(&ddr->timing_cfg_2, 0x0fa044C7); + out_be32(&ddr->sdram_cfg, 0x4300C000); + out_be32(&ddr->sdram_cfg_2, 0x24401000); + out_be32(&ddr->sdram_mode, 0x23C00542); + out_be32(&ddr->sdram_mode_2, 0x00000000); + out_be32(&ddr->sdram_interval, 0x05080100); + out_be32(&ddr->sdram_md_cntl, 0x00000000); + out_be32(&ddr->sdram_data_init, 0x00000000); + out_be32(&ddr->sdram_clk_cntl, 0x03800000); asm("sync;isync;msync"); udelay(500);
#if defined (CONFIG_DDR_ECC) /* Enable ECC checking */ - ddr->sdram_cfg = (CONFIG_SYS_DDR_CONTROL | 0x20000000); + out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL | 0x20000000); #else - ddr->sdram_cfg = CONFIG_SYS_DDR_CONTROL; + out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL); #endif
return CONFIG_SYS_SDRAM_SIZE * 1024 * 1024;
The size of the LB SDRAM on this board is 128MB, spanning CS3 and CS4. It was previously only being configured for 64MB on CS3, since that was what the original codebase of the MPC8548CDS had. In addition to setting up BR4/OR4, this also adds the TLB entry for the second half of the SDRAM.
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- board/sbc8548/sbc8548.c | 8 +++++++- board/sbc8548/tlb.c | 22 +++++++++++++++------- include/configs/sbc8548.h | 42 ++++++++++++++++++++++++++++++++++++++---- 3 files changed, 60 insertions(+), 12 deletions(-)
diff --git a/board/sbc8548/sbc8548.c b/board/sbc8548/sbc8548.c index ce998e1..f4bfd92 100644 --- a/board/sbc8548/sbc8548.c +++ b/board/sbc8548/sbc8548.c @@ -149,7 +149,7 @@ local_bus_init(void) void sdram_init(void) { -#if defined(CONFIG_SYS_OR3_PRELIM) && defined(CONFIG_SYS_BR3_PRELIM) +#if defined(CONFIG_SYS_LBC_SDRAM_SIZE)
uint idx; volatile ccsr_lbc_t *lbc = (void *)(CONFIG_SYS_MPC85xx_LBC_ADDR); @@ -169,6 +169,12 @@ sdram_init(void) out_be32(&lbc->br3, CONFIG_SYS_BR3_PRELIM); asm("msync");
+ out_be32(&lbc->or4, CONFIG_SYS_OR4_PRELIM); + asm("msync"); + + out_be32(&lbc->br4, CONFIG_SYS_BR4_PRELIM); + asm("msync"); + out_be32(&lbc->lbcr, CONFIG_SYS_LBC_LBCR); asm("msync");
diff --git a/board/sbc8548/tlb.c b/board/sbc8548/tlb.c index dbb9ba8..e173245 100644 --- a/board/sbc8548/tlb.c +++ b/board/sbc8548/tlb.c @@ -88,14 +88,22 @@ struct fsl_e_tlb_entry tlb_table[] = {
/* * TLB 5: 64M Cacheable, non-guarded - * 0xf0000000 64M LBC SDRAM + * 0xf0000000 64M LBC SDRAM First half */ SET_TLB_ENTRY(1, CONFIG_SYS_LBC_SDRAM_BASE, CONFIG_SYS_LBC_SDRAM_BASE, MAS3_SX|MAS3_SW|MAS3_SR, 0, 0, 5, BOOKE_PAGESZ_64M, 1),
/* - * TLB 6: 16M Cacheable, non-guarded + * TLB 6: 64M Cacheable, non-guarded + * 0xf4000000 64M LBC SDRAM Second half + */ + SET_TLB_ENTRY(1, CONFIG_SYS_LBC_SDRAM_BASE + 0x4000000, CONFIG_SYS_LBC_SDRAM_BASE + 0x4000000, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 6, BOOKE_PAGESZ_64M, 1), + + /* + * TLB 7: 16M Cacheable, non-guarded * 0xf8000000 1M 7-segment LED display * 0xf8100000 1M User switches * 0xf8300000 1M Board revision @@ -103,23 +111,23 @@ struct fsl_e_tlb_entry tlb_table[] = { */ SET_TLB_ENTRY(1, CONFIG_SYS_EPLD_BASE, CONFIG_SYS_EPLD_BASE, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 6, BOOKE_PAGESZ_16M, 1), + 0, 7, BOOKE_PAGESZ_16M, 1),
