[U-Boot] [PATCH] arm: Handle .gnu.hash section in ldscripts
Avoids "could not find output section .gnu.hash" ld.bfd errors on openSUSE.
Cc: Albert Aribaud albert.u.boot@aribaud.net Cc: Tom Rini trini@ti.com Signed-off-by: Andreas Färber afaerber@suse.de --- More changes like this may be needed, but these I compile-tested with v2014.01 (regression from v2013.10). colibri_t20_iris was runtime-tested. GCC 4.8.2 r206511, binutils 2.24
arch/arm/cpu/u-boot.lds | 1 + board/ti/am335x/u-boot.lds | 1 + 2 files changed, 2 insertions(+)
diff --git a/arch/arm/cpu/u-boot.lds b/arch/arm/cpu/u-boot.lds index 4da5d24..fb8bfaf 100644 --- a/arch/arm/cpu/u-boot.lds +++ b/arch/arm/cpu/u-boot.lds @@ -97,6 +97,7 @@ SECTIONS .dynamic : { *(.dynamic*) } .plt : { *(.plt*) } .interp : { *(.interp*) } + .gnu.hash : { *(.gnu.hash) } .gnu : { *(.gnu*) } .ARM.exidx : { *(.ARM.exidx*) } .gnu.linkonce.armexidx : { *(.gnu.linkonce.armexidx.*) } diff --git a/board/ti/am335x/u-boot.lds b/board/ti/am335x/u-boot.lds index 6a734b3..fec4ccf 100644 --- a/board/ti/am335x/u-boot.lds +++ b/board/ti/am335x/u-boot.lds @@ -113,6 +113,7 @@ SECTIONS .dynstr : { *(.dynstr*) } .dynamic : { *(.dynamic*) } .hash : { *(.hash*) } + .gnu.hash : { *(.gnu.hash) } .plt : { *(.plt*) } .interp : { *(.interp*) } .gnu : { *(.gnu*) }
Dear Andreas Färber,
Is this an ARM specific issue, or other architectures affected as well?
Hello,
Am 27.01.2014 15:24, schrieb Wolfgang Denk:
I figured out that the section was apparently not caught by the .gnu* wildcard and this patch fixed our build for the following ARM configs:
am335x_evm arndale colibri_t20_iris cubieboard highbank hyundai_a7hd mele_a1000 mx53loco omap3_beagle omap4_panda paz00 rpi_b
My guess was that this could be related to the arm-only commit: http://git.denx.de/?p=u-boot.git;a=commit;h=47ed5dd031d7d2c587e6afd386e79cce... (which touches on a few more .lds files than mine)
But I see nothing ARM-specific in .gnu.hash sections, so other architectures might in theory be affected as well. Cf. http://sourceware.org/ml/binutils/2006-10/msg00377.html
I did read your post for ELDK pointing someone to an FAQ entry on not using gcc-specific flags with ld, but for one I did not spot such a thing in the ld command line, and for another our toolchain did not change and v2013.10 builds succeed whereas v2014.01 builds failed without the patch. I could try to git-bisect the offending change if necessary.
Andreas
Do I understand you correctly that this fixes a _build_ error? So we can assume as long as the other archtiectures build fine, they are not affected by this?
Dear Wolfgang Denk,
Am 27.01.2014 20:11, schrieb Wolfgang Denk:
Affirmative. :)
Andreas
Affirmative. :)
OK, then we can just lean back and relax :)
Thanks!
Hi Andreas,
On Mon, 27 Jan 2014 19:46:03 +0100, Andreas Färber afaerber@suse.de wrote:
Hello,
Using gcc version 4.8.1 (Ubuntu/Linaro 4.8.1-10ubuntu7), I cannot see any issues on these boards:
am335x_evm colibri_t20_iris highbank mx53loco omap3_beagle omap4_panda paz00 rpi_b
On arndale, issues are due to warnings unrelated to linking.
Cubieboard, hyundai_a7hd, mele_a1000 are not in mainline AFAICT (but I'd like to see mele_a1000 in, as this might mean mele_a1000g could follow. :) )
Can you point me to the toolchain you are using, and if you are not building mainline code, can you make this code available to me somehow?
Andreas
Amicalement,
Hi Albert,
On Thu, 13 Feb 2014 12:39:07 +0100, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Andreas,
Hello,
Ping.
