[U-Boot] [Patch V4 0/7] add LS1043AQDS platform support
Hi all,
Here are the main changes for V4 patchset. LS1043ARDB MAINTAINERS has already been updated in U-Boot. So remove that patch in V4 patchset.
- Update the code base. - Use #ifndef CONFIG_LS102XA instead of #ifdef CONFIG_FSL_LAYERSCAPE for PCIe patch. - Fix vid support for LS1043AQDS. - Remove RAW_TIMING definition for DDR3. - Remove LS1043AQDS_MDIO_10GC related code because LS1043AQDS board has no phy for it.
[Patch V4 1/7] pci/layerscape: add support for LS1043A PCIe LUT [Patch V4 2/7] armv8/fsl-layerscape: Remove reference to gdata [Patch V4 3/7] armv8/ls1043ardb: dts: add dtb support [Patch V4 4/7] armv8/ls1043aqds: add LS1043AQDS board support [Patch V4 5/7] armv8/ls1043aqds: dts: add dtb support [Patch V4 6/7] armv8/ls1043ardb: add DSPI support [Patch V4 7/7] armv8/ls1043ardb: add USB support
The endian and base address of PEX LUT register region is different between Chassis 2 and Chassis 3, so move the base address definition to chassis specific header file and add pex_lut_* functions to access LUT register.
Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V4: - Use #ifndef CONFIG_LS102XA instead of #ifdef CONFIG_FSL_LAYERSCAPE. V3: - No change. V2: - Fix compile errors for ls1021a.
arch/arm/include/asm/arch-fsl-layerscape/config.h | 2 ++ arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h | 4 ++++ arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h | 4 ++++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 8 ++++++++ drivers/pci/pcie_layerscape.c | 14 +++++++------- 5 files changed, 25 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 87bb937..fe361da 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -44,6 +44,7 @@ #define CONFIG_SYS_FSL_CCSR_SCFG_LE #define CONFIG_SYS_FSL_ESDHC_LE #define CONFIG_SYS_FSL_IFC_LE +#define CONFIG_SYS_FSL_PEX_LUT_LE
#define CONFIG_SYS_MEMAC_LITTLE_ENDIAN
@@ -113,6 +114,7 @@ #define CONFIG_SYS_FSL_WDOG_BE #define CONFIG_SYS_FSL_DSPI_BE #define CONFIG_SYS_FSL_QSPI_BE +#define CONFIG_SYS_FSL_PEX_LUT_BE
#define QE_MURAM_SIZE 0x6000UL #define MAX_QE_RISC 1 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index d941437..f52815d 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -60,6 +60,10 @@ #define CONFIG_SYS_PCIE1_PHYS_ADDR 0x4000000000ULL #define CONFIG_SYS_PCIE2_PHYS_ADDR 0x4800000000ULL #define CONFIG_SYS_PCIE3_PHYS_ADDR 0x5000000000ULL +/* LUT registers */ +#define PCIE_LUT_BASE 0x10000 +#define PCIE_LUT_LCTRL0 0x7F8 +#define PCIE_LUT_DBG 0x7FC
/* TZ Address Space Controller Definitions */ #define TZASC1_BASE 0x01100000 /* as per CCSR map. */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 6a70d44..e700af0 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -78,6 +78,10 @@ #define CONFIG_SYS_PCIE2_PHYS_ADDR 0x1200000000ULL #define CONFIG_SYS_PCIE3_PHYS_ADDR 0x1400000000ULL #define CONFIG_SYS_PCIE4_PHYS_ADDR 0x1600000000ULL +/* LUT registers */ +#define PCIE_LUT_BASE 0x80000 +#define PCIE_LUT_LCTRL0 0x7F8 +#define PCIE_LUT_DBG 0x7FC
/* Device Configuration */ #define DCFG_BASE 0x01e00000 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index 5ed456e..8691906 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -23,6 +23,14 @@ #define scfg_out32(a, v) out_be32(a, v) #endif
+#ifdef CONFIG_SYS_FSL_PEX_LUT_LE +#define pex_lut_in32(a) in_le32(a) +#define pex_lut_out32(a, v) out_le32(a, v) +#elif defined(CONFIG_SYS_FSL_PEX_LUT_BE) +#define pex_lut_in32(a) in_be32(a) +#define pex_lut_out32(a, v) out_be32(a, v) +#endif + struct cpu_type { char name[15]; u32 soc_ver; diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index 4cee038..43e3dc4 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -11,8 +11,9 @@ #include <asm/io.h> #include <errno.h> #include <malloc.h> -#ifdef CONFIG_FSL_LAYERSCAPE +#ifndef CONFIG_LS102XA #include <asm/arch/fdt.h> +#include <asm/arch/soc.h> #endif
#ifndef CONFIG_SYS_PCI_MEMORY_BUS @@ -57,11 +58,6 @@ #define PCIE_ATU_FUNC(x) (((x) & 0x7) << 16) #define PCIE_ATU_UPPER_TARGET 0x91C
-/* LUT registers */ -#define PCIE_LUT_BASE 0x80000 -#define PCIE_LUT_LCTRL0 0x7F8 -#define PCIE_LUT_DBG 0x7FC - #define PCIE_DBI_RO_WR_EN 0x8bc
#define PCIE_LINK_CAP 0x7c @@ -162,7 +158,7 @@ static int ls_pcie_link_state(struct ls_pcie *pcie) { u32 state;
- state = readl(pcie->dbi + PCIE_LUT_BASE + PCIE_LUT_DBG) & + state = pex_lut_in32(pcie->dbi + PCIE_LUT_BASE + PCIE_LUT_DBG) & LTSSM_STATE_MASK; if (state < LTSSM_PCIE_L0) { debug("....PCIe link error. LTSSM=0x%02x.\n", state); @@ -466,16 +462,20 @@ static void ls_pcie_setup_ep(struct ls_pcie *pcie, struct ls_pcie_info *info)
for (pf = 0; pf < PCIE_PF_NUM; pf++) { for (vf = 0; vf <= PCIE_VF_NUM; vf++) { +#ifndef CONFIG_LS102XA writel(PCIE_LCTRL0_VAL(pf, vf), pcie->dbi + PCIE_LUT_BASE + PCIE_LUT_LCTRL0); +#endif ls_pcie_ep_setup_bars(pcie->dbi); ls_pcie_ep_setup_atu(pcie, info); } }
/* Disable CFG2 */ +#ifndef CONFIG_LS102XA writel(0, pcie->dbi + PCIE_LUT_BASE + PCIE_LUT_LCTRL0); +#endif } else { ls_pcie_ep_setup_bars(pcie->dbi + PCIE_NO_SRIOV_BAR_BASE); ls_pcie_ep_setup_atu(pcie, info);
V4:
V3:
- No change.
V2:
Applied to fsl-qoriq master. Thanks.
York
The global_data pointer (gd) has been set earlier in crt0_64.S. So there's no need to assign it again. Remove gdata since it is going away in U-Boot.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V4: - No change. V3: - New Patch. - Fix dead code.
arch/arm/cpu/armv8/fsl-layerscape/spl.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/spl.c b/arch/arm/cpu/armv8/fsl-layerscape/spl.c index ba551aa..e53ed9a 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/spl.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/spl.c @@ -44,8 +44,6 @@ u32 spl_boot_mode(void) #ifdef CONFIG_SPL_BUILD void board_init_f(ulong dummy) { - /* Set global data pointer */ - gd = &gdata; /* Clear global data */ memset((void *)gd, 0, sizeof(gd_t)); #ifdef CONFIG_LS2085A
V4:
- No change.
V3:
- New Patch.
- Fix dead code.
York
Reuse dts files from ls1043a linux kernel. Some parts in dts files may not be needed by U-Boot.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V4: - No change. V3: - Modified the dts file according to ls1043a upstreaming linux kernel. V2: - New Patch.
