[U-Boot] [PATCH] gpio: spear_gpio: Fix gpio_set_value() implementation
In current gpio_set_value() implementation, it always sets the gpio control bit no matter the value argument is 0 or 1. Thus the GPIOs never set to low. This patch fixes this bug.
Signed-off-by: Axel Lin axel.lin@ingics.com --- drivers/gpio/spear_gpio.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/gpio/spear_gpio.c b/drivers/gpio/spear_gpio.c index d3c728e..8878608 100644 --- a/drivers/gpio/spear_gpio.c +++ b/drivers/gpio/spear_gpio.c @@ -52,7 +52,10 @@ int gpio_set_value(unsigned gpio, int value) { struct gpio_regs *regs = (struct gpio_regs *)CONFIG_GPIO_BASE;
- writel(1 << gpio, ®s->gpiodata[DATA_REG_ADDR(gpio)]); + if (value) + writel(1 << gpio, ®s->gpiodata[DATA_REG_ADDR(gpio)]); + else + writel(0, ®s->gpiodata[DATA_REG_ADDR(gpio)]);
return 0; }
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
control bit
if (value)
else
writel(0, ®s->gpiodata[DATA_REG_ADDR(gpio)]); return 0;
Does it work the clear? Seems that it sets to 0 all the bank. I'm using the mobile
Michael
-- 1.8.1.2
Dear Michael Trimarchi,
Hi
control bit
if (value)
else
I don't think I speak language of your tribe (lol) ;-)
What's "the mobile" please ?
Best regards, Marek Vasut
Hi
scritto:
control bit
low.
if (value)
writel(1 << gpio,
else
the
mobile
Android mobile, italian dictinary and same comment of you
:D
Michael
Hi
Hi
scritto:
control bit
low.
if (value)
writel(1 << gpio,
else
the
mobile
Poor you, the android {keyboard,mailer,} is such a crap ;-(
Dear Axel Lin,
- if (value)
- else
How can this possibly work? Writing 0 to the whole bank will unset all the GPIOs, no ?
2013/6/20 Marek Vasut marex@denx.de
Dear Axel Lin,
if (value)
else
Because each GPIO is controlled by a register. And only one bit will be set when set gpio to high.
So it's safe to write 0 for clearing the bit.
Note, the gpio_get_value() implementation also assumes there is only one bit will be set. ( If this is not true, both gpio_get_value() and gpio_set_value() need fix.)
Vipin, can you review this patch and confirm this behavior?
Thanks, Axel
Hi
Dear Axel Lin,
if (value)
else
Yes, but how to reset just one bit if you use the same register offset?
I don't know this core but I know two possibilities:
1) one set register and one clear register if (enable) writel(1 << gpio, REGSET_BANK(gpio)); else writel(1 << gpio, REGCLEAR_BANK(gpio)); 2) or set operation reg = readl(REG(gpio); if (enable) reg |= 1 << gpio; else reg &= ~(1 << gpio); writel(reg, REG(GPIO));
Any other way?
Michael
Thanks, Axel _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi
Dear Axel Lin,
if (value)
else
- one set register and one clear register if (enable) writel(1 << gpio, REGSET_BANK(gpio)); else writel(1 << gpio, REGCLEAR_BANK(gpio));
- or
Any other way?
I think it's about time to read the datasheet :b
On 6/20/2013 7:26 PM, Axel Lin wrote:
2013/6/20 Marek Vasutmarex@denx.de
Dear Axel Lin,
Signed-off-by: Axel Linaxel.lin@ingics.com
writel(1<< gpio,®s->gpiodata[DATA_REG_ADDR(gpio)]);
if (value)
else
writel(0,®s->gpiodata[DATA_REG_ADDR(gpio)]);
Yes this is right. and the code is fine
Regards Vipin
Thanks, Axel .
Dear Axel Lin,
if (value)
else
The problem is not in set one bit but in reset one bit. Can you check the else path?
Michael
Regards Vipin
Thanks, Axel .
