[U-Boot-Users] resend [PATCH 4/8] ColdFire: Add MCF547x_8x dma code - 2
Signed-off-by: TsiChungLiew Tsi-Chung.Liew@freescale.com --- drivers/dma/MCD_dmaApi.c | 1026 ++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 1026 insertions(+), 0 deletions(-) create mode 100644 drivers/dma/MCD_dmaApi.c
diff --git a/drivers/dma/MCD_dmaApi.c b/drivers/dma/MCD_dmaApi.c new file mode 100644 index 0000000..b0062b7 --- /dev/null +++ b/drivers/dma/MCD_dmaApi.c @@ -0,0 +1,1026 @@ +/* + * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/*Main C file for multi-channel DMA API. */ + +#include <common.h> + +#ifdef CONFIG_FSLDMAFEC + +#include <MCD_dma.h> +#include <MCD_tasksInit.h> +#include <MCD_progCheck.h> + +/********************************************************************/ +/* This is an API-internal pointer to the DMA's registers */ +dmaRegs *MCD_dmaBar; + +/* + * These are the real and model task tables as generated by the + * build process + */ +extern TaskTableEntry MCD_realTaskTableSrc[NCHANNELS]; +extern TaskTableEntry MCD_modelTaskTableSrc[NUMOFVARIANTS]; + +/* + * However, this (usually) gets relocated to on-chip SRAM, at which + * point we access them as these tables + */ +volatile TaskTableEntry *MCD_taskTable; +TaskTableEntry *MCD_modelTaskTable; + +/* + * MCD_chStatus[] is an array of status indicators for remembering + * whether a DMA has ever been attempted on each channel, pausing + * status, etc. + */ +static int MCD_chStatus[NCHANNELS] = { + MCD_NO_DMA, MCD_NO_DMA, MCD_NO_DMA, MCD_NO_DMA, + MCD_NO_DMA, MCD_NO_DMA, MCD_NO_DMA, MCD_NO_DMA, + MCD_NO_DMA, MCD_NO_DMA, MCD_NO_DMA, MCD_NO_DMA, + MCD_NO_DMA, MCD_NO_DMA, MCD_NO_DMA, MCD_NO_DMA +}; + +/* Prototypes for local functions */ +static void MCD_memcpy(int *dest, int *src, u32 size); +static void MCD_resmActions(int channel); + +/* + * Buffer descriptors used for storage of progress info for single Dmas + * Also used as storage for the DMA for CRCs for single DMAs + * Otherwise, the DMA does not parse these buffer descriptors + */ +#ifdef MCD_INCLUDE_EU +extern MCD_bufDesc MCD_singleBufDescs[NCHANNELS]; +#else +MCD_bufDesc MCD_singleBufDescs[NCHANNELS]; +#endif +MCD_bufDesc *MCD_relocBuffDesc; + +/* Defines for the debug control register's functions */ +#define DBG_CTL_COMP1_TASK (0x00002000) +#define DBG_CTL_ENABLE (DBG_CTL_AUTO_ARM | \ + DBG_CTL_BREAK | \ + DBG_CTL_INT_BREAK | \ + DBG_CTL_COMP1_TASK) +#define DBG_CTL_DISABLE (DBG_CTL_AUTO_ARM | \ + DBG_CTL_INT_BREAK | \ + DBG_CTL_COMP1_TASK) +#define DBG_KILL_ALL_STAT (0xFFFFFFFF) + +/* Offset to context save area where progress info is stored */ +#define CSAVE_OFFSET 10 + +/* Defines for Byte Swapping */ +#define MCD_BYTE_SWAP_KILLER 0xFFF8888F +#define MCD_NO_BYTE_SWAP_ATALL 0x00040000 + +/* Execution Unit Identifiers */ +#define MAC 0 /* legacy - not used */ +#define LUAC 1 /* legacy - not used */ +#define CRC 2 /* legacy - not used */ +#define LURC 3 /* Logic Unit with CRC */ + +/* Task Identifiers */ +#define TASK_CHAINNOEU 0 +#define TASK_SINGLENOEU 1 +#ifdef MCD_INCLUDE_EU +#define TASK_CHAINEU 2 +#define TASK_SINGLEEU 3 +#define TASK_FECRX 4 +#define TASK_FECTX 5 +#else +#define TASK_CHAINEU 0 +#define TASK_SINGLEEU 1 +#define TASK_FECRX 2 +#define TASK_FECTX 3 +#endif + +/* + * Structure to remember which variant is on which channel + * TBD- need this? + */ +typedef struct MCD_remVariants_struct MCD_remVariant; +struct MCD_remVariants_struct { + int remDestRsdIncr[NCHANNELS]; /* -1,0,1 */ + int remSrcRsdIncr[NCHANNELS]; /* -1,0,1 */ + s16 remDestIncr[NCHANNELS]; /* DestIncr */ + s16 remSrcIncr[NCHANNELS]; /* srcIncr */ + u32 remXferSize[NCHANNELS]; /* xferSize */ +}; + +/* Structure to remember the startDma parameters for each channel */ +MCD_remVariant MCD_remVariants; +/********************************************************************/ +/* Function: MCD_initDma + * Purpose: Initializes the DMA API by setting up a pointer to the DMA + * registers, relocating and creating the appropriate task + * structures, and setting up some global settings + * Arguments: + * dmaBarAddr - pointer to the multichannel DMA registers + * taskTableDest - location to move DMA task code and structs to + * flags - operational parameters + * Return Value: + * MCD_TABLE_UNALIGNED if taskTableDest is not 512-byte aligned + * MCD_OK otherwise + */ +extern u32 MCD_funcDescTab0[]; + +int MCD_initDma(dmaRegs * dmaBarAddr, void *taskTableDest, u32 flags) +{ + int i; + TaskTableEntry *entryPtr; + + /* setup the local pointer to register set */ + MCD_dmaBar = dmaBarAddr; + + /* do we need to move/create a task table */ + if ((flags & MCD_RELOC_TASKS) != 0) { + int fixedSize; + u32 *fixedPtr; + /*int *tablePtr = taskTableDest;TBD */ + int varTabsOffset, funcDescTabsOffset, contextSavesOffset; + int taskDescTabsOffset; + int taskTableSize, varTabsSize, funcDescTabsSize, + contextSavesSize; + int taskDescTabSize; + + int i; + + /* check if physical address is aligned on 512 byte boundary */ + if (((u32) taskTableDest & 0x000001ff) != 0) + return (MCD_TABLE_UNALIGNED); + + /* set up local pointer to task Table */ + MCD_taskTable = taskTableDest; + + /* + * Create a task table: + * - compute aligned base offsets for variable tables and + * function descriptor tables, then + * - loop through the task table and setup the pointers + * - copy over model task table with the the actual task + * descriptor tables + */ + + taskTableSize = NCHANNELS * sizeof(TaskTableEntry); + /* align variable tables to size */ + varTabsOffset = taskTableSize + (u32) taskTableDest; + if ((varTabsOffset & (VAR_TAB_SIZE - 1)) != 0) + varTabsOffset = + (varTabsOffset + VAR_TAB_SIZE) & (~VAR_TAB_SIZE); + /* align function descriptor tables */ + varTabsSize = NCHANNELS * VAR_TAB_SIZE; + funcDescTabsOffset = varTabsOffset + varTabsSize; + + if ((funcDescTabsOffset & (FUNCDESC_TAB_SIZE - 1)) != 0) + funcDescTabsOffset = + (funcDescTabsOffset + + FUNCDESC_TAB_SIZE) & (~FUNCDESC_TAB_SIZE); + + funcDescTabsSize = FUNCDESC_TAB_NUM * FUNCDESC_TAB_SIZE; + contextSavesOffset = funcDescTabsOffset + funcDescTabsSize; + contextSavesSize = (NCHANNELS * CONTEXT_SAVE_SIZE); + fixedSize = + taskTableSize + varTabsSize + funcDescTabsSize + + contextSavesSize; + + /* zero the thing out */ + fixedPtr = (u32 *) taskTableDest; + for (i = 0; i < (fixedSize / 4); i++) + fixedPtr[i] = 0; + + entryPtr = (TaskTableEntry *) MCD_taskTable; + /* set up fixed pointers */ + for (i = 0; i < NCHANNELS; i++) { + /* update ptr to local value */ + entryPtr[i].varTab = (u32) varTabsOffset; + entryPtr[i].FDTandFlags = + (u32) funcDescTabsOffset | MCD_TT_FLAGS_DEF; + entryPtr[i].contextSaveSpace = (u32) contextSavesOffset; + varTabsOffset += VAR_TAB_SIZE; +#ifdef MCD_INCLUDE_EU + /* if not there is only one, just point to the + same one */ + funcDescTabsOffset += FUNCDESC_TAB_SIZE; +#endif + contextSavesOffset += CONTEXT_SAVE_SIZE; + } + /* copy over the function descriptor table */ + for (i = 0; i < FUNCDESC_TAB_NUM; i++) { + MCD_memcpy((void *)(entryPtr[i]. + FDTandFlags & ~MCD_TT_FLAGS_MASK), + (void *)MCD_funcDescTab0, FUNCDESC_TAB_SIZE); + } + + /* copy model task table to where the context saves stuff + leaves off */ + MCD_modelTaskTable = (TaskTableEntry *) contextSavesOffset; + + MCD_memcpy((void *)MCD_modelTaskTable, + (void *)MCD_modelTaskTableSrc, + NUMOFVARIANTS * sizeof(TaskTableEntry)); + + /* point to local version of model task table */ + entryPtr = MCD_modelTaskTable; + taskDescTabsOffset = (u32) MCD_modelTaskTable + + (NUMOFVARIANTS * sizeof(TaskTableEntry)); + + /* copy actual task code and update TDT ptrs in local + model task table */ + for (i = 0; i < NUMOFVARIANTS; i++) { + taskDescTabSize = + entryPtr[i].TDTend - entryPtr[i].TDTstart + 4; + MCD_memcpy((void *)taskDescTabsOffset, + (void *)entryPtr[i].TDTstart, + taskDescTabSize); + entryPtr[i].TDTstart = (u32) taskDescTabsOffset; + taskDescTabsOffset += taskDescTabSize; + entryPtr[i].TDTend = (u32) taskDescTabsOffset - 4; + } +#ifdef MCD_INCLUDE_EU + /* Tack single DMA BDs onto end of code so API controls + where they are since DMA might write to them */ + MCD_relocBuffDesc = + (MCD_bufDesc *) (entryPtr[NUMOFVARIANTS - 1].TDTend + 4); +#else + /* DMA does not touch them so they can be wherever and we + don't need to waste SRAM on them */ + MCD_relocBuffDesc = MCD_singleBufDescs; +#endif + } else { + /* point the would-be relocated task tables and the + buffer descriptors to the ones the linker generated */ + + if (((u32) MCD_realTaskTableSrc & 0x000001ff) != 0) + return (MCD_TABLE_UNALIGNED); + + /* need to add code to make sure that every thing else is + aligned properly TBD. this is problematic if we init + more than once or after running tasks, need to add + variable to see if we have aleady init'd */ + entryPtr = MCD_realTaskTableSrc; + for (i = 0; i < NCHANNELS; i++) { + if (((entryPtr[i].varTab & (VAR_TAB_SIZE - 1)) != 0) || + ((entryPtr[i]. + FDTandFlags & (FUNCDESC_TAB_SIZE - 1)) != 0)) + return (MCD_TABLE_UNALIGNED); + } + + MCD_taskTable = MCD_realTaskTableSrc; + MCD_modelTaskTable = MCD_modelTaskTableSrc; + MCD_relocBuffDesc = MCD_singleBufDescs; + } + + /* Make all channels as totally inactive, and remember them as such: */ + + MCD_dmaBar->taskbar = (u32) MCD_taskTable; + for (i = 0; i < NCHANNELS; i++) { + MCD_dmaBar->taskControl[i] = 0x0; + MCD_chStatus[i] = MCD_NO_DMA; + } + + /* Set up pausing mechanism to inactive state: */ + /* no particular values yet for either comparator registers */ + MCD_dmaBar->debugComp1 = 0; + MCD_dmaBar->debugComp2 = 0; + MCD_dmaBar->debugControl = DBG_CTL_DISABLE; + MCD_dmaBar->debugStatus = DBG_KILL_ALL_STAT; + + /* enable or disable commbus prefetch, really need an ifdef or + something to keep from trying to set this in the 8220 */ + if ((flags & MCD_COMM_PREFETCH_EN) != 0) + MCD_dmaBar->ptdControl &= ~PTD_CTL_COMM_PREFETCH; + else + MCD_dmaBar->ptdControl |= PTD_CTL_COMM_PREFETCH; + + return (MCD_OK); +} + +/*********************** End of MCD_initDma() ***********************/ + +/********************************************************************/ +/* Function: MCD_dmaStatus + * Purpose: Returns the status of the DMA on the requested channel + * Arguments: channel - channel number + * Returns: Predefined status indicators + */ +int MCD_dmaStatus(int channel) +{ + u16 tcrValue; + + if ((channel < 0) || (channel >= NCHANNELS)) + return (MCD_CHANNEL_INVALID); + + tcrValue = MCD_dmaBar->taskControl[channel]; + if ((tcrValue & TASK_CTL_EN) == 0) { /* nothing running */ + /* if last reported with task enabled */ + if (MCD_chStatus[channel] == MCD_RUNNING + || MCD_chStatus[channel] == MCD_IDLE) + MCD_chStatus[channel] = MCD_DONE; + } else { /* something is running */ + + /* There are three possibilities: paused, running or idle. */ + if (MCD_chStatus[channel] == MCD_RUNNING + || MCD_chStatus[channel] == MCD_IDLE) { + MCD_dmaBar->ptdDebug = PTD_DBG_TSK_VLD_INIT; + /* This register is selected to know which initiator is + actually asserted. */ + if ((MCD_dmaBar->ptdDebug >> channel) & 0x1) + MCD_chStatus[channel] = MCD_RUNNING; + else + MCD_chStatus[channel] = MCD_IDLE; + /* do not change the status if it is already paused. */ + } + } + return MCD_chStatus[channel]; +} + +/******************** End of MCD_dmaStatus() ************************/ + +/********************************************************************/ +/* Function: MCD_startDma + * Ppurpose: Starts a particular kind of DMA + * Arguments: + * srcAddr - the channel on which to run the DMA + * srcIncr - the address to move data from, or buffer-descriptor address + * destAddr - the amount to increment the source address per transfer + * destIncr - the address to move data to + * dmaSize - the amount to increment the destination address per transfer + * xferSize - the number bytes in of each data movement (1, 2, or 4) + * initiator - what device initiates the DMA + * priority - priority of the DMA + * flags - flags describing the DMA + * funcDesc - description of byte swapping, bit swapping, and CRC actions + * srcAddrVirt - virtual buffer descriptor address TBD + * Returns: MCD_CHANNEL_INVALID if channel is invalid, else MCD_OK + */ + +int MCD_startDma(int channel, s8 * srcAddr, s16 srcIncr, s8 * destAddr, + s16 destIncr, u32 dmaSize, u32 xferSize, u32 initiator, + int priority, u32 flags, u32 funcDesc +#ifdef MCD_NEED_ADDR_TRANS + s8 * srcAddrVirt +#endif + ) +{ + int srcRsdIncr, destRsdIncr; + int *cSave; + short xferSizeIncr; + int tcrCount = 0; +#ifdef MCD_INCLUDE_EU + u32 *realFuncArray; +#endif + + if ((channel < 0) || (channel >= NCHANNELS)) + return (MCD_CHANNEL_INVALID); + + /* tbd - need to determine the proper response to a bad funcDesc when + not including EU functions, for now, assign a benign funcDesc, but + maybe should return an error */ +#ifndef MCD_INCLUDE_EU + funcDesc = MCD_FUNC_NOEU1; +#endif + +#ifdef MCD_DEBUG + printf("startDma:Setting up params\n"); +#endif + /* Set us up for task-wise priority. We don't technically need to do + this on every start, but since the register involved is in the same + longword as other registers that users are in control of, setting + it more than once is probably preferable. That since the + documentation doesn't seem to be completely consistent about the + nature of the PTD control register. */ + MCD_dmaBar->ptdControl |= (u16) 0x8000; + + /* Not sure what we need to keep here rtm TBD */ +#if 1 + /* Calculate additional parameters to the regular DMA calls. */ + srcRsdIncr = srcIncr < 0 ? -1 : (srcIncr > 0 ? 