arch/arm/dts/Makefile | 1 + arch/arm/dts/fsl-ls1043a-rdb.dts | 84 ++++++++++++++++++++ arch/arm/dts/fsl-ls1043a.dtsi | 160 +++++++++++++++++++++++++++++++++++++++ configs/ls1043ardb_defconfig | 2 + 4 files changed, 247 insertions(+)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9542fff..7e12f01 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -89,6 +89,7 @@ dtb-$(CONFIG_LS102XA) += ls1021a-qds.dtb \ ls1021a-twr.dtb dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2085a-qds.dtb \ fsl-ls2085a-rdb.dtb +dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-rdb.dtb
dtb-$(CONFIG_MACH_SUN4I) += \ sun4i-a10-a1000.dtb \ diff --git a/arch/arm/dts/fsl-ls1043a-rdb.dts b/arch/arm/dts/fsl-ls1043a-rdb.dts new file mode 100644 index 0000000..17a0681 --- /dev/null +++ b/arch/arm/dts/fsl-ls1043a-rdb.dts @@ -0,0 +1,84 @@ +/* + * Device Tree Include file for Freescale Layerscape-1043A family SoC. + * + * Copyright (C) 2015, Freescale Semiconductor + * + * Mingkai Hu Mingkai.hu@freescale.com + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +/dts-v1/; +/include/ "fsl-ls1043a.dtsi" + +/ { + model = "LS1043A RDB Board"; +}; + +&i2c0 { + status = "okay"; + ina220@40 { + compatible = "ti,ina220"; + reg = <0x40>; + shunt-resistor = <1000>; + }; + adt7461a@4c { + compatible = "adi,adt7461a"; + reg = <0x4c>; + }; + eeprom@56 { + compatible = "at24,24c512"; + reg = <0x52>; + }; + + eeprom@57 { + compatible = "at24,24c512"; + reg = <0x53>; + }; + + rtc@68 { + compatible = "pericom,pt7c4338"; + reg = <0x68>; + }; +}; + +&ifc { + status = "okay"; + #address-cells = <2>; + #size-cells = <1>; + /* NOR, NAND Flashes and FPGA on board */ + ranges = <0x0 0x0 0x0 0x60000000 0x08000000 + 0x2 0x0 0x0 0x7e800000 0x00010000 + 0x3 0x0 0x0 0x7fb00000 0x00000100>; + + nor@0,0 { + compatible = "cfi-flash"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x0 0x0 0x8000000>; + bank-width = <2>; + device-width = <1>; + }; + + nand@1,0 { + compatible = "fsl,ifc-nand"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x1 0x0 0x10000>; + }; + + cpld: board-control@2,0 { + compatible = "fsl,ls1043ardb-cpld"; + reg = <0x2 0x0 0x0000100>; + }; +}; + +&duart0 { + status = "okay"; +}; + +&duart1 { + status = "okay"; +}; diff --git a/arch/arm/dts/fsl-ls1043a.dtsi b/arch/arm/dts/fsl-ls1043a.dtsi new file mode 100644 index 0000000..280e959 --- /dev/null +++ b/arch/arm/dts/fsl-ls1043a.dtsi @@ -0,0 +1,160 @@ +/* + * Device Tree Include file for Freescale Layerscape-1043A family SoC. + * + * Copyright (C) 2014-2015, Freescale Semiconductor + * + * Mingkai Hu Mingkai.hu@freescale.com + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +/include/ "skeleton64.dtsi" + +/ { + compatible = "fsl,ls1043a"; + interrupt-parent = <&gic>; + cpus { + #address-cells = <2>; + #size-cells = <0>; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x0>; + clocks = <&clockgen 1 0>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x1>; + clocks = <&clockgen 1 0>; + }; + + cpu2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x2>; + clocks = <&clockgen 1 0>; + }; + + cpu3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x3>; + clocks = <&clockgen 1 0>; + }; + }; + + sysclk: sysclk { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <100000000>; + clock-output-names = "sysclk"; + }; + + gic: interrupt-controller@1400000 { + compatible = "arm,gic-400"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x0 0x1401000 0 0x1000>, /* GICD */ + <0x0 0x1402000 0 0x2000>, /* GICC */ + <0x0 0x1404000 0 0x2000>, /* GICH */ + <0x0 0x1406000 0 0x2000>; /* GICV */ + interrupts = <1 9 0xf08>; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + clockgen: clocking@1ee1000 { + compatible = "fsl,ls1043a-clockgen"; + reg = <0x0 0x1ee1000 0x0 0x1000>; + #clock-cells = <2>; + clocks = <&sysclk>; + }; + + ifc: ifc@1530000 { + compatible = "fsl,ifc", "simple-bus"; + reg = <0x0 0x1530000 0x0 0x10000>; + interrupts = <0 43 0x4>; + }; + + i2c0: i2c@2180000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2180000 0x0 0x10000>; + interrupts = <0 56 0x4>; + clock-names = "i2c"; + clocks = <&clockgen 4 0>; + status = "disabled"; + }; + + i2c1: i2c@2190000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2190000 0x0 0x10000>; + interrupts = <0 57 0x4>; + clock-names = "i2c"; + clocks = <&clockgen 4 0>; + status = "disabled"; + }; + + i2c2: i2c@21a0000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x21a0000 0x0 0x10000>; + interrupts = <0 58 0x4>; + clock-names = "i2c"; + clocks = <&clockgen 4 0>; + status = "disabled"; + }; + + i2c3: i2c@21b0000 { + compatible = "fsl,vf610-i2c"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x21b0000 0x0 0x10000>; + interrupts = <0 59 0x4>; + clock-names = "i2c"; + clocks = <&clockgen 4 0>; + status = "disabled"; + }; + + duart0: serial@21c0500 { + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x00 0x21c0500 0x0 0x100>; + interrupts = <0 54 0x4>; + clocks = <&clockgen 4 0>; + }; + + duart1: serial@21c0600 { + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x00 0x21c0600 0x0 0x100>; + interrupts = <0 54 0x4>; + clocks = <&clockgen 4 0>; + }; + + duart2: serial@21d0500 { + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x0 0x21d0500 0x0 0x100>; + interrupts = <0 55 0x4>; + clocks = <&clockgen 4 0>; + }; + + duart3: serial@21d0600 { + compatible = "fsl,ns16550", "ns16550a"; + reg = <0x0 0x21d0600 0x0 0x100>; + interrupts = <0 55 0x4>; + clocks = <&clockgen 4 0>; + }; + }; +}; diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index ae84d2e..f77fbbf 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -2,3 +2,5 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" CONFIG_ARM=y CONFIG_TARGET_LS1043ARDB=y CONFIG_FSL_LAYERSCAPE=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" +CONFIG_OF_CONTROL=y
V4:
- No change.
V3:
V2:
- New Patch.
York
LS1043AQDS Specification: ------------------------- Memory subsystem: * 2GByte DDR4 DIMM * 128 Mbyte NOR flash single-chip memory * 512 Mbyte NAND flash * 16 Mbyte high-speed SPI flash * SD connector to interface with the SD memory card
Ethernet: * Two RGMII ports * XFI 10G port * SGMII * QSGMII with 4x 1G ports
PCIe: supports Gen 1 and Gen 2
SATA 3.0: one SATA 3.0 port
USB 3.0: two micro AB connector and one type A connector
UART: supports two UARTs up to 115200 bps for console
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Signed-off-by: Mingkai Hu Mingkai.Hu@freescale.com Signed-off-by: Hou Zhiqiang B48286@freescale.com Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V4: - Fix vid macros in config file and add vid support. - Remove RAW_TIMING definition for DDR3. - Remove LS1043AQDS_MDIO_10GC related code because LS1043AQDS has no phy for it. V3: - Update the commit message. - Remove #ifdef in fdt.h. - Rename ls1043aqds_sdcard_defconfig to ls1043aqds_sdcard_ifc_defconfig. V2: - No change.
arch/arm/Kconfig | 9 + arch/arm/include/asm/arch-fsl-layerscape/fdt.h | 1 + board/freescale/common/vid.c | 22 + board/freescale/ls1043aqds/Kconfig | 15 + board/freescale/ls1043aqds/MAINTAINERS | 9 + board/freescale/ls1043aqds/Makefile | 9 + board/freescale/ls1043aqds/README | 96 ++++ board/freescale/ls1043aqds/ddr.c | 131 ++++++ board/freescale/ls1043aqds/ddr.h | 60 +++ board/freescale/ls1043aqds/eth.c | 492 +++++++++++++++++++++ board/freescale/ls1043aqds/ls1043aqds.c | 333 ++++++++++++++ board/freescale/ls1043aqds/ls1043aqds_pbi.cfg | 14 + board/freescale/ls1043aqds/ls1043aqds_qixis.h | 39 ++ board/freescale/ls1043aqds/ls1043aqds_rcw_nand.cfg | 7 + .../freescale/ls1043aqds/ls1043aqds_rcw_sd_ifc.cfg | 8 + configs/ls1043aqds_defconfig | 3 + configs/ls1043aqds_nand_defconfig | 4 + configs/ls1043aqds_nor_ddr3_defconfig | 2 + configs/ls1043aqds_sdcard_ifc_defconfig | 4 + include/configs/ls1043aqds.h | 387 ++++++++++++++++ 20 files changed, 1645 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 0d756cb..267dd2a 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -634,6 +634,14 @@ config TARGET_LS1021ATWR select CPU_V7 select SUPPORT_SPL
+config TARGET_LS1043AQDS + bool "Support ls1043aqds" + select ARM64 + select ARMV8_MULTIENTRY + select SUPPORT_SPL + help + Support for Freescale LS1043AQDS platform. + config TARGET_LS1043ARDB bool "Support ls1043ardb" select ARM64 @@ -758,6 +766,7 @@ source "board/freescale/ls2085aqds/Kconfig" source "board/freescale/ls2085ardb/Kconfig" source "board/freescale/ls1021aqds/Kconfig" source "board/freescale/ls1021atwr/Kconfig" +source "board/freescale/ls1043aqds/Kconfig" source "board/freescale/ls1043ardb/Kconfig" source "board/freescale/mx23evk/Kconfig" source "board/freescale/mx25pdk/Kconfig" diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fdt.h b/arch/arm/include/asm/arch-fsl-layerscape/fdt.h index 4da73ab..099563e 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fdt.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fdt.h @@ -11,4 +11,5 @@ void alloc_stream_ids(int start_id, int count, u32 *stream_ids, int max_cnt); void append_mmu_masters(void *blob, const char *smmu_path, const char *master_name, u32 *stream_ids, int count); void fdt_fixup_smmu_pcie(void *blob); +void fdt_fixup_board_enet(void *fdt); #endif /* _ASM_ARMV8_FSL_LAYERSCAPE_FDT_H_ */ diff --git a/board/freescale/common/vid.c b/board/freescale/common/vid.c index 6b8af14..f1bed51 100644 --- a/board/freescale/common/vid.c +++ b/board/freescale/common/vid.c @@ -7,7 +7,12 @@ #include <common.h> #include <command.h> #include <i2c.h> +#include <asm/io.h> +#ifdef CONFIG_LS1043A +#include <asm/arch/immap_lsch2.h> +#else #include <asm/immap_85xx.h> +#endif #include "vid.h"