/* - * TLB 7: 4M Non-cacheable, guarded + * TLB 8: 4M Non-cacheable, guarded * 0xfb800000 4M 1st 4MB block of 64MB user FLASH */ SET_TLB_ENTRY(1, CONFIG_SYS_ALT_FLASH, CONFIG_SYS_ALT_FLASH, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 7, BOOKE_PAGESZ_4M, 1), + 0, 8, BOOKE_PAGESZ_4M, 1),
/* - * TLB 8: 4M Non-cacheable, guarded + * TLB 9: 4M Non-cacheable, guarded * 0xfbc00000 4M 2nd 4MB block of 64MB user FLASH */ SET_TLB_ENTRY(1, CONFIG_SYS_ALT_FLASH + 0x400000, CONFIG_SYS_ALT_FLASH + 0x400000, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 8, BOOKE_PAGESZ_4M, 1), + 0, 9, BOOKE_PAGESZ_4M, 1),
diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 8edba20..4751013 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -196,13 +196,13 @@ #define CONFIG_SYS_EEPROM_BASE 0xf8b00000
/* - * SDRAM on the Local Bus + * SDRAM on the Local Bus (CS3 and CS4) */ #define CONFIG_SYS_LBC_SDRAM_BASE 0xf0000000 /* Localbus SDRAM */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ +#define CONFIG_SYS_LBC_SDRAM_SIZE 128 /* LBC SDRAM is 128MB */
/* - * Base Register 3 and Option Register 3 configure SDRAM. + * Base Register 3 and Option Register 3 configure the 1st 1/2 SDRAM. * The SDRAM base address, CONFIG_SYS_LBC_SDRAM_BASE, is 0xf0000000. * * For BR3, need: @@ -220,7 +220,7 @@ #define CONFIG_SYS_BR3_PRELIM 0xf0001861
/* - * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. + * The SDRAM size in MB, of 1/2 CONFIG_SYS_LBC_SDRAM_SIZE, is 64. * * For OR3, need: * 64MB mask for AM, OR3[0:7] = 1111 1100 @@ -235,6 +235,40 @@
#define CONFIG_SYS_OR3_PRELIM 0xfc006cc0
+/* + * Base Register 4 and Option Register 4 configure the 2nd 1/2 SDRAM. + * The base address, (SDRAM_BASE + 1/2*SIZE), is 0xf4000000. + * + * For BR4, need: + * Base address of 0xf4000000 = BR[0:16] = 1111 0100 0000 0000 0 + * port-size = 32-bits = BR2[19:20] = 11 + * no parity checking = BR2[21:22] = 00 + * SDRAM for MSEL = BR2[24:26] = 011 + * Valid = BR[31] = 1 + * + * 0 4 8 12 16 20 24 28 + * 1111 0000 0000 0000 0001 1000 0110 0001 = f4001861 + * + */ + +#define CONFIG_SYS_BR4_PRELIM 0xf4001861 + +/* + * The SDRAM size in MB, of 1/2 CONFIG_SYS_LBC_SDRAM_SIZE, is 64. + * + * For OR4, need: + * 64MB mask for AM, OR3[0:7] = 1111 1100 + * XAM, OR3[17:18] = 11 + * 10 columns OR3[19-21] = 011 + * 12 rows OR3[23-25] = 011 + * EAD set for extra time OR[31] = 0 + * + * 0 4 8 12 16 20 24 28 + * 1111 1100 0000 0000 0110 1100 1100 0000 = fc006cc0 + */ + +#define CONFIG_SYS_OR4_PRELIM 0xfc006cc0 + #define CONFIG_SYS_LBC_LCRR 0x00000002 /* LB clock ratio reg */ #define CONFIG_SYS_LBC_LBCR 0x00000000 /* LB config reg */ #define CONFIG_SYS_LBC_LSRT 0x20000000 /* LB sdram refresh timer */
The PCI/PCI-e support for the sbc8548 was based on an earlier version of what the MPC8548CDS board was using, and in its current state it won't even compile. This re-syncs it to match the latest codebase and makes use of the new shared PCI functions to reduce board duplication.
