[U-Boot] DM, Kconfig and clang changes
Hey all,
So the release is out, and I want to make sure that some of these big changes get as much testing as we can.
Simon, can you please make up a pull request with what you think is ready to go now?
Masahiro and Jeroen, can you please make sure patchwork is up to date and perhaps setup a bundle with your changes that are ready (and for clang, not ARM centric, I want Albert to pick those up when he's ready, I'll review/comment tho).
Thanks!
Hi Tom,
On 14 July 2014 11:22, Tom Rini trini@ti.com wrote:
Hey all,
I was hoping to leave the latest base DM changes until later in the week, just so people have time to comment. About half of the patches are pretty new. But I'll take a look and see what is ready.
Thanks!
-- Tom
On Mon, Jul 14, 2014 at 11:26:08AM -0600, Simon Glass wrote:
Hi Tom,
Hey all,
Later in this week is OK, but I want to snap out -rc1 at the close of the merge window, and do that around when it's scheduled (probably Monday not Sunday morning). I don't want to rush things, but I want to make sure it's clear we're moving foward.
Dear Tom,
Please also keep Heiko's MTD/UBI/UBIFS update in mind!
On Mon, Jul 14, 2014 at 11:20:31PM +0200, Wolfgang Denk wrote:
Dear Tom,
Yes, that however is blocked on (a) fixing of some kernel issue he found with fastmap, iirc and (b) a follow-up patch doing another re-sync to show that in theory his approach is sound and with sufficient care can avoid the automerge problems Scott is (legitmately) worried about.
Hello Tom,
Am 15.07.2014 01:17, schrieb Tom Rini:
Dear Tom,
This fix is accepted from Artem, see:
http://git.infradead.org/ubifs-2.6.git/commit/e9110361a9a4e258b072b14bd44eb7...
This patch is only necessary in u-boot, if we update to linux v3.16 as there is the bug in v3.16.
I wasn;t aware of, that you block the mtd/ubi/ubifs patches until I did such a rebase to v3.15 ... so I try to do this ASAP.
bye, Heiko
Hi Tom,
On Mon, 14 Jul 2014 13:22:25 -0400 Tom Rini trini@ti.com wrote:
Hey all,
I am preparing v4 of Kconfig series.
Hopefully I will post it lator in this week or the beginning of next week.
Best Regards Masahiro Yamada
Hello Tom,
I made a bundle for most warnings assigned to you at [1]. I didn't include the removal of cmd_ide PIO and assigned the removal of lcd_puts_xy to Anatolij.
I will send an updated, non RFC patch soon for the actual clang support. I intend to drop the switch to gnu inline; clang will then only be able to build generic boards, but that will solve itself eventually. I intend to post the omap3/board changes as a seperate patch(set).
Regards, Jeroen
Hi Tom, (and Albert for [3])
Hey all,
This is just a reminder about the Kconfig series.
[1] Please apply some updates of boards.cfg
http://patchwork.ozlabs.org/patch/372347/ http://patchwork.ozlabs.org/patch/373391/
I need them to generate the initial version of board MAINTAINERS.
[2] Kconfig series also depends on the following series: http://patchwork.ozlabs.org/patch/372339/ http://patchwork.ozlabs.org/patch/372337/ http://patchwork.ozlabs.org/patch/372338/
[3] u-boot-arm is currently out of sync
(This item is rather addressed to Albert)
I notice some new boards (rmobile, sunxi) stacked on the u-boot-arm.
Because my Kconfig series is based on u-boot/master, those boards are not taken into account.
If Albert sends a pull request hopefully, I am pleased to update the Kconfig series.
Anyway it is OK if either of you is willing to fix the conflict lator. (defconfig, Kconfig, MAINTAINERS must be updated in that case.)
Hi Masahiro,
On Tue, 29 Jul 2014 20:10:23 +0900, Masahiro Yamada yamada.m@jp.panasonic.com wrote:
You mean a PR from u-boot-arm/master to u-boot/master, right? If so, one is coming up today.
Amicalement,
Hi Albert,
On Tue, 29 Jul 2014 14:03:50 +0200 Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Masahiro,
Yes. I confirmed u-boot-arm is in sync now. Thanks!
participants (7)
Albert ARIBAUD
Heiko Schocher
Jeroen Hofstee
Masahiro Yamada