2013/6/21 Michael Trimarchi michael@amarulasolutions.com:
Dear Axel Lin,
if (value)
else
Hi, I'm not the best person to answer this question because I don't have the hardware and datasheet. In the case only one bit is meaningful and the reset bits are 0, it looks ok for me to write 0 for clearing the bit. ( note, each gpio pin is controlled by different register.)
This patch is acked and reviewed by Stefan Roese and Vipin Kumar. I'm wondering if this patch is acceptable? Or maybe a test-by can help to make this patch acceptable?
Regards, Axel
Dear Axel Lin,
control
set to
*)CONFIG_GPIO_BASE;
if (value)
writel(1<<
else
all the
GPIOs, no ?
one bit
gpio_set_value()
need fix.)
If each pin is controlled by a different register why you need to 1<<gpio in set path?
And how it works for gpio 33?
Michael
Regards, Axel
2013/6/30 Michael Trimarchi michael@amarulasolutions.com:
Dear Axel Lin,
> In current gpio_set_value() implementation, it always sets the gpio > control > bit no matter the value argument is 0 or 1. Thus the GPIOs never set > to > low. This patch fixes this bug. > > Signed-off-by: Axel Linaxel.lin@ingics.com > --- > drivers/gpio/spear_gpio.c | 5 ++++- > 1 file changed, 4 insertions(+), 1 deletion(-) > > diff --git a/drivers/gpio/spear_gpio.c b/drivers/gpio/spear_gpio.c > index d3c728e..8878608 100644 > --- a/drivers/gpio/spear_gpio.c > +++ b/drivers/gpio/spear_gpio.c > @@ -52,7 +52,10 @@ int gpio_set_value(unsigned gpio, int value) > { > struct gpio_regs *regs = (struct gpio_regs > *)CONFIG_GPIO_BASE; > > - writel(1<< gpio,®s->gpiodata[DATA_REG_ADDR(gpio)]); > + if (value) > + writel(1<< > gpio,®s->gpiodata[DATA_REG_ADDR(gpio)]); > + else > + writel(0,®s->gpiodata[DATA_REG_ADDR(gpio)]);
Because the meaningful bit for different register is different.
SPEAR_GPIO_COUNT is 8, so this driver only allows setting gpio0 ~ gpio7.
Vipin, any chance to double check the datasheet and confirm if this patch is ok?
Regards, Axel
On 6/30/2013 2:27 PM, Axel Lin wrote:
2013/6/30 Michael Trimarchimichael@amarulasolutions.com:
Hi Il giorno 30/giu/2013 06:18, "Axel Lin"axel.lin@ingics.com ha scritto:
2013/6/21 Michael Trimarchimichael@amarulasolutions.com:
2013/6/20 Marek Vasutmarex@denx.de > > Dear Axel Lin, > >> In current gpio_set_value() implementation, it always sets the gpio >> control >> bit no matter the value argument is 0 or 1. Thus the GPIOs never set >> to >> low. This patch fixes this bug. >> >> Signed-off-by: Axel Linaxel.lin@ingics.com >> --- >> drivers/gpio/spear_gpio.c | 5 ++++- >> 1 file changed, 4 insertions(+), 1 deletion(-) >> >> diff --git a/drivers/gpio/spear_gpio.c b/drivers/gpio/spear_gpio.c >> index d3c728e..8878608 100644 >> --- a/drivers/gpio/spear_gpio.c >> +++ b/drivers/gpio/spear_gpio.c >> @@ -52,7 +52,10 @@ int gpio_set_value(unsigned gpio, int value) >> { >> struct gpio_regs *regs = (struct gpio_regs >> *)CONFIG_GPIO_BASE; >> >> - writel(1<< gpio,®s->gpiodata[DATA_REG_ADDR(gpio)]); >> + if (value) >> + writel(1<< >> gpio,®s->gpiodata[DATA_REG_ADDR(gpio)]); >> + else >> + writel(0,®s->gpiodata[DATA_REG_ADDR(gpio)]); > > How can this possibly work? Writing 0 to the whole bank will unset > all the > GPIOs, no ?