It borrows from the MPC8568MDS, in that it pulls the PCI-e I/O back to 0xe280_0000 (where PCI2 would be on MPC8548CDS), and similarly it coalesces the PCI and PCI-e mem into one single TLB.
Both PCI-x and PCI-e have been tested with intel e1000 cards under linux (with an accompanying dts change in place)
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- board/sbc8548/law.c | 12 ++++- board/sbc8548/sbc8548.c | 129 ++++++++++++++------------------------------- board/sbc8548/tlb.c | 48 +++++++--------- include/configs/sbc8548.h | 45 ++++++++------- 4 files changed, 94 insertions(+), 140 deletions(-)
diff --git a/board/sbc8548/law.c b/board/sbc8548/law.c index e8c7ae2..6d1efc0 100644 --- a/board/sbc8548/law.c +++ b/board/sbc8548/law.c @@ -32,8 +32,10 @@ * * 0x0000_0000 0x0fff_ffff DDR 256M * 0x8000_0000 0x9fff_ffff PCI1 MEM 512M + * 0xa000_0000 0xbfff_ffff PCIe MEM 512M * 0xe000_0000 0xe000_ffff CCSR 1M - * 0xe200_0000 0xe2ff_ffff PCI1 IO 16M + * 0xe200_0000 0xe27f_ffff PCI1 IO 8M + * 0xe280_0000 0xe2ff_ffff PCIe IO 8M * 0xf000_0000 0xf7ff_ffff SDRAM 128M * 0xf8b0_0000 0xf80f_ffff EEPROM 1M * 0xfb80_0000 0xff7f_ffff FLASH (2nd bank) 64M @@ -48,8 +50,14 @@ struct law_entry law_table[] = { #ifndef CONFIG_SPD_EEPROM SET_LAW(CONFIG_SYS_DDR_SDRAM_BASE, LAW_SIZE_256M, LAW_TRGT_IF_DDR), #endif +#ifdef CONFIG_SYS_PCI1_MEM_PHYS SET_LAW(CONFIG_SYS_PCI1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCI), - SET_LAW(CONFIG_SYS_PCI1_IO_PHYS, LAW_SIZE_16M, LAW_TRGT_IF_PCI), + SET_LAW(CONFIG_SYS_PCI1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCI), +#endif +#ifdef CONFIG_SYS_PCIE1_MEM_PHYS + SET_LAW(CONFIG_SYS_PCIE1_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_PCIE_1), + SET_LAW(CONFIG_SYS_PCIE1_IO_PHYS, LAW_SIZE_8M, LAW_TRGT_IF_PCIE_1), +#endif /* LBC window - maps 256M 0xf0000000 -> 0xffffffff */ SET_LAW(CONFIG_SYS_LBC_SDRAM_BASE, LAW_SIZE_256M, LAW_TRGT_IF_LBC), }; diff --git a/board/sbc8548/sbc8548.c b/board/sbc8548/sbc8548.c index f4bfd92..194f6ab 100644 --- a/board/sbc8548/sbc8548.c +++ b/board/sbc8548/sbc8548.c @@ -321,125 +321,74 @@ static struct pci_controller pci1_hose; static struct pci_controller pcie1_hose; #endif /* CONFIG_PCIE1 */
-int first_free_busno=0;
+#ifdef CONFIG_PCI void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + struct fsl_pci_info pci_info[2]; + u32 devdisr, pordevsr, porpllsr, io_sel; + int first_free_busno = 0; + int num = 0;
-#ifdef CONFIG_PCI1 -{ - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - struct pci_controller *hose = &pci1_hose; - struct pci_region *r = hose->regions; +#ifdef CONFIG_PCIE1 + int pcie_configured; +#endif
- uint pci_32 = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; /* PORDEVSR[15] */ - uint pci_arb = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; /* PORDEVSR[14] */ - uint pci_clk_sel = gur->porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; /* PORPLLSR[16] */ + devdisr = in_be32(&gur->devdisr); + pordevsr = in_be32(&gur->pordevsr); + porpllsr = in_be32(&gur->porpllsr); + io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19;
