[U-Boot] [PATCH] cmd: nvedit: bring error message in sync with condition under which it appears
The list of symbols listed in the error message for missing Kconfig symbols is out of sync with the symbols actually tested. Add the missing symbols and reorder their appearance to be in sync with the #if statement for easier checking.
Signed-off-by: Lothar Waßmann LW@KARO-electronics.de --- cmd/nvedit.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 9ca5cb5..41578d4 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -54,8 +54,8 @@ DECLARE_GLOBAL_DATA_PTR; !defined(CONFIG_ENV_IS_IN_REMOTE) && \ !defined(CONFIG_ENV_IS_IN_UBI) && \ !defined(CONFIG_ENV_IS_NOWHERE) -# error Define one of CONFIG_ENV_IS_IN_{EEPROM|FLASH|DATAFLASH|ONENAND|\ -SATA|SPI_FLASH|NVRAM|MMC|FAT|EXT4|REMOTE|UBI} or CONFIG_ENV_IS_NOWHERE +# error Define one of CONFIG_ENV_IS_IN_{EEPROM|FLASH|DATAFLASH|MMC|FAT|EXT4|\ +NAND|NVRAM|ONENAND|SATA|SPI_FLASH|REMOTE|UBI} or CONFIG_ENV_IS_NOWHERE #endif
Lothar Waßmann
