[U-Boot] [PATCH 20/26] ARM: implement relocation for ixp
Change the implementation for ixp to relocate the code to an arbitrary address in RAM.
Signed-off-by: Heiko Schocher hs@denx.de --- arch/arm/cpu/ixp/start.S | 280 +++++++++++++++++++++++++++++++++++++++++++ arch/arm/cpu/ixp/u-boot.lds | 14 ++- 2 files changed, 293 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index 6efe333..b2c8255 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -93,12 +93,15 @@ _fiq: .word fiq * - jump to second stage */
+.globl _TEXT_BASE _TEXT_BASE: .word TEXT_BASE
+#if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) .globl _armboot_start _armboot_start: .word _start +#endif
/* * These are defined in the board-specific linker script. @@ -123,6 +126,274 @@ FIQ_STACK_START: .word 0x0badc0de #endif
+#if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) +/* IRQ stack memory (calculated at run-time) + 8 bytes */ +.globl IRQ_STACK_START_IN +IRQ_STACK_START_IN: + .word 0x0badc0de + +.globl _datarel_start +_datarel_start: + .word __datarel_start + +.globl _datarelrolocal_start +_datarelrolocal_start: + .word __datarelrolocal_start + +.globl _datarellocal_start +_datarellocal_start: + .word __datarellocal_start + +.globl _datarelro_start +_datarelro_start: + .word __datarelro_start + +.globl _got_start +_got_start: + .word __got_start + +.globl _got_end +_got_end: + .word __got_end + +/* + * the actual reset code + */ + +reset: + /* disable mmu, set big-endian */ + mov r0, #0xf8 + mcr p15, 0, r0, c1, c0, 0 + CPWAIT r0 + + /* invalidate I & D caches & BTB */ + mcr p15, 0, r0, c7, c7, 0 + CPWAIT r0 + + /* invalidate I & Data TLB */ + mcr p15, 0, r0, c8, c7, 0 + CPWAIT r0 + + /* drain write and fill buffers */ + mcr p15, 0, r0, c7, c10, 4 + CPWAIT r0 + + /* disable write buffer coalescing */ + mrc p15, 0, r0, c1, c0, 1 + orr r0, r0, #1 + mcr p15, 0, r0, c1, c0, 1 + CPWAIT r0 + + /* set EXP CS0 to the optimum timing */ + ldr r1, =CONFIG_SYS_EXP_CS0 + ldr r2, =IXP425_EXP_CS0 + str r1, [r2] + + /* make sure flash is visible at 0 */ +#if 0 + ldr r2, =IXP425_EXP_CFG0 + ldr r1, [r2] + orr r1, r1, #0x80000000 + str r1, [r2] +#endif + mov r1, #CONFIG_SYS_SDR_CONFIG + ldr r2, =IXP425_SDR_CONFIG + str r1, [r2] + + /* disable refresh cycles */ + mov r1, #0 + ldr r3, =IXP425_SDR_REFRESH + str r1, [r3] + + /* send nop command */ + mov r1, #3 + ldr r4, =IXP425_SDR_IR + str r1, [r4] + DELAY_FOR 0x4000, r0 + + /* set SDRAM internal refresh val */ + ldr r1, =CONFIG_SYS_SDRAM_REFRESH_CNT + str r1, [r3] + DELAY_FOR 0x4000, r0 + + /* send precharge-all command to close all open banks */ + mov r1, #2 + str r1, [r4] + DELAY_FOR 0x4000, r0 + + /* provide 8 auto-refresh cycles */ + mov r1, #4 + mov r5, #8 +111: str r1, [r4] + DELAY_FOR 0x100, r0 + subs r5, r5, #1 + bne 111b + + /* set mode register in sdram */ + mov r1, #CONFIG_SYS_SDR_MODE_CONFIG + str r1, [r4] + DELAY_FOR 0x4000, r0 + + /* send normal operation command */ + mov r1, #6 + str r1, [r4] + DELAY_FOR 0x4000, r0 + + /* copy */ + mov r0, #0 + mov r4, r0 + add r2, r0, #CONFIG_SYS_MONITOR_LEN + mov r1, #0x10000000 + mov r5, r1 + + 30: + ldr r3, [r0], #4 + str r3, [r1], #4 + cmp r0, r2 + bne 30b + + /* invalidate I & D caches & BTB */ + mcr p15, 0, r0, c7, c7, 0 + CPWAIT r0 + + /* invalidate I & Data TLB */ + mcr p15, 0, r0, c8, c7, 0 + CPWAIT r0 + + /* drain write and fill buffers */ + mcr p15, 0, r0, c7, c10, 4 + CPWAIT r0 + + /* move flash to 0x50000000 */ + ldr r2, =IXP425_EXP_CFG0 + ldr r1, [r2] + bic r1, r1, #0x80000000 + str r1, [r2] + + nop + nop + nop + nop + nop + nop + + /* invalidate I & Data TLB */ + mcr p15, 0, r0, c8, c7, 0 + CPWAIT r0 + + /* enable I cache */ + mrc p15, 0, r0, c1, c0, 0 + orr r0, r0, #MMU_Control_I + mcr p15, 0, r0, c1, c0, 0 + CPWAIT r0 + + mrs r0,cpsr /* set the cpu to SVC32 mode */ + bic r0,r0,#0x1f /* (superviser mode, M=10011) */ + orr r0,r0,#0x13 + msr cpsr,r0 + +/* Set stackpointer in internal RAM to call board_init_f */ +call_board_init_f: + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) + ldr r0,=0x00000000 + bl board_init_f + +/*------------------------------------------------------------------------------*/ + +/* + * void relocate_code (addr_sp, gd, addr_moni) + * + * This "function" does not return, instead it continues in RAM + * after relocating the monitor code. + * + */ + .globl relocate_code +relocate_code: + mov r4, r0 /* save addr_sp */ + mov r5, r1 /* save addr of gd */ + mov r6, r2 /* save addr of destination */ + mov r7, r2 /* save addr of destination */ + + /* Set up the stack */ +stack_setup: + mov sp, r4 + + adr r0, _start + ldr r2, _TEXT_BASE + ldr r3, _bss_start + sub r2, r3, r2 /* r2 <- size of armboot */ + add r2, r0, r2 /* r2 <- source end address */ + cmp r0, r6 + beq clear_bss + +#ifndef CONFIG_SKIP_RELOCATE_UBOOT +copy_loop: + ldmia r0!, {r9-r10} /* copy from source address [r0] */ + stmia r6!, {r9-r10} /* copy to target address [r1] */ + cmp r0, r2 /* until source end addreee [r2] */ + ble copy_loop + +#ifndef CONFIG_PRELOADER + /* fix got entries */ + ldr r1, _TEXT_BASE /* Text base */ + mov r0, r7 /* reloc addr */ + ldr r2, _got_start /* addr in Flash */ + ldr r3, _got_end /* addr in Flash */ + sub r3, r3, r1 + add r3, r3, r0 + sub r2, r2, r1 + add r2, r2, r0 + +fixloop: + ldr r4, [r2] + sub r4, r4, r1 + add r4, r4, r0 + str r4, [r2] + add r2, r2, #4 + cmp r2, r3 + bne fixloop +#endif +#endif /* #ifndef CONFIG_SKIP_RELOCATE_UBOOT */ + +clear_bss: +#ifndef CONFIG_PRELOADER + ldr r0, _bss_start + ldr r1, _bss_end + ldr r3, _TEXT_BASE /* Text base */ + mov r4, r7 /* reloc addr */ + sub r0, r0, r3 + add r0, r0, r4 + sub r1, r1, r3 + add r1, r1, r4 + mov r2, #0x00000000 /* clear */ + +clbss_l:str r2, [r0] /* clear loop... */ + add r0, r0, #4 + cmp r0, r1 + bne clbss_l + + bl coloured_LED_init + bl red_LED_on +#endif + +/* + * We are done. Do not return, instead branch to second part of board + * initialization, now running from RAM. + */ + ldr r0, _TEXT_BASE + ldr r2, _board_init_r + sub r2, r2, r0 + add r2, r2, r7 /* position from board_init_r in RAM */ + /* setup parameters for board_init_r */ + mov r0, r5 /* gd_t */ + mov r1, r7 /* dest_addr */ + /* jump to it ... */ + mov lr, r2 + mov pc, lr + +_board_init_r: .word board_init_r + +#else /* #if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) */ /****************************************************************************/ /* */ /* the actual reset code */ @@ -304,6 +575,7 @@ clbss_l:str r2, [r0] /* clear loop... */ ldr pc, _start_armboot
_start_armboot: .word start_armboot +#endif /* #if !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) */
/****************************************************************************/ @@ -345,9 +617,13 @@ _start_armboot: .word start_armboot stmia sp, {r0 - r12} /* Calling r0-r12 */ add r8, sp, #S_PC
+#if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r2, _armboot_start sub r2, r2, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ set base 2 words into abort stack +#else + ldr r2, IRQ_STACK_START_IN +#endif ldmia r2, {r2 - r4} /* get pc, cpsr, old_r0 */ add r0, sp, #S_FRAME_SIZE /* restore sp_SVC */
@@ -382,9 +658,13 @@ _start_armboot: .word start_armboot .endm
.macro get_bad_stack +#if defined(CONFIG_SYS_ARM_WITHOUT_RELOC) ldr r13, _armboot_start @ setup our mode stack sub r13, r13, #(CONFIG_STACKSIZE+CONFIG_SYS_MALLOC_LEN) sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack +#else + ldr r13, IRQ_STACK_START_IN @ setup our mode stack +#endif
str lr, [r13] @ save caller lr / spsr mrs lr, spsr diff --git a/arch/arm/cpu/ixp/u-boot.lds b/arch/arm/cpu/ixp/u-boot.lds index b8ff2ee..f3d9dc5 100644 --- a/arch/arm/cpu/ixp/u-boot.lds +++ b/arch/arm/cpu/ixp/u-boot.lds @@ -39,11 +39,23 @@ SECTIONS .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) }
. = ALIGN(4); - .data : { *(.data) } + .data : { + *(.data) + __datarel_start = .; + *(.data.rel) + __datarelrolocal_start = .; + *(.data.rel.ro.local) + __datarellocal_start = .; + *(.data.rel.local) + __datarelro_start = .; + *(.data.rel.ro) + }
+ __got_start = .; . = ALIGN(4); .got : { *(.got) }
+ __got_end = .; . = .; __u_boot_cmd_start = .; .u_boot_cmd : { *(.u_boot_cmd) }
Heiko Schocher