Andreas
Amicalement,
Hi Albert,
Am 22.02.2014 14:27, schrieb Albert ARIBAUD:
Hi Albert,
Hi Andreas,
Hello,
Sorry, missed that. I had merged v2014.01 into the sunxi tree and updated our downstream patch from it (v2014.01-sunxi.patch). It did not seem to touch on Makefile or ldscript in an interfering way. Cf. https://github.com/afaerber/u-boot/commits/sunxi
Other downstream changes include forcing ext4 support for SPL and tweaking boot.scr vs. boot.scr.uimg filename inconsistencies.
Ping.
Somehow I did not receive the previous message...
Our latest GCC 4.8.2 can be found here: https://build.opensuse.org/package/show/openSUSE:Factory:ARM/gcc48
Matching binutils 2.24 are here: https://build.opensuse.org/package/show/openSUSE:Factory:ARM/binutils
Our latest U-Boot tarball and patches: https://build.opensuse.org/package/show/Base:System/u-boot Build logs can be found in the u-boot-* packages in the same project, with underscores stripped, e.g.: https://build.opensuse.org/package/show/Base:System/u-boot-am335xevm
Amicalement,
Andreas
Hi Andreas,
On Sun, 02 Mar 2014 18:57:14 +0100, Andreas Färber afaerber@suse.de wrote:
Hi Albert,
Hi Albert,
Hi Andreas,
Hello,
Ping.
Thanks for your reply. Apparently, the problem does not appear for the boards in mainline U-Boot which I listed above with the source code from our v2014.01 tag and using gcc 4.8.1 from Linaro. I can install 4.8.2, but meanwhile, can you try to build v2014.01 for these boards with your setup?
Amicalement,
Andreas
Amicalement,
Hi Albert,
Am 02.03.2014 20:15, schrieb Albert ARIBAUD:
Hi Andreas,
Hi Albert,
I have commented out the patch in: https://build.opensuse.org/project/show/home:a_faerber:branches:Base:System
While there are apparently frequent rebuilds scheduled ATM, it seemed like the colibri_t20_iris config intermittently built OK without it. Maybe some gcc 4.8 stable branch update [1] resolved it ... will keep an eye on the build status to confirm. If everything builds, I'm happy.
Amicalement,
Andreas
[1] https://build.opensuse.org/package/view_file/openSUSE:Factory:ARM/gcc48/gcc4...
Am 02.03.2014 21:57, schrieb Andreas Färber:
Hi Albert,
Hi Andreas,
Hi Albert,
Nah, still fails without the patch:
[ 178s] gcc -E -g -Os -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x0010E000 -I/home/abuild/rpmbuild/BUILD/u-boot-2014.01/include -I/home/abuild/rpmbuild/BUILD/u-boot-2014.01/arch/arm/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/armv7hl-suse-linux-gnueabi/4.8/include -pipe -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -mword-relocations -march=armv7-a -include /home/abuild/rpmbuild/BUILD/u-boot-2014.01/include/u-boot/u-boot.lds.h -DCPUDIR=arch/arm/cpu/armv7 -ansi -D__ASSEMBLY__ -P - </home/abuild/rpmbuild/BUILD/u-boot-2014.01/arch/arm/cpu/u-boot.lds
u-boot.lds
[ 178s] cd /home/abuild/rpmbuild/BUILD/u-boot-2014.01 && ld.bfd -pie -T u-boot.lds --gc-sections -Bstatic -Ttext 0x0010E000 arch/arm/cpu/armv7/start.o --start-group arch/arm/cpu/armv7/built-in.o arch/arm/cpu/armv7/tegra20/built-in.o arch/arm/cpu/built-in.o arch/arm/lib/built-in.o board/toradex/colibri_t20_iris/built-in.o common/built-in.o disk/built-in.o drivers/built-in.o drivers/dma/built-in.o drivers/gpio/built-in.o drivers/i2c/built-in.o drivers/input/built-in.o drivers/mmc/built-in.o drivers/mtd/built-in.o drivers/mtd/nand/built-in.o drivers/mtd/onenand/built-in.o drivers/mtd/spi/built-in.o drivers/net/built-in.o drivers/net/phy/built-in.o drivers/pci/built-in.o drivers/power/battery/built-in.o drivers/power/built-in.o drivers/power/fuel_gauge/built-in.o drivers/power/mfd/built-in.o drivers/power/pmic/built-in.o drivers/serial/built-in.o drivers/spi/built-in.o drivers/usb/eth/built-in.o drivers/usb/gadget/built-in.o drivers/usb/host/built-in.o drivers/usb/musb-new/built-in.o drivers/usb/musb/built-in.o drivers/usb/phy/built-in.o drivers/usb/ulpi/built-in.o fs/built-in.o lib/built-in.o lib/libfdt/built-in.o net/built-in.o test/built-in.o --end-group /home/abuild/rpmbuild/BUILD/u-boot-2014.01/arch/arm/lib/eabi_compat.o -L /usr/lib/gcc/armv7hl-suse-linux-gnueabi/4.8 -lgcc -Map u-boot.map -o u-boot [ 178s] ld.bfd: u-boot: could not find output section .gnu.hash [ 178s] ld.bfd: final link failed: Nonrepresentable section on output [ 178s] Makefile:556: recipe for target 'u-boot' failed [ 178s] make: *** [u-boot] Error 1
https://build.opensuse.org/package/live_build_log/home:a_faerber:branches:Ba...