- uint pci_speed = CONFIG_SYS_CLK_FREQ; /* get_clock_freq() */ + debug(" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel); + +#ifdef CONFIG_PCI1 + if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { + uint pci_32 = pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; + uint pci_arb = pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; + uint pci_clk_sel = porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; + uint pci_speed = CONFIG_SYS_CLK_FREQ; /* get_clock_freq() */
- if (!(gur->devdisr & MPC85xx_DEVDISR_PCI1)) { printf (" PCI host: %d bit, %s MHz, %s, %s\n", (pci_32) ? 32 : 64, (pci_speed == 33000000) ? "33" : (pci_speed == 66000000) ? "66" : "unknown", pci_clk_sel ? "sync" : "async", - pci_arb ? "arbiter" : "external-arbiter" - ); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCI1_MEM_BASE, - CONFIG_SYS_PCI1_MEM_PHYS, - CONFIG_SYS_PCI1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCI1_IO_BASE, - CONFIG_SYS_PCI1_IO_PHYS, - CONFIG_SYS_PCI1_IO_SIZE, - PCI_REGION_IO); - hose->region_count = r - hose->regions; - - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - first_free_busno=hose->last_busno+1; - printf ("PCI on bus %02x - %02x\n",hose->first_busno,hose->last_busno); -#ifdef CONFIG_PCIX_CHECK - if (!(gur->pordevsr & MPC85xx_PORDEVSR_PCI1)) { - /* PCI-X init */ - if (CONFIG_SYS_CLK_FREQ < 66000000) - printf("PCI-X will only work at 66 MHz\n"); - - reg16 = PCI_X_CMD_MAX_SPLIT | PCI_X_CMD_MAX_READ - | PCI_X_CMD_ERO | PCI_X_CMD_DPERR_E; - pci_hose_write_config_word(hose, bus, PCIX_COMMAND, reg16); - } -#endif + pci_arb ? "arbiter" : "external-arbiter"); + + SET_STD_PCI_INFO(pci_info[num], 1); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pci1_hose, first_free_busno); } else { printf (" PCI: disabled\n"); } -} + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCI1; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI1); /* disable */ #endif
- gur->devdisr |= MPC85xx_DEVDISR_PCI2; /* disable PCI2 */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI2); /* disable PCI2 */
#ifdef CONFIG_PCIE1 -{ - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - struct pci_controller *hose = &pcie1_hose; - struct pci_region *r = hose->regions; - - int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel); - - if (pcie_configured && !(gur->devdisr & MPC85xx_DEVDISR_PCIE)){ - printf ("\n PCIE at base address %x", - (uint)pci); - - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; - debug (" with errors. Clearing. Now 0x%08x",pci->pme_msg_det); - } - printf ("\n"); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_MEM_BASE, - CONFIG_SYS_PCIE1_MEM_PHYS, - CONFIG_SYS_PCIE1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_IO_BASE, - CONFIG_SYS_PCIE1_IO_PHYS, - CONFIG_SYS_PCIE1_IO_SIZE, - PCI_REGION_IO); - - hose->region_count = r - hose->regions; - - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - printf ("PCIE on bus %d - %d\n",hose->first_busno,hose->last_busno); - - first_free_busno=hose->last_busno+1; + pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel);
+ if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ + SET_STD_PCIE_INFO(pci_info[num], 1); + printf (" PCIE at base address %lx\n", pci_info[num].regs); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie1_hose, first_free_busno); } else { printf (" PCIE: disabled\n"); } - } + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCIE; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ #endif - } +#endif
