[U-Boot] [PATCH] Do not copy elf section to same adress
When an elf section is already at the right position (e.g. after image decompression by bootm) there is no need to copy it.
Signed-off-by: Matthias Weisser weisserm@arcor.de --- common/cmd_elf.c | 7 ++++--- 1 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/common/cmd_elf.c b/common/cmd_elf.c index bf32612..aec4579 100644 --- a/common/cmd_elf.c +++ b/common/cmd_elf.c @@ -342,9 +342,10 @@ static unsigned long load_elf_image_shdr(unsigned long addr) memset ((void *)shdr->sh_addr, 0, shdr->sh_size); } else { image = (unsigned char *) addr + shdr->sh_offset; - memcpy ((void *) shdr->sh_addr, - (const void *) image, - shdr->sh_size); + if ((void *) shdr->sh_addr != (void *) image) + memcpy((void *) shdr->sh_addr, + (const void *) image, + shdr->sh_size); } flush_cache (shdr->sh_addr, shdr->sh_size); }
Dear Matthias Weisser,
shdr->sh_size);
shdr->sh_size);
Braces required for multi-line statement.
When an elf section is already at the right position (e.g. after image decompression by bootm) there is no need to copy it. This saves some ms when bootig an elf image.
Changes since V1 - Fixed style issues
Signed-off-by: Matthias Weisser weisserm@arcor.de --- common/cmd_elf.c | 8 +++++--- 1 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/common/cmd_elf.c b/common/cmd_elf.c index bf32612..3537769 100644 --- a/common/cmd_elf.c +++ b/common/cmd_elf.c @@ -342,9 +342,11 @@ static unsigned long load_elf_image_shdr(unsigned long addr) memset ((void *)shdr->sh_addr, 0, shdr->sh_size); } else { image = (unsigned char *) addr + shdr->sh_offset; - memcpy ((void *) shdr->sh_addr, - (const void *) image, - shdr->sh_size); + if ((void *) shdr->sh_addr != (void *) image) { + memcpy((void *) shdr->sh_addr, + (const void *) image, + shdr->sh_size); + } } flush_cache (shdr->sh_addr, shdr->sh_size); }
Hi
Am 19.01.2011 12:03, schrieb Matthias Weisser:
Changes since V1
shdr->sh_size);
shdr->sh_size);
} flush_cache (shdr->sh_addr, shdr->sh_size); }}
Any comments on this patch? Any problems with it? I would like to see it in mainline and I am open for any comments.
Regards, Matthias Weißer
Changes since V1
shdr->sh_size);
shdr->sh_size);
The idea is correct, but I think the implementation is suboptimal. Instead of fixing this use case only, the test should be moved into the implementation of memcpy() itself so any other callers with such a situation benefit from it, too.
While we are at it, we should do the same with bcopy() and memmove(), too.
Thanks.
Am 11.04.2011 21:59, schrieb Wolfgang Denk:
Changes since V1
shdr->sh_size);
shdr->sh_size);
Well, I thought about that too. But decided against it as I thought it will be a bit too intervening for a patch from me as this will hit all boards.
I can't come up with an example where this may produce a problem but who knows which exotic hardware is out there which expects that a memcpy with identical src and dst addresses is executed exactly in that way. But maybe we can ignore this and let these exotic boards come up with a solution handling that special situation.
Maybe I can post a patch tomorrow. The only thing which I can't handle are architecture specific memcpy/memmove/... functions besides ARM.
Right.
That's fine. Optimized arch specific code probably already implements such a shortcut anyway.
Matthias Weisser