The questions raised here are valid and it forced me to re-read the datasheet. For your convenience, I must tell you that the device is actually pl061 from ARM, so the driver can also be named so.
The datasheet is here http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0190b/I100269...
Quoting from the datasheet "The GPIODATA register is the data register. In software control mode, values written in the GPIODATA register are transferred onto the GPOUT pins if the respective pins have been configured as outputs through the GPIODIR register.
In order to write to GPIODATA, the corresponding bits in the mask, resulting from the address bus, PADDR[9:2], must be HIGH. Otherwise the bit values remain unchanged by the write.
Similarly, the values read from this register are determined for each bit, by the mask bit derived from the address used to access the data register, PADDR[9:2]. Bits that are 1 in the address mask cause the corresponding bits in GPIODATA to be read, and bits that are 0 in the address mask cause the corresponding bits in GPIODATA to be read as 0, regardless of their value.
A read from GPIODATA returns the last bit value written if the respective pins are configured as output, or it returns the value on the corresponding input GPIN bit when these are configured as inputs. All bits are cleared by a reset."
After reading all this I am confused about numbering of the gpio's. I think the numbering should be from 1 to 8 for a device. And this would mean that we should write to *®s->datareg[1 << (gpio - 1)]* instead of the present code which is _®s->datareg[1 << (gpio + 2)]_
Moreover, One GPIO device can control only 8 pins, so there is no question of having GPIO33. In an SoC design, GPIO33 may actually map to GPIO1 of device 4. I hope I am clear on this
Regards Vipin
Regards, Axel .
Hi Vipin, Thanks for the review and providing the datasheet information. You mentioned that this is PL061. So... I just checked the gpio-pl061 driver in linux kernel. It's writing to _®s->datareg[1 << (gpio + 2)]. and seems no bug report for this.
And the gpio_get/set implementation in linux kernel has the same behavior as this patch does:
( below is from linux/drivers/gpio/gpio-pl061.c )
static int pl061_get_value(struct gpio_chip *gc, unsigned offset) { struct pl061_gpio *chip = container_of(gc, struct pl061_gpio, gc);
return !!readb(chip->base + (1 << (offset + 2))); }
static void pl061_set_value(struct gpio_chip *gc, unsigned offset, int value) { struct pl061_gpio *chip = container_of(gc, struct pl061_gpio, gc);
writeb(!!value << offset, chip->base + (1 << (offset + 2))); }
BTW, it would be great if you have the hardware to test.
Regards, Axel
After reading all this I am confused about numbering of the gpio's. I think the numbering should be from 1 to 8 for a device. And this would mean that we should write to *®s->datareg[1<< (gpio - 1)]* instead of the present code which is _®s->datareg[1<< (gpio + 2)]_
Hi Vipin,
Hello Alex,
Thanks for the review and providing the datasheet information. You mentioned that this is PL061. So... I just checked the gpio-pl061 driver in linux kernel. It's writing to _®s->datareg[1<< (gpio + 2)]. and seems no bug report for this.
Yes, I see it now. The difference is that we are using a writel and the datareg is a u32 array.
return !!readb(chip->base + (1<< (offset + 2)));
writeb(!!value<< offset, chip->base + (1<< (offset + 2)));
I am sorry about this. I have now moved to a different group and I have no access to the hardware
Regards Vipin
Regards, Axel .
2013/7/1 Vipin Kumar vipin.kumar@st.com:
Hi Vipin,
Hello Alex,
Hi, The merge window is going to close. I'm wondering if this patch is ok or not (I think it's a bug fix). I think the only issue is nobody has this hardware to test. [Sorry to back to this topic so late... just too busy recently.]
Regards, Axel
Hi
Hi Vipin,
Hello Alex,
You are right. I read the documentation and it works
Michael
Regards, Axel
participants (5)
Axel Lin
Michael Trimarchi
Stefan Roese
Vipin Kumar