int board_eth_init(bd_t *bis) { diff --git a/board/sbc8548/tlb.c b/board/sbc8548/tlb.c index e173245..dab0eb1 100644 --- a/board/sbc8548/tlb.c +++ b/board/sbc8548/tlb.c @@ -52,58 +52,52 @@ struct fsl_e_tlb_entry tlb_table[] = { 0, 0, BOOKE_PAGESZ_64M, 1),
/* - * TLB 1: 256M Non-cacheable, guarded - * 0x80000000 256M PCI1 MEM First half + * TLB 1: 1G Non-cacheable, guarded + * 0x80000000 512M PCI1 MEM + * 0xa0000000 512M PCIe MEM */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCI1_MEM_PHYS, CONFIG_SYS_PCI1_MEM_PHYS, + SET_TLB_ENTRY(1, CONFIG_SYS_PCI1_MEM_VIRT, CONFIG_SYS_PCI1_MEM_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 1, BOOKE_PAGESZ_256M, 1), + 0, 1, BOOKE_PAGESZ_1G, 1),
/* - * TLB 2: 256M Non-cacheable, guarded - * 0x90000000 256M PCI1 MEM Second half - */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCI1_MEM_PHYS + 0x10000000, CONFIG_SYS_PCI1_MEM_PHYS + 0x10000000, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 2, BOOKE_PAGESZ_256M, 1), - - /* - * TLB 3: 256M Cacheable, non-guarded + * TLB 2: 256M Cacheable, non-guarded * 0x0 256M DDR SDRAM */ #if !defined(CONFIG_SPD_EEPROM) SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE, MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 3, BOOKE_PAGESZ_256M, 1), + 0, 2, BOOKE_PAGESZ_256M, 1), #endif
/* - * TLB 4: 64M Non-cacheable, guarded + * TLB 3: 64M Non-cacheable, guarded * 0xe0000000 1M CCSRBAR - * 0xe2000000 16M PCI1 IO + * 0xe2000000 8M PCI1 IO + * 0xe2800000 8M PCIe IO */ SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 4, BOOKE_PAGESZ_64M, 1), + 0, 3, BOOKE_PAGESZ_64M, 1),
/* - * TLB 5: 64M Cacheable, non-guarded + * TLB 4: 64M Cacheable, non-guarded * 0xf0000000 64M LBC SDRAM First half */ SET_TLB_ENTRY(1, CONFIG_SYS_LBC_SDRAM_BASE, CONFIG_SYS_LBC_SDRAM_BASE, MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 5, BOOKE_PAGESZ_64M, 1), + 0, 4, BOOKE_PAGESZ_64M, 1),
/* - * TLB 6: 64M Cacheable, non-guarded + * TLB 5: 64M Cacheable, non-guarded * 0xf4000000 64M LBC SDRAM Second half */ SET_TLB_ENTRY(1, CONFIG_SYS_LBC_SDRAM_BASE + 0x4000000, CONFIG_SYS_LBC_SDRAM_BASE + 0x4000000, MAS3_SX|MAS3_SW|MAS3_SR, 0, - 0, 6, BOOKE_PAGESZ_64M, 1), + 0, 5, BOOKE_PAGESZ_64M, 1),
/* - * TLB 7: 16M Cacheable, non-guarded + * TLB 6: 16M Cacheable, non-guarded * 0xf8000000 1M 7-segment LED display * 0xf8100000 1M User switches * 0xf8300000 1M Board revision @@ -111,23 +105,23 @@ struct fsl_e_tlb_entry tlb_table[] = { */ SET_TLB_ENTRY(1, CONFIG_SYS_EPLD_BASE, CONFIG_SYS_EPLD_BASE, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 7, BOOKE_PAGESZ_16M, 1), + 0, 6, BOOKE_PAGESZ_16M, 1),
/* - * TLB 8: 4M Non-cacheable, guarded + * TLB 7: 4M Non-cacheable, guarded * 0xfb800000 4M 1st 4MB block of 64MB user FLASH */ SET_TLB_ENTRY(1, CONFIG_SYS_ALT_FLASH, CONFIG_SYS_ALT_FLASH, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 8, BOOKE_PAGESZ_4M, 1), + 0, 7, BOOKE_PAGESZ_4M, 1),