Regards, Andreas
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Hi Albert,
Hi Andreas,
Hi Albert,
u-boot.lds
When this fails can you save the objdir?
- -- Tom
Hi Andreas,
(seems an answer from me yesterday didn't make it out of the NSA interceptors...)
Hi Albert,
Hi Andreas,
Hi Albert,
u-boot.lds
You are trying this with your codebase, right? If so, can you try and build vanilla v2014.01 with the exact same build environment? If it builds fine, then can you tell me which changes your patch(es) made to linker scripts in your tree wrt 2014.01?
Regards, Andreas
Amicalement,
Hi Andreas,
Hi Albert,
Hi Andreas,
Hi Albert,
u-boot.lds
Regards, Andreas
Amicalement,
On Mon, 3 Mar 2014 08:00:52 +0100, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Andreas,
Hi Albert,
Hi Andreas,
Hi Albert,
> Can you point me to the toolchain you are using, and if you are not > building mainline code, can you make this code available to me somehow?
u-boot.lds
Ping.
Regards, Andreas
Amicalement,
Am 09.03.2014 21:05, schrieb Albert ARIBAUD:
Hi Andreas,
Hi Albert,
Hi Andreas,
Hi Albert,
Am 22.02.2014 14:27, schrieb Albert ARIBAUD: > On Thu, 13 Feb 2014 12:39:07 +0100, Albert ARIBAUD > albert.u.boot@aribaud.net wrote: > >> Can you point me to the toolchain you are using, and if you are not >> building mainline code, can you make this code available to me somehow?
u-boot.lds
Commented out all our patches at: https://build.opensuse.org/project/show/home:a_faerber:branches:Base:System
Failure of any sunxi-added targets is to be expected, of course.
If it
Ping.
I had previously pointed to our patches and explained that they do not touch on any existing linker scripts. They merely change CONFIG_ options, tweak environment settings and add the sunxi targets.
As for the other open question, OBS does not package build intermediaries of failed builds, so I'll need to reproduce it locally. ATM I'm lacking time because QEMU is about to enter Hard Freeze for 2.0.
Amicalement, Andreas
Regards, Andreas
Amicalement,
Hi Andreas,
Hi Andreas,
Hi Albert,
Hi Andreas,
> Hi Albert, > > Am 22.02.2014 14:27, schrieb Albert ARIBAUD: >> On Thu, 13 Feb 2014 12:39:07 +0100, Albert ARIBAUD >> albert.u.boot@aribaud.net wrote: >> >>> Can you point me to the toolchain you are using, and if you are not >>> building mainline code, can you make this code available to me somehow?
> Our latest GCC 4.8.2 can be found here: > https://build.opensuse.org/package/show/openSUSE:Factory:ARM/gcc48 > > Matching binutils 2.24 are here: > https://build.opensuse.org/package/show/openSUSE:Factory:ARM/binutils > > Our latest U-Boot tarball and patches: > https://build.opensuse.org/package/show/Base:System/u-boot > Build logs can be found in the u-boot-* packages in the same project, > with underscores stripped, e.g.: > https://build.opensuse.org/package/show/Base:System/u-boot-am335xevm
u-boot.lds
Not sure I'm getting this: if you build vanilla v2014.01, there shouldn't be any sunxi target built at all, should it?
