[PATCH] board: ti: am65x: Do not disable SA2UL in DT
This is no longer needed as the SA2UL can now be shared with Linux. Leave the SA2UL DT node enabled.
Signed-off-by: Andrew Davis afd@ti.com --- board/ti/am65x/evm.c | 10 ---------- 1 file changed, 10 deletions(-)
diff --git a/board/ti/am65x/evm.c b/board/ti/am65x/evm.c index 7182a8cad1..8a0a506a3e 100644 --- a/board/ti/am65x/evm.c +++ b/board/ti/am65x/evm.c @@ -115,16 +115,6 @@ int ft_board_setup(void *blob, struct bd_info *bd) return ret; }
-#if defined(CONFIG_TI_SECURE_DEVICE) - /* Make Crypto HW reserved for secure world use */ - ret = fdt_disable_node(blob, "/bus@100000/crypto@4e00000"); - if (ret < 0) - ret = fdt_disable_node(blob, - "/interconnect@100000/crypto@4E00000"); - if (ret) - printf("%s: disabling SA2UL failed %d\n", __func__, ret); -#endif - return 0; } #endif
Signed-off-by: Andrew Davis afd@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Andrew Davis
