[U-Boot] [PATCH 2/2] armv8: ls2085a: Remove phy configuration from QDS and RDB
As phy_connect and phy_config are being called from DPAA2 driver. Remove calling of mentioned function from board file.
Signed-off-by: Pratiyush Mohan Srivastava pratiyush.srivastava@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- board/freescale/ls2080aqds/eth.c | 25 ------------------- board/freescale/ls2080ardb/eth_ls2080rdb.c | 39 ------------------------------ 2 files changed, 64 deletions(-)
diff --git a/board/freescale/ls2080aqds/eth.c b/board/freescale/ls2080aqds/eth.c index 0637ecf..5b9c2d1 100644 --- a/board/freescale/ls2080aqds/eth.c +++ b/board/freescale/ls2080aqds/eth.c @@ -548,12 +548,6 @@ void ls2080a_handle_phy_interface_sgmii(int dpmac_id) dpmac_info[dpmac_id].board_mux = EMI1_SLOT1; bus = mii_dev_for_muxval(EMI1_SLOT1); wriop_set_mdio(dpmac_id, bus); - dpmac_info[dpmac_id].phydev = phy_connect( - dpmac_info[dpmac_id].bus, - dpmac_info[dpmac_id].phy_addr, - NULL, - dpmac_info[dpmac_id].enet_if); - phy_config(dpmac_info[dpmac_id].phydev); break; case 2: /* Slot housing a SGMII riser card? */ @@ -562,12 +556,6 @@ void ls2080a_handle_phy_interface_sgmii(int dpmac_id) dpmac_info[dpmac_id].board_mux = EMI1_SLOT2; bus = mii_dev_for_muxval(EMI1_SLOT2); wriop_set_mdio(dpmac_id, bus); - dpmac_info[dpmac_id].phydev = phy_connect( - dpmac_info[dpmac_id].bus, - dpmac_info[dpmac_id].phy_addr, - NULL, - dpmac_info[dpmac_id].enet_if); - phy_config(dpmac_info[dpmac_id].phydev); break; case 3: break; @@ -606,12 +594,6 @@ serdes2: dpmac_info[dpmac_id].board_mux = EMI1_SLOT4; bus = mii_dev_for_muxval(EMI1_SLOT4); wriop_set_mdio(dpmac_id, bus); - dpmac_info[dpmac_id].phydev = phy_connect( - dpmac_info[dpmac_id].bus, - dpmac_info[dpmac_id].phy_addr, - NULL, - dpmac_info[dpmac_id].enet_if); - phy_config(dpmac_info[dpmac_id].phydev); break; case 5: break; @@ -679,13 +661,6 @@ void ls2080a_handle_phy_interface_qsgmii(int dpmac_id) dpmac_info[dpmac_id].board_mux = EMI1_SLOT1; bus = mii_dev_for_muxval(EMI1_SLOT1); wriop_set_mdio(dpmac_id, bus); - dpmac_info[dpmac_id].phydev = phy_connect( - dpmac_info[dpmac_id].bus, - dpmac_info[dpmac_id].phy_addr, - NULL, - dpmac_info[dpmac_id].enet_if); - - phy_config(dpmac_info[dpmac_id].phydev); break; case 3: break; diff --git a/board/freescale/ls2080ardb/eth_ls2080rdb.c b/board/freescale/ls2080ardb/eth_ls2080rdb.c index db50e4e..58ea746 100644 --- a/board/freescale/ls2080ardb/eth_ls2080rdb.c +++ b/board/freescale/ls2080ardb/eth_ls2080rdb.c @@ -20,42 +20,6 @@
DECLARE_GLOBAL_DATA_PTR;
-int load_firmware_cortina(struct phy_device *phy_dev) -{ - if (phy_dev->drv->config) - return phy_dev->drv->config(phy_dev); - - return 0; -} - -void load_phy_firmware(void) -{ - int i; - u8 phy_addr; - struct phy_device *phy_dev; - struct mii_dev *dev; - phy_interface_t interface; - - /*Initialize and upload firmware for all the PHYs*/ - for (i = WRIOP1_DPMAC1; i <= WRIOP1_DPMAC8; i++) { - interface = wriop_get_enet_if(i); - if (interface == PHY_INTERFACE_MODE_XGMII) { - dev = wriop_get_mdio(i); - phy_addr = wriop_get_phy_address(i); - phy_dev = phy_find_by_mask(dev, 1 << phy_addr, - interface); - if (!phy_dev) { - printf("No phydev for phyaddr %d\n", phy_addr); - continue; - } - - /*Flash firmware for All CS4340 PHYS */ - if (phy_dev->phy_id == PHY_UID_CS4340) - load_firmware_cortina(phy_dev); - } - } -} - int board_eth_init(bd_t *bis) { #if defined(CONFIG_FSL_MC_ENET) @@ -125,9 +89,6 @@ int board_eth_init(bd_t *bis) } }
- /* Load CORTINA CS4340 PHY firmware */ - load_phy_firmware(); - cpu_eth_init(bis); #endif /* CONFIG_FMAN_ENET */
Prabhakar Kushwaha