DECLARE_GLOBAL_DATA_PTR; @@ -240,7 +245,11 @@ static int set_voltage_to_IR(int i2caddress, int vdd) * SoC before converting into an IR VID value */ vdd += board_vdd_drop_compensation(); +#ifdef CONFIG_LS1043A + vid = DIV_ROUND_UP(vdd - 265, 5); +#else vid = DIV_ROUND_UP(vdd - 245, 5); +#endif
ret = i2c_write(i2caddress, IR36021_LOOP1_MANUAL_ID_OFFSET, 1, (void *)&vid, sizeof(vid)); @@ -276,8 +285,12 @@ static int set_voltage(int i2caddress, int vdd) int adjust_vdd(ulong vdd_override) { int re_enable = disable_interrupts(); +#ifdef CONFIG_LS1043A + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); +#else ccsr_gur_t __iomem *gur = (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); +#endif u32 fusesr; u8 vid; int vdd_target, vdd_current, vdd_last; @@ -352,12 +365,21 @@ int adjust_vdd(ulong vdd_override) * | T | | | | | * ------------------------------------------------------ */ +#ifdef CONFIG_LS1043A + vid = (fusesr >> FSL_CHASSIS2_DCFG_FUSESR_ALTVID_SHIFT) & + FSL_CHASSIS2_DCFG_FUSESR_ALTVID_MASK; + if ((vid == 0) || (vid == FSL_CHASSIS2_DCFG_FUSESR_ALTVID_MASK)) { + vid = (fusesr >> FSL_CHASSIS2_DCFG_FUSESR_VID_SHIFT) & + FSL_CHASSIS2_DCFG_FUSESR_VID_MASK; + } +#else vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_ALTVID_SHIFT) & FSL_CORENET_DCFG_FUSESR_ALTVID_MASK; if ((vid == 0) || (vid == FSL_CORENET_DCFG_FUSESR_ALTVID_MASK)) { vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_VID_SHIFT) & FSL_CORENET_DCFG_FUSESR_VID_MASK; } +#endif vdd_target = vdd[vid];
/* check override variable for overriding VDD */ diff --git a/board/freescale/ls1043aqds/Kconfig b/board/freescale/ls1043aqds/Kconfig new file mode 100644 index 0000000..7e27f8f --- /dev/null +++ b/board/freescale/ls1043aqds/Kconfig @@ -0,0 +1,15 @@ +if TARGET_LS1043AQDS + +config SYS_BOARD + default "ls1043aqds" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "ls1043aqds" + +endif diff --git a/board/freescale/ls1043aqds/MAINTAINERS b/board/freescale/ls1043aqds/MAINTAINERS new file mode 100644 index 0000000..0c7f648 --- /dev/null +++ b/board/freescale/ls1043aqds/MAINTAINERS @@ -0,0 +1,9 @@ +LS1043AQDS BOARD +M: Mingkai Hu Mingkai.Hu@freescale.com +S: Maintained +F: board/freescale/ls1043aqds/ +F: include/configs/ls1043aqds.h +F: configs/ls1043aqds_defconfig +F: configs/ls1043aqds_nor_ddr3_defconfig +F: configs/ls1043aqds_nand_defconfig +F: configs/ls1043aqds_sdcard_ifc_defconfig diff --git a/board/freescale/ls1043aqds/Makefile b/board/freescale/ls1043aqds/Makefile new file mode 100644 index 0000000..f727bfd --- /dev/null +++ b/board/freescale/ls1043aqds/Makefile @@ -0,0 +1,9 @@ +# +# Copyright 2015 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += ddr.o +obj-y += eth.o +obj-y += ls1043aqds.o diff --git a/board/freescale/ls1043aqds/README b/board/freescale/ls1043aqds/README new file mode 100644 index 0000000..6261a77 --- /dev/null +++ b/board/freescale/ls1043aqds/README @@ -0,0 +1,96 @@ +Overview +-------- +The LS1043A Development System (QDS) is a high-performance computing, +evaluation, and development platform that supports the QorIQ LS1043A +LayerScape Architecture processor. The LS1043AQDS provides SW development +platform for the Freescale LS1043A processor series, with a complete +debugging environment. + +LS1043A SoC Overview +-------------------- +The LS1043A integrated multicore processor combines four ARM Cortex-A53 +processor cores with datapath acceleration optimized for L2/3 packet +processing, single pass security offload and robust traffic management +and quality of service. + +The LS1043A SoC includes the following function and features: + - Four 64-bit ARM Cortex-A53 CPUs + - 1 MB unified L2 Cache + - One 32-bit DDR3L/DDR4 SDRAM memory controllers with ECC and interleaving + support + - Data Path Acceleration Architecture (DPAA) incorporating acceleration the + the following functions: + - Packet parsing, classification, and distribution (FMan) + - Queue management for scheduling, packet sequencing, and congestion + management (QMan) + - Hardware buffer management for buffer allocation and de-allocation (BMan) + - Cryptography acceleration (SEC) + - Ethernet interfaces by FMan + - Up to 1 x XFI supporting 10G interface + - Up to 1 x QSGMII + - Up to 4 x SGMII supporting 1000Mbps + - Up to 2 x SGMII supporting 2500Mbps + - Up to 2 x RGMII supporting 1000Mbps + - High-speed peripheral interfaces + - Three PCIe 2.0 controllers, one supporting x4 operation + - One serial ATA (SATA 3.0) controllers + - Additional peripheral interfaces + - Three high-speed USB 3.0 controllers with integrated PHY + - Enhanced secure digital host controller (eSDXC/eMMC) + - Quad Serial Peripheral Interface (QSPI) Controller + - Serial peripheral interface (SPI) controller + - Four I2C controllers + - Two DUARTs + - Integrated flash controller supporting NAND and NOR flash + - QorIQ platform's trust architecture 2.1 + + LS1043AQDS board Overview + ----------------------- + - SERDES Connections, 4 lanes supporting: + - PCI Express - 3.0 + - SGMII, SGMII 2.5 + - QSGMII + - SATA 3.0 + - XFI + - DDR Controller + - 2GB 40bits (8-bits ECC) DDR4 SDRAM. Support rates of up to 1600MT/s + -IFC/Local Bus + - One in-socket 128 MB NOR flash 16-bit data bus + - One 512 MB NAND flash with ECC support + - PromJet Port + - FPGA connection + - USB 3.0 + - Three high speed USB 3.0 ports + - First USB 3.0 port configured as Host with Type-A connector + - The other two USB 3.0 ports configured as OTG with micro-AB connector + - SDHC port connects directly to an adapter card slot, featuring: + - Optional clock feedback paths, and optional high-speed voltage translation assistance + - SD slots for SD, SDHC (1x, 4x, 8x), and/or MMC + - eMMC memory devices + - DSPI: Onboard support for three SPI flash memory devices + - 4 I2C controllers + - One SATA onboard connectors + - UART + - Two 4-pin serial ports at up to 115.2 Kbit/s + - Two DB9 D-Type connectors supporting one Serial port each + - ARM JTAG support + +Memory map from core's view +---------------------------- +Start Address End Address Description Size +0x00_0000_0000 0x00_000F_FFFF Secure Boot ROM 1MB +0x00_0100_0000 0x00_0FFF_FFFF CCSRBAR 240MB +0x00_1000_0000 0x00_1000_FFFF OCRAM0 64KB +0x00_1001_0000 0x00_1001_FFFF OCRAM1 64KB +0x00_2000_0000 0x00_20FF_FFFF DCSR 16MB +0x00_6000_0000 0x00_67FF_FFFF IFC - NOR Flash 128MB +0x00_7E80_0000 0x00_7E80_FFFF IFC - NAND Flash 64KB +0x00_7FB0_0000 0x00_7FB0_0FFF IFC - FPGA 4KB +0x00_8000_0000 0x00_FFFF_FFFF DRAM1 2GB + +Booting Options +--------------- +a) Promjet Boot +b) NOR boot +c) NAND boot +d) SD boot diff --git a/board/freescale/ls1043aqds/ddr.c b/board/freescale/ls1043aqds/ddr.c new file mode 100644 index 0000000..705e384 --- /dev/null +++ b/board/freescale/ls1043aqds/ddr.c @@ -0,0 +1,131 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fsl_ddr_sdram.h> +#include <fsl_ddr_dimm_params.h> +#ifdef CONFIG_FSL_DEEP_SLEEP +#include <fsl_sleep.h> +#endif +#include "ddr.h" + +DECLARE_GLOBAL_DATA_PTR; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + const struct board_specific_parameters *pbsp, *pbsp_highest = NULL; + ulong ddr_freq; + + if (ctrl_num > 3) { + printf("Not supported controller number %d\n", ctrl_num); + return; + } + if (!pdimm->n_ranks) + return; + + pbsp = udimms[0]; + + /* Get clk_adjust, wrlvl_start, wrlvl_ctl, according to the board ddr + * freqency and n_banks specified in board_specific_parameters table. + */ + ddr_freq = get_ddr_freq(0) / 1000000; + while (pbsp->datarate_mhz_high) { + if (pbsp->n_ranks == pdimm->n_ranks) { + if (ddr_freq <= pbsp->datarate_mhz_high) { + popts->clk_adjust = pbsp->clk_adjust; + popts->wrlvl_start = pbsp->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + popts->cpo_override = pbsp->cpo_override; + popts->write_data_delay = + pbsp->write_data_delay; + goto found; + } + pbsp_highest = pbsp; + } + pbsp++; + } + + if (pbsp_highest) { + printf("Error: board specific timing not found for %lu MT/s\n", + ddr_freq); + printf("Trying to use the highest speed (%u) parameters\n", + pbsp_highest->datarate_mhz_high); + popts->clk_adjust = pbsp_highest->clk_adjust; + popts->wrlvl_start = pbsp_highest->wrlvl_start; + popts->wrlvl_ctl_2 = pbsp->wrlvl_ctl_2; + popts->wrlvl_ctl_3 = pbsp->wrlvl_ctl_3; + } else { + panic("DIMM is not supported by this board"); + } +found: + debug("Found timing match: n_ranks %d, data rate %d, rank_gb %d\n", + pbsp->n_ranks, pbsp->datarate_mhz_high, pbsp->rank_gb); + + /* force DDR bus width to 32 bits */ + popts->data_bus_width = 1; + popts->otf_burst_chop_en = 0; + popts->burst_length = DDR_BL8; + popts->bstopre = 0; /* enable auto precharge */ + + /* + * Factors to consider for half-strength driver enable: + * - number of DIMMs installed + */ + popts->half_strength_driver_enable = 1; + /* + * Write leveling override + */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + /* + * Rtt and Rtt_WR override + */ + popts->rtt_override = 0; + + /* Enable ZQ calibration */ + popts->zq_en = 1; + +#ifdef CONFIG_SYS_FSL_DDR4 + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_80ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_80ohm) | + DDR_CDR2_VREF_OVRD(70); /* Vref = 70% */ +#else + popts->cswl_override = DDR_CSWL_CS0; + + /* DHC_EN =1, ODT = 75 Ohm */ + popts->ddr_cdr1 = DDR_CDR1_DHC_EN | DDR_CDR1_ODT(DDR_CDR_ODT_75ohm); + popts->ddr_cdr2 = DDR_CDR2_ODT(DDR_CDR_ODT_75ohm); +#endif +} + +phys_size_t initdram(int board_type) +{ + phys_size_t dram_size; + +#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) + return fsl_ddr_sdram_size(); +#else + puts("Initializing DDR....using SPD\n"); + + dram_size = fsl_ddr_sdram(); +#endif + +#ifdef CONFIG_FSL_DEEP_SLEEP + fsl_dp_ddr_restore(); +#endif + + return dram_size; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = gd->ram_size; +} diff --git a/board/freescale/ls1043aqds/ddr.h b/board/freescale/ls1043aqds/ddr.h new file mode 100644 index 0000000..8adb660 --- /dev/null +++ b/board/freescale/ls1043aqds/ddr.h @@ -0,0 +1,60 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __DDR_H__ +#define __DDR_H__ + +struct board_specific_parameters { + u32 n_ranks; + u32 datarate_mhz_high; + u32 rank_gb; + u32 clk_adjust; + u32 wrlvl_start; + u32 wrlvl_ctl_2; + u32 wrlvl_ctl_3; + u32 cpo_override; + u32 write_data_delay; + u32 force_2t; +}; + +/* + * These tables contain all valid speeds we want to override with board + * specific parameters. datarate_mhz_high values need to be in ascending order + * for each n_ranks group. + */ +static const struct board_specific_parameters udimm0[] = { + /* + * memory controller 0 + * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T + * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | + */ +#ifdef CONFIG_SYS_FSL_DDR4 + {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, + {2, 1900, 0, 4, 6, 0x08080A0C, 0x0D0E0F0A,}, + {1, 1666, 0, 4, 6, 0x0708090B, 0x0C0D0E0A,}, + {1, 1900, 0, 4, 9, 0x0A0B0C0B, 0x0D0E0F0D,}, + {1, 2200, 0, 4, 10, 0x0B0C0D0C, 0x0E0F110E,}, +#elif defined(CONFIG_SYS_FSL_DDR3) + {1, 833, 1, 6, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, + {1, 1350, 1, 6, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, + {1, 833, 2, 6, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, + {1, 1350, 2, 6, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, + {2, 833, 4, 6, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, + {2, 1350, 4, 6, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, + {2, 1350, 0, 6, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, + {2, 1666, 4, 4, 0xa, 0x0B08090C, 0x0B0E0D0A, 0x1f, 2, 0}, + {2, 1666, 0, 4, 0xa, 0x0B08090C, 0x0B0E0D0A, 0x1f, 2, 0}, +#else +#error DDR type not defined +#endif + {} +}; + +static const struct board_specific_parameters *udimms[] = { + udimm0, +}; + +#endif diff --git a/board/freescale/ls1043aqds/eth.c b/board/freescale/ls1043aqds/eth.c new file mode 100644 index 0000000..b7fc360 --- /dev/null +++ b/board/freescale/ls1043aqds/eth.c @@ -0,0 +1,492 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <netdev.h> +#include <fm_eth.h> +#include <fsl_mdio.h> +#include <fsl_dtsec.h> +#include <malloc.h> +#include <asm/arch/fsl_serdes.h> + +#include "../common/qixis.h" +#include "../common/fman.h" +#include "ls1043aqds_qixis.h" + +#define EMI_NONE 0xFF +#define EMI1_RGMII1 0 +#define EMI1_RGMII2 1 +#define EMI1_SLOT1 2 +#define EMI1_SLOT2 3 +#define EMI1_SLOT3 4 +#define EMI1_SLOT4 5 +#define EMI2 6 + +static int mdio_mux[NUM_FM_PORTS]; + +static const char * const mdio_names[] = { + "LS1043AQDS_MDIO_RGMII1", + "LS1043AQDS_MDIO_RGMII2", + "LS1043AQDS_MDIO_SLOT1", + "LS1043AQDS_MDIO_SLOT2", + "LS1043AQDS_MDIO_SLOT3", + "LS1043AQDS_MDIO_SLOT4", + "NULL", +}; + +/* Map SerDes1 4 lanes to default slot, will be initialized dynamically */ +static u8 lane_to_slot[] = {1, 2, 3, 4}; + +static const char *ls1043aqds_mdio_name_for_muxval(u8 muxval) +{ + return mdio_names[muxval]; +} + +struct mii_dev *mii_dev_for_muxval(u8 muxval) +{ + struct mii_dev *bus; + const char *name; + + if (muxval > EMI2) + return NULL; + + name = ls1043aqds_mdio_name_for_muxval(muxval); + + if (!name) { + printf("No bus for muxval %x\n", muxval); + return NULL; + } + + bus = miiphy_get_dev_by_name(name); + + if (!bus) { + printf("No bus by name %s\n", name); + return NULL; + } + + return bus; +} + +struct ls1043aqds_mdio { + u8 muxval; + struct mii_dev *realbus; +}; + +static void ls1043aqds_mux_mdio(u8 muxval) +{ + u8 brdcfg4; + + if (muxval < 7) { + brdcfg4 = QIXIS_READ(brdcfg[4]); + brdcfg4 &= ~BRDCFG4_EMISEL_MASK; + brdcfg4 |= (muxval << BRDCFG4_EMISEL_SHIFT); + QIXIS_WRITE(brdcfg[4], brdcfg4); + } +} + +static int ls1043aqds_mdio_read(struct mii_dev *bus, int addr, int devad, + int regnum) +{ + struct ls1043aqds_mdio *priv = bus->priv; + + ls1043aqds_mux_mdio(priv->muxval); + + return priv->realbus->read(priv->realbus, addr, devad, regnum); +} + +static int ls1043aqds_mdio_write(struct mii_dev *bus, int addr, int devad, + int regnum, u16 value) +{ + struct ls1043aqds_mdio *priv = bus->priv; + + ls1043aqds_mux_mdio(priv->muxval); + + return priv->realbus->write(priv->realbus, addr, devad, + regnum, value); +} + +static int ls1043aqds_mdio_reset(struct mii_dev *bus) +{ + struct ls1043aqds_mdio *priv = bus->priv; + + return priv->realbus->reset(priv->realbus); +} + +static int ls1043aqds_mdio_init(char *realbusname, u8 muxval) +{ + struct ls1043aqds_mdio *pmdio; + struct mii_dev *bus = mdio_alloc(); + + if (!bus) { + printf("Failed to allocate ls1043aqds MDIO bus\n"); + return -1; + } + + pmdio = malloc(sizeof(*pmdio)); + if (!pmdio) { + printf("Failed to allocate ls1043aqds private data\n"); + free(bus); + return -1; + } + + bus->read = ls1043aqds_mdio_read; + bus->write = ls1043aqds_mdio_write; + bus->reset = ls1043aqds_mdio_reset; + sprintf(bus->name, ls1043aqds_mdio_name_for_muxval(muxval)); + + pmdio->realbus = miiphy_get_dev_by_name(realbusname); + + if (!pmdio->realbus) { + printf("No bus with name %s\n", realbusname); + free(bus); + free(pmdio); + return -1; + } + + pmdio->muxval = muxval; + bus->priv = pmdio; + return mdio_register(bus); +} + +void board_ft_fman_fixup_port(void *fdt, char *compat, phys_addr_t addr, + enum fm_port port, int offset) +{ + struct fixed_link f_link; + + if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_SGMII) { + if (port == FM1_DTSEC9) { + fdt_set_phy_handle(fdt, compat, addr, + "sgmii_riser_s1_p1"); + } else if (port == FM1_DTSEC2) { + fdt_set_phy_handle(fdt, compat, addr, + "sgmii_riser_s2_p1"); + } else if (port == FM1_DTSEC5) { + fdt_set_phy_handle(fdt, compat, addr, + "sgmii_riser_s3_p1"); + } else if (port == FM1_DTSEC6) { + fdt_set_phy_handle(fdt, compat, addr, + "sgmii_riser_s4_p1"); + } + } else if (fm_info_get_enet_if(port) == + PHY_INTERFACE_MODE_SGMII_2500) { + /* 2.5G SGMII interface */ + f_link.phy_id = port; + f_link.duplex = 1; + f_link.link_speed = 1000; + f_link.pause = 0; + f_link.asym_pause = 0; + /* no PHY for 2.5G SGMII */ + fdt_delprop(fdt, offset, "phy-handle"); + fdt_setprop(fdt, offset, "fixed-link", &f_link, sizeof(f_link)); + fdt_setprop_string(fdt, offset, "phy-connection-type", + "sgmii-2500"); + } else if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_QSGMII) { + switch (mdio_mux[port]) { + case EMI1_SLOT1: + switch (port) { + case FM1_DTSEC1: + fdt_set_phy_handle(fdt, compat, addr, + "qsgmii_s1_p1"); + break; + case FM1_DTSEC2: + fdt_set_phy_handle(fdt, compat, addr, + "qsgmii_s1_p2"); + break; + case FM1_DTSEC5: + fdt_set_phy_handle(fdt, compat, addr, + "qsgmii_s1_p3"); + break; + case FM1_DTSEC6: + fdt_set_phy_handle(fdt, compat, addr, + "qsgmii_s1_p4"); + break; + default: + break; + } + break; + case EMI1_SLOT2: + switch (port) { + case FM1_DTSEC1: + fdt_set_phy_handle(fdt, compat, addr, + "qsgmii_s2_p1"); + break; + case FM1_DTSEC2: + fdt_set_phy_handle(fdt, compat, addr, + "qsgmii_s2_p2"); + break; + case FM1_DTSEC5: + fdt_set_phy_handle(fdt, compat, addr, + "qsgmii_s2_p3"); + break; + case FM1_DTSEC6: + fdt_set_phy_handle(fdt, compat, addr, + "qsgmii_s2_p4"); + break; + default: + break; + } + break; + default: + break; + } + fdt_delprop(fdt, offset, "phy-connection-type"); + fdt_setprop_string(fdt, offset, "phy-connection-type", + "qsgmii"); + } else if (fm_info_get_enet_if(port) == PHY_INTERFACE_MODE_XGMII && + port == FM1_10GEC1) { + /* XFI interface */ + f_link.phy_id = port; + f_link.duplex = 1; + f_link.link_speed = 10000; + f_link.pause = 0; + f_link.asym_pause = 0; + /* no PHY for XFI */ + fdt_delprop(fdt, offset, "phy-handle"); + fdt_setprop(fdt, offset, "fixed-link", &f_link, sizeof(f_link)); + fdt_setprop_string(fdt, offset, "phy-connection-type", "xgmii"); + } +} + +void fdt_fixup_board_enet(void *fdt) +{ + int i; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 srds_s1; + + srds_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT; + + for (i = FM1_DTSEC1; i < NUM_FM_PORTS; i++) { + switch (fm_info_get_enet_if(i)) { + case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_QSGMII: + switch (mdio_mux[i]) { + case EMI1_SLOT1: + fdt_status_okay_by_alias(fdt, "emi1_slot1"); + break; + case EMI1_SLOT2: + fdt_status_okay_by_alias(fdt, "emi1_slot2"); + break; + case EMI1_SLOT3: + fdt_status_okay_by_alias(fdt, "emi1_slot3"); + break; + case EMI1_SLOT4: + fdt_status_okay_by_alias(fdt, "emi1_slot4"); + break; + default: + break; + } + break; + case PHY_INTERFACE_MODE_XGMII: + break; + default: + break; + } + } +} + +int board_eth_init(bd_t *bis) +{ +#ifdef CONFIG_FMAN_ENET + int i, idx, lane, slot, interface; + struct memac_mdio_info dtsec_mdio_info; + struct memac_mdio_info tgec_mdio_info; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 srds_s1; + + srds_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT; + + /* Initialize the mdio_mux array so we can recognize empty elements */ + for (i = 0; i < NUM_FM_PORTS; i++) + mdio_mux[i] = EMI_NONE; + + dtsec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_DTSEC_MDIO_ADDR; + + dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the 1G MDIO bus */ + fm_memac_mdio_init(bis, &dtsec_mdio_info); + + tgec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_TGEC_MDIO_ADDR; + tgec_mdio_info.name = DEFAULT_FM_TGEC_MDIO_NAME; + + /* Register the 10G MDIO bus */ + fm_memac_mdio_init(bis, &tgec_mdio_info); + + /* Register the muxing front-ends to the MDIO buses */ + ls1043aqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII1); + ls1043aqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII2); + ls1043aqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT1); + ls1043aqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT2); + ls1043aqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT3); + ls1043aqds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT4); + ls1043aqds_mdio_init(DEFAULT_FM_TGEC_MDIO_NAME, EMI2); + + /* Set the two on-board RGMII PHY address */ + fm_info_set_phy_address(FM1_DTSEC3, RGMII_PHY1_ADDR); + fm_info_set_phy_address(FM1_DTSEC4, RGMII_PHY2_ADDR); + + switch (srds_s1) { + case 0x2555: + /* 2.5G SGMII on lane A, MAC 9 */ + fm_info_set_phy_address(FM1_DTSEC9, 9); + break; + case 0x4555: + case 0x4558: + /* QSGMII on lane A, MAC 1/2/5/6 */ + fm_info_set_phy_address(FM1_DTSEC1, + QSGMII_CARD_PORT1_PHY_ADDR_S1); + fm_info_set_phy_address(FM1_DTSEC2, + QSGMII_CARD_PORT2_PHY_ADDR_S1); + fm_info_set_phy_address(FM1_DTSEC5, + QSGMII_CARD_PORT3_PHY_ADDR_S1); + fm_info_set_phy_address(FM1_DTSEC6, + QSGMII_CARD_PORT4_PHY_ADDR_S1); + break; + case 0x1355: + /* SGMII on lane B, MAC 2*/ + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT1_PHY_ADDR); + break; + case 0x2355: + /* 2.5G SGMII on lane A, MAC 9 */ + fm_info_set_phy_address(FM1_DTSEC9, 9); + /* SGMII on lane B, MAC 2*/ + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT1_PHY_ADDR); + break; + case 0x3335: + /* SGMII on lane C, MAC 5 */ + fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT1_PHY_ADDR); + case 0x3355: + case 0x3358: + /* SGMII on lane B, MAC 2 */ + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT1_PHY_ADDR); + case 0x3555: + case 0x3558: + /* SGMII on lane A, MAC 9 */ + fm_info_set_phy_address(FM1_DTSEC9, SGMII_CARD_PORT1_PHY_ADDR); + break; + case 0x1455: + /* QSGMII on lane B, MAC 1/2/5/6 */ + fm_info_set_phy_address(FM1_DTSEC1, + QSGMII_CARD_PORT1_PHY_ADDR_S2); + fm_info_set_phy_address(FM1_DTSEC2, + QSGMII_CARD_PORT2_PHY_ADDR_S2); + fm_info_set_phy_address(FM1_DTSEC5, + QSGMII_CARD_PORT3_PHY_ADDR_S2); + fm_info_set_phy_address(FM1_DTSEC6, + QSGMII_CARD_PORT4_PHY_ADDR_S2); + break; + case 0x2455: + /* 2.5G SGMII on lane A, MAC 9 */ + fm_info_set_phy_address(FM1_DTSEC9, 9); + /* QSGMII on lane B, MAC 1/2/5/6 */ + fm_info_set_phy_address(FM1_DTSEC1, + QSGMII_CARD_PORT1_PHY_ADDR_S2); + fm_info_set_phy_address(FM1_DTSEC2, + QSGMII_CARD_PORT2_PHY_ADDR_S2); + fm_info_set_phy_address(FM1_DTSEC5, + QSGMII_CARD_PORT3_PHY_ADDR_S2); + fm_info_set_phy_address(FM1_DTSEC6, + QSGMII_CARD_PORT4_PHY_ADDR_S2); + break; + case 0x2255: + /* 2.5G SGMII on lane A, MAC 9 */ + fm_info_set_phy_address(FM1_DTSEC9, 9); + /* 2.5G SGMII on lane B, MAC 2 */ + fm_info_set_phy_address(FM1_DTSEC2, 2); + break; + case 0x3333: + /* SGMII on lane A/B/C/D, MAC 9/2/5/6 */ + fm_info_set_phy_address(FM1_DTSEC9, + SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, + SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC5, + SGMII_CARD_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC6, + SGMII_CARD_PORT1_PHY_ADDR); + break; + default: + printf("Invalid SerDes protocol 0x%x for LS1043AQDS\n", + srds_s1); + break; + } + + for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { + idx = i - FM1_DTSEC1; + interface = fm_info_get_enet_if(i); + switch (interface) { + case PHY_INTERFACE_MODE_SGMII: + case PHY_INTERFACE_MODE_SGMII_2500: + case PHY_INTERFACE_MODE_QSGMII: + if (interface == PHY_INTERFACE_MODE_SGMII) { + lane = serdes_get_first_lane(FSL_SRDS_1, + SGMII_FM1_DTSEC1 + idx); + } else if (interface == PHY_INTERFACE_MODE_SGMII_2500) { + lane = serdes_get_first_lane(FSL_SRDS_1, + SGMII_2500_FM1_DTSEC1 + idx); + } else { + lane = serdes_get_first_lane(FSL_SRDS_1, + QSGMII_FM1_A); + } + + if (lane < 0) + break; + + slot = lane_to_slot[lane]; + debug("FM1@DTSEC%u expects SGMII in slot %u\n", + idx + 1, slot); + if (QIXIS_READ(present2) & (1 << (slot - 1))) + fm_disable_port(i); + + switch (slot) { + case 1: + mdio_mux[i] = EMI1_SLOT1; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; + case 2: + mdio_mux[i] = EMI1_SLOT2; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; + case 3: + mdio_mux[i] = EMI1_SLOT3; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; + case 4: + mdio_mux[i] = EMI1_SLOT4; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; + default: + break; + } + break; + case PHY_INTERFACE_MODE_RGMII: + if (i == FM1_DTSEC3) + mdio_mux[i] = EMI1_RGMII1; + else if (i == FM1_DTSEC4) + mdio_mux[i] = EMI1_RGMII2; + fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i])); + break; + default: + break; + } + } + + cpu_eth_init(bis); +#endif /* CONFIG_FMAN_ENET */ + + return pci_eth_init(bis); +} diff --git a/board/freescale/ls1043aqds/ls1043aqds.c b/board/freescale/ls1043aqds/ls1043aqds.c new file mode 100644 index 0000000..d6696ca --- /dev/null +++ b/board/freescale/ls1043aqds/ls1043aqds.c @@ -0,0 +1,333 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <i2c.h> +#include <fdt_support.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch/fdt.h> +#include <asm/arch/soc.h> +#include <ahci.h> +#include <hwconfig.h> +#include <mmc.h> +#include <scsi.h> +#include <fm_eth.h> +#include <fsl_csu.h> +#include <fsl_esdhc.h> +#include <fsl_ifc.h> +#include <spl.h> + +#include "../common/qixis.h" +#include "ls1043aqds_qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +enum { + MUX_TYPE_GPIO, +}; + +/* LS1043AQDS serdes mux */ +#define CFG_SD_MUX1_SLOT2 0x0 /* SLOT2 TX/RX0 */ +#define CFG_SD_MUX1_SLOT1 0x1 /* SLOT1 TX/RX1 */ +#define CFG_SD_MUX2_SLOT3 0x0 /* SLOT3 TX/RX0 */ +#define CFG_SD_MUX2_SLOT1 0x1 /* SLOT1 TX/RX2 */ +#define CFG_SD_MUX3_SLOT4 0x0 /* SLOT4 TX/RX0 */ +#define CFG_SD_MUX3_MUX4 0x1 /* MUX4 */ +#define CFG_SD_MUX4_SLOT3 0x0 /* SLOT3 TX/RX1 */ +#define CFG_SD_MUX4_SLOT1 0x1 /* SLOT1 TX/RX3 */ + +int checkboard(void) +{ + char buf[64]; +#ifndef CONFIG_SD_BOOT + u8 sw; +#endif + + puts("Board: LS1043AQDS, boot from "); + +#ifdef CONFIG_SD_BOOT + puts("SD\n"); +#else + sw = QIXIS_READ(brdcfg[0]); + sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; + + if (sw < 0x8) + printf("vBank: %d\n", sw); + else if (sw == 0x8) + puts("PromJet\n"); + else if (sw == 0x9) + puts("NAND\n"); + else if (sw == 0x15) + printf("IFCCard\n"); + else + printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); +#endif + + printf("Sys ID: 0x%02x, Sys Ver: 0x%02x\n", + QIXIS_READ(id), QIXIS_READ(arch)); + + printf("FPGA: v%d (%s), build %d\n", + (int)QIXIS_READ(scver), qixis_read_tag(buf), + (int)qixis_read_minor()); + + return 0; +} + +bool if_board_diff_clk(void) +{ + u8 diff_conf = QIXIS_READ(brdcfg[11]); + + return diff_conf & 0x40; +} + +unsigned long get_board_sys_clk(void) +{ + u8 sysclk_conf = QIXIS_READ(brdcfg[1]); + + switch (sysclk_conf & 0x0f) { + case QIXIS_SYSCLK_64: + return 64000000; + case QIXIS_SYSCLK_83: + return 83333333; + case QIXIS_SYSCLK_100: + return 100000000; + case QIXIS_SYSCLK_125: + return 125000000; + case QIXIS_SYSCLK_133: + return 133333333; + case QIXIS_SYSCLK_150: + return 150000000; + case QIXIS_SYSCLK_160: + return 160000000; + case QIXIS_SYSCLK_166: + return 166666666; + } + + return 66666666; +} + +unsigned long get_board_ddr_clk(void) +{ + u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); + + if (if_board_diff_clk()) + return get_board_sys_clk(); + switch ((ddrclk_conf & 0x30) >> 4) { + case QIXIS_DDRCLK_100: + return 100000000; + case QIXIS_DDRCLK_125: + return 125000000; + case QIXIS_DDRCLK_133: + return 133333333; + } + + return 66666666; +} + +int select_i2c_ch_pca9547(u8 ch) +{ + int ret; + + ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); + if (ret) { + puts("PCA: failed to select proper channel\n"); + return ret; + } + + return 0; +} + +int dram_init(void) +{ + /* + * When resuming from deep sleep, the I2C channel may not be + * in the default channel. So, switch to the default channel + * before accessing DDR SPD. + */ + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + gd->ram_size = initdram(0); + + return 0; +} + +int i2c_multiplexer_select_vid_channel(u8 channel) +{ + return select_i2c_ch_pca9547(channel); +} + +void board_retimer_init(void) +{ + u8 reg; + + /* Retimer is connected to I2C1_CH7_CH5 */ + reg = I2C_MUX_CH7; + i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, ®, 1); + reg = I2C_MUX_CH5; + i2c_write(I2C_MUX_PCA_ADDR_SEC, 0, 1, ®, 1); + + /* Access to Control/Shared register */ + reg = 0x0; + i2c_write(I2C_RETIMER_ADDR, 0xff, 1, ®, 1); + + /* Read device revision and ID */ + i2c_read(I2C_RETIMER_ADDR, 1, 1, ®, 1); + debug("Retimer version id = 0x%x\n", reg); + + /* Enable Broadcast. All writes target all channel register sets */ + reg = 0x0c; + i2c_write(I2C_RETIMER_ADDR, 0xff, 1, ®, 1); + + /* Reset Channel Registers */ + i2c_read(I2C_RETIMER_ADDR, 0, 1, ®, 1); + reg |= 0x4; + i2c_write(I2C_RETIMER_ADDR, 0, 1, ®, 1); + + /* Enable override divider select and Enable Override Output Mux */ + i2c_read(I2C_RETIMER_ADDR, 9, 1, ®, 1); + reg |= 0x24; + i2c_write(I2C_RETIMER_ADDR, 9, 1, ®, 1); + + /* Select VCO Divider to full rate (000) */ + i2c_read(I2C_RETIMER_ADDR, 0x18, 1, ®, 1); + reg &= 0x8f; + i2c_write(I2C_RETIMER_ADDR, 0x18, 1, ®, 1); + + /* Selects active PFD MUX Input as Re-timed Data (001) */ + i2c_read(I2C_RETIMER_ADDR, 0x1e, 1, ®, 1); + reg &= 0x3f; + reg |= 0x20; + i2c_write(I2C_RETIMER_ADDR, 0x1e, 1, ®, 1); + + /* Set data rate as 10.3125 Gbps */ + reg = 0x0; + i2c_write(I2C_RETIMER_ADDR, 0x60, 1, ®, 1); + reg = 0xb2; + i2c_write(I2C_RETIMER_ADDR, 0x61, 1, ®, 1); + reg = 0x90; + i2c_write(I2C_RETIMER_ADDR, 0x62, 1, ®, 1); + reg = 0xb3; + i2c_write(I2C_RETIMER_ADDR, 0x63, 1, ®, 1); + reg = 0xcd; + i2c_write(I2C_RETIMER_ADDR, 0x64, 1, ®, 1); +} + +int board_early_init_f(void) +{ + fsl_lsch2_early_init_f(); + + return 0; +} + +#ifdef CONFIG_FSL_DEEP_SLEEP +/* determine if it is a warm boot */ +bool is_warm_boot(void) +{ +#define DCFG_CCSR_CRSTSR_WDRFR (1 << 3) + struct ccsr_gur __iomem *gur = (void *)CONFIG_SYS_FSL_GUTS_ADDR; + + if (in_be32(&gur->crstsr) & DCFG_CCSR_CRSTSR_WDRFR) + return 1; + + return 0; +} +#endif + +int config_board_mux(int ctrl_type) +{ + u8 reg14; + + reg14 = QIXIS_READ(brdcfg[14]); + + switch (ctrl_type) { + case MUX_TYPE_GPIO: + reg14 = (reg14 & (~0x30)) | 0x20; + break; + default: + puts("Unsupported mux interface type\n"); + return -1; + } + + QIXIS_WRITE(brdcfg[14], reg14); + + return 0; +} + +int config_serdes_mux(void) +{ + return 0; +} + + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ + if (hwconfig("gpio")) + config_board_mux(MUX_TYPE_GPIO); + + return 0; +} +#endif + +int board_init(void) +{ + struct ccsr_cci400 *cci = (struct ccsr_cci400 *) + CONFIG_SYS_CCI400_ADDR; + + /* Set CCI-400 control override register to enable barrier + * transaction */ + out_le32(&cci->ctrl_ord, + CCI400_CTRLORD_EN_BARRIER); + + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + board_retimer_init(); + +#ifdef CONFIG_SYS_FSL_SERDES + config_serdes_mux(); +#endif + +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); +#endif + +#ifdef CONFIG_ENV_IS_NOWHERE + gd->env_addr = (ulong)&default_environment[0]; +#endif + return 0; +} + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + +#ifdef CONFIG_SYS_DPAA_FMAN + fdt_fixup_fman_ethernet(blob); + fdt_fixup_board_enet(blob); +#endif + return 0; +} +#endif + +u8 flash_read8(void *addr) +{ + return __raw_readb(addr + 1); +} + +void flash_write16(u16 val, void *addr) +{ + u16 shftval = (((val >> 8) & 0xff) | ((val << 8) & 0xff00)); + + __raw_writew(shftval, addr); +} + +u16 flash_read16(void *addr) +{ + u16 val = __raw_readw(addr); + + return (((val) >> 8) & 0x00ff) | (((val) << 8) & 0xff00); +} diff --git a/board/freescale/ls1043aqds/ls1043aqds_pbi.cfg b/board/freescale/ls1043aqds/ls1043aqds_pbi.cfg new file mode 100644 index 0000000..f072274 --- /dev/null +++ b/board/freescale/ls1043aqds/ls1043aqds_pbi.cfg @@ -0,0 +1,14 @@ +#Configure Scratch register +09570600 00000000 +09570604 10000000 +#Alt base register +09570158 00001000 +#Disable CCI barrier tranaction +09570178 0000e010 +09180000 00000008 +#USB PHY frequency sel +09570418 0000009e +0957041c 0000009e +09570420 0000009e +#flush PBI data +096100c0 000fffff diff --git a/board/freescale/ls1043aqds/ls1043aqds_qixis.h b/board/freescale/ls1043aqds/ls1043aqds_qixis.h new file mode 100644 index 0000000..8783be8 --- /dev/null +++ b/board/freescale/ls1043aqds/ls1043aqds_qixis.h @@ -0,0 +1,39 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1043AQDS_QIXIS_H__ +#define __LS1043AQDS_QIXIS_H__ + +/* Definitions of QIXIS Registers for LS1043AQDS */ + +/* BRDCFG4[4:7] select EC1 and EC2 as a pair */ +#define BRDCFG4_EMISEL_MASK 0xe0 +#define BRDCFG4_EMISEL_SHIFT 5 + +/* SYSCLK */ +#define QIXIS_SYSCLK_66 0x0 +#define QIXIS_SYSCLK_83 0x1 +#define QIXIS_SYSCLK_100 0x2 +#define QIXIS_SYSCLK_125 0x3 +#define QIXIS_SYSCLK_133 0x4 +#define QIXIS_SYSCLK_150 0x5 +#define QIXIS_SYSCLK_160 0x6 +#define QIXIS_SYSCLK_166 0x7 +#define QIXIS_SYSCLK_64 0x8 + +/* DDRCLK */ +#define QIXIS_DDRCLK_66 0x0 +#define QIXIS_DDRCLK_100 0x1 +#define QIXIS_DDRCLK_125 0x2 +#define QIXIS_DDRCLK_133 0x3 + +/* BRDCFG2 - SD clock*/ +#define QIXIS_SDCLK1_100 0x0 +#define QIXIS_SDCLK1_125 0x1 +#define QIXIS_SDCLK1_165 0x2 +#define QIXIS_SDCLK1_100_SP 0x3 + +#endif diff --git a/board/freescale/ls1043aqds/ls1043aqds_rcw_nand.cfg b/board/freescale/ls1043aqds/ls1043aqds_rcw_nand.cfg new file mode 100644 index 0000000..935ffc0 --- /dev/null +++ b/board/freescale/ls1043aqds/ls1043aqds_rcw_nand.cfg @@ -0,0 +1,7 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# serdes protocol +0810000f 0c000000 00000000 00000000 +14550002 80004012 e0106000 61002000 +00000000 00000000 00000000 00038800 +00000000 00001100 00000096 00000001 diff --git a/board/freescale/ls1043aqds/ls1043aqds_rcw_sd_ifc.cfg b/board/freescale/ls1043aqds/ls1043aqds_rcw_sd_ifc.cfg new file mode 100644 index 0000000..17a5dd0 --- /dev/null +++ b/board/freescale/ls1043aqds/ls1043aqds_rcw_sd_ifc.cfg @@ -0,0 +1,8 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# RCW +# Enable IFC; disable QSPI +0810000f 0c000000 00000000 00000000 +14550002 80004012 60040000 61002000 +00000000 00000000 00000000 00038800 +00000000 00001100 00000096 00000001 diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig new file mode 100644 index 0000000..ee5bea2 --- /dev/null +++ b/configs/ls1043aqds_defconfig @@ -0,0 +1,3 @@ +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_ARM=y +CONFIG_TARGET_LS1043AQDS=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig new file mode 100644 index 0000000..377ca74 --- /dev/null +++ b/configs/ls1043aqds_nand_defconfig @@ -0,0 +1,4 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" +CONFIG_ARM=y +CONFIG_TARGET_LS1043AQDS=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig new file mode 100644 index 0000000..7b1951f --- /dev/null +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -0,0 +1,2 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1043AQDS=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig new file mode 100644 index 0000000..0fdb959 --- /dev/null +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -0,0 +1,4 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" +CONFIG_ARM=y +CONFIG_TARGET_LS1043AQDS=y diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h new file mode 100644 index 0000000..4aeb238 --- /dev/null +++ b/include/configs/ls1043aqds.h @@ -0,0 +1,387 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1043AQDS_H__ +#define __LS1043AQDS_H__ + +#include "ls1043a_common.h" + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#if defined(CONFIG_NAND_BOOT) || defined(CONFIG_SD_BOOT) +#define CONFIG_SYS_TEXT_BASE 0x82000000 +#else +#define CONFIG_SYS_TEXT_BASE 0x60100000 +#endif + +#ifndef __ASSEMBLY__ +unsigned long get_board_sys_clk(void); +unsigned long get_board_ddr_clk(void); +#endif + +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 100000000 + +#define CONFIG_SKIP_LOWLEVEL_INIT + +#define CONFIG_LAYERSCAPE_NS_ACCESS + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +/* Physical Memory Map */ +#define CONFIG_CHIP_SELECTS_PER_CTRL 4 +#define CONFIG_NR_DRAM_BANKS 1 + +#define CONFIG_DDR_SPD +#define SPD_EEPROM_ADDRESS 0x51 +#define