If it
Ping.
I am not asking about changing linker scripts; I am asking about trying your build environment on the pristine v2014.01 codebase, e.g. build all mainline ARM targets with your toolchains.
Could you just run this in a git clone of U-Boot with v2014.01 checked out?
ARCH=arm CROSS_COMPILE=your-toolchain-prefix- ./MAKEALL -a arm
It would build all targets unattended using your toolchain (assuming it is in your PATH of course).
Amicalement,
Am 09.03.2014 21:34, schrieb Albert ARIBAUD:
Am 02.03.2014 20:15, schrieb Albert ARIBAUD: > On Sun, 02 Mar 2014 18:57:14 +0100, Andreas Färber afaerber@suse.de > wrote: >> Am 22.02.2014 14:27, schrieb Albert ARIBAUD: >>> On Thu, 13 Feb 2014 12:39:07 +0100, Albert ARIBAUD >>> albert.u.boot@aribaud.net wrote: >>> >>>> Can you point me to the toolchain you are using, and if you are not >>>> building mainline code, can you make this code available to me somehow? [...] >> Our latest GCC 4.8.2 can be found here: >> https://build.opensuse.org/package/show/openSUSE:Factory:ARM/gcc48 >> >> Matching binutils 2.24 are here: >> https://build.opensuse.org/package/show/openSUSE:Factory:ARM/binutils >> >> Our latest U-Boot tarball and patches: >> https://build.opensuse.org/package/show/Base:System/u-boot >> Build logs can be found in the u-boot-* packages in the same project, >> with underscores stripped, e.g.: >> https://build.opensuse.org/package/show/Base:System/u-boot-am335xevm > > Thanks for your reply. Apparently, the problem does not appear for the > boards in mainline U-Boot which I listed above with the source code > from our v2014.01 tag and using gcc 4.8.1 from Linaro. I can install > 4.8.2, but meanwhile, can you try to build v2014.01 for these boards > with your setup? > > am335x_evm colibri_t20_iris highbank mx53loco omap3_beagle > omap4_panda paz00 rpi_b
u-boot.lds
I removed the patches from the spec file in our build service. That doesn't drop the packages for those no longer patched-in targets, so failures of those targets are to be expected. I am not building locally.
Here's a vanilla "highbank" target failing: https://build.opensuse.org/package/live_build_log/home:a_faerber:branches:Ba...
If it
Ping.
You did ask above "which changes" our patches "made to linker scripts". And the answer is: None, apart from the already commented-out gnuhash.patch, which corresponds to this very patch under discussion.
My local ARM machines are all 13.1, not Factory, but I can try running that command there later.
Hi Andreas,
Am 02.03.2014 21:57, schrieb Andreas Färber: > Am 02.03.2014 20:15, schrieb Albert ARIBAUD: >> On Sun, 02 Mar 2014 18:57:14 +0100, Andreas Färber afaerber@suse.de >> wrote: >>> Am 22.02.2014 14:27, schrieb Albert ARIBAUD: >>>> On Thu, 13 Feb 2014 12:39:07 +0100, Albert ARIBAUD >>>> albert.u.boot@aribaud.net wrote: >>>> >>>>> Can you point me to the toolchain you are using, and if you are not >>>>> building mainline code, can you make this code available to me somehow? > [...] >>> Our latest GCC 4.8.2 can be found here: >>> https://build.opensuse.org/package/show/openSUSE:Factory:ARM/gcc48 >>> >>> Matching binutils 2.24 are here: >>> https://build.opensuse.org/package/show/openSUSE:Factory:ARM/binutils >>> >>> Our latest U-Boot tarball and patches: >>> https://build.opensuse.org/package/show/Base:System/u-boot >>> Build logs can be found in the u-boot-* packages in the same project, >>> with underscores stripped, e.g.: >>> https://build.opensuse.org/package/show/Base:System/u-boot-am335xevm >> >> Thanks for your reply. Apparently, the problem does not appear for the >> boards in mainline U-Boot which I listed above with the source code >> from our v2014.01 tag and using gcc 4.8.1 from Linaro. I can install >> 4.8.2, but meanwhile, can you try to build v2014.01 for these boards >> with your setup? >> >> am335x_evm colibri_t20_iris highbank mx53loco omap3_beagle >> omap4_panda paz00 rpi_b > > I have commented out the patch in: > https://build.opensuse.org/project/show/home:a_faerber:branches:Base:System > > While there are apparently frequent rebuilds scheduled ATM, it seemed > like the colibri_t20_iris config intermittently built OK without it. > Maybe some gcc 4.8 stable branch update [1] resolved it ... will keep an > eye on the build status to confirm. If everything builds, I'm happy.
