[U-Boot] [PATCH] x86: theadorable-x86-common: Remove "ip=dhcp" from default environment
Without ethernet cable plugged, "ip=dhcp" leads to a complete hangup in Linux booting and the system does not boot into userland at all. Since its not required to have an active network connection on these board, lets remove this statement from the default environment.
Signed-off-by: Stefan Roese sr@denx.de Cc: Bin Meng bmeng.cn@gmail.com --- include/configs/theadorable-x86-common.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/theadorable-x86-common.h b/include/configs/theadorable-x86-common.h index 37b78c1b57..8de659a496 100644 --- a/include/configs/theadorable-x86-common.h +++ b/include/configs/theadorable-x86-common.h @@ -88,7 +88,7 @@ "/boot/initrd.img-${kernel-ver}-generic;" \ "run boot\0" \ "yocto_args=setenv bootargs root=/dev/sda${yocto_part} " \ - "ip=dhcp panic=1\0" \ + "panic=1\0" \ "yocto_args_fast=setenv bootargs root=/dev/sda${yocto_part} " \ "quiet panic=1\0" \ "yocto_boot=run yocto_args addmtd addmisc addtty_yocto;" \ @@ -110,7 +110,7 @@ "fi\0" \ "swupdate-initrd=/boot/swupdate-image-theadorable.ext4.gz\0" \ "swupdate-kernel=/boot/bzImage\0" \ - "swupdate_args=setenv bootargs root=/dev/ram rw ip=dhcp panic=1\0" \ + "swupdate_args=setenv bootargs root=/dev/ram rw panic=1\0" \ "swupdate_dev=0\0" \ "swupdate_factory=0\0" \ "swupdate_interface=usb\0" \
applied to u-boot-x86, thanks!
Bin Meng
Stefan Roese