/* - * TLB 9: 4M Non-cacheable, guarded + * TLB 8: 4M Non-cacheable, guarded * 0xfbc00000 4M 2nd 4MB block of 64MB user FLASH */ SET_TLB_ENTRY(1, CONFIG_SYS_ALT_FLASH + 0x400000, CONFIG_SYS_ALT_FLASH + 0x400000, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, 9, BOOKE_PAGESZ_4M, 1), + 0, 8, BOOKE_PAGESZ_4M, 1),
diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 4751013..4ef3028 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -42,7 +42,14 @@ #undef CONFIG_PCI1 /* PCI controller 1 */ #undef CONFIG_PCIE1 /* PCIE controler 1 (slot 1) */ #undef CONFIG_RIO -#undef CONFIG_FSL_PCI_INIT /* Use common FSL init code */ + +#ifdef CONFIG_PCI +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ +#endif +#ifdef CONFIG_PCIE1 +#define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */ +#endif
#define CONFIG_TSEC_ENET /* tsec ethernet support */ #define CONFIG_ENV_OVERWRITE @@ -342,31 +349,27 @@ * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. */ +#define CONFIG_SYS_PCI_VIRT 0x80000000 /* 1G PCI TLB */ #define CONFIG_SYS_PCI_PHYS 0x80000000 /* 1G PCI TLB */
-#define CONFIG_SYS_PCI1_MEM_BASE 0x80000000 -#define CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_BASE +#define CONFIG_SYS_PCI1_MEM_VIRT 0x80000000 +#define CONFIG_SYS_PCI1_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCI1_MEM_PHYS 0x80000000 #define CONFIG_SYS_PCI1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCI1_IO_BASE 0x00000000 -#define CONFIG_SYS_PCI1_IO_PHYS 0xe2000000 -#define CONFIG_SYS_PCI1_IO_SIZE 0x00100000 /* 1M */ - -#ifdef CONFIG_PCI2 -#define CONFIG_SYS_PCI2_MEM_BASE 0xa0000000 -#define CONFIG_SYS_PCI2_MEM_PHYS CONFIG_SYS_PCI2_MEM_BASE -#define CONFIG_SYS_PCI2_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCI2_IO_BASE 0x00000000 -#define CONFIG_SYS_PCI2_IO_PHYS 0xe2800000 -#define CONFIG_SYS_PCI2_IO_SIZE 0x00100000 /* 1M */ -#endif +#define CONFIG_SYS_PCI1_IO_VIRT 0xe2000000 +#define CONFIG_SYS_PCI1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCI1_IO_PHYS 0xe2000000 +#define CONFIG_SYS_PCI1_IO_SIZE 0x00800000 /* 8M */
#ifdef CONFIG_PCIE1 -#define CONFIG_SYS_PCIE1_MEM_BASE 0xa0000000 -#define CONFIG_SYS_PCIE1_MEM_PHYS CONFIG_SYS_PCIE1_MEM_BASE +#define CONFIG_SYS_PCIE1_MEM_VIRT 0xa0000000 +#define CONFIG_SYS_PCIE1_MEM_BUS 0xa0000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xa0000000 #define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_BASE 0x00000000 -#define CONFIG_SYS_PCIE1_IO_PHYS 0xe3000000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00100000 /* 1M */ +#define CONFIG_SYS_PCIE1_IO_VIRT 0xe2800000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_PHYS 0xe2800000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00800000 /* 8M */ #endif
#ifdef CONFIG_RIO @@ -385,7 +388,7 @@ #undef CONFIG_EEPRO100 #undef CONFIG_TULIP
-#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */
#endif /* CONFIG_PCI */
Prior to this commit, to enable PCI, you had to go manually edit the board config header, and if you had 33MHz PCI, you had to manually change CONFIG_SYS_NS16550_CLK too, which was not real user friendly,
This adds the typical PCI and clock speed make targets to the toplevel Makefile in accordance with what is being done with other boards (i.e. using the "-t" to mkconfig).