1 : 0); + destRsdIncr = destIncr < 0 ? -1 : (destIncr > 0 ? 1 : 0); + + xferSizeIncr = (xferSize & 0xffff) | 0x20000000; + + /* Remember for each channel which variant is running. */ + MCD_remVariants.remSrcRsdIncr[channel] = srcRsdIncr; + MCD_remVariants.remDestRsdIncr[channel] = destRsdIncr; + MCD_remVariants.remDestIncr[channel] = destIncr; + MCD_remVariants.remSrcIncr[channel] = srcIncr; + MCD_remVariants.remXferSize[channel] = xferSize; +#endif + + cSave = + (int *)(MCD_taskTable[channel].contextSaveSpace) + CSAVE_OFFSET + + CURRBD; + +#ifdef MCD_INCLUDE_EU + /* may move this to EU specific calls */ + realFuncArray = + (u32 *) (MCD_taskTable[channel].FDTandFlags & 0xffffff00); + /* Modify the LURC's normal and byte-residue-loop functions according + to parameter. */ + realFuncArray[(LURC * 16)] = xferSize == 4 ? + funcDesc : xferSize == 2 ? + funcDesc & 0xfffff00f : funcDesc & 0xffff000f; + realFuncArray[(LURC * 16 + 1)] = + (funcDesc & MCD_BYTE_SWAP_KILLER) | MCD_NO_BYTE_SWAP_ATALL; +#endif + /* Write the initiator field in the TCR, and also set the + initiator-hold bit. Note that,due to a hardware quirk, this could + collide with an MDE access to the initiator-register file, so we + have to verify that the write reads back correctly. */ + + MCD_dmaBar->taskControl[channel] = + (initiator << 8) | TASK_CTL_HIPRITSKEN | TASK_CTL_HLDINITNUM; + + while (((MCD_dmaBar->taskControl[channel] & 0x1fff) != + ((initiator << 8) | TASK_CTL_HIPRITSKEN | TASK_CTL_HLDINITNUM)) + && (tcrCount < 1000)) { + tcrCount++; + /*MCD_dmaBar->ptd_tcr[channel] = (initiator << 8) | 0x0020; */ + MCD_dmaBar->taskControl[channel] = + (initiator << 8) | TASK_CTL_HIPRITSKEN | + TASK_CTL_HLDINITNUM; + } + + MCD_dmaBar->priority[channel] = (u8) priority & PRIORITY_PRI_MASK; + /* should be albe to handle this stuff with only one write to ts reg + - tbd */ + if (channel < 8 && channel >= 0) { + MCD_dmaBar->taskSize0 &= ~(0xf << (7 - channel) * 4); + MCD_dmaBar->taskSize0 |= + (xferSize & 3) << (((7 - channel) * 4) + 2); + MCD_dmaBar->taskSize0 |= (xferSize & 3) << ((7 - channel) * 4); + } else { + MCD_dmaBar->taskSize1 &= ~(0xf << (15 - channel) * 4); + MCD_dmaBar->taskSize1 |= + (xferSize & 3) << (((15 - channel) * 4) + 2); + MCD_dmaBar->taskSize1 |= (xferSize & 3) << ((15 - channel) * 4); + } + + /* setup task table flags/options which mostly control the line + buffers */ + MCD_taskTable[channel].FDTandFlags &= ~MCD_TT_FLAGS_MASK; + MCD_taskTable[channel].FDTandFlags |= (MCD_TT_FLAGS_MASK & flags); + + if (flags & MCD_FECTX_DMA) { + /* TDTStart and TDTEnd */ + MCD_taskTable[channel].TDTstart = + MCD_modelTaskTable[TASK_FECTX].TDTstart; + MCD_taskTable[channel].TDTend = + MCD_modelTaskTable[TASK_FECTX].TDTend; + MCD_startDmaENetXmit(srcAddr, srcAddr, destAddr, MCD_taskTable, + channel); + } else if (flags & MCD_FECRX_DMA) { + /* TDTStart and TDTEnd */ + MCD_taskTable[channel].TDTstart = + MCD_modelTaskTable[TASK_FECRX].TDTstart; + MCD_taskTable[channel].TDTend = + MCD_modelTaskTable[TASK_FECRX].TDTend; + MCD_startDmaENetRcv(srcAddr, srcAddr, destAddr, MCD_taskTable, + channel); + } else if (flags & MCD_SINGLE_DMA) { + /* this buffer descriptor is used for storing off initial + parameters for later progress query calculation and for the + DMA to write the resulting checksum. The DMA does not use + this to determine how to operate, that info is passed with + the init routine */ + MCD_relocBuffDesc[channel].srcAddr = srcAddr; + MCD_relocBuffDesc[channel].destAddr = destAddr; + + /* definitely not its final value */ + MCD_relocBuffDesc[channel].lastDestAddr = destAddr; + + MCD_relocBuffDesc[channel].dmaSize = dmaSize; + MCD_relocBuffDesc[channel].flags = 0; /* not used */ + MCD_relocBuffDesc[channel].csumResult = 0; /* not used */ + MCD_relocBuffDesc[channel].next = 0; /* not used */ + + /* Initialize the progress-querying stuff to show no + progress: */ + ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[SRCPTR + CSAVE_OFFSET] = (int)srcAddr; + ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[DESTPTR + CSAVE_OFFSET] = (int)destAddr; + ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[DCOUNT + CSAVE_OFFSET] = 0; + ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[CURRBD + CSAVE_OFFSET] = +(u32) & (MCD_relocBuffDesc[channel]); + /* tbd - need to keep the user from trying to call the EU + routine when MCD_INCLUDE_EU is not defined */ + if (funcDesc == MCD_FUNC_NOEU1 || funcDesc == MCD_FUNC_NOEU2) { + /* TDTStart and TDTEnd */ + MCD_taskTable[channel].TDTstart = + MCD_modelTaskTable[TASK_SINGLENOEU].TDTstart; + MCD_taskTable[channel].TDTend = + MCD_modelTaskTable[TASK_SINGLENOEU].TDTend; + MCD_startDmaSingleNoEu(srcAddr, srcIncr, destAddr, + destIncr, dmaSize, xferSizeIncr, + flags, (int *) + &(MCD_relocBuffDesc[channel]), + cSave, MCD_taskTable, channel); + } else { + /* TDTStart and TDTEnd */ + MCD_taskTable[channel].TDTstart = + MCD_modelTaskTable[TASK_SINGLEEU].TDTstart; + MCD_taskTable[channel].TDTend = + MCD_modelTaskTable[TASK_SINGLEEU].TDTend; + MCD_startDmaSingleEu(srcAddr, srcIncr, destAddr, + destIncr, dmaSize, xferSizeIncr, + flags, (int *) + &(MCD_relocBuffDesc[channel]), + cSave, MCD_taskTable, channel); + } + } else { /* chained DMAS */ + /* Initialize the progress-querying stuff to show no + progress: */ +#if 1 + /* (!defined(MCD_NEED_ADDR_TRANS)) */ + ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[SRCPTR + CSAVE_OFFSET] + = (int)((MCD_bufDesc *) srcAddr)->srcAddr; + ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[DESTPTR + CSAVE_OFFSET] + = (int)((MCD_bufDesc *) srcAddr)->destAddr; +#else + /* if using address translation, need the virtual addr of the + first buffdesc */ + ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[SRCPTR + CSAVE_OFFSET] + = (int)((MCD_bufDesc *) srcAddrVirt)->srcAddr; + ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[DESTPTR + CSAVE_OFFSET] + = (int)((MCD_bufDesc *) srcAddrVirt)->destAddr; +#endif + ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[DCOUNT + CSAVE_OFFSET] = 0; + ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[CURRBD + CSAVE_OFFSET] = (u32) srcAddr; + + if (funcDesc == MCD_FUNC_NOEU1 || funcDesc == MCD_FUNC_NOEU2) { + /*TDTStart and TDTEnd */ + MCD_taskTable[channel].TDTstart = + MCD_modelTaskTable[TASK_CHAINNOEU].TDTstart; + MCD_taskTable[channel].TDTend = + MCD_modelTaskTable[TASK_CHAINNOEU].TDTend; + MCD_startDmaChainNoEu((int *)srcAddr, srcIncr, + destIncr, xferSize, + xferSizeIncr, cSave, + MCD_taskTable, channel); + } else { + /*TDTStart and TDTEnd */ + MCD_taskTable[channel].TDTstart = + MCD_modelTaskTable[TASK_CHAINEU].TDTstart; + MCD_taskTable[channel].TDTend = + MCD_modelTaskTable[TASK_CHAINEU].TDTend; + MCD_startDmaChainEu((int *)srcAddr, srcIncr, destIncr, + xferSize, xferSizeIncr, cSave, + MCD_taskTable, channel); + } + } + MCD_chStatus[channel] = MCD_IDLE; + return (MCD_OK); +} + +/************************ End of MCD_startDma() *********************/ + +/********************************************************************/ +/* Function: MCD_XferProgrQuery + * Purpose: Returns progress of DMA on requested channel + * Arguments: channel - channel to retrieve progress for + * progRep - pointer to user supplied MCD_XferProg struct + * Returns: MCD_CHANNEL_INVALID if channel is invalid, else MCD_OK + * + * Notes: + * MCD_XferProgrQuery() upon completing or after aborting a DMA, or + * while the DMA is in progress, this function returns the first + * DMA-destination address not (or not yet) used in the DMA. When + * encountering a non-ready buffer descriptor, the information for + * the last completed descriptor is returned. + * + * MCD_XferProgQuery() has to avoid the possibility of getting + * partially-updated information in the event that we should happen + * to query DMA progress just as the DMA is updating it. It does that + * by taking advantage of the fact context is not saved frequently for + * the most part. We therefore read it at least twice until we get the + * same information twice in a row. + * + * Because a small, but not insignificant, amount of time is required + * to write out the progress-query information, especially upon + * completion of the DMA, it would be wise to guarantee some time lag + * between successive readings of the progress-query information. + */ + +/* How many iterations of the loop below to execute to stabilize values */ +#define STABTIME 0 + +int MCD_XferProgrQuery(int channel, MCD_XferProg * progRep) +{ + MCD_XferProg prevRep; + int again; /* true if we are to try again to ge + consistent results */ + int i; /* used as a time-waste counter */ + int destDiffBytes; /* Total no of bytes that we think actually + got xfered. */ + int numIterations; /* number of iterations */ + int bytesNotXfered; /* bytes that did not get xfered. */ + s8 *LWAlignedInitDestAddr, *LWAlignedCurrDestAddr; + int subModVal, addModVal; /* Mode values to added and subtracted + from the final destAddr */ + + if ((channel < 0) || (channel >= NCHANNELS)) + return (MCD_CHANNEL_INVALID); + + /* Read a trial value for the progress-reporting values */ + prevRep.lastSrcAddr = + (s8 *) ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[SRCPTR + CSAVE_OFFSET]; + prevRep.lastDestAddr = + (s8 *) ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[DESTPTR + CSAVE_OFFSET]; + prevRep.dmaSize = + ((volatile int *)MCD_taskTable[channel].contextSaveSpace)[DCOUNT + + CSAVE_OFFSET]; + prevRep.currBufDesc = + (MCD_bufDesc *) ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[CURRBD + CSAVE_OFFSET]; + /* Repeatedly reread those values until they match previous values: */ + do { + /* Waste a little bit of time to ensure stability: */ + for (i = 0; i < STABTIME; i++) { + /* make sure this loop does something so that it + doesn't get optimized out */ + i += i >> 2; + } + /* Check them again: */ + progRep->lastSrcAddr = + (s8 *) ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[SRCPTR + CSAVE_OFFSET]; + progRep->lastDestAddr = + (s8 *) ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[DESTPTR + CSAVE_OFFSET]; + progRep->dmaSize = + ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[DCOUNT + CSAVE_OFFSET]; + progRep->currBufDesc = + (MCD_bufDesc *) ((volatile int *)MCD_taskTable[channel]. + contextSaveSpace)[CURRBD + CSAVE_OFFSET]; + /* See if they match: */ + if (prevRep.lastSrcAddr != progRep->lastSrcAddr + || prevRep.lastDestAddr != progRep->lastDestAddr + || prevRep.dmaSize != progRep->dmaSize + || prevRep.currBufDesc != progRep->currBufDesc) { + /* If they don't match, remember previous values and + try again: */ + prevRep.lastSrcAddr = progRep->lastSrcAddr; + prevRep.lastDestAddr = progRep->lastDestAddr; + prevRep.dmaSize = progRep->dmaSize; + prevRep.currBufDesc = progRep->currBufDesc; + again = MCD_TRUE; + } else + again = MCD_FALSE; + } while (again == MCD_TRUE); + + /* Update the dCount, srcAddr and destAddr */ + /* To calculate dmaCount, we consider destination address. C + overs M1,P1,Z for destination */ + switch (MCD_remVariants.remDestRsdIncr[channel]) { + case MINUS1: + subModVal = + ((int)progRep-> + lastDestAddr) & ((MCD_remVariants.remXferSize[channel]) - + 1); + addModVal = + ((int)progRep->currBufDesc-> + destAddr) & ((MCD_remVariants.remXferSize[channel]) - 1); + LWAlignedInitDestAddr = + (progRep->currBufDesc->destAddr) - addModVal; + LWAlignedCurrDestAddr = (progRep->lastDestAddr) - subModVal; + destDiffBytes = LWAlignedInitDestAddr - LWAlignedCurrDestAddr; + bytesNotXfered = + (destDiffBytes / MCD_remVariants.remDestIncr[channel]) * + (MCD_remVariants.remDestIncr[channel] + + MCD_remVariants.remXferSize[channel]); + progRep->dmaSize = + destDiffBytes - bytesNotXfered + addModVal - subModVal; + break; + case ZERO: + progRep->lastDestAddr = progRep->currBufDesc->destAddr; + break; + case PLUS1: + /* This value has to be subtracted from the final + calculated dCount. */ + subModVal = + ((int)progRep->currBufDesc-> + destAddr) & ((MCD_remVariants.remXferSize[channel]) - 1); + /* These bytes are already in lastDestAddr. */ + addModVal = + ((int)progRep-> + lastDestAddr) & ((MCD_remVariants.remXferSize[channel]) - + 1); + LWAlignedInitDestAddr = + (progRep->currBufDesc->destAddr) - subModVal; + LWAlignedCurrDestAddr = (progRep->lastDestAddr) - addModVal; + destDiffBytes = (progRep->lastDestAddr - LWAlignedInitDestAddr); + numIterations = + (LWAlignedCurrDestAddr - + LWAlignedInitDestAddr) / + MCD_remVariants.remDestIncr[channel]; + bytesNotXfered = + numIterations * (MCD_remVariants.remDestIncr[channel] + - MCD_remVariants.remXferSize[channel]); + progRep->dmaSize = destDiffBytes - bytesNotXfered - subModVal; + break; + default: + break; + } + + /* This covers M1,P1,Z for source */ + switch (MCD_remVariants.remSrcRsdIncr[channel]) { + case MINUS1: + progRep->lastSrcAddr = + progRep->currBufDesc->srcAddr + + (MCD_remVariants.remSrcIncr[channel] * + (progRep->dmaSize / MCD_remVariants.remXferSize[channel])); + break; + case ZERO: + progRep->lastSrcAddr = progRep->currBufDesc->srcAddr; + break; + case PLUS1: + progRep->lastSrcAddr = + progRep->currBufDesc->srcAddr + + (MCD_remVariants.remSrcIncr[channel] * + (progRep->dmaSize / MCD_remVariants.remXferSize[channel])); + break; + default: + break; + } + + return (MCD_OK); +} + +/******************* End of MCD_XferProgrQuery() ********************/ + +/********************************************************************/ +/* MCD_resmActions() does the majority of the actions of a DMA resume. + * It is called from MCD_killDma() and MCD_resumeDma(). It has to be + * a separate function because the kill function has to negate the task + * enable before resuming it, but the resume function has to do nothing + * if there is no DMA on that channel (i.e., if the enable bit is 0). + */ +static void MCD_resmActions(int channel) +{ + MCD_dmaBar->debugControl = DBG_CTL_DISABLE; + MCD_dmaBar->debugStatus = MCD_dmaBar->debugStatus; + /* This register is selected to know which initiator is + actually asserted. */ + MCD_dmaBar->ptdDebug = PTD_DBG_TSK_VLD_INIT; + + if ((MCD_dmaBar->ptdDebug >> channel) & 0x1) + MCD_chStatus[channel] = MCD_RUNNING; + else + MCD_chStatus[channel] = MCD_IDLE; +} + +/********************* End of MCD_resmActions() *********************/ + +/********************************************************************/ +/* Function: MCD_killDma + * Purpose: Halt the DMA on the requested channel, without any + * intention of resuming the DMA. + * Arguments: channel - requested channel + * Returns: MCD_CHANNEL_INVALID if channel is invalid, else MCD_OK + * + * Notes: + * A DMA may be killed from any state, including paused state, and it + * always goes to the MCD_HALTED state even if it is killed while in + * the MCD_NO_DMA or MCD_IDLE states. + */ +int MCD_killDma(int channel) +{ + /* MCD_XferProg progRep; */ + + if ((channel < 0) || (channel >= NCHANNELS)) + return (MCD_CHANNEL_INVALID); + + MCD_dmaBar->taskControl[channel] = 0x0; + MCD_resumeDma(channel); + /* + * This must be after the write to the TCR so that the task doesn't + * start up again momentarily, and before the status assignment so + * as to override whatever MCD_resumeDma() may do to the channel + * status. + */ + MCD_chStatus[channel] = MCD_HALTED; + + /* + * Update the current buffer descriptor's lastDestAddr field + * + * MCD_XferProgrQuery (channel, &progRep); + * progRep.currBufDesc->lastDestAddr = progRep.lastDestAddr; + */ + return (MCD_OK); +} + +/************************ End of MCD_killDma() **********************/ + +/********************************************************************/ +/* Function: MCD_continDma + * Purpose: Continue a DMA which as stopped due to encountering an + * unready buffer descriptor. + * Arguments: channel - channel to continue the DMA on + * Returns: MCD_CHANNEL_INVALID if channel is invalid, else MCD_OK + * + * Notes: + * This routine does not check to see if there is a task which can + * be continued. Also this routine should not be used with single DMAs. + */ +int MCD_continDma(int channel) +{ + if ((channel < 0) || (channel >= NCHANNELS)) + return (MCD_CHANNEL_INVALID); + + MCD_dmaBar->taskControl[channel] |= TASK_CTL_EN; + MCD_chStatus[channel] = MCD_RUNNING; + + return (MCD_OK); +} + +/********************** End of MCD_continDma() **********************/ + +/********************************************************************* + * MCD_pauseDma() and MCD_resumeDma() below use the DMA's debug unit + * to freeze a task and resume it. We freeze a task by breakpointing + * on the stated task. That is, not any specific place in the task, + * but any time that task executes. In particular, when that task + * executes, we want to freeze that task and only that task. + * + * The bits of the debug control register influence interrupts vs. + * breakpoints as follows: + * - Bits 14 and 0 enable or disable debug functions. If enabled, you + * will get the interrupt but you may or may not get a breakpoint. + * - Bits 2 and 1 decide whether you also get a breakpoint in addition + * to an interrupt. + * + * The debug unit can do these actions in response to either internally + * detected breakpoint conditions from the comparators, or in response + * to the external breakpoint pin, or both. + * - Bits 