[U-Boot] [PATCH v6 12/12] sf: Code cleanups
- comment typo's - func args have a proper names
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- drivers/mtd/spi/sf_internal.h | 6 +++--- drivers/mtd/spi/sf_ops.c | 4 ++-- drivers/mtd/spi/sf_probe.c | 4 ++-- 3 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index c77961f..da69549 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -60,10 +60,10 @@ #endif
/* Common status */ -#define STATUS_WIP 0x01 +#define STATUS_WIP (1 << 0) #define STATUS_QEB_WINSPAN (1 << 1) #define STATUS_QEB_MXIC (1 << 6) -#define STATUS_PEC 0x80 +#define STATUS_PEC (1 << 7)
/* Flash timeout values */ #define SPI_FLASH_PROG_TIMEOUT (2 * CONFIG_SYS_HZ) @@ -105,7 +105,7 @@ int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len); int spi_flash_cmd_read_status(struct spi_flash *flash, u8 *rs);
/* Program the status register */ -int spi_flash_cmd_write_status(struct spi_flash *flash, u8 sr); +int spi_flash_cmd_write_status(struct spi_flash *flash, u8 ws);
/* Read the config register */ int spi_flash_cmd_read_config(struct spi_flash *flash, u8 *rc); diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index 658294c..7a499d5 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -39,13 +39,13 @@ int spi_flash_cmd_read_status(struct spi_flash *flash, u8 *rs) return 0; }
-int spi_flash_cmd_write_status(struct spi_flash *flash, u8 sr) +int spi_flash_cmd_write_status(struct spi_flash *flash, u8 ws) { u8 cmd; int ret;
cmd = CMD_WRITE_STATUS; - ret = spi_flash_write_common(flash, &cmd, 1, &sr, 1); + ret = spi_flash_write_common(flash, &cmd, 1, &ws, 1); if (ret < 0) { debug("SF: fail to write status register\n"); return ret; diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 8715b7c..98fc271 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -167,7 +167,7 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, cmd = spi_read_cmds_array[cmd - 1]; flash->read_cmd = cmd; } else { - /* Go for for default supported read cmd */ + /* Go for default supported read cmd */ flash->read_cmd = CMD_READ_ARRAY_FAST; }
@@ -200,7 +200,7 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, flash->dummy_cycles = 1; }
- /* Poll cmd seclection */ + /* Poll cmd selection */ flash->poll_cmd = CMD_READ_STATUS; #ifdef CONFIG_SPI_FLASH_STMICRO if (params->flags & E_FSR)