CONFIG_SYS_SPD_BUS_NUM 0 + +#define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ +#ifndef CONFIG_SYS_FSL_DDR4 +#define CONFIG_SYS_FSL_DDR3 /* Use DDR3 memory */ +#endif + +#define CONFIG_DDR_ECC +#ifdef CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#endif + +#define CONFIG_SYS_HAS_SERDES + +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#define CONFIG_PHYLIB +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_REALTEK +#define CONFIG_PHYLIB_10G +#define RGMII_PHY1_ADDR 0x1 +#define RGMII_PHY2_ADDR 0x2 +#define SGMII_CARD_PORT1_PHY_ADDR 0x1C +#define SGMII_CARD_PORT2_PHY_ADDR 0x1D +#define SGMII_CARD_PORT3_PHY_ADDR 0x1E +#define SGMII_CARD_PORT4_PHY_ADDR 0x1F +/* PHY address on QSGMII riser card on slot 1 */ +#define QSGMII_CARD_PORT1_PHY_ADDR_S1 0x4 +#define QSGMII_CARD_PORT2_PHY_ADDR_S1 0x5 +#define QSGMII_CARD_PORT3_PHY_ADDR_S1 0x6 +#define QSGMII_CARD_PORT4_PHY_ADDR_S1 0x7 +/* PHY address on QSGMII riser card on slot 2 */ +#define QSGMII_CARD_PORT1_PHY_ADDR_S2 0x8 +#define QSGMII_CARD_PORT2_PHY_ADDR_S2 0x9 +#define QSGMII_CARD_PORT3_PHY_ADDR_S2 0xA +#define QSGMII_CARD_PORT4_PHY_ADDR_S2 0xB +#endif + +#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_SYS_FSL_PBL_PBI board/freescale/ls1043aqds/ls1043aqds_pbi.cfg +#endif + +#ifdef CONFIG_NAND_BOOT +#define CONFIG_SYS_FSL_PBL_RCW board/freescale/ls1043aqds/ls1043aqds_rcw_nand.cfg +#endif + +#ifdef CONFIG_SD_BOOT +#define CONFIG_SYS_FSL_PBL_RCW board/freescale/ls1043aqds/ls1043aqds_rcw_sd_ifc.cfg +#endif + +/* + * IFC Definitions + */ +#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) +#define CONFIG_SYS_NOR0_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR1_CSPR_EXT (0x0) +#define CONFIG_SYS_NOR1_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS \ + + 0x8000000) | \ + CSPR_PORT_SIZE_16 | \ + CSPR_MSEL_NOR | \ + CSPR_V) +#define CONFIG_SYS_NOR_AMASK IFC_AMASK(128 * 1024 * 1024) + +#define CONFIG_SYS_NOR_CSOR (CSOR_NOR_ADM_SHIFT(4) | \ + CSOR_NOR_TRHZ_80) +#define CONFIG_SYS_NOR_FTIM0 (FTIM0_NOR_TACSE(0x4) | \ + FTIM0_NOR_TEADC(0x5) | \ + FTIM0_NOR_TEAHC(0x5)) +#define CONFIG_SYS_NOR_FTIM1 (FTIM1_NOR_TACO(0x35) | \ + FTIM1_NOR_TRAD_NOR(0x1a) | \ + FTIM1_NOR_TSEQRAD_NOR(0x13)) +#define CONFIG_SYS_NOR_FTIM2 (FTIM2_NOR_TCS(0x4) | \ + FTIM2_NOR_TCH(0x4) | \ + FTIM2_NOR_TWPH(0xe) | \ + FTIM2_NOR_TWP(0x1c)) +#define CONFIG_SYS_NOR_FTIM3 0 + +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS, \ + CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000} + +#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS +#define CONFIG_SYS_WRITE_SWAPPED_DATA + +/* + * NAND Flash Definitions + */ +#define CONFIG_NAND_FSL_IFC + +#define CONFIG_SYS_NAND_BASE 0x7e800000 +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE + +#define CONFIG_SYS_NAND_CSPR_EXT (0x0) + +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_NAND \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64*1024) +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 3 Bytes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ + | CSOR_NAND_SPRZ_64 /* Spare size = 64 */ \ + | CSOR_NAND_PB(64)) /* 64 Pages Per Block */ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x7) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x7) | \ + FTIM0_NAND_TWH(0xa)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0xe) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0xf) | \ + FTIM2_NAND_TREH(0xa) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE +#define CONFIG_CMD_NAND + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +#ifdef CONFIG_NAND_BOOT +#define CONFIG_SPL_PAD_TO 0x20000 /* block aligned */ +#define CONFIG_SYS_NAND_U_BOOT_OFFS CONFIG_SPL_PAD_TO +#define CONFIG_SYS_NAND_U_BOOT_SIZE (640 << 10) +#endif + +/* + * QIXIS Definitions + */ +#define CONFIG_FSL_QIXIS + +#ifdef CONFIG_FSL_QIXIS +#define QIXIS_BASE 0x7fb00000 +#define QIXIS_BASE_PHYS QIXIS_BASE +#define CONFIG_SYS_I2C_FPGA_ADDR 0x66 +#define QIXIS_LBMAP_SWITCH 6 +#define QIXIS_LBMAP_MASK 0x0f +#define QIXIS_LBMAP_SHIFT 0 +#define QIXIS_LBMAP_DFLTBANK 0x00 +#define QIXIS_LBMAP_ALTBANK 0x04 +#define QIXIS_RST_CTL_RESET 0x44 +#define QIXIS_RCFG_CTL_RECONFIG_IDLE 0x20 +#define QIXIS_RCFG_CTL_RECONFIG_START 0x21 +#define QIXIS_RCFG_CTL_WATCHDOG_ENBLE 0x08 + +#define CONFIG_SYS_FPGA_CSPR_EXT (0x0) +#define CONFIG_SYS_FPGA_CSPR (CSPR_PHYS_ADDR(QIXIS_BASE_PHYS) | \ + CSPR_PORT_SIZE_8 | \ + CSPR_MSEL_GPCM | \ + CSPR_V) +#define CONFIG_SYS_FPGA_AMASK IFC_AMASK(64 * 1024) +#define CONFIG_SYS_FPGA_CSOR (CSOR_NOR_ADM_SHIFT(4) | \ + CSOR_NOR_NOR_MODE_AVD_NOR | \ + CSOR_NOR_TRHZ_80) + +/* + * QIXIS Timing parameters for IFC GPCM + */ +#define CONFIG_SYS_FPGA_FTIM0 (FTIM0_GPCM_TACSE(0xc) | \ + FTIM0_GPCM_TEADC(0x20) | \ + FTIM0_GPCM_TEAHC(0x10)) +#define CONFIG_SYS_FPGA_FTIM1 (FTIM1_GPCM_TACO(0x50) | \ + FTIM1_GPCM_TRAD(0x1f)) +#define CONFIG_SYS_FPGA_FTIM2 (FTIM2_GPCM_TCS(0x8) | \ + FTIM2_GPCM_TCH(0x8) | \ + FTIM2_GPCM_TWP(0xf0)) +#define CONFIG_SYS_FPGA_FTIM3 0x0 +#endif + +#ifdef CONFIG_NAND_BOOT +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NOR1_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR3_EXT CONFIG_SYS_FPGA_CSPR_EXT +#define CONFIG_SYS_CSPR3 CONFIG_SYS_FPGA_CSPR +#define CONFIG_SYS_AMASK3 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_CSOR3 CONFIG_SYS_FPGA_CSOR +#define CONFIG_SYS_CS3_FTIM0 CONFIG_SYS_FPGA_FTIM0 +#define CONFIG_SYS_CS3_FTIM1 CONFIG_SYS_FPGA_FTIM1 +#define CONFIG_SYS_CS3_FTIM2 CONFIG_SYS_FPGA_FTIM2 +#define CONFIG_SYS_CS3_FTIM3 CONFIG_SYS_FPGA_FTIM3 +#else +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NOR0_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NOR0_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR1_EXT CONFIG_SYS_NOR1_CSPR_EXT +#define CONFIG_SYS_CSPR1 CONFIG_SYS_NOR1_CSPR +#define CONFIG_SYS_AMASK1 CONFIG_SYS_NOR_AMASK +#define CONFIG_SYS_CSOR1 CONFIG_SYS_NOR_CSOR +#define CONFIG_SYS_CS1_FTIM0 CONFIG_SYS_NOR_FTIM0 +#define CONFIG_SYS_CS1_FTIM1 CONFIG_SYS_NOR_FTIM1 +#define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 +#define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3 +#define CONFIG_SYS_CSPR2_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR2 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK2 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR2 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS2_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS2_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS2_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS2_FTIM3 CONFIG_SYS_NAND_FTIM3 +#define CONFIG_SYS_CSPR3_EXT CONFIG_SYS_FPGA_CSPR_EXT +#define CONFIG_SYS_CSPR3 CONFIG_SYS_FPGA_CSPR +#define CONFIG_SYS_AMASK3 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_CSOR3 CONFIG_SYS_FPGA_CSOR +#define CONFIG_SYS_CS3_FTIM0 CONFIG_SYS_FPGA_FTIM0 +#define CONFIG_SYS_CS3_FTIM1 CONFIG_SYS_FPGA_FTIM1 +#define CONFIG_SYS_CS3_FTIM2 CONFIG_SYS_FPGA_FTIM2 +#define CONFIG_SYS_CS3_FTIM3 CONFIG_SYS_FPGA_FTIM3 +#endif + +/* + * I2C bus multiplexer + */ +#define I2C_MUX_PCA_ADDR_PRI 0x77 +#define I2C_MUX_PCA_ADDR_SEC 0x76 /* Secondary multiplexer */ +#define I2C_RETIMER_ADDR 0x18 +#define I2C_MUX_CH_DEFAULT 0x8 +#define I2C_MUX_CH_CH7301 0xC +#define I2C_MUX_CH5 0xD +#define I2C_MUX_CH7 0xF + +#define I2C_MUX_CH_VOL_MONITOR 0xa + +/* Voltage monitor on channel 2*/ +#define I2C_VOL_MONITOR_ADDR 0x40 +#define I2C_VOL_MONITOR_BUS_V_OFFSET 0x2 +#define I2C_VOL_MONITOR_BUS_V_OVF 0x1 +#define I2C_VOL_MONITOR_BUS_V_SHIFT 3 + +#define CONFIG_VID_FLS_ENV "ls1043aqds_vdd_mv" +#ifndef CONFIG_SPL_BUILD +#define CONFIG_VID +#endif +#define CONFIG_VOL_MONITOR_IR36021_SET +#define CONFIG_VOL_MONITOR_INA220 +/* The lowest and highest voltage allowed for LS1043AQDS */ +#define VDD_MV_MIN 819 +#define VDD_MV_MAX 1212 + +/* + * Miscellaneous configurable options + */ +#define CONFIG_MISC_INIT_R +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_CMD_GREPENV +#define CONFIG_CMD_MEMINFO +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END 0x9fffffff + +#define CONFIG_SYS_HZ 1000 + +/* + * Stack sizes + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (30 * 1024) + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_MONITOR_BASE CONFIG_SPL_TEXT_BASE +#else +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif + +/* + * Environment + */ +#define CONFIG_ENV_OVERWRITE + +#ifdef CONFIG_NAND_BOOT +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_OFFSET (1024 * 1024) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x200000) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x20000 +#endif + +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_MII +#define CONFIG_CMDLINE_TAG + +#endif /* __LS1043AQDS_H__ */
Memory subsystem:
- 2GByte DDR4 DIMM
- 128 Mbyte NOR flash single-chip memory
- 512 Mbyte NAND flash
- 16 Mbyte high-speed SPI flash
- SD connector to interface with the SD memory card
Ethernet:
- Two RGMII ports
- XFI 10G port
- SGMII
- QSGMII with 4x 1G ports
V4:
V3:
V2:
- No change.
Added CONFIG_SYS_NS16550=y in defconfig files. Applied to fsl-qoriq master. Thanks.