[ 178s] gcc -E -g -Os -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -D__KERNEL__ -DCONFIG_SYS_TEXT_BASE=0x0010E000 -I/home/abuild/rpmbuild/BUILD/u-boot-2014.01/include -I/home/abuild/rpmbuild/BUILD/u-boot-2014.01/arch/arm/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/lib/gcc/armv7hl-suse-linux-gnueabi/4.8/include -pipe -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -mword-relocations -march=armv7-a -include /home/abuild/rpmbuild/BUILD/u-boot-2014.01/include/u-boot/u-boot.lds.h -DCPUDIR=arch/arm/cpu/armv7 -ansi -D__ASSEMBLY__ -P - </home/abuild/rpmbuild/BUILD/u-boot-2014.01/arch/arm/cpu/u-boot.lds > u-boot.lds [ 178s] cd /home/abuild/rpmbuild/BUILD/u-boot-2014.01 && ld.bfd -pie -T u-boot.lds --gc-sections -Bstatic -Ttext 0x0010E000 arch/arm/cpu/armv7/start.o --start-group arch/arm/cpu/armv7/built-in.o arch/arm/cpu/armv7/tegra20/built-in.o arch/arm/cpu/built-in.o arch/arm/lib/built-in.o board/toradex/colibri_t20_iris/built-in.o common/built-in.o disk/built-in.o drivers/built-in.o drivers/dma/built-in.o drivers/gpio/built-in.o drivers/i2c/built-in.o drivers/input/built-in.o drivers/mmc/built-in.o drivers/mtd/built-in.o drivers/mtd/nand/built-in.o drivers/mtd/onenand/built-in.o drivers/mtd/spi/built-in.o drivers/net/built-in.o drivers/net/phy/built-in.o drivers/pci/built-in.o drivers/power/battery/built-in.o drivers/power/built-in.o drivers/power/fuel_gauge/built-in.o drivers/power/mfd/built-in.o drivers/power/pmic/built-in.o drivers/serial/built-in.o drivers/spi/built-in.o drivers/usb/eth/built-in.o drivers/usb/gadget/built-in.o drivers/usb/host/built-in.o drivers/usb/musb-new/built-in.o drivers/usb/musb/built-in.o drivers/usb/phy/built-in.o drivers/usb/ulpi/built-in.o fs/built-in.o lib/built-in.o lib/libfdt/built-in.o net/built-in.o test/built-in.o --end-group /home/abuild/rpmbuild/BUILD/u-boot-2014.01/arch/arm/lib/eabi_compat.o -L /usr/lib/gcc/armv7hl-suse-linux-gnueabi/4.8 -lgcc -Map u-boot.map -o u-boot [ 178s] ld.bfd: u-boot: could not find output section .gnu.hash [ 178s] ld.bfd: final link failed: Nonrepresentable section on output [ 178s] Makefile:556: recipe for target 'u-boot' failed [ 178s] make: *** [u-boot] Error 1
If it
Ping.
Understood -- my question about linker script changes was conditioned to succeeding in building pristine v2014.01, so I had mentally put it aside until v2014.01 build results are known.
Thanks!