14 and 1 perform the above-described functions for + * internally-generated conditions, i.e., the debug comparators. + * - Bits 0 and 2 perform the above-described functions for external + * conditions, i.e., the breakpoint external pin. + * + * Note that, although you "always" get the interrupt when you turn + * the debug functions, the interrupt can nevertheless, if desired, be + * masked by the corresponding bit in the PTD's IMR. Note also that + * this means that bits 14 and 0 must enable debug functions before + * bits 1 and 2, respectively, have any effect. + * + * NOTE: It's extremely important to not pause more than one DMA channel + * at a time. + ********************************************************************/ + +/********************************************************************/ +/* Function: MCD_pauseDma + * Purpose: Pauses the DMA on a given channel (if any DMA is running + * on that channel). + * Arguments: channel + * Returns: MCD_CHANNEL_INVALID if channel is invalid, else MCD_OK + */ +int MCD_pauseDma(int channel) +{ + /* MCD_XferProg progRep; */ + + if ((channel < 0) || (channel >= NCHANNELS)) + return (MCD_CHANNEL_INVALID); + + if (MCD_dmaBar->taskControl[channel] & TASK_CTL_EN) { + MCD_dmaBar->debugComp1 = channel; + MCD_dmaBar->debugControl = + DBG_CTL_ENABLE | (1 << (channel + 16)); + MCD_chStatus[channel] = MCD_PAUSED; + + /* + * Update the current buffer descriptor's lastDestAddr field + * + * MCD_XferProgrQuery (channel, &progRep); + * progRep.currBufDesc->lastDestAddr = progRep.lastDestAddr; + */ + } + return (MCD_OK); +} + +/************************* End of MCD_pauseDma() ********************/ + +/********************************************************************/ +/* Function: MCD_resumeDma + * Purpose: Resumes the DMA on a given channel (if any DMA is + * running on that channel). + * Arguments: channel - channel on which to resume DMA + * Returns: MCD_CHANNEL_INVALID if channel is invalid, else MCD_OK + */ +int MCD_resumeDma(int channel) +{ + if ((channel < 0) || (channel >= NCHANNELS)) + return (MCD_CHANNEL_INVALID); + + if (MCD_dmaBar->taskControl[channel] & TASK_CTL_EN) + MCD_resmActions(channel); + + return (MCD_OK); +} + +/************************ End of MCD_resumeDma() ********************/ + +/********************************************************************/ +/* Function: MCD_csumQuery + * Purpose: Provide the checksum after performing a non-chained DMA + * Arguments: channel - channel to report on + * csum - pointer to where to write the checksum/CRC + * Returns: MCD_ERROR if the channel is invalid, else MCD_OK + * + * Notes: + * + */ +int MCD_csumQuery(int channel, u32 * csum) +{ +#ifdef MCD_INCLUDE_EU + if ((channel < 0) || (channel >= NCHANNELS)) + return (MCD_CHANNEL_INVALID); + + *csum = MCD_relocBuffDesc[channel].csumResult; + return (MCD_OK); +#else + return (MCD_ERROR); +#endif +} + +/*********************** End of MCD_resumeDma() *********************/ + +/********************************************************************/ +/* Function: MCD_getCodeSize + * Purpose: Provide the size requirements of the microcoded tasks + * Returns: Size in bytes + */ +int MCD_getCodeSize(void) +{ +#ifdef MCD_INCLUDE_EU + return (0x2b5c); +#else + return (0x173c); +#endif +} + +/********************** End of MCD_getCodeSize() ********************/ + +/********************************************************************/ +/* Function: MCD_getVersion + * Purpose: Provide the version string and number + * Arguments: longVersion - user supplied pointer to a pointer to a char + * which points to the version string + * Returns: Version number and version string (by reference) + */ +char MCD_versionString[] = "Multi-channel DMA API Alpha v0.3 (2004-04-26)"; +#define MCD_REV_MAJOR 0x00 +#define MCD_REV_MINOR 0x03 + +int MCD_getVersion(char **longVersion) +{ + *longVersion = MCD_versionString; + return ((MCD_REV_MAJOR << 8) | MCD_REV_MINOR); +} + +/********************** End of MCD_getVersion() *********************/ + +/********************************************************************/ +/* Private version of memcpy() + * Note that everything this is used for is longword-aligned. + */ +static void MCD_memcpy(int *dest, int *src, u32 size) +{ + u32 i; + + for (i = 0; i < size; i += sizeof(int), dest++, src++) + *dest = *src; +} +#endif /* CONFIG_FSLDMAFEC */
Tsi-Chung Liew