York
Reuse the dts files from ls1043a linux kernel.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V4: - No change. V3: - No change. V2: - New Patch.
arch/arm/dts/Makefile | 3 +- arch/arm/dts/fsl-ls1043a-qds.dts | 124 +++++++++++++++++++++++++++++++++++++++ configs/ls1043aqds_defconfig | 2 + 3 files changed, 128 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7e12f01..88a500d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -89,7 +89,8 @@ dtb-$(CONFIG_LS102XA) += ls1021a-qds.dtb \ ls1021a-twr.dtb dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2085a-qds.dtb \ fsl-ls2085a-rdb.dtb -dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-rdb.dtb +dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds.dtb \ + fsl-ls1043a-rdb.dtb
dtb-$(CONFIG_MACH_SUN4I) += \ sun4i-a10-a1000.dtb \ diff --git a/arch/arm/dts/fsl-ls1043a-qds.dts b/arch/arm/dts/fsl-ls1043a-qds.dts new file mode 100644 index 0000000..7435222 --- /dev/null +++ b/arch/arm/dts/fsl-ls1043a-qds.dts @@ -0,0 +1,124 @@ +/* + * Device Tree Include file for Freescale Layerscape-1043A family SoC. + * + * Copyright (C) 2015, Freescale Semiconductor + * + * Mingkai Hu Mingkai.hu@freescale.com + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +/dts-v1/; +/include/ "fsl-ls1043a.dtsi" + +/ { + model = "LS1043A QDS Board"; +}; + +&i2c0 { + status = "okay"; + pca9547@77 { + compatible = "philips,pca9547"; + reg = <0x77>; + #address-cells = <1>; + #size-cells = <0>; + + i2c@0 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0>; + + rtc@68 { + compatible = "dallas,ds3232"; + reg = <0x68>; + /* IRQ10_B */ + interrupts = <0 150 0x4>; + }; + }; + + i2c@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x2>; + + ina220@40 { + compatible = "ti,ina220"; + reg = <0x40>; + shunt-resistor = <1000>; + }; + + ina220@41 { + compatible = "ti,ina220"; + reg = <0x41>; + shunt-resistor = <1000>; + }; + }; + + i2c@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <0x3>; + + eeprom@56 { + compatible = "at24,24c512"; + reg = <0x56>; + }; + + eeprom@57 { + compatible = "at24,24c512"; + reg = <0x57>; + }; + + adt7461a@4c { + compatible = "adt7461a"; + reg = <0x4c>; + }; + }; + }; +}; + +&ifc { + #address-cells = <2>; + #size-cells = <1>; + /* NOR, NAND Flashes and FPGA on board */ + ranges = <0x0 0x0 0x0 0x60000000 0x08000000 + 0x2 0x0 0x0 0x7e800000 0x00010000 + 0x3 0x0 0x0 0x7fb00000 0x00000100>; + status = "okay"; + + nor@0,0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "cfi-flash"; + reg = <0x0 0x0 0x8000000>; + bank-width = <2>; + device-width = <1>; + }; + + nand@2,0 { + compatible = "fsl,ifc-nand"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x1 0x0 0x10000>; + }; + + fpga: board-control@3,0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "simple-bus"; + reg = <0x3 0x0 0x0000100>; + bank-width = <1>; + device-width = <1>; + ranges = <0 3 0 0x100>; + }; +}; + +&duart0 { + status = "okay"; +}; + +&duart1 { + status = "okay"; +}; diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index ee5bea2..cf163d6 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -1,3 +1,5 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" CONFIG_ARM=y CONFIG_TARGET_LS1043AQDS=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds" +CONFIG_OF_CONTROL=y
V4:
- No change.
V3:
- No change.
V2:
- New Patch.
York
Use the U-Boot Driver Model. Just enable Freescale DSPI driver and set DSPI related parameters in dts file.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V4: - No change. V3: - New Patch. - Tested on LS1043ARDB board.
arch/arm/dts/fsl-ls1043a-rdb.dts | 19 +++++++++++++++++++ arch/arm/dts/fsl-ls1043a.dtsi | 26 ++++++++++++++++++++++++++ configs/ls1043ardb_defconfig | 3 +++ configs/ls1043ardb_nand_defconfig | 5 +++++ configs/ls1043ardb_sdcard_defconfig | 5 +++++ include/configs/ls1043ardb.h | 10 ++++++++++ 6 files changed, 68 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1043a-rdb.dts b/arch/arm/dts/fsl-ls1043a-rdb.dts index 17a0681..16c5c89 100644 --- a/arch/arm/dts/fsl-ls1043a-rdb.dts +++ b/arch/arm/dts/fsl-ls1043a-rdb.dts @@ -15,6 +15,25 @@
/ { model = "LS1043A RDB Board"; + + aliases { + spi1 = &dspi0; + }; + +}; + +&dspi0 { + bus-num = <0>; + status = "okay"; + + dspiflash: n25q12a { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + reg = <0>; + spi-max-frequency = <1000000>; /* input clock */ + }; + };
&i2c0 { diff --git a/arch/arm/dts/fsl-ls1043a.dtsi b/arch/arm/dts/fsl-ls1043a.dtsi index 280e959..85ea81e 100644 --- a/arch/arm/dts/fsl-ls1043a.dtsi +++ b/arch/arm/dts/fsl-ls1043a.dtsi @@ -79,6 +79,32 @@ clocks = <&sysclk>; };
+ dspi0: dspi@2100000 { + compatible = "fsl,vf610-dspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2100000 0x0 0x10000>; + interrupts = <0 64 0x4>; + clock-names = "dspi"; + clocks = <&clockgen 4 0>; + num-cs = <6>; + big-endian; + status = "disabled"; + }; + + dspi1: dspi@2110000 { + compatible = "fsl,vf610-dspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x0 0x2110000 0x0 0x10000>; + interrupts = <0 65 0x4>; + clock-names = "dspi"; + clocks = <&clockgen 4 0>; + num-cs = <6>; + big-endian; + status = "disabled"; + }; + ifc: ifc@1530000 { compatible = "fsl,ifc", "simple-bus"; reg = <0x0 0x1530000 0x0 0x10000>; diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index f77fbbf..0102e0d 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -4,3 +4,6 @@ CONFIG_TARGET_LS1043ARDB=y CONFIG_FSL_LAYERSCAPE=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_DM_SPI=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index fffaca0..661cbc2 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -2,3 +2,8 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT,SYS_FSL_DDR4" CONFIG_ARM=y CONFIG_TARGET_LS1043ARDB=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_DM_SPI=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 5fe0470..b53dd15 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -2,3 +2,8 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SYS_FSL_DDR4" CONFIG_ARM=y CONFIG_TARGET_LS1043ARDB=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-rdb" +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_DM_SPI=y diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 307d947..3fa9b3b 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -222,6 +222,16 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
+/* DSPI */ +#define CONFIG_FSL_DSPI +#ifdef CONFIG_FSL_DSPI +#define CONFIG_CMD_SF +#define CONFIG_DM_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_SF_DEFAULT_BUS 1 +#define CONFIG_SF_DEFAULT_CS 0 +#endif + /* * Environment */
V4:
- No change.
V3:
- New Patch.
York
Add support for the third USB controller for LS1043A.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V4: - No change. V3: - New Patch. Tested on LS1043ARDB board.
arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h | 6 +++--- board/freescale/ls1043ardb/ls1043ardb.c | 16 ++++++++++++++++ include/configs/ls1043ardb.h | 13 +++++++++++++ include/linux/usb/xhci-fsl.h | 9 ++++++++- 4 files changed, 40 insertions(+), 4 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index f52815d..83caa91 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -30,9 +30,9 @@ #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x011c0600) #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_IMMR + 0x011d0500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_IMMR + 0x011d0600) -#define CONFIG_SYS_FSL_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x01f00000) -#define CONFIG_SYS_FSL_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02000000) -#define CONFIG_SYS_FSL_XHCI_USB3_ADDR (CONFIG_SYS_IMMR + 0x02100000) +#define CONFIG_SYS_LS1043A_XHCI_USB1_ADDR (CONFIG_SYS_IMMR + 0x01f00000) +#define CONFIG_SYS_LS1043A_XHCI_USB2_ADDR (CONFIG_SYS_IMMR + 0x02000000) +#define CONFIG_SYS_LS1043A_XHCI_USB3_ADDR (CONFIG_SYS_IMMR + 0x02100000) #define CONFIG_SYS_PCIE1_ADDR (CONFIG_SYS_IMMR + 0x2400000) #define CONFIG_SYS_PCIE2_ADDR (CONFIG_SYS_IMMR + 0x2500000) #define CONFIG_SYS_PCIE3_ADDR (CONFIG_SYS_IMMR + 0x2600000) diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c index 9032ed3..cdd50d6 100644 --- a/board/freescale/ls1043ardb/ls1043ardb.c +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -69,7 +69,23 @@ int dram_init(void)
int board_early_init_f(void) { + struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; + u32 usb_pwrfault; + fsl_lsch2_early_init_f(); + +#ifdef CONFIG_HAS_FSL_XHCI_USB + out_be32(&scfg->rcwpmuxcr0, 0x3333); + out_be32(&scfg->usbdrvvbus_selcr, SCFG_USBDRVVBUS_SELCR_USB1); + usb_pwrfault = (SCFG_USBPWRFAULT_DEDICATED << + SCFG_USBPWRFAULT_USB3_SHIFT) | + (SCFG_USBPWRFAULT_DEDICATED << + SCFG_USBPWRFAULT_USB2_SHIFT) | + (SCFG_USBPWRFAULT_SHARED << + SCFG_USBPWRFAULT_USB1_SHIFT); + out_be32(&scfg->usbpwrfault_selcr, usb_pwrfault); +#endif + return 0; }
diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index 3fa9b3b..7d113a0 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -278,4 +278,17 @@ #define CONFIG_ETHPRIME "FM1@DTSEC3" #endif
+/* USB */ +#define CONFIG_HAS_FSL_XHCI_USB +#ifdef CONFIG_HAS_FSL_XHCI_USB +#define CONFIG_USB_XHCI +#define CONFIG_USB_XHCI_FSL +#define CONFIG_USB_XHCI_DWC3 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 3 +#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 +#define CONFIG_CMD_USB +#define CONFIG_USB_STORAGE +#define CONFIG_CMD_EXT2 +#endif + #endif /* __LS1043ARDB_H__ */ diff --git a/include/linux/usb/xhci-fsl.h b/include/linux/usb/xhci-fsl.h index 602a413..b0ff129 100644 --- a/include/linux/usb/xhci-fsl.h +++ b/include/linux/usb/xhci-fsl.h @@ -54,11 +54,18 @@ struct fsl_xhci { #if defined(CONFIG_LS102XA) #define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS102XA_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR 0 +#define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0 #elif defined(CONFIG_LS2085A) #define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS2085A_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_LS2085A_XHCI_USB2_ADDR +#define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0 +#elif defined(CONFIG_LS1043A) +#define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS1043A_XHCI_USB1_ADDR +#define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_LS1043A_XHCI_USB2_ADDR +#define CONFIG_SYS_FSL_XHCI_USB3_ADDR CONFIG_SYS_LS1043A_XHCI_USB3_ADDR #endif
#define FSL_USB_XHCI_ADDR {CONFIG_SYS_FSL_XHCI_USB1_ADDR, \ - CONFIG_SYS_FSL_XHCI_USB2_ADDR} + CONFIG_SYS_FSL_XHCI_USB2_ADDR, \ + CONFIG_SYS_FSL_XHCI_USB3_ADDR} #endif /* _ASM_ARCH_XHCI_FSL_H_ */
V4:
- No change.
V3:
York
Gong Qianyu
York Sun