Amicalement,
Hi Albert, Andreas,
Hi Andreas,
On Sun, 02 Mar 2014 23:00:19 +0100, Andreas Färber afaerber@suse.de wrote: > Am 02.03.2014 21:57, schrieb Andreas Färber: >> Am 02.03.2014 20:15, schrieb Albert ARIBAUD: >>> On Sun, 02 Mar 2014 18:57:14 +0100, Andreas Färber >>> afaerber@suse.de wrote: >>>> Am 22.02.2014 14:27, schrieb Albert ARIBAUD: >>>>> On Thu, 13 Feb 2014 12:39:07 +0100, Albert ARIBAUD >>>>> albert.u.boot@aribaud.net wrote: >>>>> >>>>>> Can you point me to the toolchain you are using, and if >>>>>> you are not building mainline code, can you make this >>>>>> code available to me somehow? >> [...] >>>> Our latest GCC 4.8.2 can be found here: >>>> https://build.opensuse.org/package/show/openSUSE:Factory:ARM/gcc48 >>>> >>>> Matching binutils 2.24 are here: >>>> https://build.opensuse.org/package/show/openSUSE:Factory:ARM/binutils >>>> >>>> Our latest U-Boot tarball and patches: >>>> https://build.opensuse.org/package/show/Base:System/u-boot >>>> Build logs can be found in the u-boot-* packages in the >>>> same project, with underscores stripped, e.g.: >>>> https://build.opensuse.org/package/show/Base:System/u-boot-am335xevm >>> >>> Thanks for your reply. Apparently, the problem does not >>> appear for the boards in mainline U-Boot which I listed >>> above with the source code from our v2014.01 tag and using >>> gcc 4.8.1 from Linaro. I can install 4.8.2, but meanwhile, >>> can you try to build v2014.01 for these boards with your >>> setup? >>> >>> am335x_evm colibri_t20_iris highbank mx53loco omap3_beagle >>> omap4_panda paz00 rpi_b >> >> I have commented out the patch in: >> https://build.opensuse.org/project/show/home:a_faerber:branches:Base:System >> >> While there are apparently frequent rebuilds scheduled ATM, >> it seemed like the colibri_t20_iris config intermittently >> built OK without it. Maybe some gcc 4.8 stable branch update >> [1] resolved it ... will keep an eye on the build status to >> confirm. If everything builds, I'm happy. > > Nah, still fails without the patch: > > [ 178s] gcc -E -g -Os -ffunction-sections -fdata-sections > -fno-common -ffixed-r9 -msoft-float -D__KERNEL__ > -DCONFIG_SYS_TEXT_BASE=0x0010E000 > -I/home/abuild/rpmbuild/BUILD/u-boot-2014.01/include > -I/home/abuild/rpmbuild/BUILD/u-boot-2014.01/arch/arm/include > -fno-builtin -ffreestanding -nostdinc -isystem > /usr/lib/gcc/armv7hl-suse-linux-gnueabi/4.8/include -pipe > -DCONFIG_ARM -D__ARM__ -marm -mno-thumb-interwork > -mabi=aapcs-linux -mword-relocations -march=armv7-a -include > /home/abuild/rpmbuild/BUILD/u-boot-2014.01/include/u-boot/u-boot.lds.h > -DCPUDIR=arch/arm/cpu/armv7 -ansi -D__ASSEMBLY__ -P - > </home/abuild/rpmbuild/BUILD/u-boot-2014.01/arch/arm/cpu/u-boot.lds >> u-boot.lds > [ 178s] cd /home/abuild/rpmbuild/BUILD/u-boot-2014.01 && > ld.bfd -pie -T u-boot.lds --gc-sections -Bstatic -Ttext > 0x0010E000 arch/arm/cpu/armv7/start.o --start-group > arch/arm/cpu/armv7/built-in.o > arch/arm/cpu/armv7/tegra20/built-in.o arch/arm/cpu/built-in.o > arch/arm/lib/built-in.o > board/toradex/colibri_t20_iris/built-in.o common/built-in.o > disk/built-in.o drivers/built-in.o drivers/dma/built-in.o > drivers/gpio/built-in.o drivers/i2c/built-in.o > drivers/input/built-in.o drivers/mmc/built-in.o > drivers/mtd/built-in.o drivers/mtd/nand/built-in.o > drivers/mtd/onenand/built-in.o drivers/mtd/spi/built-in.o > drivers/net/built-in.o drivers/net/phy/built-in.o > drivers/pci/built-in.o drivers/power/battery/built-in.o > drivers/power/built-in.o drivers/power/fuel_gauge/built-in.o > drivers/power/mfd/built-in.o drivers/power/pmic/built-in.o > drivers/serial/built-in.o drivers/spi/built-in.o > drivers/usb/eth/built-in.o drivers/usb/gadget/built-in.o > drivers/usb/host/built-in.o drivers/usb/musb-new/built-in.o > drivers/usb/musb/built-in.o drivers/usb/phy/built-in.o > drivers/usb/ulpi/built-in.o fs/built-in.o lib/built-in.o > lib/libfdt/built-in.o net/built-in.o test/built-in.o > --end-group /home/abuild/rpmbuild/BUILD/u-boot-2014.01/arch/arm/lib/eabi_compat.o > -L /usr/lib/gcc/armv7hl-suse-linux-gnueabi/4.8 -lgcc -Map > u-boot.map -o u-boot [ 178s] ld.bfd: u-boot: could not find > output section .gnu.hash [ 178s] ld.bfd: final link failed: > Nonrepresentable section on output [ 178s] Makefile:556: > recipe for target 'u-boot' failed [ 178s] make: *** [u-boot] > Error 1
I can report the same issue with OBS build of u-boot.
