[PATCH] spl: remove duplicate SPL_MD5 option
There is another SPL_MD5 option defined in lib/Kconfig. Renaming SPL_MD5_SUPPORT introduced duplicate option with different description. As for now FIT and hash algorithm options are not related to each others, removing a duplicate option seems OK.
Fixes: 4b00fd1a84c ("Kconfig: Rename SPL_MD5_SUPPORT to SPL_MD5") Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io ---
common/spl/Kconfig | 12 ------------ 1 file changed, 12 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index bee231b583a..c66d70e2a99 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -561,18 +561,6 @@ config SPL_CRC32 for detected accidental image corruption. For secure applications you should consider SHA1 or SHA256.
-config SPL_MD5 - bool "Support MD5" - depends on SPL_FIT - help - Enable this to support MD5 in FIT images within SPL. An MD5 - checksum is a 128-bit hash value used to check that the image - contents have not been corrupted. Note that MD5 is not considered - secure as it is possible (with a brute-force attack) to adjust the - image while still retaining the same MD5 hash value. For secure - applications where images may be changed maliciously, you should - consider SHA256 or SHA384. - config SPL_FIT_IMAGE_TINY bool "Remove functionality from SPL FIT loading to reduce size" depends on SPL_FIT
Oleksandr Suvorov