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- MAKEALL | 4 ++++ Makefile | 8 ++++++-- include/configs/sbc8548.h | 43 +++++++++++++++++++++++++++++++++---------- 3 files changed, 43 insertions(+), 12 deletions(-)
diff --git a/MAKEALL b/MAKEALL index 1d50c34..b394adb 100755 --- a/MAKEALL +++ b/MAKEALL @@ -399,6 +399,10 @@ LIST_85xx=" \ PM856 \ sbc8540 \ sbc8548 \ + sbc8548_PCI_33 \ + sbc8548_PCI_66 \ + sbc8548_PCI_33_PCIE \ + sbc8548_PCI_66_PCIE \ sbc8560 \ socrates \ stxgp3 \ diff --git a/Makefile b/Makefile index d8daa89..55ee25d 100644 --- a/Makefile +++ b/Makefile @@ -2544,8 +2544,12 @@ sbc8540_66_config: unconfig fi @$(MKCONFIG) -a SBC8540 ppc mpc85xx sbc8560
-sbc8548_config: unconfig - @$(MKCONFIG) $(@:_config=) ppc mpc85xx sbc8548 +sbc8548_config \ +sbc8548_PCI_33_config \ +sbc8548_PCI_66_config \ +sbc8548_PCI_33_PCIE_config \ +sbc8548_PCI_66_PCIE_config: unconfig + @$(MKCONFIG) -t $(@:_config=) sbc8548 ppc mpc85xx sbc8548
sbc8560_config \ sbc8560_33_config \ diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 4ef3028..cfb743f 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -1,5 +1,5 @@ /* - * Copyright 2007 Wind River Systems <www.windriver.com> + * Copyright 2007,2009 Wind River Systems <www.windriver.com> * Copyright 2007 Embedded Specialties, Inc. * Copyright 2004, 2007 Freescale Semiconductor. * @@ -24,23 +24,40 @@
/* * sbc8548 board configuration file - * - * Please refer to doc/README.sbc85xx for more info. - * + * Please refer to doc/README.sbc8548 for more info. */ #ifndef __CONFIG_H #define __CONFIG_H
-/* High Level Configuration Options */ +/* + * Top level Makefile configuration choices + */ +#ifdef CONFIG_MK_PCI +#define CONFIG_PCI +#define CONFIG_PCI1 +#endif + +#ifdef CONFIG_MK_66 +#define CONFIG_SYS_CLK_DIV 1 +#endif + +#ifdef CONFIG_MK_33 +#define CONFIG_SYS_CLK_DIV 2 +#endif + +#ifdef CONFIG_MK_PCIE +#define CONFIG_PCIE1 +#endif + +/* + * High Level Configuration Options + */ #define CONFIG_BOOKE 1 /* BOOKE */ #define CONFIG_E500 1 /* BOOKE e500 family */ #define CONFIG_MPC85xx 1 /* MPC8540/60/55/41/48 */ #define CONFIG_MPC8548 1 /* MPC8548 specific */ #define CONFIG_SBC8548 1 /* SBC8548 board specific */
-#undef CONFIG_PCI /* enable any pci type devices */ -#undef CONFIG_PCI1 /* PCI controller 1 */ -#undef CONFIG_PCIE1 /* PCIE controler 1 (slot 1) */ #undef CONFIG_RIO
#ifdef CONFIG_PCI @@ -58,7 +75,13 @@
#define CONFIG_FSL_LAW 1 /* Use common FSL init code */
-#define CONFIG_SYS_CLK_FREQ 66000000 /* SBC8548 default SYSCLK */ +/* + * Below assumes that CCB:SYSCLK remains unchanged at 6:1 via SW2:[1-4] + */ +#ifndef CONFIG_SYS_CLK_DIV +#define CONFIG_SYS_CLK_DIV 1 /* 2, if 33MHz PCI card installed */ +#endif +#define CONFIG_SYS_CLK_FREQ (66000000 / CONFIG_SYS_CLK_DIV)