When u-boot is build with qemu emulated environment with gcc-4.8.2 (native armv7l toolchain) in the OBS it needs patch prepared by Andreas.
However I can build the same code from u-boot directory (without this patch) with following toolchain: arm-v7a-linux-gnueabi-gcc (OSELAS.Toolchain-2013.12.0 linaro-4.8-2013.11) 4.8.3 20131111
Any ideas how to solve this?
If it
Ping.
Thanks!
Amicalement,
Hi Lukasz,
On Thu, 13 Mar 2014 16:43:09 +0100, Lukasz Majewski l.majewski@samsung.com wrote:
Hmm, ok, so maybe I can reproduce this by building U-Boot on native armv7 hardware. Any target which systematically fails building?
Hmm... So it depends on the toolchain.
Are both toolchains you used available somewhere so that I can fetch them and experiment locally?
Amicalement,
Hi Albert,
Hi Lukasz,
The Trats2 fails to be build. But to me it seems like compiler and linker issue.
Yes they are available. References below:
arm-v7a-linux-gnueabi-gcc (OSELAS.Toolchain-2013.12.0linaro-4.8-2013.11) 4.8.3 20131111 linaro-4.8-2013.11) 4.8.3 20131111 http://www.ptxdist.org/software/ptxdist/index_en.html
The one which is used in the OBS: gcc-4.8-2.56.armv7l.rpm
can be download from: http://download.tizen.org/snapshots/tizen/rd-pq/latest/repos/mobile/armv7l/p...
I hope, that it helps.
Amicalement,
Hi Lukasz,
On Fri, 14 Mar 2014 08:37:00 +0100, Lukasz Majewski l.majewski@samsung.com wrote:
Hi Albert,
Hi Lukasz,
Thanks -- I'll test these, not today but certainly before next monday.
Amicalement,
Hi Albert,
Hi Andreas,
Hi Albert,
u-boot.lds
Looks more like an issue with the linker script used by u-boot. .gnu.hash is simply what recent linkers produce by default - you could try if using -Wl,--hash-style=sysv works around the issue, but it would still point to a linker script bug IMHO (or a bug in binutils, not gcc).
Richard.
Regards, Andreas
Hi Albert,
Hi Andreas,
Hi Albert,
u-boot.lds
If that was true it would be consistently happening, but it's not. I hope it's possible to save the output when the build fails.
- -- Tom
Tested on snow
Tested-by: Simon Glass sjg@chromium.org
before:
$ crosfw -b daisy Configuring for smdk5250 board... /usr/x86_64-pc-linux-gnu/armv7a-cros-linux-gnueabi/binutils-bin/2.22/ld.bfd.real: u-boot: could not find output section .gnu.hash /usr/x86_64-pc-linux-gnu/armv7a-cros-linux-gnueabi/binutils-bin/2.22/ld.bfd.real: final link failed: Nonrepresentable section on output make[1]: *** [u-boot] Error 1 make[1]: *** Waiting for unfinished jobs.... make: *** [sub-make] Error 2
after:
no error
Hi Andreas,
- .gnu.hash : { *(.gnu.hash) } .gnu : { *(.gnu*) } .ARM.exidx : { *(.ARM.exidx*) } .gnu.linkonce.armexidx : { *(.gnu.linkonce.armexidx.*) }
- .gnu.hash : { *(.gnu.hash) } .plt : { *(.plt*) } .interp : { *(.interp*) } .gnu : { *(.gnu*) }
Applied to u-boot-arm/master, thanks!
Amicalement,
participants (7)
Albert ARIBAUD
Andreas Färber
Lukasz Majewski
Richard Biener
