Re: [U-Boot] [PATCH 2/3] ARM: board: cm_fx6: fixup mtd partitions in the fdt
Hi Nikita,
On 07/07/2016 10:53 AM, Nikita Kiryanov wrote:
On Wed, Jun 22, 2016 at 07:17:53PM +0300, Igor Grinberg wrote:
On 06/19/2016 06:44 PM, Christopher Spinrath wrote:
The cm-fx6 module has an on-board st,m25p compatible spi flash chip used for u-boot (binary & environment). Overwrite the partitions in the device tree by the partition table provided in the mtdparts environment variable, if it is set.
This allows to specify a kernel independent partitioning in the environment and provides a convient way for the user to adapt the partition table.
Signed-off-by: Christopher Spinrath christopher.spinrath@rwth-aachen.de
board/compulab/cm_fx6/cm_fx6.c | 16 +++++++++++++++- 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/board/compulab/cm_fx6/cm_fx6.c b/board/compulab/cm_fx6/cm_fx6.c index 712057a..81a7ae2 100644 --- a/board/compulab/cm_fx6/cm_fx6.c +++ b/board/compulab/cm_fx6/cm_fx6.c
+#ifdef CONFIG_FDT_FIXUP_PARTITIONS +struct node_info nodes[] = {
- { "st,m25p", MTD_DEV_TYPE_NOR, },
Nikita, is this enough for all flashes we assemble on cm-fx6?
Yes, CM-FX6 is using M25PX16 and SST25VF016B, both of which are supported by the m25p80.c driver. However, on the mainline branch I don't see "m25p" in the list of device ids, and IIRC the request is to favor "jedec,spi-nor" as compatible string over device specific ones.
Linux is going to use "st,m25p", "jedec,spi-nor" as compatible list (currently queued for inclusion in v4.8: https://git.kernel.org/cgit/linux/kernel/git/arm/arm-soc.git/tree/arch/arm/b... ).
I have chosen "st,m25p" here to cover both the mainline and CompuLab's device trees (I have seen some where "jedec,spi-nor" is not in the list). However, if you prefer I will switch to "jedec,spi-nor" (excluding some device trees) in v2.
Thanks, Christopher
+}; +#endif
-- Regards, Igor.
Hi Christopher,
On Thu, Jul 07, 2016 at 03:30:25PM +0200, Christopher Spinrath wrote:
Hi Nikita,
Does it have to be an "or" situation? m25p is necessary to serve older CM-FX6 kernels, but it is not supported in the mainline kernel, so the correct course of actions seems to be to use both "st,m25p" and "jedec,spi-nor".
Nikita Kiryanov