/* * These can be toggled for performance analysis, otherwise use default. @@ -315,7 +338,7 @@ #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK 400000000 /* get_bus_freq(0) */ +#define CONFIG_SYS_NS16550_CLK (400000000 / CONFIG_SYS_CLK_DIV)
#define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200}
MAKEALL | 4 ++++ Makefile | 8 ++++++-- include/configs/sbc8548.h | 43 ++++++++++++++++++++++++++++++++ +---------- 3 files changed, 43 insertions(+), 12 deletions(-)
applied to 85xx.
- k
board/sbc8548/law.c | 12 ++++- board/sbc8548/sbc8548.c | 129 +++++++++++++ +------------------------------- board/sbc8548/tlb.c | 48 +++++++--------- include/configs/sbc8548.h | 45 ++++++++------- 4 files changed, 94 insertions(+), 140 deletions(-)
applied to 85xx.
- k
board/sbc8548/sbc8548.c | 8 +++++++- board/sbc8548/tlb.c | 22 +++++++++++++++------- include/configs/sbc8548.h | 42 ++++++++++++++++++++++++++++++++++++ ++---- 3 files changed, 60 insertions(+), 12 deletions(-)
applied to 85xx.
- k
Dear Paul Gortmaker,
In message 5ad17f25a126b25be24467d1712d30a775a5b494.1253492532.git.paul.gortmaker@windriver.com you wrote:
- SET_TLB_ENTRY(1, CONFIG_SYS_LBC_SDRAM_BASE + 0x4000000, CONFIG_SYS_LBC_SDRAM_BASE + 0x4000000,
Line too long.
On Mon, Sep 21, 2009 at 10:36 AM, Paul Gortmaker paul.gortmaker@windriver.com wrote:
Correct me if I'm wrong, but I thought the general rule was the other way (i.e. the way it alreay was). See for example:
http://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=commit;h=ed7a1b681de1e3...
This prevents, for example, accidentally writing words and longs to byte sized registers.
Regards,
G
Dear Graeme Russ,
In message d66caabb0909201837g28da0ed5k6069e96775cfb358@mail.gmail.com you wrote:
You are wrong. We must use I/O accessors.
Ouch. This patch is clearly bloken. Sorry it escaped my attention.
Using a C structure to describe the hardware is a good thing, but we still must use I/O accessors to access the registers.
This needs to be fixed in your code.
Right. The I/O accessors still allow for strict type checking.
On Mon, Sep 21, 2009 at 6:48 PM, Wolfgang Denk wd@denx.de wrote:
Dear Graeme Russ,
Thanks for the correction :)
Hence my incorrect assumption ;)
Will do
Right, which still makes my patch better than the completely unchecked previous version of the SC520 MMCR accessors
Regards,
G
board/sbc8548/sbc8548.c | 91 ++++++++++++++++++++++ +------------------------ 1 files changed, 45 insertions(+), 46 deletions(-)
applied to 85xx.
- k
applied to 85xx.
- k
applied to 85xx.
- k
Graeme Russ
Kumar Gala
Paul Gortmaker
